path: root/fs
2008-10-28misc: replace NIP6_FMT with %p6 format specifierHarvey Harrison
The iscsi_ibft.c changes are almost certainly a bugfix as the pointer 'ip' is a u8 *, so they never print the last 8 bytes of the IPv6 address, and the eight bytes they do print have a zero byte with them in each 16-bit word. Other than that, this should cause no difference in functionality. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace all current users of NIP6_SEQFMT with %#p6Harvey Harrison
The define in kernel.h can be done away with at a later time. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27Switch to a valid email address...Alan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26epoll: avoid double-inserts in case of EFAULTDavide Libenzi
In commit f337b9c58332bdecde965b436e47ea4c94d30da0 ("epoll: drop unnecessary test") Thomas found that there is an unnecessary (always true) test in ep_send_events(). The callback never inserts into ->rdllink while the send loop is performed, and also does the ~EP_PRIVATE_BITS test. Given we're holding the mutex during this time, the conditions tested inside the loop are always true. HOWEVER. The test "!ep_is_linked(&epi->rdllink)" wasn't there because we insert into ->rdllink, but because the send-events loop might terminate before the whole list is scanned (-EFAULT). In such cases, when the loop terminates early, and when a (leftover) file received an event while we're performing the lockless loop, we need such test to avoid to double insert the epoll items. The list_splice() done a few steps below, will correctly re-insert the ones that were left on "txlist". This should fix the kenrel.org bugzilla entry 11831. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26select: deal with math overflow from borderline valid userland dataArjan van de Ven
Some userland apps seem to pass in a "0" for the seconds, and several seconds worth of usecs to select(). The old kernels accepted this just fine, so the new kernels must too. However, due to the upscaling of the microseconds to nanoseconds we had some cases where we got math overflow, and depending on the GCC version (due to inlining decisions) that actually resulted in an -EINVAL return. This patch fixes this by adding the excess microseconds to the seconds field. Also with thanks to Marcin Slusarz for spotting some implementation bugs in the diagnostics patches. Reported-by: Carlos R. Mafra <crmafra2@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-25ext4: Fix duplicate entries returned from getdents() system callTheodore Ts'o
Fix a regression caused by commit d0156417, "ext4: fix ext4_dx_readdir hash collision handling", where deleting files in a large directory (requiring more than one getdents system call), results in some filenames being returned twice. This was caused by a failure to update info->curr_hash and info->curr_minor_hash, so that if the directory had gotten modified since the last getdents() system call (as would be the case if the user is running "rm -r" or "git clean"), a directory entry would get returned twice to the userspace. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> This patch fixes the bug reported by Markus Trippelsdorf at: http://bugzilla.kernel.org/show_bug.cgi?id=11844 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
2008-10-25ext3: Fix duplicate entries returned from getdents() system callTheodore Ts'o
Fix a regression caused by commit 6a897cf4, "ext3: fix ext3_dx_readdir hash collision handling", where deleting files in a large directory (requiring more than one getdents system call), results in some filenames being returned twice. This was caused by a failure to update info->curr_hash and info->curr_minor_hash, so that if the directory had gotten modified since the last getdents() system call (as would be the case if the user is running "rm -r" or "git clean"), a directory entry would get returned twice to the userspace. This patch fixes the bug reported by Markus Trippelsdorf at: http://bugzilla.kernel.org/show_bug.cgi?id=11844 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
2008-10-23Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: (35 commits) proc: remove fs/proc/proc_misc.c proc: move /proc/vmcore creation to fs/proc/vmcore.c proc: move pagecount stuff to fs/proc/page.c proc: move all /proc/kcore stuff to fs/proc/kcore.c proc: move /proc/schedstat boilerplate to kernel/sched_stats.h proc: move /proc/modules boilerplate to kernel/module.c proc: move /proc/diskstats boilerplate to block/genhd.c proc: move /proc/zoneinfo boilerplate to mm/vmstat.c proc: move /proc/vmstat boilerplate to mm/vmstat.c proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.c proc: move /proc/buddyinfo boilerplate to mm/vmstat.c proc: move /proc/vmallocinfo to mm/vmalloc.c proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.c proc: move /proc/slab_allocators boilerplate to mm/slab.c proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.c proc: move /proc/stat to fs/proc/stat.c proc: move rest of /proc/partitions code to block/genhd.c proc: move /proc/cpuinfo code to fs/proc/cpuinfo.c proc: move /proc/devices code to fs/proc/devices.c proc: move rest of /proc/locks to fs/locks.c ...
2008-10-23ext4: remove unused variable in ext4_get_parentChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> [ All users removed in "switch all filesystems over to d_obtain_alias", aka commit 440037287c5ebb07033ab927ca16bb68c291d309 ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23ext3 quota support: fix compile failureLinus Torvalds
This one was due to a merge error: we added a use of nd.path in commit 2d7c820e56ce83b23daee9eb5343730fb309418e ("ext3: add checks for errors from jbd"), and concurrently we got rid of 'nd' and used a naked 'path' in commit 8264613def2e5c4f12bc3167713090fd172e6055 ("[PATCH] switch quota_on-related stuff to kern_path()"). That all merged cleanly, but it didn't actually _work_. This should fix it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23Merge branch 'v28-range-hrtimers-for-linus-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'v28-range-hrtimers-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits) hrtimers: add missing docbook comments to struct hrtimer hrtimers: simplify hrtimer_peek_ahead_timers() hrtimers: fix docbook comments DECLARE_PER_CPU needs linux/percpu.h hrtimers: fix typo rangetimers: fix the bug reported by Ingo for real rangetimer: fix BUG_ON reported by Ingo rangetimer: fix x86 build failure for the !HRTIMERS case select: fix alpha OSF wrapper select: fix alpha OSF wrapper hrtimer: peek at the timer queue just before going idle hrtimer: make the futex() system call use the per process slack value hrtimer: make the nanosleep() syscall use the per process slack hrtimer: fix signed/unsigned bug in slack estimator hrtimer: show the timer ranges in /proc/timer_list hrtimer: incorporate feedback from Peter Zijlstra hrtimer: add a hrtimer_start_range() function hrtimer: another build fix hrtimer: fix build bug found by Ingo hrtimer: make select() and poll() use the hrtimer range feature ...
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: handle the TCP_Server_Info->tsk field more carefully cifs: fix unlinking of rename target when server doesn't support open file renames [CIFS] improve setlease handling [CIFS] fix saving of resume key before CIFSFindNext cifs: make cifs_rename handle -EACCES errors [CIFS] fix build error [CIFS] undo changes in cifs_rename_pending_delete if it errors out cifs: track DeletePending flag in cifsInodeInfo cifs: don't use CREATE_DELETE_ON_CLOSE in cifs_rename_pending_delete [CIFS] eliminate usage of kthread_stop for cifsd [CIFS] Add nodfs mount option
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
2008-10-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (46 commits) [PATCH] fs: add a sanity check in d_free [PATCH] i_version: remount support [patch] vfs: make security_inode_setattr() calling consistent [patch 1/3] FS_MBCACHE: don't needlessly make it built-in [PATCH] move executable checking into ->permission() [PATCH] fs/dcache.c: update comment of d_validate() [RFC PATCH] touch_mnt_namespace when the mount flags change [PATCH] reiserfs: add missing llseek method [PATCH] fix ->llseek for more directories [PATCH vfs-2.6 6/6] vfs: add LOOKUP_RENAME_TARGET intent [PATCH vfs-2.6 5/6] vfs: remove LOOKUP_PARENT from non LOOKUP_PARENT lookup [PATCH vfs-2.6 4/6] vfs: remove unnecessary fsnotify_d_instantiate() [PATCH vfs-2.6 3/6] vfs: add __d_instantiate() helper [PATCH vfs-2.6 2/6] vfs: add d_ancestor() [PATCH vfs-2.6 1/6] vfs: replace parent == dentry->d_parent by IS_ROOT() [PATCH] get rid of on-stack dentry in udf [PATCH 2/2] anondev: switch to IDA [PATCH 1/2] anondev: init IDR statically [JFFS2] Use d_splice_alias() not d_add() in jffs2_lookup() [PATCH] Optimise NFS readdir hack slightly. ...
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix sparse warnings 9p: rdma: RDMA Transport Support for 9P 9p: fix format warning 9p: fix debug build error
2008-10-23Merge branch 'for-2.6.28' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux: nfsd: clean up expkey_parse error cases nfsd: Drop reference in expkey_parse error cases nfsd: Fix memory leak in nfsd_getxattr NFSD: Fix BUG during NFSD shutdown processing
2008-10-23jbd: abort instead of waiting for nonexistent transactionsDuane Griffin
The __log_wait_for_space function sits in a loop checkpointing transactions until there is sufficient space free in the journal. However, if there are no transactions to be processed (e.g. because the free space calculation is wrong due to a corrupted filesystem) it will never progress. Check for space being required when no transactions are outstanding and abort the journal instead of endlessly looping. This patch fixes the bug reported by Sami Liedes at: http://bugzilla.kernel.org/show_bug.cgi?id=10976 Signed-off-by: Duane Griffin <duaneg@dghda.com> Tested-by: Sami Liedes <sliedes@cc.hut.fi> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: test BH_Write_EIO to detect errors on metadata buffersHidehiro Kawai
__try_to_free_cp_buf(), __process_buffer(), and __wait_cp_io() test BH_Uptodate flag to detect write I/O errors on metadata buffers. But by commit 95450f5a7e53d5752ce1a0d0b8282e10fe745ae0 "ext3: don't read inode block if the buffer has a write error"(*), BH_Uptodate flag can be set to inode buffers with BH_Write_EIO in order to avoid reading old inode data. So now, we have to test BH_Write_EIO flag of checkpointing inode buffers instead of BH_Uptodate. This patch does it. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23ext3: add checks for errors from jbdHidehiro Kawai
If the journal has aborted due to a checkpointing failure, we have to keep the contents of the journal space. Otherwise, the filesystem will lose uncheckpointed metadata completely and become inconsistent. To avoid this, we need to keep needs_recovery flag if checkpoint has failed. With this patch, ext3_put_super() detects a checkpointing failure from the return value of journal_destroy(), then it invokes ext3_abort() to make the filesystem read only and keep needs_recovery flag. Errors from journal_flush() are also handled by this patch in some places. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: fix error handling for checkpoint ioHidehiro Kawai
When a checkpointing IO fails, current JBD code doesn't check the error and continue journaling. This means latest metadata can be lost from both the journal and filesystem. This patch leaves the failed metadata blocks in the journal space and aborts journaling in the case of log_do_checkpoint(). To achieve this, we need to do: 1. don't remove the failed buffer from the checkpoint list where in the case of __try_to_free_cp_buf() because it may be released or overwritten by a later transaction 2. log_do_checkpoint() is the last chance, remove the failed buffer from the checkpoint list and abort the journal 3. when checkpointing fails, don't update the journal super block to prevent the journaled contents from being cleaned. For safety, don't update j_tail and j_tail_sequence either 4. when checkpointing fails, notify this error to the ext3 layer so that ext3 don't clear the needs_recovery flag, otherwise the journaled contents are ignored and cleaned in the recovery phase 5. if the recovery fails, keep the needs_recovery flag 6. prevent cleanup_journal_tail() from being called between __journal_drop_transaction() and journal_abort() (a race issue between journal_flush() and __log_wait_for_space() Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23proc: remove fs/proc/proc_misc.cAlexey Dobriyan
Now that everything was moved to their more or less expected places, apply rm(1). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: move /proc/vmcore creation to fs/proc/vmcore.cAlexey Dobriyan
2008-10-23proc: move pagecount stuff to fs/proc/page.cAlexey Dobriyan
2008-10-23proc: move all /proc/kcore stuff to fs/proc/kcore.cAlexey Dobriyan
2008-10-23proc: move /proc/schedstat boilerplate to kernel/sched_stats.hAlexey Dobriyan
2008-10-23proc: move /proc/modules boilerplate to kernel/module.cAlexey Dobriyan
2008-10-23proc: move /proc/diskstats boilerplate to block/genhd.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23proc: move /proc/zoneinfo boilerplate to mm/vmstat.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org>
2008-10-23proc: move /proc/vmstat boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/buddyinfo boilerplate to mm/vmstat.cAlexey Dobriyan
2008-10-23proc: move /proc/vmallocinfo to mm/vmalloc.cAlexey Dobriyan
2008-10-23proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.cAlexey Dobriyan
Lose dummy ->write hook in case of SLUB, it's possible now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-23proc: move /proc/slab_allocators boilerplate to mm/slab.cAlexey Dobriyan
2008-10-23proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.cAlexey Dobriyan
2008-10-23proc: move /proc/stat to fs/proc/stat.cAlexey Dobriyan
2008-10-23proc: move rest of /proc/partitions code to block/genhd.cAlexey Dobriyan
2008-10-23proc: move /proc/cpuinfo code to fs/proc/cpuinfo.cAlexey Dobriyan
2008-10-23proc: move /proc/devices code to fs/proc/devices.cAlexey Dobriyan
2008-10-23proc: move rest of /proc/locks to fs/locks.cAlexey Dobriyan
2008-10-23proc: move /proc/kmsg creation to fs/proc/kmsg.cAlexey Dobriyan
2008-10-23proc: remove remnants of ->read_proc in proc_misc.cAlexey Dobriyan
2008-10-23proc: move /proc/execdomains to kernel/exec_domain.cAlexey Dobriyan
2008-10-23proc: switch /proc/cmdline to seq_fileAlexey Dobriyan
and move it to fs/proc/cmdline.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: move /proc/filesystems to fs/filesystems.cAlexey Dobriyan
2008-10-23proc: move /proc/stram to m68k-specific codeAlexey Dobriyan
2008-10-23proc: move /proc/hardware to m68k-specific codeAlexey Dobriyan
2008-10-23proc: switch /proc/version to seq_fileAlexey Dobriyan
and move it to fs/proc/version.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: switch /proc/meminfo to seq_fileAlexey Dobriyan
and move it to fs/proc/meminfo.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-23proc: switch /proc/uptime to seq_fileAlexey Dobriyan
and move it to fs/proc/uptime.c while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
