path: root/fs
2006-03-23[PATCH] sem2mutex: NCPFSIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] convert ext3's truncate_sem to a mutexArjan van de Ven
ext3's truncate_sem is always released in the same function it's taken and it otherwise is a mutex as well.. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: HPFSIngo Molnar
2006-03-23[PATCH] sem2mutex: autofs4 wq_semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: JFFSIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: fs/seq_file.cIngo Molnar
2006-03-23[PATCH] sem2mutex: fs/libfs.cIngo Molnar
2006-03-23[PATCH] sem2mutex: jbd, j_checkpoint_mutexArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: ipruneIngo Molnar
2006-03-23[PATCH] sem2mutex: vfs_rename_mutexArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: eventpollArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: inotifyIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: John McCutchan <ttb@tentacle.dhs.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Robert Love <rml@novell.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: quotaIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: blockdev #2Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] convert fs/9p/ to mutexes, fix locking bugsIngo Molnar
Convert fs/9p/mux.c from semaphore to mutex. NOTE: fixed locking bugs in the process - the code was using semaphores the other way around. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Fix oops in invalidate_dquots()Jan Kara
When quota is being turned off we assumed that all the references to dquots were already dropped. That need not be true as inodes being deleted are not on superblock's inodes list and hence we need not reach it when removing quota references from inodes. So invalidate_dquots() has to wait for all the users of dquots (as quota is already marked as turned off, no new references can be acquired and so this is bound to happen rather early). When we do this, we can also remove the iprune_sem locking as it was protecting us against exactly the same problem when freeing inodes icache memory. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Shrinks sizeof(files_struct) and better layoutEric Dumazet
1) Reduce the size of (struct fdtable) to exactly 64 bytes on 32bits platforms, lowering kmalloc() allocated space by 50%. 2) Reduce the size of (files_struct), using a special 32 bits (or 64bits) embedded_fd_set, instead of a 1024 bits fd_set for the close_on_exec_init and open_fds_init fields. This save some ram (248 bytes per task) as most tasks dont open more than 32 files. D-Cache footprint for such tasks is also reduced to the minimum. 3) Reduce size of allocated fdset. Currently two full pages are allocated, that is 32768 bits on x86 for example, and way too much. The minimum is now L1_CACHE_BYTES. UP and SMP should benefit from this patch, because most tasks will touch only one cache line when open()/close() stdin/stdout/stderr (0/1/2), (next_fd, close_on_exec_init, open_fds_init, fd_array[0 .. 2] being in the same cache line) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] ext3_readdir: use generic readaheadAndrew Morton
Linus points out that ext3_readdir's readahead only cuts in when ext3_readdir() is operating at the very start of the directory. So for large directories we end up performing no readahead at all and we suck. So take it all out and use the core VM's page_cache_readahead(). This means that ext3 directory reads will use all of readahead's dynamic sizing goop. Note that we're using the directory's filp->f_ra to hold the readahead state, but readahead is actually being performed against the underlying blockdev's address_space. Fortunately the readahead code is all set up to handle this. Tested with printk. It works. I was struggling to find a real workload which actually cared. (The patch also exports page_cache_readahead() to GPL modules) Cc: "Stephen C. Tweedie" <sct@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] proc: fix duplicate line in /proc/devicesNeil Horman
Fix a duplicate block device line printed after the "Block device" header in /proc/devices. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: fixed path to moved file in include/linux/device.h Fix spelling in E1000_DISABLE_PACKET_SPLIT Kconfig description Documentation/dvb/get_dvb_firmware: fix firmware URL Documentation: Update to BUG-HUNTING Remove superfluous NOTIFY_COOKIE_LEN define add "tags" to .gitignore Fix "frist", "fisrt", typos fix rwlock usage example It's UTF-8
2006-03-22[PATCH] page migration reorgChristoph Lameter
Centralize the page migration functions in anticipation of additional tinkering. Creates a new file mm/migrate.c 1. Extract buffer_migrate_page() from fs/buffer.c 2. Extract central migration code from vmscan.c 3. Extract some components from mempolicy.c 4. Export pageout() and remove_from_swap() from vmscan.c 5. Make it possible to configure NUMA systems without page migration and non-NUMA systems with page migration. I had to so some #ifdeffing in mempolicy.c that may need a cleanup. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] convert hugetlbfs_counter to atomicChen, Kenneth W
Implementation of hugetlbfs_counter() is functionally equivalent to atomic_inc_return(). Use the simpler atomic form. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] hugepage: Strict page reservation for hugepage inodesDavid Gibson
These days, hugepages are demand-allocated at first fault time. There's a somewhat dubious (and racy) heuristic when making a new mmap() to check if there are enough available hugepages to fully satisfy that mapping. A particularly obvious case where the heuristic breaks down is where a process maps its hugepages not as a single chunk, but as a bunch of individually mmap()ed (or shmat()ed) blocks without touching and instantiating the pages in between allocations. In this case the size of each block is compared against the total number of available hugepages. It's thus easy for the process to become overcommitted, because each block mapping will succeed, although the total number of hugepages required by all blocks exceeds the number available. In particular, this defeats such a program which will detect a mapping failure and adjust its hugepage usage downward accordingly. The patch below addresses this problem, by strictly reserving a number of physical hugepages for hugepage inodes which have been mapped, but not instatiated. MAP_SHARED mappings are thus "safe" - they will fail on mmap(), not later with an OOM SIGKILL. MAP_PRIVATE mappings can still trigger an OOM. (Actually SHARED mappings can technically still OOM, but only if the sysadmin explicitly reduces the hugepage pool between mapping and instantiation) This patch appears to address the problem at hand - it allows DB2 to start correctly, for instance, which previously suffered the failure described above. This patch causes no regressions on the libhugetblfs testsuite, and makes a test (designed to catch this problem) pass which previously failed (ppc64, POWER5). Signed-off-by: David Gibson <dwg@au1.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: nommu use compound pagesNick Piggin
Now that compound page handling is properly fixed in the VM, move nommu over to using compound pages rather than rolling their own refcounting. nommu vm page refcounting is broken anyway, but there is no need to have divergent code in the core VM now, nor when it gets fixed. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: David Howells <dhowells@redhat.com> (Needs testing, please). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] slab: Remove SLAB_NO_REAP optionChristoph Lameter
SLAB_NO_REAP is documented as an option that will cause this slab not to be reaped under memory pressure. However, that is not what happens. The only thing that SLAB_NO_REAP controls at the moment is the reclaim of the unused slab elements that were allocated in batch in cache_reap(). Cache_reap() is run every few seconds independently of memory pressure. Could we remove the whole thing? Its only used by three slabs anyways and I cannot find a reason for having this option. There is an additional problem with SLAB_NO_REAP. If set then the recovery of objects from alien caches is switched off. Objects not freed on the same node where they were initially allocated will only be reused if a certain amount of objects accumulates from one alien node (not very likely) or if the cache is explicitly shrunk. (Strangely __cache_shrink does not check for SLAB_NO_REAP) Getting rid of SLAB_NO_REAP fixes the problems with alien cache freeing. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] v9fs: assign dentry ops to negative dentriesLatchesar Ionkov
If a file is not found in v9fs_vfs_lookup, the function creates negative dentry, but doesn't assign any dentry ops. This leaves the negative entry in the cache (there is no d_delete to mark it for removal). If the file is created outside of the mounted v9fs filesystem, the file shows up in the directory with weird permissions. This patch assigns the default v9fs dentry ops to the negative dentry. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22It's UTF-8Alexey Dobriyan
Fix some comments to "UTF-8". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-20[PATCH] sysfs: fix a kobject leak in sysfs_add_link on the error pathGreg Kroah-Hartman
As pointed out by Oliver Neukum. Cc: Maneesh Soni <maneesh@in.ibm.com> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] sysfs: don't export dir symbolsGreg Kroah-Hartman
These functions should only be used by the kobject core, and if any driver tries to use them, bad things happen. Unexport them to try to prevent this from happening. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] debugfs: Add debugfs_create_blob() helper for exporting binary dataMichael Ellerman
I wanted to export a binary blob via debugfs, and although it was pretty easy it seems like it'd be easier if there was a helper for it. It's a pity we need the wrapper struct but I can't see a cleaner way to do it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] sysfs: fix problem with duplicate sysfs directories and filesManeesh Soni
The following patch checks for existing sysfs_dirent before preparing new one while creating sysfs directories and files. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] sysfs: kzalloc conversionEric Sesterhenn
this converts fs/sysfs to kzalloc() usage. compile tested with make allyesconfig Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] kobj_map semaphore to mutex conversionJes Sorensen
Convert the kobj_map code to use a mutex instead of a semaphore. It converts the single two users as well, genhd.c and char_dev.c. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] sysfs: sysfs_remove_dir() needs to invalidate the dentryGreg Kroah-Hartman
When calling sysfs_remove_dir() don't allow any further sysfs functions to work for this kobject anymore. This fixes a nasty USB cdc-acm oops on disconnect. Many thanks to Bob Copeland and Paul Fulghum for taking the time to track this down. Cc: Bob Copeland <email@bobcopeland.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: add uid, gid, and umask mount options JFS: Take logsync lock before testing mp->lsn JFS: kzalloc conversion JFS: Add missing file from fa3241d24cf1182b0ffb6e4d412c3bc2a2ab7bf6 JFS: Use the kthread_ API JFS: Fix regression. fsck complains if symlinks do not have INLINEEA attribute JFS: ext2 inode attributes for jfs JFS: semaphore to mutex conversion. JFS: make buddy table static JFS: Add back directory i_size calculations for legacy partitions
2006-03-17[PATCH] nfsservctl(): remove user-triggerable printkPeter Staubach
A user can use nfsservctl() to spam the logs. This can happen because the arguments to the nfsservctl() system call are versioned. This is a good thing. However, when a bad version is detected, the kernel prints a message and then returns an error. Signed-off-by: Peter Staubach <staubach@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] v9fs: fix overzealous dropping of dentry which breaks dcacheEric Van Hensbergen
There is a d_drop in dir_release which caused problems as it invalidates dcache entries too soon. This was likely a part of the wierd cwd behavior folks were seeing. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-15[PATCH] Fix ext2 readdir f_pos re-validation logicAl Viro
This fixes not one, but _two_, silly (but admittedly hard to hit) bugs in the ext2 filesystem "readdir()" function. It also cleans up the code to avoid the unnecessary goto mess. The bugs were related to re-valiating the f_pos value after somebody had either done an "lseek()" on the directory to an invalid offset, or when the offset had become invalid due to a file being unlinked in the directory. The code would not only set the f_version too eagerly, it would also not update f_pos appropriately for when the offset fixup took place. When that happened, we'd occasionally subsequently fail the readdir() even when we shouldn't (no real harm done, but an ugly printk, and obviously you would end up not necessarily seeing all entries). Thanks to Masoud Sharbiani <masouds@google.com> who noticed the problem and had a test-case for it, and also fixed up a thinko in the first version of this patch. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Masoud Sharbiani <masouds@google.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-15[PATCH] fs/namespace.c:dup_namespace(): fix a use after freeAdrian Bunk
The Coverity checker spotted the following bug in dup_namespace(): <-- snip --> if (!new_ns->root) { up_write(&namespace_sem); kfree(new_ns); goto out; } ... out: return new_ns; <-- snip --> Callers expect a non-NULL result to not be freed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14[PATCH] page migration: fail if page is in a vma flagged VM_LOCKEDChristoph Lameter
page migration currently simply retries a couple of times if try_to_unmap() fails without inspecting the return code. However, SWAP_FAIL indicates that the page is in a vma that has the VM_LOCKED flag set (if ignore_refs ==1). We can check for that return code and avoid retrying the migration. migrate_page_remove_references() now needs to return a reason why the failure occured. So switch migrate_page_remove_references to use -Exx style error messages. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14Merge git://oss.sgi.com:8090/oss/git/rc-fixesLinus Torvalds
* git://oss.sgi.com:8090/oss/git/rc-fixes: Fix a direct I/O locking issue revealed by the new mutex code.
2006-03-15Fix a direct I/O locking issue revealed by the new mutex code.Nathan Scott
Affects only XFS (i.e. DIO_OWN_LOCKING case) - currently it is not possible to get i_mutex locking correct when using DIO_OWN direct I/O locking in a filesystem due to indeterminism in the possible return code/lock/unlock combinations. This can cause a direct read to attempt a double i_mutex unlock inside XFS. We're now ensuring __blockdev_direct_IO always exits with the inode i_mutex (still) held for a direct reader. Tested with the three different locking modes (via direct block device access, ext3 and XFS) - both reading and writing; cannot find any regressions resulting from this change, and it clearly fixes the mutex_unlock warning originally reported here: http://marc.theaimsgroup.com/?l=linux-kernel&m=114189068126253&w=2 Signed-off-by: Nathan Scott <nathans@sgi.com> Acked-by: Christoph Hellwig <hch@lst.de>
2006-03-14Merge with /home/shaggy/git/linus-clean/Dave Kleikamp
2006-03-14[PATCH] JFS: Take logsync lock before testing mp->lsnDave Kleikamp
This fixes a race where lsn could be cleared before taking the lock Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14[PATCH] NLM: Ensure we do not Oops in the case of an unlockTrond Myklebust
In theory, NLM specs assure us that the server will only reply LCK_GRANTED or LCK_DENIED_GRACE_PERIOD to our NLM_UNLOCK request. In practice, we should not assume this to be the case, and the code will currently Oops if we do. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14[PATCH] NFSv4: fix mount segfault on errors returned that are < -1000Trond Myklebust
It turns out that nfs4_proc_get_root() may return raw NFSv4 errors instead of mapping them to kernel errors. Problem spotted by Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14[PATCH] NFS: Fix a potential panic in O_DIRECTTrond Myklebust
Based on an original patch by Mike O'Connor and Greg Banks of SGI. Mike states: A normal user can panic an NFS client and cause a local DoS with 'judicious'(?) use of O_DIRECT. Any O_DIRECT write to an NFS file where the user buffer starts with a valid mapped page and contains an unmapped page, will crash in this way. I haven't followed the code, but O_DIRECT reads with similar user buffers will probably also crash albeit in different ways. Details: when nfs_get_user_pages() calls get_user_pages(), it detects and correctly handles get_user_pages() returning an error, which happens if the first page covered by the user buffer's address range is unmapped. However, if the first page is mapped but some subsequent page isn't, get_user_pages() will return a positive number which is less than the number of pages requested (this behaviour is sort of analagous to a short write() call and appears to be intentional). nfs_get_user_pages() doesn't detect this and hands off the array of pages (whose last few elements are random rubbish from the newly allocated array memory) to it's caller, whence they go to nfs_direct_write_seg(), which then totally ignores the nr_pages it's given, and calculates its own idea of how many pages are in the array from the user buffer length. Needless to say, when it comes to transmit those uninitialised page* pointers, we see a crash in the network stack. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] ext3: fix nobh mode for chattr +j inodesBadari Pulavarty
One can do "chattr +j" on a file to change its journalling mode. Fix writeback mode with "nobh" handling for it. Even though, we mount ext3 filesystem in writeback mode with "nobh" option, some one can do "chattr +j" on a single file to force it to do journalled mode. In order to do journaling, ext3_block_truncate_page() need to fallback to default case of creating buffers and adding them to transaction etc. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] ext3: ext3_symlink should use GFP_NOFS allocations insideKirill Korotaev
This patch fixes illegal __GFP_FS allocation inside ext3 transaction in ext3_symlink(). Such allocation may re-enter ext3 code from try_to_free_pages. But JBD/ext3 code keeps a pointer to current journal handle in task_struct and, hence, is not reentrable. This bug led to "Assertion failure in journal_dirty_metadata()" messages. http://bugzilla.openvz.org/show_bug.cgi?id=115 Signed-off-by: Andrey Savochkin <saw@saw.sw.com.sg> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[PATCH] mtd: 64 bit fixesAtsushi Nemoto
Fix some bugs in mtd/jffs2 on 64bit platform. The MEMGETBADBLOCK/MEMSETBADBLOCK ioctl are not listed in compat_ioctl.h. And some variables in jffs2 are declared as uint32_t but used to hold size_t values. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
