path: root/include/acpi
2005-07-29/home/lenb/src/to-linus branch 'acpi-2.6.12'Len Brown
2005-07-29[ACPI] suspend/resume ACPI PCI Interrupt LinksDavid Shaohua Li
Add reference count and disable ACPI PCI Interrupt Link when no device still uses it. Warn when drivers have not released Link at suspend time. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
2005-07-12[ACPI] enable C2 and C3 idle power states on SMPVenkatesh Pallipadi
http://bugzilla.kernel.org/show_bug.cgi?id=4401 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] Bind PCI devices with ACPI devicesDavid Shaohua Li
Implement the framework for binding physical devices with ACPI devices. A physical bus like PCI bus should create a 'acpi_bus_type', with: .find_device: For device which has parent such as normal PCI devices. .find_bridge: It's for special devices, such as PCI root bridge or IDE controller. Such devices generally haven't a parent or ->bus. We use the special method to get an ACPI handle. Uses new field in struct device: firmware_data http://bugzilla.kernel.org/show_bug.cgi?id=4277 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] generic Hot Key supportLuming Yu
See Documentation/acpi-hotkey.txt Use cmdline "acpi_specific_hotkey" to enable legacy platform specific drivers. http://bugzilla.kernel.org/show_bug.cgi?id=3887 Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-06-27[PATCH] acpi bridge hotadd: Export the interface to get PCI id for an ACPI ↵Rajesh Shah
handle Export an acpi interface to get PCI domain/bus/devfn information from the corresponding namespace handle. Used by acpiphp code to transpate the device handle of the hot-plugged root bridge to the corresponding pci location information. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] acpi bridge hotadd: Allow ACPI .add and .start operations to be done ↵Rajesh Shah
independently Create new interfaces to recursively add an acpi namespace object to the acpi device list, and recursively start the namespace object. This is needed for ACPI based hotplug of a root bridge hierarchy where the add operation must be performed first and the start operation must be performed separately after the hot-plugged devices have been properly configured. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
