Now that the headers are fixed and carry their own wait, all fs/nfsd/
source files can include a minimal set of headers. and still compile just
fine.
This patch should improve the compilation speed of the nfsd module.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
NFSv4 opens may function as locks denying other NFSv4 users the rights
to open a file.
We're requiring a user to have write permissions before they can deny
write. We're *not* requiring a user to have write permissions to deny
read, which is if anything a more drastic denial.
What was intended was to require write permissions for DENY_READ.
All nfsd security depends on the security checks in fh_verify, and
especially on nfsd_setuser().
It therefore bothers me that the nfsd_setuser call may be made from
three different places, depending on whether the filehandle has already
been mapped to a dentry, and on whether subtreechecking is in force.
Instead, make an unconditional call in fh_verify(), so it's trivial to
verify that the call always occurs.
That leaves us with a redundant nfsd_setuser() call in the subtreecheck
case--it needs the correct user set earlier in order to check execute
permissions on the path to this filehandle--but I'm willing to accept
that minor inefficiency in the subtreecheck case in return for more
straightforward permission checking.
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
SUNRPC: Address buffer overrun in rpc_uaddr2sockaddr()
NFSv4: Fix a cache validation bug which causes getcwd() to return ENOENT
This is for consistency with various ioctl() operations that include the
suffix "PGRP" in their names, and also for consistency with PRIO_PGRP,
used with setpriority() and getpriority(). Also, using PGRP instead of
GID avoids confusion with the common abbreviation of "group ID".
I'm fine with anything that makes it more consistent, and if PGRP is what
is the predominant abbreviation then I see no need to further confuse
matters by adding a third one.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Fix a small issue for the stack pointer in /proc/<pid>/stat. In case of a
kernel thread the value of the printed stack pointer should be 0.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: copy li_lsn before dropping AIL lock
XFS bug in log recover with quota (bugzilla id 855)
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
cifs: clear server inode number flag while autodisabling
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: deleted inconsistent comment in nilfs_load_inode_block()
nilfs2: deleted struct nilfs_dat_group_desc
nilfs2: fix lock order reversal in chcp operation
Access to log items on the AIL is generally protected by m_ail_lock;
this is particularly needed when we're getting or setting the 64-bit
li_lsn on a 32-bit platform. This patch fixes a couple places where we
were accessing the log item after dropping the AIL lock on 32-bit
machines.
This can result in a partially-zeroed log->l_tail_lsn if
xfs_trans_ail_delete is racing with xfs_trans_ail_update, and in at
least some cases, this can leave the l_tail_lsn with a zero cycle
number, which means xlog_space_left will think the log is full (unless
CONFIG_XFS_DEBUG is set, in which case we'll trip an ASSERT), leading to
processes stuck forever in xlog_grant_log_space.
Thanks to Adrian VanderSpek for first spotting the race potential and to
Dave Chinner for debug assistance.
Signed-off-by: Nathaniel W. Turner <nate@houseofnate.net>
Signed-off-by: Alex Elder <aelder@sgi.com>
I was hit by a bug in linux 2.6.31 when XFS is not able to recover the
log after a crash if fs was mounted with quotas. Gory details in XFS
bugzilla: http://oss.sgi.com/bugzilla/show_bug.cgi?id=855.
It looks like wrong struct is used in buffer length check, and the following
patch should fix the problem.
xfs_dqblk_t has a size of 104+32 bytes, while xfs_disk_dquot_t is 104 bytes
long, and this is exactly what I see in system logs - "XFS: dquot too small
(104) in xlog_recover_do_dquot_trans."
Signed-off-by: Jan Rekorajski <baggins@sith.mimuw.edu.pl>
Fix the commit ec06aedd44 that intended to turn off querying for server inode
numbers when server doesn't consistently support inode numbers. Presumably
the commit didn't actually clear the CIFS_MOUNT_SERVER_INUM flag, perhaps a
typo.
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de>
Acked-by: Jeff Layton <jlayton@redhat.com>
Cc: Stable <stable@kernel.org>
Signed-off-by: Steve French <sfrench@us.ibm.com>
The comment says, "Caller of this function MUST lock s_inode_lock",
however just above the comment, it locks s_inode_lock in the function.
Signed-off-by: Jiro SEKIBA <jir@unicus.jp>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Commit 8177e6d6dfb9cd03d9bdeb647c32161f8f58f686 ("nfsd: clean up
readdirplus encoding") introduced single character typo in nfs3 readdir+
implementation. Unfortunately that typo has quite bad side effects:
random memory corruption, followed (on my box) with immediate
spontaneous box reboot.
Using 'p1' instead of 'p' fixes my Linux box rebooting whenever VMware
ESXi box tries to list contents of my home directory.
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
None of this stuff is used outside nfsd, so move it out of the common
linux include directory.
Actually, probably none of the stuff in include/linux/nfsd/nfsd.h really
belongs there, so later we may remove that file entirely.
Will fix the following lock order reversal lockdep detected:
[ INFO: possible circular locking dependency detected ]
2.6.32-rc6 #7
chcp/30157 is trying to acquire lock:
(&nilfs->ns_mount_mutex){+.+.+.}, at: [<fed7cfcc>] nilfs_cpfile_change_cpmode+0x46/0x752 [nilfs2]
but task is already holding lock:
(&nilfs->ns_segctor_sem){++++.+}, at: [<fed7ca32>] nilfs_transaction_begin+0xba/0x110 [nilfs2]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (&nilfs->ns_segctor_sem){++++.+}:
[<c105799c>] __lock_acquire+0x109c/0x139d
[<c1057d26>] lock_acquire+0x89/0xa0
[<c14151e2>] down_read+0x31/0x45
[<fed6d77b>] nilfs_attach_checkpoint+0x8f/0x16b [nilfs2]
[<fed6e393>] nilfs_get_sb+0x3e7/0x653 [nilfs2]
[<c10c0ccb>] vfs_kern_mount+0x8b/0x124
[<c10c0db2>] do_kern_mount+0x37/0xc3
[<c10d7517>] do_mount+0x64d/0x69d
[<c10d75cd>] sys_mount+0x66/0x95
[<c1002a14>] sysenter_do_call+0x12/0x32
-> #1 (&type->s_umount_key#31/1){+.+.+.}:
[<c104c0f3>] down_write_nested+0x34/0x52
[<c10c08fe>] sget+0x22e/0x389
[<fed6e133>] nilfs_get_sb+0x187/0x653 [nilfs2]
-> #0 (&nilfs->ns_mount_mutex){+.+.+.}:
[<c1057727>] __lock_acquire+0xe27/0x139d
[<c1414d63>] mutex_lock_nested+0x41/0x23e
[<fed801b2>] nilfs_ioctl+0x11a/0x7da [nilfs2]
[<c10cca12>] vfs_ioctl+0x27/0x6e
[<c10ccf93>] do_vfs_ioctl+0x491/0x4db
[<c10cd022>] sys_ioctl+0x45/0x5f
Because of an integer overflow on start_blk, various kind of wrong results
would be returned by the generic_block_fiemap() handler, such as no
extents when there is a 4GB+ hole at the beginning of the file, or wrong
fe_logical when an extent starts after the first 4GB.
Signed-off-by: Mike Hommey <mh@glandium.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Eric Sandeen <sandeen@sgi.com>
Cc: Josef Bacik <jbacik@redhat.com>
Cc: Mark Fasheh <mfasheh@suse.com>
In setup_arg_pages we work hard to assign a value to ret, but on exit we
always return 0.
Also remove a now duplicated exit path and branch to out_unlock instead.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
For FS_IOC_RESVSP and FS_IOC_RESVSP64 compat_sys_ioctl() uses its
arg argument as a pointer to userspace. However it is missing a
a call to compat_ptr() which will do a proper pointer conversion.
This was introduced with 3e63cbb1 "fs: Add new pre-allocation ioctls
to vfs for compatibility with legacy xfs ioctls".
Cc: Ankit Jain <me@ankitjain.org>
Acked-by: Christoph Hellwig <hch@lst.de>
Acked-by: Arnd Bergmann <arndbergmann@googlemail.com>
Cc: <stable@kernel.org> [2.6.31.x]
Daniel Lezcano reported a leak in 'struct pid' and 'struct pid_namespace'
that is discussed in:
http://lkml.org/lkml/2009/10/2/159.
To summarize the thread, when container-init is terminated, it sets the
PF_EXITING flag, zaps other processes in the container and waits to reap
them. As a part of reaping, the container-init should flush any /proc
dentries associated with the processes. But because the container-init is
itself exiting and the following PF_EXITING check, the dentries are not
flushed, resulting in leak in /proc inodes and dentries.
This fix reverts the commit 7766755a2f249e7e0 ("Fix /proc dcache deadlock
in do_exit") which introduced the check for PF_EXITING. At the time of
the commit, shrink_dcache_parent() flushed dentries from other filesystems
also and could have caused a deadlock which the commit fixed. But as
pointed out by Eric Biederman, after commit 0feae5c47aabdde59,
shrink_dcache_parent() no longer affects other filesystems. So reverting
the commit is now safe.
As pointed out by Jan Kara, the leak is not as critical since the
unclaimed space will be reclaimed under memory pressure or by:
echo 3 > /proc/sys/vm/drop_caches
But since this check is no longer required, its best to remove it.
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Reported-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Acked-by: Jan Kara <jack@ucw.cz>
Cc: Andrea Arcangeli <andrea@cpushare.com>
Cc: Serge Hallyn <serue@us.ibm.com>
This fixes:
ERROR: "log_start_commit" [fs/ext3/ext3.ko] undefined!
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: fix panic when trying to destroy a newly allocated
Btrfs: allow more metadata chunk preallocation
Btrfs: fallback on uncompressed io if compressed io fails
Btrfs: find ideal block group for caching
Btrfs: avoid null deref in unpin_extent_cache()
Btrfs: skip btrfs_release_path in btrfs_update_root and btrfs_del_root
Btrfs: fix some metadata enospc issues
Btrfs: fix how we set max_size for free space clusters
Btrfs: cleanup transaction starting and fix journal_info usage
Btrfs: fix data allocation hint start
There is a problem where iget5_locked will look for an inode, not find it, and
then subsequently try to allocate it. Another CPU will have raced in and
allocated the inode instead, so when iget5_locked gets the inode spin lock again
and does a search, it finds the new inode. So it goes ahead and calls
destroy_inode on the inode it just allocated. The problem is we don't set
BTRFS_I(inode)->root until the new inode is completely initialized. This patch
makes us set root to NULL when alloc'ing a new inode, so when we get to
btrfs_destroy_inode and we see that root is NULL we can just free up the memory
and continue on. This fixes the panic
http://www.kerneloops.org/submitresult.php?number=812690
Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
JBD/JBD2: free j_wbuf if journal init fails.
ext3: Wait for proper transaction commit on fsync
ext3: retry failed direct IO allocations
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: partial revert to fix double brelse WARNING()
ext4: Fix return value of ext4_split_unwritten_extents() to fix direct I/O
ext4: code clean up for dio fallocate handling
ext4: skip conversion of uninit extents after direct IO if there isn't any
ext4: fix ext4_ext_direct_IO()'s return value after converting uninit extents
ext4: discard preallocation when restarting a transaction during truncate
On an FS where all of the space has not been allocated into chunks yet,
the enospc can return enospc just because the existing metadata chunks
are full.
We get around this by allowing more metadata chunks to be allocated up
to a certain limit, and finding the right limit is a little fuzzy. The
problem is the reservations for delalloc would preallocate way too much
of the FS as metadata. We need to start saying no and just force some
IO to happen.
But we also need to let a reasonable amount of the FS become metadata.
This bumps the hard limit up, later releases will have a better system.
Currently compressed IO does not deal with not having its entire extent able to
be allocated. So if we have enough free space to allocate for the extent, but
its not contiguous, it will fail spectacularly. This patch fixes this by
falling back on uncompressed IO which lets us spread the delalloc extent across
multiple extents. I tested this by making us randomly think the reservation had
failed to make it fallback on the uncompressed io way and it seemed to work
fine. Thanks,
This patch changes a few things. Hopefully the comments are helpfull, but
I'll try and be as verbose here.
Problem:
My fedora box was taking 1 minute and 21 seconds to boot with btrfs as root.
Part of this problem was we pick the first block group we can find and start
caching it, even if it may not have enough free space. The other problem is
we only search for cached block groups the first time around, which we won't
find any cached block groups because this is a newly mounted fs, so we end up
caching several block groups during bootup, which with alot of fragmentation
takes around 30-45 seconds to complete, which bogs down the system. So
Solution:
1) Don't cache block groups willy-nilly at first. Instead try and figure out
which block group has the most free, and therefore will take the least amount
of time to cache.
2) Don't be so picky about cached block groups. The other problem is once
we've filled up a cluster, if the block group isn't finished caching the next
time we try and do the allocation we'll completely ignore the cluster and
start searching from the beginning of the space, which makes us cache more
block groups, which slows us down even more. So instead of skipping block
groups that are not finished caching when we have a hint, only skip the block
group if it hasn't started caching yet.
There is one other tweak in here. Before if we allocated a chunk and still
couldn't find new space, we'd end up switching the space info to force another
chunk allocation. This could make us end up with way too many chunks, so keep
track of this particular case.
With this patch and my previous cluster fixes my fedora box now boots in 43
seconds, and according to the bootchart is not held up by our block group
caching at all.
I re-orderred the checks to avoid dereferencing "em" if it was null.
Found by smatch static checker.
We don't need to call btrfs_release_path because btrfs_free_path will do
that for us.
Signed-off-by: Li Dongyang <Jerry87905@gmail.com>
We weren't reserving metadata space for rename, rmdir and unlink, which could
cause problems.
This patch fixes a problem where max_size can be set to 0 even though we
filled the cluster properly. We set max_size to 0 if we restart the cluster
window, but if the new start entry is big enough to be our new cluster then we
could return with a max_size set to 0, which will mean the next time we try to
allocate from this cluster it will fail. So set max_extent to the entry's
size. Tested this on my box and now we actually allocate from the cluster
after we fill it. Thanks,
We use journal_info to tell if we're in a nested transaction to make sure we
don't commit the transaction within a nested transaction. We use another
method to see if there are any outstanding ioctl trans handles, so if we're
starting one do not set current->journal_info, since it will screw with other
filesystems. This patch also cleans up the starting stuff so there aren't any
magic numbers.
Sometimes our start allocation hint when we cow a file can be either
EXTENT_HOLE or some other such place holder, which is not optimal. So if we
find that our em->block_start is one of these special values, check to see
where the first block of the inode is stored, and use that as a hint. If that
block is also a special value, just fallback on a hint of 0 and let the
allocator figure out a good place to put the data.
If journal init fails, we need to free j_wbuf.
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Tao Ma <tao.ma@oracle.com>
We cannot rely on buffer dirty bits during fsync because pdflush can come
before fsync is called and clear dirty bits without forcing a transaction
commit. What we do is that we track which transaction has last changed
the inode and which transaction last changed allocation and force it to
disk on fsync.
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
On a 256M 4k block filesystem, doing this in a loop:
dd if=/dev/zero of=test oflag=direct bs=1M count=64
rm -f test
eventually leads to spurious ENOSPC:
dd: writing `test': No space left on device
As with other block allocation callers, it looks like we need to
potentially retry the allocations on the initial ENOSPC.
A similar patch went into ext4 (commit
fbbf69456619de5d251cb9f1df609069178c62d5)
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Changeset a65318bf3afc93ce49227e849d213799b072c5fd (NFSv4: Simplify some
cache consistency post-op GETATTRs) incorrectly changed the getattr
bitmap for readdir().
This causes the readdir() function to fail to return a
fileid/inode number, which again exposed a bug in the NFS readdir code that
causes spurious ENOENT errors to appear in applications (see
http://bugzilla.kernel.org/show_bug.cgi?id=14541).
The immediate band aid is to revert the incorrect bitmap change, but more
long term, we should change the NFS readdir code to cope with the
fact that NFSv4 servers are not required to support fileids/inode numbers.
Reported-by: Daniel J Blueman <daniel.blueman@gmail.com>
Cc: stable@kernel.org
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
nilfs2: fix missing cleanup of gc cache on error cases
nilfs2: fix kernel oops in error case of nilfs_ioctl_move_blocks
This is a partial revert of commit 6487a9d (only the changes made to
fs/ext4/namei.c), since it is causing the following brelse()
double-free warning when running fsstress on a file system with 1k
blocksize and we run into a block allocation failure while converting
a single-block directory to a multi-block hash-tree indexed directory.
WARNING: at fs/buffer.c:1197 __brelse+0x2e/0x33()
Hardware name:
VFS: brelse: Trying to free free buffer
Modules linked in:
Pid: 2226, comm: jbd2/sdd-8 Not tainted 2.6.32-rc6-00577-g0003f55 #101
Call Trace:
[<c01587fb>] warn_slowpath_common+0x65/0x95
[<c0158869>] warn_slowpath_fmt+0x29/0x2c
[<c021168e>] __brelse+0x2e/0x33
[<c0288a9f>] jbd2_journal_refile_buffer+0x67/0x6c
[<c028a9ed>] jbd2_journal_commit_transaction+0x319/0x14d8
[<c0164d73>] ? try_to_del_timer_sync+0x58/0x60
[<c0175bcc>] ? sched_clock_cpu+0x12a/0x13e
[<c017f6b4>] ? trace_hardirqs_off+0xb/0xd
[<c0175c1f>] ? cpu_clock+0x3f/0x5b
[<c017f6ec>] ? lock_release_holdtime+0x36/0x137
[<c0664ad0>] ? _spin_unlock_irqrestore+0x44/0x51
[<c0180af3>] ? trace_hardirqs_on_caller+0x103/0x124
[<c0180b1f>] ? trace_hardirqs_on+0xb/0xd
[<c0290d1c>] kjournald2+0x11a/0x310
[<c017118e>] ? autoremove_wake_function+0x0/0x38
[<c0290c02>] ? kjournald2+0x0/0x310
[<c0170ee6>] kthread+0x66/0x6b
[<c0170e80>] ? kthread+0x0/0x6b
[<c01251b3>] kernel_thread_helper+0x7/0x10
---[ end trace 5579351b86af61e3 ]---
Commit 6487a9d was an attempt some buffer head leaks in an ENOSPC
error path, but in some cases it actually results in an excess ENOSPC,
as shown above. Fixing this means cleaning up who is responsible for
releasing the buffer heads from the callee to the caller of
add_dirent_to_buf().
Since that's a relatively complex change, and we're late in the rcX
development cycle, I'm reverting this now, and holding back a more
complete fix until after 2.6.32 ships. We've lived with this
buffer_head leak on ENOSPC in ext3 and ext4 for a very long time; a
few more months won't kill us.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: Curt Wohlgemuth <curtw@google.com>
This fixes an -rc1 regression brought by the commit:
1cf58fa840472ec7df6bf2312885949ebb308853 ("nilfs2: shorten freeze
period due to GC in write operation v3").
Although the patch moved out a function call of
nilfs_ioctl_move_blocks() to nilfs_ioctl_clean_segments() from
nilfs_ioctl_prepare_clean_segments(), it didn't move corresponding
cleanup job needed for the error case.
This will move the missing cleanup job to the destination function.
Acked-by: Jiro SEKIBA <jir@unicus.jp>
This fixes a kernel oops reported by Markus Trippelsdorf in the email
titled "[NILFS users] kernel Oops while running nilfs_cleanerd".
The oops was caused by a bug of error path in
nilfs_ioctl_move_blocks() function, which was inlined in
nilfs_ioctl_clean_segments().
nilfs_ioctl_move_blocks checks duplication of blocks which will be
moved in garbage collection. But, the check should have be done
within nilfs_ioctl_move_inode_block() to prevent list corruption among
buffers storing the target blocks.
To fix the kernel oops, this moves forward the duplication check
before the list insertion.
I also tested this for stable trees [2.6.30, 2.6.31].
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: stable <stable@kernel.org>
Because it's lighter weight, CIFS tries to use CIFSGetSrvInodeNumber to
verify the accessibility of the root inode and then falls back to doing a
full QPathInfo if that fails with -EOPNOTSUPP. I have at least a report
of a server that returns NT_STATUS_INTERNAL_ERROR rather than something
that translates to EOPNOTSUPP.
Rather than trying to be clever with that call, just have
is_path_accessible do a normal QPathInfo. That call is widely
supported and it shouldn't increase the overhead significantly.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
It's possible that a server will return a valid FileID when we query the
FILE_INTERNAL_INFO for the root inode, but then zeroed out inode numbers
when we do a FindFile with an infolevel of
SMB_FIND_FILE_ID_FULL_DIR_INFO.
In this situation turn off querying for server inode numbers, generate a
warning for the user and just generate an inode number using iunique.
Once we generate any inode number with iunique we can no longer use any
server inode numbers or we risk collisions, so ensure that we don't do
that in cifs_get_inode_info either.
Reported-by: Timothy Normand Miller <theosib@gmail.com>
To prepare for a direct I/O write, we need to split the unwritten
extents before submitting the I/O. When no extents needed to be
split, ext4_split_unwritten_extents() was incorrectly returning 0
instead of the size of uninitialized extents. This bug caused the
wrong return value sent back to VFS code when it gets called from
async IO path, leading to an unnecessary fall back to buffered IO.
This bug also hid the fact that the check to see whether or not a
split would be necessary was incorrect; we can only skip splitting the
extent if the write completely covers the uninitialized extent.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: invalidate target of rename
fuse: fix kunmap in fuse_ioctl_copy_user
fuse: prevent fuse_put_request on invalid pointer
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/kvm: Remove problematic BUILD_BUG_ON statement
powerpc/pci: Fix regression in powerpc MSI-X
powerpc: Avoid giving out RTC dates below EPOCH
powerpc/mm: Remove debug context clamping from nohash code
powerpc: Cleanup Kconfig selection of hugetlbfs support
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
sysfs: Don't leak secdata when a sysfs_dirent is freed.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, fs: Fix x86 procfs stack information for threads on 64-bit
x86: Add reboot quirk for 3 series Mac mini
x86: Fix printk message typo in mtrr cleanup code
dma-debug: Fix compile warning with PAE enabled
x86/amd-iommu: Un__init function required on shutdown
x86/amd-iommu: Workaround for erratum 63
