path: root/include/asm-alpha/mmzone.h
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-27[PATCH] remove zone_mem_mapKAMEZAWA Hiroyuki
This patch removes zone_mem_map. pfn_to_page uses pgdat, page_to_pfn uses zone. page_to_pfn can use pgdat instead of zone, which is only one user of zone_mem_map. By modifing it, we can remove zone_mem_map. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Lameter <christoph@lameter.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify pfn_to_page: alpha pfn_to_pageKAMEZAWA Hiroyuki
Alpha can use generic funcs. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove non-DISCONTIG use of pgdat->node_mem_mapDave Hansen
This patch effectively eliminates direct use of pgdat->node_mem_map outside of the DISCONTIG code. On a flat memory system, these fields aren't currently used, neither are they on a sparsemem system. There was also a node_mem_map(nid) macro on many architectures. Its use along with the use of ->node_mem_map itself was not consistent. It has been removed in favor of two new, more explicit, arch-independent macros: pgdat_page_nr(pgdat, pagenr) nid_page_nr(nid, pagenr) I called them "pgdat" and "nid" because we overload the term "node" to mean "NUMA node", "DISCONTIG node" or "pg_data_t" in very confusing ways. I believe the newer names are much clearer. These macros can be overridden in the sparsemem case with a theoretically slower operation using node_start_pfn and pfn_to_page(), instead. We could make this the only behavior if people want, but I don't want to change too much at once. One thing at a time. This patch removes more code than it adds. Compile tested on alpha, alpha discontig, arm, arm-discontig, i386, i386 generic, NUMAQ, Summit, ppc64, ppc64 discontig, and x86_64. Full list here: http://sr71.net/patches/2.6.12/2.6.12-rc1-mhp2/configs/ Boot tested on NUMAQ, x86 SMP and ppc64 power4/5 LPARs. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Martin J. Bligh <mbligh@aracnet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
