git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
Resolved conflicts:
fs/xfs/xfs_trans_priv.h:
- deleted struct xfs_ail field xa_flags
- kept field xa_log_flush in struct xfs_ail
fs/xfs/xfs_trans_ail.c:
- in xfsaild_push(), in XFS_ITEM_PUSHBUF case, replaced
"flush_log = 1" with "ailp->xa_log_flush++"
Signed-off-by: Alex Elder <aelder@sgi.com>
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: revert to using a kthread for AIL pushing
xfs: force the log if we encounter pinned buffers in .iop_pushbuf
xfs: do not update xa_last_pushed_lsn for locked items
* 'btrfs-3.0' of git://github.com/chrismason/linux:
Btrfs: make sure not to defrag extents past i_size
Btrfs: fix recursive auto-defrag
When we call xfs_flush_buftarg (generally from sync or umount) it already
is too late to flush the data workqueues, as I/O completion is signalled
for them and we are thus already done with the data we would flush here.
There are places where flushing them might be useful, but the current
sync interface doesn't give us that opportunity.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
The calling convention that returns a pointer to a static buffer is
fairly nasty, so just opencode it in the only caller that is left.
Use xfs_ioerror_alert instead of opencoding a very similar error
message.
Instead of passing the block number and mount structure explicitly
get them off the bp and fix make the argument order more natural.
Also move it to xfs_buf.c and stop printing the device name given
that we already get the fs name as part of xfs_alert, and we know
what device is operates on because of the caller that gets printed,
finally rename it to xfs_buf_ioerror_alert and pass __func__ as
argument where it makes sense.
Change _xfs_buf_initialize to allocate the buffer directly and rename it to
xfs_buf_alloc now that is the only buffer allocation routine. Also remove
the xfs_buf_deallocate wrapper around the kmem_zone_free calls for buffers.
For each call to xfs_buf_stale we call xfs_buf_delwri_dequeue either
directly before or after it, or are guaranteed by the surrounding
conditionals that we are never called on delwri buffers. Simply
this situation by moving the call to xfs_buf_delwri_dequeue into
xfs_buf_stale.
The code is unused and under a config option that doesn't exist, remove it.
The code to flush buffers in the umount code is a bit iffy: we first
flush all delwri buffers out, but then might be able to queue up a
new one when logging the sb counts. On a normal shutdown that one
would get flushed out when doing the synchronous superblock write in
xfs_unmountfs_writesb, but we skip that one if the filesystem has
been shut down.
Fix this by moving the delwri list flushing until just before unmounting
the log, and while we're at it also remove the superflous delwri list
and buffer lru flusing for the rt and log device that can never have
cached or delwri buffers.
Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Tested-by: Amit Sahrawat <amit.sahrawat83@gmail.com>
Directories are only updated transactionally, which means fsync only
needs to flush the log the inode is currently dirty, but not bother
with checking for dirty data, non-transactional updates, and most
importanly doesn't have to flush disk caches except as part of a
transaction commit.
While the first two optimizations can't easily be measured, the
latter actually makes a difference when doing lots of fsync that do
not actually have to commit the inode, e.g. because an earlier fsync
already pushed the log far enough.
The new xfs_dir_fsync is identical to xfs_nfs_commit_metadata except
for the prototype, but I'm not sure creating a common helper for the
two is worth it given how simple the functions are.
The AIL push code will issue a log force on ever single push loop
that it exits and has encountered pinned items. It doesn't rescan
these pinned items until it revisits the AIL from the start. Hence
we only need to force the log once per walk from the start of the
AIL to the target LSN.
This results in numbers like this:
xs_push_ail_flush..... 1456
xs_log_force......... 1485
For an 8-way 50M inode create workload - almost all the log forces
are coming from the AIL pushing code.
Reduce the number of log forces by only forcing the log if the
previous walk found pinned buffers. This reduces the numbers to:
xs_push_ail_flush..... 665
xs_log_force......... 682
For the same test.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Stats show that for an 8-way unlink @ ~80,000 unlinks/s we are doing
~1 million cache hit lookups to ~3000 buffer creates. That's almost
3 orders of magnitude more cahce hits than misses, so optimising for
cache hits is quite important. In the cache hit case, we do not need
to allocate a new buffer in case of a cache miss, so we are
effectively hitting the allocator for no good reason for vast the
majority of calls to _xfs_buf_find. 8-way create workloads are
showing similar cache hit/miss ratios.
The result is profiles that look like this:
samples pcnt function DSO
_______ _____ _______________________________ _________________
1036.00 10.0% _xfs_buf_find [kernel.kallsyms]
582.00 5.6% kmem_cache_alloc [kernel.kallsyms]
519.00 5.0% __memcpy [kernel.kallsyms]
468.00 4.5% __ticket_spin_lock [kernel.kallsyms]
388.00 3.7% kmem_cache_free [kernel.kallsyms]
331.00 3.2% xfs_log_commit_cil [kernel.kallsyms]
Further, there is a fair bit of work involved in initialising a new
buffer once a cache miss has occurred and we currently do that under
the rbtree spinlock. That increases spinlock hold time on what are
heavily used trees.
To fix this, remove the initialisation of the buffer from
_xfs_buf_find() and only allocate the new buffer once we've had a
cache miss. Initialise the buffer immediately after allocating it in
xfs_buf_get, too, so that is it ready for insert if we get another
cache miss after allocation. This minimises lock hold time and
avoids unnecessary allocator churn. The resulting profiles look
like:
_______ _____ ___________________________ _________________
8111.00 9.1% _xfs_buf_find [kernel.kallsyms]
4380.00 4.9% __memcpy [kernel.kallsyms]
4341.00 4.8% __ticket_spin_lock [kernel.kallsyms]
3401.00 3.8% kmem_cache_alloc [kernel.kallsyms]
2856.00 3.2% xfs_log_commit_cil [kernel.kallsyms]
2625.00 2.9% __kmalloc [kernel.kallsyms]
2380.00 2.7% kfree [kernel.kallsyms]
2016.00 2.3% kmem_cache_free [kernel.kallsyms]
Showing a significant reduction in time spent doing allocation and
freeing from slabs (kmem_cache_alloc and kmem_cache_free).
There is no reason to keep a reference to the inode even if we unlock
it during transaction commit because we never drop a reference between
the ijoin and commit. Also use this fact to merge xfs_trans_ijoin_ref
back into xfs_trans_ijoin - the third argument decides if an unlock
is needed now.
I'm actually starting to wonder if allowing inodes to be unlocked
at transaction commit really is worth the effort. The only real
benefit is that they can be unlocked earlier when commiting a
synchronous transactions, but that could be solved by doing the
log force manually after the unlock, too.
Let the transaction commit unlock the inode before it potentially causes
a synchronous log force.
Only read the LSN we need to push to with the ilock held, and then release
it before we do the log force to improve concurrency.
This also removes the only direct caller of _xfs_trans_commit, thus
allowing it to be merged into the plain xfs_trans_commit again.
XFS_TRANS_SWAPEXT is a transaction type, not a flag for xfs_trans_commit, so
don't pass it in xfs_swap_extents.
In xfs_ioc_trim it is possible that computing the last allocation group
to discard might overflow for big start & len values, because the result
might be bigger then xfs_agnumber_t which is 32 bit long. Fix this by not
allowing the start and end block of the range to be beyond the end of the
file system.
Note that if the start is beyond the end of the file system we have to
return -EINVAL, but in the "end" case we have to truncate it to the fs
size.
Also introduce "end" variable, rather than using start+len which which
might be more confusing to get right as this bug shows.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Convert all function prototypes to the short form used elsewhere,
and remove duplicates of comments already placed at the function
body.
Fix a case in xfs_bmap_add_extent_unwritten_real where we aren't
passing the returned error on.
All the parameters passed to xfs_bmap_add_extent_hole_real() are in
the xfs_bmalloca structure now. Just pass the bmalloca parameter to
the function instead of 8 separate parameters.
All the parameters passed to xfs_bmap_add_extent_delay_real() are in
Rather than passing the firstblock and freelist structure around,
embed it into the bmalloca structure and remove it from the function
parameters.
This also enables the minleft parameter to be set only once in
xfs_bmapi_write(), and the freelist cursor directly queried in
xfs_bmapi_allocate to clear it when the lowspace algorithm is
activated.
Rather that putting extent records on the stack and then pointing to
them in the bmalloca structure which is in the same stack frame, put
the extent records directly in the bmalloca structure. This reduces
the number of args that need to be passed around.
All the variables xfs_bmap_isaeof() is passed are contained within
the xfs_bmalloca structure. Pass that instead.
There is no real need to the xfs_bmap_add_extent, as the callers
know what kind of extents they need to it. Removing it means
duplicating the extents to btree conversion logic in three places,
but overall it's still much simpler code and quite a bit less code.
Add a common helper for finding the last extent in a file.
Largely based on a patch from Dave Chinner.
Now that all the read-only users of xfs_bmapi have been converted to
use xfs_bmapi_read(), we can remove all the read-only handling cases
from xfs_bmapi().
Once this is done, rename xfs_bmapi to xfs_bmapi_write to reflect
the fact it is for allocation only. This enables us to kill the
XFS_BMAPI_WRITE flag as well.
Also clean up xfs_bmapi_write to the style used in the newly added
xfs_bmapi_read/delay functions.
To further improve the readability of xfs_bmapi(), factor the
unwritten extent conversion out into a separate function. This
removes large block of logic from the xfs_bmapi() code loop and
makes it easier to see the operational logic flow for xfs_bmapi().
To further improve the readability of xfs_bmapi(), factor the extent
allocation out into a separate function. This removes a large block
of logic from the xfs_bmapi() code loop and makes it easier to see
We can just call xfs_bmap_add_extent_hole_delay directly to add a
delayed allocated regions to the extent tree, instead of going
through all the complexities of xfs_bmap_add_extent that aren't
needed for this simple case.
Delalloc reservations are much simpler than allocations, so give
them a separate bmapi-level interface. Using the previously added
xfs_bmapi_reserve_delalloc we get a function that is only minimally
more complicated than xfs_bmapi_read, which is far from the complexity
in xfs_bmapi. Also remove the XFS_BMAPI_DELAY code after switching
over the only user to xfs_bmapi_delay.
Move the reservation of delayed allocations, and addition of delalloc
regions to the extent trees into a new helper function. For now
this adds some twisted goto logic to xfs_bmapi, but that will be
cleaned up in the following patches.
Now we have xfs_bmapi_read, there is no need for xfs_bmapi_single().
Change the remaining caller over and kill the function.
xfs_bmapi() currently handles both extent map reading and
allocation. As a result, the code is littered with "if (wr)"
branches to conditionally do allocation operations if required.
This makes the code much harder to follow and causes significant
indent issues with the code.
Given that read mapping is much simpler than allocation, we can
split out read mapping from xfs_bmapi() and reuse the logic that
we have already factored out do do all the hard work of handling the
extent map manipulations. The results in a much simpler function for
the common extent read operations, and will allow the allocation
code to be simplified in another commit.
Once xfs_bmapi_read() is implemented, convert all the callers of
xfs_bmapi() that are only reading extents to use the new function.
To further improve the readability of xfs_bmapi(), factor the pure
extent map manipulations out into separate functions. This removes
large blocks of logic from the xfs_bmapi() code loop and makes it
Instead of using a local variable that needs to updated when we modify
the extent map just check ifp->if_bytes directly where we use it.
We already have the worst case blocks reserved, so xfs_icsb_modify_counters
won't fail in xfs_bmap_add_extent_delay_real. In fact we've had an assert
to catch this case since day and it never triggered. So remove the code
to try smaller reservations, and just return the error for that case in
addition to keeping the assert.
Both xfs_bmap_add_extent_hole_delay and xfs_bmap_add_extent_hole_real
already contain code to handle the case where there is no extent to
merge with, which is effectively the same as the code duplicated here.
