path: root/fs
2009-11-05nfsd: use STATEID_FMT and STATEID_VAL for printing stateidsBenny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-11-04nfsd: register NFS_ACL with rpcbindPeter Staubach
Modify the NFS server to register the NFS_ACL services with the rpcbind daemon. This allows the client to ping for the existence of the NFS_ACL support via commands such as "rpcinfo -t <server> nfs_acl". This patch also modifies the NFS_ACL support so that responses to version 2 NULLPROC requests can be made. The changelog for the patch which turned off this functionality mentioned something about not registering the NFS_ACL as being part of some tradition. I can't find this tradition and the only other implementation which supports NFS_ACL does register them with the rpcbind daemon. Signed-off-by: Peter Staubach <staubach@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfsd: Fix sort_pacl in fs/nfsd/nf4acl.c to actually sort groupsFrank Filz
We have been doing some extensive testing of Linux support for ACLs on NFDS v4. We have noticed that the server rejects ACLs where the groups are out of order, for example, the following ACL is rejected: A::OWNER@:rwaxtTcCy A::user101@domain:rwaxtcy A::GROUP@:rwaxtcy A:g:group102@domain:rwaxtcy A:g:group101@domain:rwaxtcy A::EVERYONE@:rwaxtcy Examining the server code, I found that after converting an NFS v4 ACL to POSIX, sort_pacl is called to sort the user ACEs and group ACEs. Unfortunately, a minor bug causes the group sort to be skipped. Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfsd4.1: common slot allocation size calculationJ. Bruce Fields
We do the same calculation in a couple places; use a helper function, and add a little documentation, in the hopes of preventing bugs like that fixed in the last patch. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfsd4.1: fix session memory use calculationJ. Bruce Fields
Unbalanced calculations on creation and destruction of sessions could cause our estimate of cache memory used to become negative, sometimes resulting in spurious SERVERFAULT returns to client CREATE_SESSION requests. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfs: new subdir Documentation/filesystems/nfsJ. Bruce Fields
We're adding enough nfs documentation that it may as well have its own subdirectory. Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27Merge commit 'v2.6.32-rc5' into for-2.6.33J. Bruce Fields
2009-10-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: fix socket fd translation dlm: fix lowcomms_connect_node for sctp
2009-10-15Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: always pin metadata in discard mode Btrfs: enable discard support Btrfs: add -o discard option Btrfs: properly wait log writers during log sync Btrfs: fix possible ENOSPC problems with truncate Btrfs: fix btrfs acl #ifdef checks Btrfs: streamline tree-log btree block writeout Btrfs: avoid tree log commit when there are no changes Btrfs: only write one super copy during fsync
2009-10-14sysfs: Allow sysfs_notify_dirent to be called from interrupt context.Neil Brown
sysfs_notify_dirent is a simple atomic operation that can be used to alert user-space that new data can be read from a sysfs attribute. Unfortunately it cannot currently be called from non-process context because of its use of spin_lock which is sometimes taken with interrupts enabled. So change all lockers of sysfs_open_dirent_lock to disable interrupts, thus making sysfs_notify_dirent safe to be called from non-process context (as drivers/md does in md_safemode_timeout). sysfs_get_open_dirent is (documented as being) only called from process context, so it uses spin_lock_irq. Other places use spin_lock_irqsave. The usage for sysfs_notify_dirent in md_safemode_timeout was introduced in 2.6.28, so this patch is suitable for that and more recent kernels. Reported-by: Joel Andres Granados <jgranado@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-14sysfs: Allow sysfs_move_dir(..., NULL) again.Cornelia Huck
As device_move() and kobject_move() both handle a NULL destination, sysfs_move_dir() should do this as well (again) and fall back to sysfs_root in that case. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-14Btrfs: always pin metadata in discard modeChris Mason
We have an optimization in btrfs to allow blocks to be immediately freed if they were allocated in this transaction and never written. Otherwise they are pinned and freed when the transaction commits. This isn't optimal for discard mode because immediately freeing them means immediately discarding them. It is better to give the block to the pinning code and letting the (slow) discard happen later. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-14Btrfs: enable discard supportChristoph Hellwig
The discard support code in btrfs currently is guarded by ifdefs for BIO_RW_DISCARD, which is never defines as it's the name of an enum memeber. Just remove the useless ifdefs to actually enable the code. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-14Btrfs: add -o discard optionChristoph Hellwig
Enable discard by default is not a good idea given the the trim speed of SSD prototypes we've seen, and the carecteristics for many high-end arrays. Turn of discards by default and require the -o discard option to enable them on. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-14Btrfs: properly wait log writers during log syncYan, Zheng
A recently fsync optimization make btrfs_sync_log skip calling wait_for_writer in the single log writer case. This is incorrect since the writer count can also be increased by btrfs_pin_log. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-14Btrfs: fix possible ENOSPC problems with truncateJosef Bacik
There's a problem where we don't do any space reservation for truncates, which can cause you to OOPs because you will be allowed to go off in the weeds a bit since we don't account for the delalloc bytes that are created as a result of the truncate. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-13Btrfs: fix btrfs acl #ifdef checksChris Mason
The btrfs acl code was #ifdefing for a define that didn't exist. This correctly matches it to the values used by the Kconfig file. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-13Btrfs: streamline tree-log btree block writeoutChris Mason
Syncing the tree log is a 3 phase operation. 1) write and wait for all the tree log blocks for a given root. 2) write and wait for all the tree log blocks for the tree of tree log roots. 3) write and wait for the super blocks (barriers here) This isn't as efficient as it could be because there is no requirement to wait for the blocks from step one to hit the disk before we start writing the blocks from step two. This commit changes the sequence so that we don't start waiting until all the tree blocks from both steps one and two have been sent to disk. We do this by breaking up btrfs_write_wait_marked_extents into two functions, which is trivial because it was already broken up into two parts. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-13Btrfs: avoid tree log commit when there are no changesChris Mason
rpm has a habit of running fdatasync when the file hasn't changed. We already detect if a file hasn't been changed in the current transaction but it might have been sent to the tree-log in this transaction and not changed since the last call to fsync. In this case, we want to avoid a tree log sync, which includes a number of synchronous writes and barriers. This commit extends the existing tracking of the last transaction to change a file to also track the last sub-transaction. The end result is that rpm -ivh and -Uvh are roughly twice as fast, and on par with ext3. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-13Btrfs: only write one super copy during fsyncChris Mason
During a tree-log commit for fsync, we've been writing at least two copies of the super block and forcing them to disk. The other filesystems write only one, and this change brings us on par with them. A full transaction commit will write all the super copies, so we still have redundant info written on a regular basis. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-13Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cciss: Add cciss_allow_hpsa module parameter cciss: Fix multiple calls to pci_release_regions blk-settings: fix function parameter kernel-doc notation writeback: kill space in debugfs item name writeback: account IO throttling wait as iowait elv_iosched_store(): fix strstrip() misuse cfq-iosched: avoid probable slice overrun when idling cfq-iosched: apply bool value where we return 0/1 cfq-iosched: fix think time allowed for seekers cfq-iosched: fix the slice residual sign cfq-iosched: abstract out the 'may this cfqq dispatch' logic block: use proper BLK_RW_ASYNC in blk_queue_start_tag() block: Seperate read and write statistics of in_flight requests v2 block: get rid of kblock_schedule_delayed_work() cfq-iosched: fix possible problem with jiffies wraparound cfq-iosched: fix issue with rq-rq merging and fifo list ordering
2009-10-13ext3: Don't update superblock write time when filesystem is read-onlyTheodore Ts'o
This avoids updating the superblock write time when we are mounting the root file system read/only but we need to replay the journal; at that point, for people who are east of GMT and who make their clock tick in localtime for Windows bug-for-bug compatibility, and this will cause e2fsck to complain and force a full file system check. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2009-10-12NFS: suppress a build warningStefan Richter
struct sockaddr_storage * can safely be used as struct sockaddr *. Suppress an "incompatible pointer type" warning. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-11ROMFS: fix length used with romfs_dev_strnlen() functionBernd Schmidt
An interestingly corrupted romfs file system exposed a problem with the romfs_dev_strnlen function: it's passing the wrong value to its helpers. Rather than limit the string to the length passed in by the callers, it uses the size of the device as the limit. Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix file clone ioctl for bookend extents Btrfs: fix uninit compiler warning in cow_file_range_nocow Btrfs: constify dentry_operations Btrfs: optimize back reference update during btrfs_drop_snapshot Btrfs: remove negative dentry when deleting subvolumne Btrfs: optimize fsync for the single writer case Btrfs: async delalloc flushing under space pressure Btrfs: release delalloc reservations on extent item insertion Btrfs: delay clearing EXTENT_DELALLOC for compressed extents Btrfs: cleanup extent_clear_unlock_delalloc flags Btrfs: fix possible softlockup in the allocator Btrfs: fix deadlock on async thread startup
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: ima: ecryptfs fix imbalance message eCryptfs: Remove Kconfig NET dependency and select MD5 ecryptfs: depends on CRYPTO
2009-10-09Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: stop calling filemap_fdatawait inside ->fsync fix readahead calculations in xfs_dir2_leaf_getdents() xfs: make sure xfs_sync_fsdata covers the log xfs: mark inodes dirty before issuing I/O xfs: cleanup ->sync_fs xfs: fix xfs_quiesce_data xfs: implement ->dirty_inode to fix timestamp handling
2009-10-09Btrfs: fix file clone ioctl for bookend extentsChris Mason
The file clone ioctl was incorrectly taking the offset into the extent on disk into account when calculating the length of the cloned extent. The length never changes based on the offset into the physical extent. Test case: fallocate -l 1g image mke2fs image bcp image image2 e2fsck -f image2 (errors on image2) The math bug ends up wrapping the length of the extent, and things go wrong from there. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-09Btrfs: fix uninit compiler warning in cow_file_range_nocowChris Mason
The extent_type variable was exposed uninit via a goto. It should be impossible to trigger because it is protected by a check on another variable, but this makes sure. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-09Btrfs: constify dentry_operationsAlexey Dobriyan
2009-10-09Btrfs: optimize back reference update during btrfs_drop_snapshotYan, Zheng
This patch reading level 0 tree blocks that already use full backrefs. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-09Btrfs: remove negative dentry when deleting subvolumneYan, Zheng
The use of btrfs_dentry_delete is removing dentries from the dcache when deleting subvolumne. btrfs_dentry_delete ignores negative dentries. This is incorrect since if we don't remove the negative dentry, its parent dentry can't be removed. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFSv4: Kill nfs4_renewd_prepare_shutdown() NFSv4: Fix the referral mount code nfs: Avoid overrun when copying client IP address string NFS: Fix port initialisation in nfs_remount() NFS: Fix port and mountport display in /proc/self/mountinfo NFS: Fix a default mount regression...
2009-10-08Btrfs: optimize fsync for the single writer caseJosef Bacik
This patch optimizes the tree logging stuff so it doesn't always wait 1 jiffie for new people to join the logging transaction if there is only ever 1 writer. This helps a little bit with latency where we have something like RPM where it will fdatasync every file it writes, and so waiting the 1 jiffie for every fdatasync really starts to add up. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Btrfs: async delalloc flushing under space pressureJosef Bacik
This patch moves the delalloc flushing that occurs when we are under space pressure off to a async thread pool. This helps since we only free up metadata space when we actually insert the extent item, which means it takes quite a while for space to be free'ed up if we wait on all ordered extents. However, if space is freed up due to inline extents being inserted, we can wake people who are waiting up early, and they can finish their work. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Btrfs: release delalloc reservations on extent item insertionJosef Bacik
This patch fixes an issue with the delalloc metadata space reservation code. The problem is we used to free the reservation as soon as we allocated the delalloc region. The problem with this is if we are not inserting an inline extent, we don't actually insert the extent item until after the ordered extent is written out. This patch does 3 things, 1) It moves the reservation clearing stuff into the ordered code, so when we remove the ordered extent we remove the reservation. 2) It adds a EXTENT_DO_ACCOUNTING flag that gets passed when we clear delalloc bits in the cases where we want to clear the metadata reservation when we clear the delalloc extent, in the case that we do an inline extent or we invalidate the page. 3) It adds another waitqueue to the space info so that when we start a fs wide delalloc flush, anybody else who also hits that area will simply wait for the flush to finish and then try to make their allocation. This has been tested thoroughly to make sure we did not regress on performance. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Btrfs: delay clearing EXTENT_DELALLOC for compressed extentsChris Mason
When compression is on, the cow_file_range code is farmed off to worker threads. This allows us to do significant CPU work in parallel on SMP machines. But it is a delicate balance around when we clear flags and how. In the past we cleared the delalloc flag immediately, which was safe because the pages stayed locked. But this is causing problems with the newest ENOSPC code, and with the recent extent state cleanups we can now clear the delalloc bit at the same time the uncompressed code does. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Btrfs: cleanup extent_clear_unlock_delalloc flagsChris Mason
extent_clear_unlock_delalloc has a growing set of ugly parameters that is very difficult to read and maintain. This switches to a flag field and well named flag defines. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-10-08Merge branch 'master' into for-linusAlex Elder
2009-10-08xfs: stop calling filemap_fdatawait inside ->fsyncChristoph Hellwig
Now that the VFS actually waits for the data I/O to complete before calling into ->fsync we can stop doing it ourselves. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08fix readahead calculations in xfs_dir2_leaf_getdents()Eric Sandeen
This is for bug #850, http://oss.sgi.com/bugzilla/show_bug.cgi?id=850 XFS file system segfaults , repeatedly and 100% reproducable in 2.6.30 , 2.6.31 The above only showed up on a CONFIG_XFS_DEBUG=y kernel, because xfs_bmapi() ASSERTs that it has been asked for at least one map, and it was getting 0. The root cause is that our guesstimated "bufsize" from xfs_file_readdir was fairly small, and the bufsize -= length; in the loop was going negative - except bufsize is a size_t, so it was wrapping to a very large number. Then when we did ra_want = howmany(bufsize + mp->m_dirblksize, mp->m_sb.sb_blocksize) - 1; with that very large number, the (int) ra_want was coming out negative, and a subsequent compare: if (1 + ra_want > map_blocks ... was coming out -true- (negative int compare w/ uint) and we went back to xfs_bmapi() for more, even though we did not need more, and asked for 0 maps, and hit the ASSERT. We have kind of a type mess here, but just keeping bufsize from going negative is probably sufficient to avoid the problem. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08xfs: make sure xfs_sync_fsdata covers the logDave Chinner
We want to always cover the log after writing out the superblock, and in case of a synchronous writeout make sure we actually wait for the log to be covered. That way a filesystem that has been sync()ed can be considered clean by log recovery. Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08xfs: mark inodes dirty before issuing I/ODave Chinner
To make sure they get properly waited on in sync when I/O is in flight and we latter need to update the inode size. Requires a new helper to check if an ioend structure is beyond the current EOF. Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08xfs: cleanup ->sync_fsChristoph Hellwig
Sort out ->sync_fs to not perform a superblock writeback for the wait = 0 case as that is just an optional first pass and the superblock will be written back properly in the next call with wait = 1. Instead perform an opportunistic quota writeback to have less work later. Also remove the freeze special case as we do a proper wait = 1 call in the freeze code anyway. Also rename the function to xfs_fs_sync_fs to match the normal naming convention, update comments and avoid calling into the laptop_mode logic on an error. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08xfs: fix xfs_quiesce_dataDave Chinner
We need to do a synchronous xfs_sync_fsdata to make sure the superblock actually is on disk when we return. Also remove SYNC_BDFLUSH flag to xfs_sync_inodes because that particular flag is never checked. Move xfs_filestream_flush call later to only release inodes after they have been written out. Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08xfs: implement ->dirty_inode to fix timestamp handlingChristoph Hellwig
This is picking up on Felix's repost of Dave's patch to implement a .dirty_inode method. We really need this notification because the VFS keeps writing directly into the inode structure instead of going through methods to update this state. In addition to the long-known atime issue we now also have a caller in VM code that updates c/mtime that way for shared writeable mmaps. And I found another one that no one has noticed in practice in the FIFO code. So implement ->dirty_inode to set i_update_core whenever the inode gets externally dirtied, and switch the c/mtime handling to the same scheme we already use for atime (always picking up the value from the Linux inode). Note that this patch also removes the xfs_synchronize_atime call in xfs_reclaim it was superflous as we already synchronize the time when writing the inode via the log (xfs_inode_item_format) or the normal buffers (xfs_iflush_int). In addition also remove the I_CLEAR check before copying the Linux timestamps - now that we always have the Linux inode available we can always use the timestamps in it. Also switch to just using file_update_time for regular reads/writes - that will get us all optimization done to it for free and make sure we notice early when it breaks. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-10-08ima: ecryptfs fix imbalance messageMimi Zohar
The unencrypted files are being measured. Update the counters to get rid of the ecryptfs imbalance message. (http://bugzilla.redhat.com/519737) Reported-by: Sachin Garg Cc: Eric Paris <eparis@redhat.com> Cc: Dustin Kirkland <kirkland@canonical.com> Cc: James Morris <jmorris@namei.org> Cc: David Safford <safford@watson.ibm.com> Cc: stable@kernel.org Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-10-08eCryptfs: Remove Kconfig NET dependency and select MD5Tyler Hicks
eCryptfs no longer uses a netlink interface to communicate with ecryptfsd, so NET is not a valid dependency anymore. MD5 is required and must be built for eCryptfs to be of any use. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-10-08ecryptfs: depends on CRYPTORandy Dunlap
ecryptfs uses crypto APIs so it should depend on CRYPTO. Otherwise many build errors occur. [63 lines not pasted] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
