path: root/fs
2007-07-16HFS+: add custom dentry hash and comparison operationsDuane Griffin
Add custom dentry hash and comparison operations for HFS+ filesystems that are case-insensitive and/or do automatic unicode decomposition. The new operations reuse the existing HFS+ ASCII to unicode conversion, unicode decomposition and case folding functionality. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFS+: refactor ASCII to unicode conversion routine for later reuseDuane Griffin
The HFS+ filesystem is case-insensitive and does automatic unicode decomposition by default, but does not provide custom dentry operations. This can lead to multiple dentries being cached for lookups on a filename with varying case and/or character (de)composition. These patches add custom dentry hash and comparison operations for case-sensitive and/or automatically decomposing HFS+ filesystems. Unicode decomposition and case-folding are performed as required to ensure equivalent filenames are hashed to the same values and compare as equal. This patch: Refactor existing HFS+ ASCII to unicode string conversion routine to split out character conversion functionality. This will be reused by the custom dentry hash and comparison routines. This approach avoids unnecessary memory allocation compared to using the string conversion routine directly in the new functions. [akpm@linux-foundation.org: avoid use-of-uninitialised] Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mistaken ext4_inode_bitmap for ext4_block_bitmapToshiyuki Okajima
In ext4_new_blocks(), one of two ext4_block_bitmap() calls should be ext4_inode_bitmap() call. It is not harmful in normal processing, but it should be fixed. Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16is_power_of_2(): jbdvignesh babu
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2(). Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16is_power_of_2: ext3/super.cvignesh babu
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2() Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16drop obsolete sys_ioctl exportChristoph Hellwig
sys_ioctl() was only exported for our first version of compat ioctl handling. Now that the whole compat ioctl handling mess is more or less sorted out there are no more modular users left and we can kill it. There's one exception and that's sparc64's solaris compat module, but sparc64 has it's own export predating the generic one by years for that which this patch leaves untouched. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16namespace: ensure clone_flags are always stored in an unsigned longEric W. Biederman
While working on unshare support for the network namespace I noticed we were putting clone flags in an int. Which is weird because the syscall uses unsigned long and we at least need an unsigned to properly hold all of the unshare flags. So to make the code consistent, this patch updates the code to use unsigned long instead of int for the clone flags in those places where we get it wrong today. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext3: remove extra IS_RDONLY() checkDave Hansen
ext3_change_inode_journal_flag() is only called from one location: ext3_ioctl(EXT3_IOC_SETFLAGS). That ioctl case already has a IS_RDONLY() call in it so this one is superfluous. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16diskquota: 32bit quota tools on 64bit architecturesVasily Tarasov
OpenVZ Linux kernel team has discovered the problem with 32bit quota tools working on 64bit architectures. In 2.6.10 kernel sys32_quotactl() function was replaced by sys_quotactl() with the comment "sys_quotactl seems to be 32/64bit clean, enable it for 32bit" However this isn't right. Look at if_dqblk structure: struct if_dqblk { __u64 dqb_bhardlimit; __u64 dqb_bsoftlimit; __u64 dqb_curspace; __u64 dqb_ihardlimit; __u64 dqb_isoftlimit; __u64 dqb_curinodes; __u64 dqb_btime; __u64 dqb_itime; __u32 dqb_valid; }; For 32 bit quota tools sizeof(if_dqblk) == 0x44. But for 64 bit kernel its size is 0x48, 'cause of alignment! Thus we got a problem. Attached patch reintroduce sys32_quotactl() function, that handles this and related situations. [michal.k.k.piotrowski@gmail.com: build fix] [akpm@linux-foundation.org: Make it link with CONFIG_QUOTA=n] Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jan Kara <jack@ucw.cz> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext4: fix deadlock in ext4_remount() and orphan list handlingJan Kara
ext4_orphan_add() and ext4_orphan_del() functions lock sb->s_lock with a transaction started with ext4_mark_recovery_complete() waits for a transaction holding sb->s_lock, thus leading to a possible deadlock. At the moment we call ext4_mark_recovery_complete() from ext4_remount() we have done all the work needed for remounting and thus we are safe to drop sb->s_lock before we wait for transactions to commit. Note that at this moment we are still guarded by s_umount lock against other remounts/umounts. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Eric Sandeen <sandeen@sandeen.net> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext3: fix deadlock in ext3_remount() and orphan list handlingJan Kara
ext3_orphan_add() and ext3_orphan_del() functions lock sb->s_lock with a transaction started with ext3_mark_recovery_complete() waits for a transaction holding sb->s_lock, thus leading to a possible deadlock. At the moment we call ext3_mark_recovery_complete() from ext3_remount() we have done all the work needed for remounting and thus we are safe to drop sb->s_lock before we wait for transactions to commit. Note that at this moment we are still guarded by s_umount lock against other remounts/umounts. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Eric Sandeen <sandeen@sandeen.net> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix create_new_namespaces() return valueCedric Le Goater
dup_mnt_ns() and clone_uts_ns() return NULL on failure. This is wrong, create_new_namespaces() uses ERR_PTR() to catch an error. This means that the subsequent create_new_namespaces() will hit BUG_ON() in copy_mnt_ns() or copy_utsname(). Modify create_new_namespaces() to also use the errors returned by the copy_*_ns routines and not to systematically return ENOMEM. [oleg@tv-sign.ru: better changelog] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16binfmt_elf warning fixAndrew Morton
fs/binfmt_elf.c: In function 'load_elf_binary': fs/binfmt_elf.c:1002: warning: 'interp_map_addr' may be used uninitialized in this function The compiler (gcc-4.1.0) is correct, but it failed to notice that we didn't use the resulting value. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16revert "vanishing ioctl handler debugging"Andrew Morton
Revert my do_ioctl() debugging patch: Paul fixed the bug. Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16hugetlbfs: handle empty options stringLee Schermerhorn
I was seeing a null pointer deref in fs/super.c:vfs_kern_mount(). Some file system get_sb() handler was returning NULL mnt_sb with a non-negative return value. I also noticed a "hugetlbfs: Bad mount option:" message in the log. Turns out that hugetlbfs_parse_options() was not checking for an empty option string after call to strsep(). On failure, hugetlbfs_parse_options() returns 1. hugetlbfs_fill_super() just passed this return code back up the call stack where vfs_kern_mount() missed the error and proceeded with a NULL mnt_sb. Apparently introduced by patch: hugetlbfs-use-lib-parser-fix-docs.patch The problem was exposed by this line in my fstab: none /huge hugetlbfs defaults 0 0 It can also be demonstrated by invoking mount of hugetlbfs directly with no options or a bogus option. This patch: 1) adds the check for empty option to hugetlbfs_parse_options(), 2) enhances the error message to bracket any unrecognized option with quotes , 3) modifies hugetlbfs_parse_options() to return -EINVAL on any unrecognized option, 4) adds a BUG_ON() to vfs_kern_mount() to catch any get_sb() handler that returns a NULL mnt->mnt_sb with a return value >= 0. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16hugetlbfs: use lib/parser, fix docsRandy Dunlap
Use lib/parser.c to parse hugetlbfs mount options. Correct docs in hugetlbpage.txt. old size of hugetlbfs_fill_super: 675 bytes new size of hugetlbfs_fill_super: 686 bytes (hugetlbfs_parse_options() is inlined) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Acked-by: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFSPlus: change kmalloc/memset to kzallocWyatt Banks
Removed kmalloc and memset in favor of kzalloc. To explain the HFSPLUS_SB() macro in the removed memset call: hfsplus_fs.h:#define HFSPLUS_SB(super) (*(struct hfsplus_sb_info *)(super)->s_fs_info) Signed-off-by: Wyatt Banks <wyatt@banksresearch.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16taskstats: add context-switch countersMaxim Uvarov
Make available to the user the following task and process performance statistics: * Involuntary Context Switches (task_struct->nivcsw) * Voluntary Context Switches (task_struct->nvcsw) Statistics information is available from: 1. taskstats interface (Documentation/accounting/) 2. /proc/PID/status (task only). This data is useful for detecting hyperactivity patterns between processes. [akpm@linux-foundation.org: cleanup] Signed-off-by: Maxim Uvarov <muvarov@ru.mvista.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Jonathan Lim <jlim@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext3/ext4: orphan list corruption due bad inodeVasily Averin
After ext3 orphan list check has been added into ext3_destroy_inode() (please see my previous patch) the following situation has been detected: EXT3-fs warning (device sda6): ext3_unlink: Deleting nonexistent file (37901290), 0 Inode 00000101a15b7840: orphan list check failed! 00000773 6f665f00 74616d72 00000573 65725f00 06737270 66000000 616d726f ... Call Trace: [<ffffffff80211ea9>] ext3_destroy_inode+0x79/0x90 [<ffffffff801a2b16>] sys_unlink+0x126/0x1a0 [<ffffffff80111479>] error_exit+0x0/0x81 [<ffffffff80110aba>] system_call+0x7e/0x83 First messages said that unlinked inode has i_nlink=0, then ext3_unlink() adds this inode into orphan list. Second message means that this inode has not been removed from orphan list. Inode dump has showed that i_fop = &bad_file_ops and it can be set in make_bad_inode() only. Then I've found that ext3_read_inode() can call make_bad_inode() without any error/warning messages, for example in the following case: ... if (inode->i_nlink == 0) { if (inode->i_mode == 0 || !(EXT3_SB(inode->i_sb)->s_mount_state & EXT3_ORPHAN_FS)) { /* this inode is deleted */ brelse (bh); goto bad_inode; ... Bad inode can live some time, ext3_unlink can add it to orphan list, but ext3_delete_inode() do not deleted this inode from orphan list. As result we can have orphan list corruption detected in ext3_destroy_inode(). However it is not clear for me how to fix this issue correctly. As far as i see is_bad_inode() is called after iget() in all places excluding ext3_lookup() and ext3_get_parent(). I believe it makes sense to add bad inode check to these functions too and call iput if bad inode detected. Signed-off-by: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext3/ext4: orphan list check on destroy_inodeVasily Averin
Customers claims to ext3-related errors, investigation showed that ext3 orphan list has been corrupted and have the reference to non-ext3 inode. The following debug helps to understand the reasons of this issue. [akpm@linux-foundation.org: update for print_hex_dump() changes] Signed-off-by: Vasily Averin <vvs@sw.ru> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Remove capability.h from mm.hAlexey Dobriyan
I forgot to remove capability.h from mm.h while removing sched.h! This patch remedies that, because the only inline function which was using CAP_something was made out of line. Cross-compile tested without regressions on: all powerpc defconfigs all mips defconfigs all m68k defconfigs all arm defconfigs all ia64 defconfigs alpha alpha-allnoconfig alpha-defconfig alpha-up arm i386 i386-allnoconfig i386-defconfig i386-up ia64 ia64-allnoconfig ia64-defconfig ia64-up m68k mips parisc parisc-allnoconfig parisc-defconfig parisc-up powerpc powerpc-up s390 s390-allnoconfig s390-defconfig s390-up sparc sparc-allnoconfig sparc-defconfig sparc-up sparc64 sparc64-allnoconfig sparc64-defconfig sparc64-up um-x86_64 x86_64 x86_64-allnoconfig x86_64-defconfig x86_64-up as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16seq_file: more atomicity in traverse()Alexey Dobriyan
Original problem: in some circumstances seq_file interface can present infinite proc file to the following script when normally said proc file is finite: while read line; do [do something with $line] done </proc/$FILE bash, to implement such loop does essentially read(0, buf, 128); [find \n] lseek(0, -difference, SEEK_CUR); Consider, proc file prints list of objects each of them consists of many lines, each line is shorter than 128 bytes. Two objects in list, with ->index'es being 0 and 1. Current one is 1, as bash prints second object line by line. Imagine first object being removed right before lseek(). traverse() will be called, because there is negative offset. traverse() will reset ->index to 0 (!). traverse() will call ->next() and get NULL in any usual iterate-over-list code using list_for_each_entry_continue() and such. There is one object in list now after all... traverse() will return 0, lseek() will update file position and pretend everything is OK. So, what we have now: ->f_pos points to place where second object will be printed, but ->index is 0. seq_read() instead of returning EOF, will start printing first line of first object every time it's called, until enough objects are added to ->f_pos return in bounds. Fix is to update ->index only after we're sure we saw enough objects down the road. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16O_CLOEXEC for SCM_RIGHTSUlrich Drepper
Part two in the O_CLOEXEC saga: adding support for file descriptors received through Unix domain sockets. The patch is once again pretty minimal, it introduces a new flag for recvmsg and passes it just like the existing MSG_CMSG_COMPAT flag. I think this bit is not used otherwise but the networking people will know better. This new flag is not recognized by recvfrom and recv. These functions cannot be used for that purpose and the asymmetry this introduces is not worse than the already existing MSG_CMSG_COMPAT situations. The patch must be applied on the patch which introduced O_CLOEXEC. It has to remove static from the new get_unused_fd_flags function but since scm.c cannot live in a module the function still hasn't to be exported. Here's a test program to make sure the code works. It's so much longer than the actual patch... #include <errno.h> #include <error.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #include <unistd.h> #include <sys/socket.h> #include <sys/un.h> #ifndef O_CLOEXEC # define O_CLOEXEC 02000000 #endif #ifndef MSG_CMSG_CLOEXEC # define MSG_CMSG_CLOEXEC 0x40000000 #endif int main (int argc, char *argv[]) { if (argc > 1) { int fd = atol (argv[1]); printf ("child: fd = %d\n", fd); if (fcntl (fd, F_GETFD) == 0 || errno != EBADF) { puts ("file descriptor valid in child"); return 1; } return 0; } struct sockaddr_un sun; strcpy (sun.sun_path, "./testsocket"); sun.sun_family = AF_UNIX; char databuf[] = "hello"; struct iovec iov[1]; iov[0].iov_base = databuf; iov[0].iov_len = sizeof (databuf); union { struct cmsghdr hdr; char bytes[CMSG_SPACE (sizeof (int))]; } buf; struct msghdr msg = { .msg_iov = iov, .msg_iovlen = 1, .msg_control = buf.bytes, .msg_controllen = sizeof (buf) }; struct cmsghdr *cmsg = CMSG_FIRSTHDR (&msg); cmsg->cmsg_level = SOL_SOCKET; cmsg->cmsg_type = SCM_RIGHTS; cmsg->cmsg_len = CMSG_LEN (sizeof (int)); msg.msg_controllen = cmsg->cmsg_len; pid_t child = fork (); if (child == -1) error (1, errno, "fork"); if (child == 0) { int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (bind (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "bind"); if (listen (sock, SOMAXCONN) < 0) error (1, errno, "listen"); int conn = accept (sock, NULL, NULL); if (conn == -1) error (1, errno, "accept"); *(int *) CMSG_DATA (cmsg) = sock; if (sendmsg (conn, &msg, MSG_NOSIGNAL) < 0) error (1, errno, "sendmsg"); return 0; } /* For a test suite this should be more robust like a barrier in shared memory. */ sleep (1); int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (connect (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "connect"); unlink (sun.sun_path); *(int *) CMSG_DATA (cmsg) = -1; if (recvmsg (sock, &msg, MSG_CMSG_CLOEXEC) < 0) error (1, errno, "recvmsg"); int fd = *(int *) CMSG_DATA (cmsg); if (fd == -1) error (1, 0, "no descriptor received"); char fdname[20]; snprintf (fdname, sizeof (fdname), "%d", fd); execl ("/proc/self/exe", argv[0], fdname, NULL); puts ("execl failed"); return 1; } [akpm@linux-foundation.org: Fix fastcall inconsistency noted by Michael Buesch] [akpm@linux-foundation.org: build fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Buesch <mb@bu3sch.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Introduce O_CLOEXECUlrich Drepper
The problem is as follows: in multi-threaded code (or more correctly: all code using clone() with CLONE_FILES) we have a race when exec'ing. thread #1 thread #2 fd=open() fork + exec fcntl(fd,F_SETFD,FD_CLOEXEC) In some applications this can happen frequently. Take a web browser. One thread opens a file and another thread starts, say, an external PDF viewer. The result can even be a security issue if that open file descriptor refers to a sensitive file and the external program can somehow be tricked into using that descriptor. Just adding O_CLOEXEC support to open() doesn't solve the whole set of problems. There are other ways to create file descriptors (socket, epoll_create, Unix domain socket transfer, etc). These can and should be addressed separately though. open() is such an easy case that it makes not much sense putting the fix off. The test program: #include <errno.h> #include <fcntl.h> #include <stdio.h> #include <unistd.h> #ifndef O_CLOEXEC # define O_CLOEXEC 02000000 #endif int main (int argc, char *argv[]) { int fd; if (argc > 1) { fd = atol (argv[1]); printf ("child: fd = %d\n", fd); if (fcntl (fd, F_GETFD) == 0 || errno != EBADF) { puts ("file descriptor valid in child"); return 1; } return 0; } fd = open ("/proc/self/exe", O_RDONLY | O_CLOEXEC); printf ("in parent: new fd = %d\n", fd); char buf[20]; snprintf (buf, sizeof (buf), "%d", fd); execl ("/proc/self/exe", argv[0], buf, NULL); puts ("execl failed"); return 1; } [kyle@parisc-linux.org: parisc fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16buffer: kill old incorrect commentEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fs/block_dev.c: use list_for_each_entry()Matthias Kaehlcke
fs/block_dev.c: Use list_for_each_entry() instead of list_for_each() in nr_blockdev_pages() Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mutex_unlock() later in seq_lseek()Alexey Dobriyan
All manipulations with struct seq_file::version are done under struct seq_file::lock except one introduced in commit d6b7a781c51c91dd054e5c437885205592faac21 aka "[PATCH] Speed up /proc/pid/maps" Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext2: fix a comment when ext2_release_file() is calledJan Kara
Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16/proc/*/environ: wrong placing of ptrace_may_attach() checkAlexey Dobriyan
It's a bit dopey-looking and can permit a task to cause a pagefault in an mm which it doesn't have permission to read from. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove useless tolower in isofsyoung dave
Remove useless tolower in isofs Signed-off-by: dave young <hidave.darkstar@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16AFS: drop explicit externRandy Dunlap
Don't use explicit extern specifier and quieten sparse warning: fs/afs/vnode.c:564:12: warning: function 'afs_vnode_link' with external linkage has definition Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16AFS: implement file lockingDavid Howells
Implement file locking for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16procfs directory entry cleanupChangli Gao
Function proc_register() will assign proc_dir_operations and proc_dir_inode_operations to ent's members proc_fops and proc_iops correctly if ent is a directory. So the early assignment isn't necessary. Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Only send SIGXFSZ when exceeding rlimits.Micah Cowan
Some users have been having problems with utilities like cp or dd dumping core when they try to copy a file that's too large for the destination filesystem (typically, > 4gb). Apparently, some defunct standards required SIGXFSZ to be sent in such circumstances, but SUS only requires/allows it for when a written file exceeds the process's resource limits. I'd like to limit SIGXFSZs to the bare minimum required by SUS. Patch sent per http://lkml.org/lkml/2007/4/10/302 Signed-off-by: Micah Cowan <micahcowan@ubuntu.com> Acked-by: Alan Cox <alan@redhat.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16PIE randomizationJan Kratochvil
This patch is using mmap()'s randomization functionality in such a way that it maps the main executable of (specially compiled/linked -pie/-fpie) ET_DYN binaries onto a random address (in cases in which mmap() is allowed to perform a randomization). Origin of this patch is in exec-shield (http://people.redhat.com/mingo/exec-shield/) [jkosina@suse.cz: pie randomization: fix BAD_ADDR macro] Signed-off-by: Jan Kratochvil <honza@jikos.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16isofs: fix up CodingStyleDave Jones
fs/isofs/* had a bunch of CodingStyle issues. * Indentation was a mix of spaces and tabs * "int * foo" instead of "int *foo" * "while ( foo )" instead of "while (foo)" * if (foo) blah; on one line instead of two * Missing printk KERN_ levels * lots of trailing whitespace * lines >80 columns changed to wrap. * Unnecessary prototype removed by shuffling code order in C file. Should be no functional changes other than slight size increase due to printk changes. Further improvement possible, but this is a start.. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix compiler warnings in acorn.cDenver Gingerich
warning: 'adfs_partition' defined but not used warning: 'riscix_partition' defined but not used warning: 'linux_partition' defined but not used Signed-off-by: Denver Gingerich <denver@ossguy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fat: gcc 4.3 warning fixOGAWA Hirofumi
This patch fixes the following warnings. fs/fat/dir.c: In function 'fat_parse_long': include/linux/msdos_fs.h:294: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds The ->name is defined as "name[8], ext[3]", but fat_checksum() uses those as name[11]. There is no actual problem, but it's not a good manner. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make NFS client use seq_list_xxx helpersPavel Emelianov
This includes /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes entries. Both need to show the header and use the list_head. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/self/mounts(tats) use seq_list_xxx helpersPavel Emelianov
One more simple and stupid switching to the new API. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/tty/drivers use seq_list_xxx helpersPavel Emelianov
Simple and stupid like some previous ones. Just use new API. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make AFS use seq_list_xxx helpersPavel Emelianov
These proc files show some header before dumping the list, so the seq_list_start_head() is used. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16vxfs warning fixesAndrew Morton
gcc-4.3: fs/freevxfs/vxfs_lookup.c: In function 'vxfs_find_entry': fs/freevxfs/vxfs_lookup.c:139: warning: cast from pointer to integer of different size fs/freevxfs/vxfs_lookup.c: In function 'vxfs_readdir': fs/freevxfs/vxfs_lookup.c:294: warning: cast from pointer to integer of different size Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for inode dataCyrill Gorcunov
This patch adds checking for granted memory while filling up inode data to prevent possible NULL pointer usage. If there is not enough memory to fill inode data we just mark it as "bad". Also some whitespace cleanup. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for data of new inodesCyrill Gorcunov
Add checking for granted memory for inode data at the moment of its creation. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use boot based time for uptime in /procTomas Janousek
Commit 411187fb05cd11676b0979d9fbf3291db69dbce2 caused uptime not to increase during suspend. This may cause confusion so I restore the old behaviour by using the boot based time instead of monotonic for uptime. Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use boot based time for process start time and boot time in /procTomas Janousek
Commit 411187fb05cd11676b0979d9fbf3291db69dbce2 caused boot time to move and process start times to become invalid after suspend. Using boot based time for those restores the old behaviour and fixes the issue. [akpm@linux-foundation.org: little cleanup] Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Cc: Tomas Smetana <tsmetana@redhat.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Fix rmmod/read/write races in /proc entriesAlexey Dobriyan
Fix following races: =========================================== 1. Write via ->write_proc sleeps in copy_from_user(). Module disappears meanwhile. Or, more generically, system call done on /proc file, method supplied by module is called, module dissapeares meanwhile. pde = create_proc_entry() if (!pde) return -ENOMEM; pde->write_proc = ... open write copy_from_user pde = create_proc_entry(); if (!pde) { remove_proc_entry(); return -ENOMEM; /* module unloaded */ } *boom* ========================================== 2. bogo-revoke aka proc_kill_inodes() remove_proc_entry vfs_read proc_kill_inodes [check ->f_op validness] [check ->f_op->read validness] [verify_area, security permissions checks] ->f_op = NULL; if (file->f_op->read) /* ->f_op dereference, boom */ NOTE, NOTE, NOTE: file_operations are proxied for regular files only. Let's see how this scheme behaves, then extend if needed for directories. Directories creators in /proc only set ->owner for them, so proxying for directories may be unneeded. NOTE, NOTE, NOTE: methods being proxied are ->llseek, ->read, ->write, ->poll, ->unlocked_ioctl, ->ioctl, ->compat_ioctl, ->open, ->release. If your in-tree module uses something else, yell on me. Full audit pending. [akpm@linux-foundation.org: build fix] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16invalidate_mapping_pages(): add cond_reschedAndrew Morton
invalidate_mapping_pages() can sometimes take a long time (millions of pages to free). Long enough for the softlockup detector to trigger. We used to have a cond_resched() in there but I took it out because the drop_caches code calls invalidate_mapping_pages() under inode_lock. The patch adds a nasty flag and puts the cond_resched() back. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16jbd2 commit: fix transaction droppingJan Kara
We have to check that also the second checkpoint list is non-empty before dropping the transaction. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
