There is nothing known wrong with the inotify watch addition/modification
but this patch seperates the two code paths to make them each easy to
verify as correct.
Signed-off-by: Eric Paris <eparis@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
ext3: Improve error message that changing journaling mode on remount is not possible
ext3: Update Kconfig description of EXT3_DEFAULTS_TO_ORDERED
Commit 76db6d9500caeaa774a3e32a997eba30bbdc176b (nfs41: add session setup
to the state manager) introduces an infinite loop possibility in the NFSv4
state manager. By first checking nfs4_has_session() before clearing the
NFS4CLNT_SESSION_SETUP flag, it allows for a situation where someone sets
that flag, but it never gets cleared, and so the state manager loops.
In fact commit c3fad1b1aaf850bf692642642ace7cd0d64af0a3 (nfs41: add session
reset to state manager) causes this to happen every time we get a network
partition error.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
ocfs2/dlm: Wait on lockres instead of erroring cancel requests
ocfs2: Add missing lock name
ocfs2: Don't oops in ocfs2_kill_sb on a failed mount
ocfs2: release the buffer head in ocfs2_do_truncate.
ocfs2: Handle quota file corruption more gracefully
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed
user_shm_lock() calls in hugetlb_file_setup() but left the
user_shm_unlock call in shm_destroy().
In detail:
Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock()
is not called in hugetlb_file_setup(). However, user_shm_unlock() is
called in any case in shm_destroy() and in the following
atomic_dec_and_lock(&up->__count) in free_uid() is executed and if
up->__count gets zero, also cleanup_user_struct() is scheduled.
Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set.
However, the ref counter up->__count gets unexpectedly non-positive and
the corresponding structs are freed even though there are live
references to them, resulting in a kernel oops after a lots of
shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set.
Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the
time of shm_destroy() may give a different answer from at the time
of hugetlb_file_setup(). And fixed newseg()'s no_id error path,
which has missed user_shm_unlock() ever since it came in 2.6.9.
Reported-by: Stefan Huber <shuber2@gmail.com>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Tested-by: Stefan Huber <shuber2@gmail.com>
Cc: stable@kernel.org
possible
This patch makes the error message about changing journaling mode on remount
more descriptive. Some people are going to hit this error now due to commit
bbae8bcc49bc4d002221dab52c79a50a82e7cd1f if they configure a kernel to default
to data=writeback mode. The problem happens if they have data=ordered set for
the root filesystem in /etc/fstab but not in the kernel command line (and they
don't use initrd). Their filesystem then gets mounted as data=writeback by
kernel but then their boot fails because init scripts won't be able to remount
the filesystem rw. Better error message will hopefully make it easier for them
to find the error in their setup and bother us less with error reports :).
The old description for this configuration option was perhaps not
completely balanced in terms of describing the tradeoffs of using a
default of data=writeback vs. data=ordered. Despite the fact that old
description very strongly recomended disabling this feature, all of
the major distributions have elected to preserve the existing 'legacy'
default, which is a strong hint that it perhaps wasn't telling the
whole story.
This revised description has been vetted by a number of ext3
developers as being better at informing the user about the tradeoffs
of enabling or disabling this configuration feature.
Cc: linux-ext4@vger.kernel.org
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
vfs_read() offset is defined as loff_t, but kernel_read()
offset is only defined as unsigned long. Redefine
kernel_read() offset as loff_t.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
In commit a8e7d49aa7be728c4ae241a75a2a124cdcabc0c5 ("Fix race in
create_empty_buffers() vs __set_page_dirty_buffers()"), I removed a test
for a NULL page mapping unintentionally when some of the code inside
__set_page_dirty() was moved to the callers.
That removal generally didn't matter, since a filesystem would serialize
truncation (which clears the page mapping) against writing (which marks
the buffer dirty), so locking at a higher level (either per-page or an
inode at a time) should mean that the buffer page would be stable. And
indeed, nothing bad seemed to happen.
Except it turns out that apparently reiserfs does something odd when
under load and writing out the journal, and we have a number of bugzilla
entries that look similar:
http://bugzilla.kernel.org/show_bug.cgi?id=13556
http://bugzilla.kernel.org/show_bug.cgi?id=13756
http://bugzilla.kernel.org/show_bug.cgi?id=13876
and it looks like reiserfs depended on that check (the common theme
seems to be "data=journal", and a journal writeback during a truncate).
I suspect reiserfs should have some additional locking, but in the
meantime this should get us back to the pre-2.6.29 behavior.
Pattern-pointed-out-by: Roland Kletzing <devzero@web.de>
Cc: stable@kernel.org (2.6.29 and 2.6.30)
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Nick Piggin <npiggin@suse.de>
* 'btrfs' of git://git.kernel.dk/linux-2.6-block:
btrfs: fix inode rbtree corruption
Node may not be inserted over existing node. This causes inode tree
corruption and I was seeing crashes in inode_tree_del which I can not
reproduce after this patch.
The other way to fix this would be to tie inode lifetime in the rbtree
with inode while not in freeing state. I had a look at this but it is
not so trivial at this point. At least this patch gets things working again.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Chris Mason <chris.mason@oracle.com>
Acked-by: Yan Zheng <zheng.yan@oracle.com>
In case a downconvert is queued, and a flock receives a signal,
BUG_ON(lockres->l_action != OCFS2_AST_INVALID) is triggered
because a lock cancel triggers a dlmunlock while an AST is
scheduled.
To avoid this, allow a LKM_CANCEL to pass through, and let it
wait on __dlm_wait_on_lockres().
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
Acked-off-by: Mark Fasheh <mfasheh@suse.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
There is missing name for NFSSync cluster lock. This makes lockdep unhappy
because we end up passing NULL to lockdep when initializing lock key. Fix it.
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: fix oopses with doubly mounted snapshots
nilfs2: missing a read lock for segment writer in nilfs_attach_checkpoint()
The commit 2ff05b2b (oom: move oom_adj value) moveed the oom_adj value to
the mm_struct. It was a very good first step for sanitize OOM.
However Paul Menage reported the commit makes regression to his job
scheduler. Current OOM logic can kill OOM_DISABLED process.
Why? His program has the code of similar to the following.
set_oom_adj(OOM_DISABLE); /* The job scheduler never killed by oom */
if (vfork() == 0) {
set_oom_adj(0); /* Invoked child can be killed */
execve("foo-bar-cmd");
vfork() parent and child are shared the same mm_struct. then above
set_oom_adj(0) doesn't only change oom_adj for vfork() child, it's also
change oom_adj for vfork() parent. Then, vfork() parent (job scheduler)
lost OOM immune and it was killed.
Actually, fork-setting-exec idiom is very frequently used in userland program.
We must not break this assumption.
Then, this patch revert commit 2ff05b2b and related commit.
Reverted commit list
- commit 2ff05b2b4e (oom: move oom_adj value from task_struct to mm_struct)
- commit 4d8b9135c3 (oom: avoid unnecessary mm locking and scanning for OOM_DISABLE)
- commit 8123681022 (oom: only oom kill exiting tasks with attached memory)
- commit 933b787b57 (mm: copy over oom_adj value at fork time)
Cc: Paul Menage <menage@google.com>
get_sb_pseudo sets s_maxbytes to ~0ULL which becomes negative when cast
to a signed value. Fix it to use MAX_LFS_FILESIZE which casts properly
to a positive signed value.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Steve French <smfrench@gmail.com>
Cc: Robert Love <rlove@google.com>
will fix kernel oopses like the following:
# mount -t nilfs2 -r -o cp=20 /dev/sdb1 /test1
# mount -t nilfs2 -r -o cp=20 /dev/sdb1 /test2
# umount /test1
# umount /test2
BUG: sleeping function called from invalid context at arch/x86/mm/fault.c:1069
in_atomic(): 0, irqs_disabled(): 1, pid: 3886, name: umount.nilfs2
1 lock held by umount.nilfs2/3886:
#0: (&type->s_umount_key#31){+.+...}, at: [<c10b398a>] deactivate_super+0x52/0x6c
irq event stamp: 1219
hardirqs last enabled at (1219): [<c135c774>] __mutex_unlock_slowpath+0xf8/0x119
hardirqs last disabled at (1218): [<c135c6d5>] __mutex_unlock_slowpath+0x59/0x119
softirqs last enabled at (1214): [<c1033316>] __do_softirq+0x1a5/0x1ad
softirqs last disabled at (1205): [<c1033354>] do_softirq+0x36/0x5a
Pid: 3886, comm: umount.nilfs2 Not tainted 2.6.31-rc6 #55
Call Trace:
[<c1023549>] __might_sleep+0x107/0x10e
[<c13603c0>] do_page_fault+0x246/0x397
[<c136017a>] ? do_page_fault+0x0/0x397
[<c135e753>] error_code+0x6b/0x70
[<c104f805>] ? __lock_acquire+0x91/0x12fd
[<c1050a62>] ? __lock_acquire+0x12ee/0x12fd
[<c1050b2b>] lock_acquire+0xba/0xdd
[<d0d17d3f>] ? nilfs_detach_segment_constructor+0x2f/0x2fa [nilfs2]
[<c135d4fe>] down_write+0x2a/0x46
[<d0d17d3f>] nilfs_detach_segment_constructor+0x2f/0x2fa [nilfs2]
[<c104ea2c>] ? mark_held_locks+0x43/0x5b
[<c104ecb1>] ? trace_hardirqs_on_caller+0x10b/0x133
[<c104ece4>] ? trace_hardirqs_on+0xb/0xd
[<d0d09ac1>] nilfs_put_super+0x2f/0xca [nilfs2]
[<c10b3352>] generic_shutdown_super+0x49/0xb8
[<c10b33de>] kill_block_super+0x1d/0x31
[<c10e6599>] ? vfs_quota_off+0x0/0x12
[<c10b398f>] deactivate_super+0x57/0x6c
[<c10c4bc3>] mntput_no_expire+0x8c/0xb4
[<c10c5094>] sys_umount+0x27f/0x2a4
[<c10c50c6>] sys_oldumount+0xd/0xf
[<c10031a4>] sysenter_do_call+0x12/0x38
This turns out to be a bug brought by an -rc1 patch ("nilfs2: simplify
remaining sget() use").
In the patch, a new "put resource" function, nilfs_put_sbinfo()
was introduced to delay freeing nilfs_sb_info struct.
But the nilfs_put_sbinfo() mistakenly used atomic_dec_and_test()
function to check the reference count, and it caused the nilfs_sb_info
was freed when user mounted a snapshot twice.
This bug also suggests there was unseen memory leak in usual mount
/umount operations for nilfs.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
'ns_cno' of structure 'the_nilfs' must be protected from segment
writer, in other words, the caller of nilfs_get_checkpoint should hold
read lock for nilfs->ns_segctor_sem. This patch adds the lock/unlock
operations in nilfs_attach_checkpoint() when calling
nilfs_cpfile_get_checkpoint().
Signed-off-by: Zhang Qiang <zhangqiang.buaa@gmail.com>
If we fail to mount the filesystem, we have to be careful not to dereference
uninitialized structures in ocfs2_kill_sb.
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: fix locking in xfs_iget_cache_hit
The inotify_add_watch man page specifies that inotify_add_watch() will
return a non-negative integer. However, historically the inotify
watches started at 1, not at 0.
Turns out that the inotifywait program provided by the inotify-tools
package doesn't properly handle a 0 watch descriptor. In 7e790dd5 we
changed from starting at 1 to starting at 0. This patch starts at 1,
just like in previous kernels, but also just like in previous kernels
it's possible for it to wrap back to 0. This preserves the kernel
functionality exactly like it was before the patch (neither method broke
the spec)
In f44aebcc the tail drop logic of events with no file backing
(q_overflow and in_ignored) was reversed so IN_IGNORED events would
never be tail dropped. This now means that Q_OVERFLOW events are NOT
tail dropped. The fix is to not tail drop IN_IGNORED, but to tail drop
Q_OVERFLOW.
inotify decides if private data it passed to get added to an event was
used by checking list_empty(). But it's possible that the event may
have been dequeued and the private event removed so it would look empty.
The fix is to use the return code from fsnotify_add_notify_event rather
than looking at the list.
In ocfs2_do_truncate, we forget to release last_eb_bh which
will cause memleak. So call brelse in the end.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
ocfs2_read_virt_blocks() does BUG when we try to read a block from a file
beyond its end. Since this can happen due to filesystem corruption, it
is not really an appropriate answer. Make ocfs2_read_quota_block() check
the condition and handle it by calling ocfs2_error() and returning EIO.
[ Modified to print ip_blkno in the error - Joel ]
Reported-by: Tristan Ye <tristan.ye@oracle.com>
The locking in xfs_iget_cache_hit currently has numerous problems:
- we clear the reclaim tag without i_flags_lock which protects
modifications to it
- we call inode_init_always which can sleep with pag_ici_lock
held (this is oss.sgi.com BZ #819)
- we acquire and drop i_flags_lock a lot and thus provide no
consistency between the various flags we set/clear under it
This patch fixes all that with a major revamp of the locking in
the function. The new version acquires i_flags_lock early and
only drops it once we need to call into inode_init_always or before
calling xfs_ilock.
This patch fixes a bug seen in the wild where we race modifying the
reclaim tag.
Reviewed-by: Felix Blyakher <felixb@sgi.com>
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Signed-off-by: Felix Blyakher <felixb@sgi.com>
The triggered field of struct poll_wqueues introduced in commit
5f820f648c92a5ecc771a96b3c29aa6e90013bba ("poll: allow f_op->poll to
sleep").
It was first set to 1 in pollwake() (now __pollwake() ), tested and
later set to 0 in poll_schedule_timeout(), but not initialized before.
As a result when the process needs to sleep, triggered was likely to be
non-zero even if pollwake() is not called before the first
poll_schedule_timeout(), meaning schedule_hrtimeout_range() would not be
called and an extra loop calling all ->poll() would be done.
This patch initialize triggered to 0 in poll_initwait() so the ->poll()
are not called twice before the process goes to sleep when it needs to.
Signed-off-by: Guillaume Knispel <gknispel@proformatique.com>
Acked-by: Tejun Heo <tj@kernel.org>
Although this file is only ever written and not read by
userspace, it seems that the utils are opening this
file O_RDWR, so we need to allow that.
Also fixes the whitespace which seemed to be broken.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: David Teigland <teigland@redhat.com>
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (22 commits)
ocfs2: Fix possible deadlock when extending quota file
ocfs2: keep index within status_map[]
ocfs2: Initialize the cluster we're writing to in a non-sparse extend
ocfs2: Remove redundant BUG_ON in __dlm_queue_ast()
ocfs2/quota: Release lock for error in ocfs2_quota_write.
ocfs2: Define credit counts for quota operations
ocfs2: Remove syncjiff field from quota info
ocfs2: Fix initialization of blockcheck stats
ocfs2: Zero out padding of on disk dquot structure
ocfs2: Initialize blocks allocated to local quota file
ocfs2: Mark buffer uptodate before calling ocfs2_journal_access_dq()
ocfs2: Make global quota files blocksize aligned
ocfs2: Use ocfs2_rec_clusters in ocfs2_adjust_adjacent_records.
ocfs2: Fix deadlock on umount
ocfs2: Add extra credits and access the modified bh in update_edge_lengths.
ocfs2: Fail ocfs2_get_block() immediately when a block needs allocation
ocfs2: Fix error return in ocfs2_write_cluster()
ocfs2: Fix compilation warning for fs/ocfs2/xattr.c
ocfs2: Initialize count in aio_write before generic_write_checks
ocfs2: log the actual return value of ocfs2_file_aio_write()
xfs: fix spin_is_locked assert on uni-processor builds
xfs: check for dinode realtime flag corruption
use XFS_CORRUPTION_ERROR in xfs_btree_check_sblock
xfs: switch to NOFS allocation under i_lock in xfs_attr_rmtval_get
xfs: switch to NOFS allocation under i_lock in xfs_readlink_bmap
xfs: switch to NOFS allocation under i_lock in xfs_attr_rmtval_set
xfs: switch to NOFS allocation under i_lock in xfs_buf_associate_memory
xfs: switch to NOFS allocation under i_lock in xfs_dir_cilookup_result
xfs: switch to NOFS allocation under i_lock in xfs_da_buf_make
xfs: switch to NOFS allocation under i_lock in xfs_da_state_alloc
xfs: switch to NOFS allocation under i_lock in xfs_getbmap
xfs: avoid memory allocation under m_peraglock in growfs code
We can't call nfs_readdata_release()/nfs_writedata_release() without
first initialising and referencing args.context. Doing so inside
nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment()
causes an Oops.
We should rather be calling nfs_readdata_free()/nfs_writedata_free() in
those cases.
Looking at the O_DIRECT code, the "struct nfs_direct_req" is already
referencing the nfs_open_context for us. Since the readdata and writedata
structures carry a reference to that, we can simplify things by getting rid
of the extra nfs_open_context references, so that we can replace all
instances of nfs_readdata_release()/nfs_writedata_release().
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Without SMP or preemption spin_is_locked always returns false,
so we can't do an assert with it. Instead use assert_spin_locked,
which does the right thing on all builds.
Reported-by: Johannes Engel <jcnengel@googlemail.com>
Tested-by: Johannes Engel <jcnengel@googlemail.com>
Ramon tested XFS with a modified version of fsfuzzer and hit a NULL
pointer dereference in __xfs_get_blocks due to the RT device target
pointer being NULL.
To fix this reject inode with the realtime bit set on a a filesystem
without an RT subvolume during inode read.
Reported-by: Ramon de Carvalho Valle <ramon@risesecurity.org>
Tested-by: Ramon de Carvalho Valle <ramon@risesecurity.org>
In Red Hat Bug 512552
- Can't write to XFS mount during raid5 resync
a user ran into corruption while resyncing a raid, and we failed
a consistency test, but didn't get much more info; it'd be nice
to call XFS_CORRUPTION_ERROR here so we can see the buffer
contents.
Signed-off-by: Eric Sandeen <sandeen@sandeen.net>
xfs_attr_rmtval_get is always called with i_lock held, but i_lock is taken
in reclaim context so all allocations under it must avoid recursions into
the filesystem.
Reported by the new reclaim context tracing in lockdep.
xfs_readlink_bmap is called with i_lock held, but i_lock is taken in
the filesystem.
xfs_attr_rmtval_set is always called with i_lock held, and i_lock is taken
the filesystem.
xfs_buf_associate_memory is used for setting up the spare buffer for the
log wrap case in xlog_sync which can happen under i_lock when called from
xfs_fsync. The i_lock mutex is taken in reclaim context so all allocations
under it must avoid recursions into the filesystem. There are a couple
more uses of xfs_buf_associate_memory in the log recovery code that are
also affected by this, but I'd rather keep the code simple than passing on
a gfp_mask argument. Longer term we should just stop requiring the memoery
allocation in xlog_sync by some smaller rework of the buffer layer.
xfs_dir_cilookup_result is always called with i_lock held, but i_lock is taken
in reclaim context so all allocations under it must avoid recursions into the
filesystem.
i_lock is taken in the reclaim context so all allocations under it
xfs_da_state_alloc is always called with i_lock held, but i_lock is taken in
filesystem.
xfs_getbmap allocates memory with i_lock held, but i_lock is taken in
the filesystem.
Allocate the memory for the larger m_perag array before taking the
per-AG lock as the per-AG lock can be taken under the i_lock which
can be taken from reclaim context.
In OCFS2, allocator locks rank above transaction start. Thus we
cannot extend quota file from inside a transaction less we could
deadlock.
We solve the problem by starting transaction not already in
ocfs2_acquire_dquot() but only in ocfs2_local_read_dquot() and
ocfs2_global_read_dquot() and we allocate blocks to quota files before starting
the transaction. In case we crash, quota files will just have a few blocks
more but that's no problem since we just use them next time we extend the
quota file.
The problem is minor, but without ->cred_guard_mutex held we can race
with exec() and get the new ->mm but check old creds.
Now we do not need to re-check task->mm after ptrace_may_access(), it
can't be changed to the new mm under us.
Strictly speaking, this also fixes another very minor problem. Unless
security check fails or the task exits mm_for_maps() should never
return NULL, the caller should get either old or new ->mm.
Acked-by: Serge Hallyn <serue@us.ibm.com>
mm_for_maps() takes ->mmap_sem after security checks, this looks
strange and obfuscates the locking rules. Move this lock to its
single caller, m_start().
It would be nice to kill __ptrace_may_access(). It requires task_lock(),
but this lock is only needed to read mm->flags in the middle.
Convert mm_for_maps() to use ptrace_may_access(), this also simplifies
the code a little bit.
Also, we do not need to take ->mmap_sem in advance. In fact I think
mm_for_maps() should not play with ->mmap_sem at all, the caller should
take this lock.
With or without this patch, without ->cred_guard_mutex held we can race
Reviewed-by: Serge Hallyn <serue@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: fix balancing oops when invalidate_inode_pages2 returns EBUSY
Btrfs: correct error-handling zlib error handling
Btrfs: remove superfluous NULL pointer check in btrfs_rename()
Btrfs: make sure the async caching thread advances the key
Btrfs: fix btrfs_remove_from_free_space corner case
* git://git.kernel.org/pub/scm/linux/kernel/git/hch/xfs-icache-races:
xfs: fix freeing of inodes not yet added to the inode cache
vfs: add __destroy_inode
vfs: fix inode_init_always calling convention
Do not exceed array status_map[]
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Mark Fasheh <mfasheh@suse.com>
