path: root/fs
2008-02-13udf: fix udf_add_free_spaceMarcin Slusarz
In commit 742ba02a51c8d0bf5446b154531179760c1ed0a2 (udf: create common function for changing free space counter) by accident I reversed safety condition which lead to null pointer dereference in case of media error and wrong counting of free space in normal situation Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Jan Kara <jack@suse.cz> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13udf: fix directory offset handlingJan Kara
Patch cleaning up UDF directory offset handling missed modifications in dir.c (because I've submitted an old version :(). Fix it. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Tested-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13fs/smbfs/inode.c: fix warning message deprecating smbfsSergio Luis
Fix the warning message regarding smbfs to "smbfs is deprecated and will be removed from the 2.6.27 kernel. Please migrate to cifs" instead of "smbfs is deprecated and will be removedfrom the 2.6.27 kernel. Please migrate to cifs" Signed-off-by: Sergio Luis <sergio@uece.br> Screwed-up-by: Andrew Morton <akpm@linux-foundation.org> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13kernel-doc: fix fs/pipe.c notationRandy Dunlap
Fix several kernel-doc notation errors in fs/pipe.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11Merge branch 'for-linus' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-linus' of git://linux-nfs.org/~bfields/linux: SUNPRC: Fix printk format warning nfsd: clean up svc_reserve_auth() NLM: don't requeue block if it was invalidated while GRANT_MSG was in flight NLM: don't reattempt GRANT_MSG when there is already an RPC in flight NLM: have server-side RPC clients default to soft RPC tasks NLM: set RPC_CLNT_CREATE_NOPING for NLM RPC clients
2008-02-10NLM: don't requeue block if it was invalidated while GRANT_MSG was in flightJeff Layton
It's possible for lockd to catch a SIGKILL while a GRANT_MSG callback is in flight. If this happens we don't want lockd to insert the block back into the nlm_blocked list. This helps that situation, but there's still a possible race. Fixing that will mean adding real locking for nlm_blocked. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10NLM: don't reattempt GRANT_MSG when there is already an RPC in flightJeff Layton
With the current scheme in nlmsvc_grant_blocked, we can end up with more than one GRANT_MSG callback for a block in flight. Right now, we requeue the block unconditionally so that a GRANT_MSG callback is done again in 30s. If the client is unresponsive, it can take more than 30s for the call already in flight to time out. There's no benefit to having more than one GRANT_MSG RPC queued up at a time, so put it on the list with a timeout of NLM_NEVER before doing the RPC call. If the RPC call submission fails, we requeue it with a short timeout. If it works, then nlmsvc_grant_callback will end up requeueing it with a shorter timeout after it completes. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10NLM: have server-side RPC clients default to soft RPC tasksJeff Layton
Now that it no longer does an RPC ping, lockd always ends up queueing an RPC task for the GRANT_MSG callback. But, it also requeues the block for later attempts. Since these are hard RPC tasks, if the client we're calling back goes unresponsive the GRANT_MSG callbacks can stack up in the RPC queue. Fix this by making server-side RPC clients default to soft RPC tasks. lockd requeues the block anyway, so this should be OK. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10NLM: set RPC_CLNT_CREATE_NOPING for NLM RPC clientsJeff Layton
It's currently possible for an unresponsive NLM client to completely lock up a server's lockd. The scenario is something like this: 1) client1 (or a process on the server) takes a lock on a file 2) client2 tries to take a blocking lock on the same file and awaits the callback 3) client2 goes unresponsive (plug pulled, network partition, etc) 4) client1 releases the lock ...at that point the server's lockd will try to queue up a GRANT_MSG callback for client2, but first it requeues the block with a timeout of 30s. nlm_async_call will attempt to bind the RPC client to client2 and will call rpc_ping. rpc_ping entails a sync RPC call and if client2 is unresponsive it will take around 60s for that to time out. Once it times out, it's already time to retry the block and the whole process repeats. Once in this situation, nlmsvc_retry_blocked will never return until the host starts responding again. lockd won't service new calls. Fix this by skipping the RPC ping on NLM RPC clients. This makes nlm_async_call return quickly when called. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10splice: fix user pointer access in get_iovec_page_array()Bastian Blank
Commit 8811930dc74a503415b35c4a79d14fb0b408a361 ("splice: missing user pointer access verification") added the proper access_ok() calls to copy_from_user_mmap_sem() which ensures we can copy the struct iovecs from userspace to the kernel. But we also must check whether we can access the actual memory region pointed to by the struct iovec to fix the access checks properly. Signed-off-by: Bastian Blank <waldi@debian.org> Acked-by: Oliver Pinter <oliver.pntr@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-10ext4: Add new "development flag" to the ext4 filesystemTheodore Tso
This flag is simply a generic "this is a crash/burn test filesystem" marker. If it is set, then filesystem code which is "in development" will be allowed to mount the filesystem. Filesystem code which is not considered ready for prime-time will check for this flag, and if it is not set, it will refuse to touch the filesystem. As we start rolling ext4 out to distro's like Fedora, et. al, this makes it less likely that a user might accidentally start using ext4 on a production filesystem; a bad thing, since that will essentially make it be unfsckable until e2fsprogs catches up. Signed-off-by: Theodore Tso <tytso@MIT.EDU> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-02-10ext4: Don't panic in case of corrupt bitmapAneesh Kumar K.V
Multiblock allocator calls BUG_ON in many case if the free and used blocks count obtained looking at the bitmap is different from what the allocator internally accounted for. Use ext4_error in such case and don't panic the system. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-10ext4: allocate struct ext4_allocation_context from a kmem cacheEric Sandeen
struct ext4_allocation_context is rather large, and this bloats the stack of many functions which use it. Allocating it from a named slab cache will alleviate this. For example, with this change (on top of the noinline patch sent earlier): -ext4_mb_new_blocks 200 +ext4_mb_new_blocks 40 -ext4_mb_free_blocks 344 +ext4_mb_free_blocks 168 -ext4_mb_release_inode_pa 216 +ext4_mb_release_inode_pa 40 -ext4_mb_release_group_pa 192 +ext4_mb_release_group_pa 24 Most of these stack-allocated structs are actually used only for mballoc history; and in those cases often a smaller struct would do. So changing that may be another way around it, at least for those functions, if preferred. For now, in those cases where the ac is only for history, an allocation failure simply skips the history recording, and does not cause any other failures. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-10JBD2: Clear buffer_ordered flag for barried IO request on successDave Kleikamp
In JBD2 jbd2_journal_write_commit_record(), clear the buffer_ordered flag for the bh after barried IO has succeed. This prevents later, if the same buffer head were submitted to the underlying device, which has been reconfigured to not support barrier request, the JBD2 commit code could treat it as a normal IO (without barrier). This is a port from JBD/ext3 fix from Neil Brown. More details from Neil: Some devices - notably dm and md - can change their behaviour in response to BIO_RW_BARRIER requests. They might start out accepting such requests but on reconfiguration, they find out that they cannot any more. JBD2 deal with this by always testing if BIO_RW_BARRIER requests fail with EOPNOTSUPP, and retrying the write requests without the barrier (probably after waiting for any pending writes to complete). However there is a bug in the handling this in JBD2 for ext4 . When ext4/JBD2 to submit a BIO_RW_BARRIER request, it sets the buffer_ordered flag on the buffer head. If the request completes successfully, the flag STAYS SET. Other code might then write the same buffer_head after the device has been reconfigured to not accept barriers. This write will then fail, but the "other code" is not ready to handle EOPNOTSUPP errors and the error will be treated as fatal. Cc: Neil Brown <neilb@suse.de> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-10ext4: Fix Direct I/O lockingJan Kara
We cannot start transaction in ext4_direct_IO() and just let it last during the whole write because dio_get_page() acquires mmap_sem which ranks above transaction start (e.g. because we have dependency chain mmap_sem->PageLock->journal_start, or because we update atime while holding mmap_sem) and thus deadlocks could happen. We solve the problem by starting a transaction separately for each ext4_get_block() call. We *could* have a problem that we allocate a block and before its data are written out the machine crashes and thus we expose stale data. But that does not happen because for hole-filling generic code falls back to buffered writes and for file extension, we add inode to orphan list and thus in case of crash, journal replay will truncate inode back to the original size. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-10ext4: Fix circular locking dependency with migrate and rm.Aneesh Kumar K.V
In order to prevent a circular locking dependency when an unlink operation is racing with an ext4 migration, we delay taking i_data_sem until just before switch the inode format, and use i_mutex to prevent writes and truncates during the first part of the migration operation. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-05allow in-inode EAs on ext4 root inodeEric Sandeen
The ext3 root inode was treated specially with respect to in-inode extended attributes, for reasons detailed in the removed comment below. The first mkfs-created inodes would not get extra_i_size or the EXT3_STATE_XATTR flag set in ext3_read_inode, which disallowed reading or setting in-inode EAs on the root. However, in ext4, ext4_mark_inode_dirty calls ext4_expand_extra_isize for all inodes; once this is done EAs may be placed in the root ext4 inode body. But for reasons above, it won't be found after a reboot. testcase: setfattr -n user.name -v value mntpt/ setfattr -n user.name2 -v value2 mntpt/ umount mntpt/; remount mntpt/ getfattr -d mntpt/ name2/value2 has gone missing; debugfs shows it in the inode body, but it is not found there by getattr. The following fixes it up; newer mkfs appears to properly zero the inodes, so this workaround isn't needed for ext4. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-02-10ext4: Fix null bh pointer dereference in mballocAneesh Kumar K.V
Repoted by Adrian Bunk <bunk@kernel.org>: The Coverity checker spotted the following NULL dereference: static int ext4_mb_mark_diskspace_used { ... if (!bitmap_bh) goto out_err; ... out_err: sb->s_dirt = 1; put_bh(bitmap_bh); ... Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-02-05deprecate smbfs in favour of cifsAndrew Morton
smbfs is a bit buggy and has no maintainer. Change it to shout at the user on the first five mount attempts - tell them to switch to CIFS. Come December we'll mark it BROKEN and see what happens. [olecom@flower.upol.cz: documentation update] Cc: Urban Widmark <urban@teststation.com> Acked-by: Steven French <sfrench@us.ibm.com> Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Cc: Jeff Layton <jlayton@redhat.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: fix hostfs tv_usec calculationsDominique Quatravaux
To convert from tv_nsec to tv_usec, one needs to divide by 1000, not multiply. Signed-off-by: Dominique Quatravaux <dominique@quatravaux.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Add 64-bit capability support to the kernelAndrew Morgan
The patch supports legacy (32-bit) capability userspace, and where possible translates 32-bit capabilities to/from userspace and the VFS to 64-bit kernel space capabilities. If a capability set cannot be compressed into 32-bits for consumption by user space, the system call fails, with -ERANGE. FWIW libcap-2.00 supports this change (and earlier capability formats) http://www.kernel.org/pub/linux/libs/security/linux-privs/kernel-2.6/ [akpm@linux-foundation.org: coding-syle fixes] [akpm@linux-foundation.org: use get_task_comm()] [ezk@cs.sunysb.edu: build fix] [akpm@linux-foundation.org: do not initialise statics to 0 or NULL] [akpm@linux-foundation.org: unused var] [serue@us.ibm.com: export __cap_ symbols] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: James Morris <jmorris@namei.org> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05VFS: Reorder vfs_getxattr to avoid unnecessary calls to the LSMDavid P. Quigley
Originally vfs_getxattr would pull the security xattr variable using the inode getxattr handle and then proceed to clobber it with a subsequent call to the LSM. This patch reorders the two operations such that when the xattr requested is in the security namespace it first attempts to grab the value from the LSM directly. If it fails to obtain the value because there is no module present or the module does not support the operation it will fall back to using the inode getxattr operation. In the event that both are inaccessible it returns EOPNOTSUPP. Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Chris Wright <chrisw@sous-sol.org> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05VFS/Security: Rework inode_getsecurity and callers to return resulting bufferDavid P. Quigley
This patch modifies the interface to inode_getsecurity to have the function return a buffer containing the security blob and its length via parameters instead of relying on the calling function to give it an appropriately sized buffer. Security blobs obtained with this function should be freed using the release_secctx LSM hook. This alleviates the problem of the caller having to guess a length and preallocate a buffer for this function allowing it to be used elsewhere for Labeled NFS. The patch also removed the unused err parameter. The conversion is similar to the one performed by Al Viro for the security_getprocattr hook. Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Chris Wright <chrisw@sous-sol.org> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05writeback: speed up writeback of big dirty filesFengguang Wu
After making dirty a 100M file, the normal behavior is to start the writeback for all data after 30s delays. But sometimes the following happens instead: - after 30s: ~4M - after 5s: ~4M - after 5s: all remaining 92M Some analyze shows that the internal io dispatch queues goes like this: s_io s_more_io ------------------------- 1) 100M,1K 0 2) 1K 96M 3) 0 96M 1) initial state with a 100M file and a 1K file 2) 4M written, nr_to_write <= 0, so write more 3) 1K written, nr_to_write > 0, no more writes(BUG) nr_to_write > 0 in (3) fools the upper layer to think that data have all been written out. The big dirty file is actually still sitting in s_more_io. We cannot simply splice s_more_io back to s_io as soon as s_io becomes empty, and let the loop in generic_sync_sb_inodes() continue: this may starve newly expired inodes in s_dirty. It is also not an option to draw inodes from both s_more_io and s_dirty, an let the loop go on: this might lead to live locks, and might also starve other superblocks in sync time(well kupdate may still starve some superblocks, that's another bug). We have to return when a full scan of s_io completes. So nr_to_write > 0 does not necessarily mean that "all data are written". This patch introduces a flag writeback_control.more_io to indicate that more io should be done. With it the big dirty file no longer has to wait for the next kupdate invokation 5s later. In sync_sb_inodes() we only set more_io on super_blocks we actually visited. This avoids the interaction between two pdflush deamons. Also in __sync_single_inode() we don't blindly keep requeuing the io if the filesystem cannot progress. Failing to do so may lead to 100% iowait. Tested-by: Mike Snitzer <snitzer@gmail.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05skip writing data pages when inode is under I_SYNCQi Yong
Since I_SYNC was split out from I_LOCK, the concern in commit 4b89eed93e0fa40a63e3d7b1796ec1337ea7a3aa ("Write back inode data pages even when the inode itself is locked") is not longer valid. We should revert to the original behavior: in __writeback_single_inode(), when we find an I_SYNC-ed inode and we're not doing a data-integrity sync, skip writing entirely. Otherwise, we are double calling do_writepages() Signed-off-by: Qi Yong <qiyong@fc-cn.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Cc: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Fix /proc dcache deadlock in do_exitAndrea Arcangeli
This patch fixes a sles9 system hang in start_this_handle from a customer with some heavy workload where all tasks are waiting on kjournald to commit the transaction, but kjournald waits on t_updates to go down to zero (it never does). This was reported as a lowmem shortage deadlock but when checking the debug data I noticed the VM wasn't under pressure at all (well it was really under vm pressure, because lots of tasks hanged in the VM prune_dcache methods trying to flush dirty inodes, but no task was hanging in GFP_NOFS mode, the holder of the journal handle should have if this was a vm issue in the first place). No task was apparently holding the leftover handle in the committing transaction, so I deduced t_updates was stuck to 1 because a journal_stop was never run by some path (this turned out to be correct). With a debug patch adding proper reverse links and stack trace logging in ext3 deployed in production, I found journal_stop is never run because mark_inode_dirty_sync is called inside release_task called by do_exit. (that was quite fun because I would have never thought about this subtleness, I thought a regular path in ext3 had a bug and it forgot to call journal_stop) do_exit->release_task->mark_inode_dirty_sync->schedule() (will never come back to run journal_stop) The reason is that shrink_dcache_parent is racy by design (feature not a bug) and it can do blocking I/O in some case, but the point is that calling shrink_dcache_parent at the last stage of do_exit isn't safe for self-reaping tasks. I guess the memory pressure of the unbalanced highmem system allowed to trigger this more easily. Now mainline doesn't have this line in iput (like sles9 has): if (inode->i_state & I_DIRTY_DELAYED) mark_inode_dirty_sync(inode); so it will probably not crash with ext3, but for example ext2 implements an I/O-blocking ext2_put_inode that will lead to similar screwups with ext2_free_blocks never coming back and it's definitely wrong to call blocking-IO paths inside do_exit. So this should fix a subtle bug in mainline too (not verified in practice though). The equivalent fix for ext3 is also not verified yet to fix the problem in sles9 but I don't have doubt it will (it usually takes days to crash, so it'll take weeks to be sure). An alternate fix would be to offload that work to a kernel thread, but I don't think a reschedule for this is worth it, the vm should be able to collect those entries for the synchronous release_task. Signed-off-by: Andrea Arcangeli <andrea@suse.de> Cc: Jan Kara <jack@ucw.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: make page monitoring /proc file optionalMatt Mackall
Make /proc/ page monitoring configurable This puts the following files under an embedded config option: /proc/pid/clear_refs /proc/pid/smaps /proc/pid/pagemap /proc/kpagecount /proc/kpageflags [akpm@linux-foundation.org: Kconfig fix] Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: add /proc/kpageflags interfaceMatt Mackall
This makes a subset of physical page flags available to userspace. Together with /proc/pid/kpagemap, this allows tracking of a wide variety of VM behaviors. Exported flags are decoupled from the kernel's internal flags. This allows us to reorder flag bits, and synthesize any bits that get redefined in terms of other bits. [akpm@linux-foundation.org: remove unneeded access_ok()] [akpm@linux-foundation.org: s/0/NULL/] Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: add /proc/kpagecount interfaceMatt Mackall
This makes physical page map counts available to userspace. Together with /proc/pid/pagemap and /proc/pid/clear_refs, this can be used to monitor memory usage on a per-page basis. [akpm@linux-foundation.org: remove unneeded access_ok()] [bunk@stusta.de: make struct proc_kpagemap static] Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: add /proc/pid/pagemap interfaceMatt Mackall
This interface provides a mapping for each page in an address space to its physical page frame number, allowing precise determination of what pages are mapped and what pages are shared between processes. New in this version: - headers gone again (as recommended by Dave Hansen and Alan Cox) - 64-bit entries (as per discussion with Andi Kleen) - swap pte information exported (from Dave Hansen) - page walker callback for holes (from Dave Hansen) - direct put_user I/O (as suggested by Rusty Russell) This patch folds in cleanups and swap PTE support from Dave Hansen <haveblue@us.ibm.com>. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: regroup task_mmu by interfaceMatt Mackall
Reorder source so that all the code and data for each interface is together. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: move clear_refs code to task_mmu.cMatt Mackall
This puts all the clear_refs code where it belongs and probably lets things compile on MMU-less systems as well. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: simplify interdependence of maps and smapsMatt Mackall
This pulls the shared map display code out of show_map and puts it in show_smap where it belongs. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Acked-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: use pagewalker in clear_refs and smapsMatt Mackall
Use the generic pagewalker for smaps and clear_refs Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: add proportional set size accounting in smapsFengguang Wu
The "proportional set size" (PSS) of a process is the count of pages it has in memory, where each page is divided by the number of processes sharing it. So if a process has 1000 pages all to itself, and 1000 shared with one other process, its PSS will be 1500. - lwn.net: "ELC: How much memory are applications really using?" The PSS proposed by Matt Mackall is a very nice metic for measuring an process's memory footprint. So collect and export it via /proc/<pid>/smaps. Matt Mackall's pagemap/kpagemap and John Berthels's exmap can also do the job. They are comprehensive tools. But for PSS, let's do it in the simple way. Cc: John Berthels <jjberthels@gmail.com> Cc: Bernardo Innocenti <bernie@codewiz.org> Cc: Padraig Brady <P@draigBrady.com> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Hugh Dickins <hugh@veritas.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05hugetlb: allow sticky directory mount optionKen Chen
Allow sticky directory mount option for hugetlbfs. This allows admin to create a shared hugetlbfs mount point for multiple users, while prevent accidental file deletion that users may step on each other. It is similiar to default tmpfs mount option, or typical option used on /tmp. Signed-off-by: Ken Chen <kenchen@google.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <hermes@gibson.dropbear.id.au> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05bufferhead: revert constructor removalChristoph Lameter
The constructor for buffer_head slabs was removed recently. We need the constructor back in slab defrag in order to insure that slab objects always have a definite state even before we allocated them. I think we mistakenly merged the removal of the constuctor into a cleanup patch. You (ie: akpm) had a test that showed that the removal of the constructor led to a small regression. The prior state makes things easier for slab defrag. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05is_vmalloc_addr(): Check if an address is within the vmalloc boundariesChristoph Lameter
Checking if an address is a vmalloc address is done in a couple of places. Define a common version in mm.h and replace the other checks. Again the include structures suck. The definition of VMALLOC_START and VMALLOC_END is not available in vmalloc.h since highmem.c cannot be included there. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: new timerfd APIDavide Libenzi
This is the new timerfd API as it is implemented by the following patch: int timerfd_create(int clockid, int flags); int timerfd_settime(int ufd, int flags, const struct itimerspec *utmr, struct itimerspec *otmr); int timerfd_gettime(int ufd, struct itimerspec *otmr); The timerfd_create() API creates an un-programmed timerfd fd. The "clockid" parameter can be either CLOCK_MONOTONIC or CLOCK_REALTIME. The timerfd_settime() API give new settings by the timerfd fd, by optionally retrieving the previous expiration time (in case the "otmr" parameter is not NULL). The time value specified in "utmr" is absolute, if the TFD_TIMER_ABSTIME bit is set in the "flags" parameter. Otherwise it's a relative time. The timerfd_gettime() API returns the next expiration time of the timer, or {0, 0} if the timerfd has not been set yet. Like the previous timerfd API implementation, read(2) and poll(2) are supported (with the same interface). Here's a simple test program I used to exercise the new timerfd APIs: http://www.xmailserver.org/timerfd-test2.c [akpm@linux-foundation.org: coding-style cleanups] [akpm@linux-foundation.org: fix ia64 build] [akpm@linux-foundation.org: fix m68k build] [akpm@linux-foundation.org: fix mips build] [akpm@linux-foundation.org: fix alpha, arm, blackfin, cris, m68k, s390, sparc and sparc64 builds] [heiko.carstens@de.ibm.com: fix s390] [akpm@linux-foundation.org: fix powerpc build] [akpm@linux-foundation.org: fix sparc64 more] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05exec: rework the group exit and fix the race with killOleg Nesterov
As Roland pointed out, we have the very old problem with exec. de_thread() sets SIGNAL_GROUP_EXIT, kills other threads, changes ->group_leader and then clears signal->flags. All signals (even fatal ones) sent in this window (which is not too small) will be lost. With this patch exec doesn't abuse SIGNAL_GROUP_EXIT. signal_group_exit(), the new helper, should be used to detect exit_group() or exec() in progress. It can have more users, but this patch does only strictly necessary changes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Robin Holt <holt@sgi.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05get_task_comm(): return the resultAndrew Morton
It was dumb to make get_task_comm() return void. Change it to return a pointer to the resulting output for caller convenience. Cc: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05lockdep: annotate epollPeter Zijlstra
On Sat, 2008-01-05 at 13:35 -0800, Davide Libenzi wrote: > I remember I talked with Arjan about this time ago. Basically, since 1) > you can drop an epoll fd inside another epoll fd 2) callback-based wakeups > are used, you can see a wake_up() from inside another wake_up(), but they > will never refer to the same lock instance. > Think about: > > dfd = socket(...); > efd1 = epoll_create(); > efd2 = epoll_create(); > epoll_ctl(efd1, EPOLL_CTL_ADD, dfd, ...); > epoll_ctl(efd2, EPOLL_CTL_ADD, efd1, ...); > > When a packet arrives to the device underneath "dfd", the net code will > issue a wake_up() on its poll wake list. Epoll (efd1) has installed a > callback wakeup entry on that queue, and the wake_up() performed by the > "dfd" net code will end up in ep_poll_callback(). At this point epoll > (efd1) notices that it may have some event ready, so it needs to wake up > the waiters on its poll wait list (efd2). So it calls ep_poll_safewake() > that ends up in another wake_up(), after having checked about the > recursion constraints. That are, no more than EP_MAX_POLLWAKE_NESTS, to > avoid stack blasting. Never hit the same queue, to avoid loops like: > > epoll_ctl(efd2, EPOLL_CTL_ADD, efd1, ...); > epoll_ctl(efd3, EPOLL_CTL_ADD, efd2, ...); > epoll_ctl(efd4, EPOLL_CTL_ADD, efd3, ...); > epoll_ctl(efd1, EPOLL_CTL_ADD, efd4, ...); > > The code "if (tncur->wq == wq || ..." prevents re-entering the same > queue/lock. Since the epoll code is very careful to not nest same instance locks allow the recursion. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05ext4: Don't set EXTENTS_FL flag for fast symlinksValerie Clement
For fast symbolic links, the file content is stored in the i_block[] array, which is not compatible with the new file extents format. e2fsck reports error on such files because EXTENTS_FL is set. Don't set the EXTENTS_FL flag when creating fast symlinks. In the case of file migration, skip fast symbolic links. Signed-off-by: Valerie Clement <valerie.clement@bull.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-05JBD2: Use the incompat macro for testing the incompat feature.Aneesh Kumar K.V
JBD2_FEATURE_INCOMPAT_ASYNC_COMMIT needs to be checked with JBD2_HAS_INCOMPAT_FEATURE Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-05jbd2: Fix reference counting on the journal commit block's buffer headAneesh Kumar K.V
With journal checksum patch we added asynchronous commits of journal commit headers, and accidentally dropped taking a reference on the buffer head. (Before the change, sync_dirty_buffer did the get_bh(). The associative put_bh is done by journal_wait_on_commit_record().) Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-04Merge branch 'locks' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'locks' of git://linux-nfs.org/~bfields/linux: pid-namespaces-vs-locks-interaction file locks: Use wait_event_interruptible_timeout() locks: clarify posix_locks_deadlock
2008-02-04vm audit: add VM_DONTEXPAND to mmap for drivers that need itNick Piggin
Drivers that register a ->fault handler, but do not range-check the offset argument, must set VM_DONTEXPAND in the vm_flags in order to prevent an expanding mremap from overflowing the resource. I've audited the tree and attempted to fix these problems (usually by adding VM_DONTEXPAND where it is not obvious). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
