path: root/fs
2010-03-15Btrfs: cache ordered extent when completing ioJosef Bacik
When finishing io we run btrfs_dec_test_ordered_pending, and then immediately run btrfs_lookup_ordered_extent, but btrfs_dec_test_ordered_pending does that already, so we're searching twice when we don't have to. This patch lets us pass a btrfs_ordered_extent in to btrfs_dec_test_ordered_pending so if we do complete io on that ordered extent we can just use the one we found then instead of having to do another btrfs_lookup_ordered_extent. This made my fio job with the other patch go from 24 mb/s to 29 mb/s. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: cache extent state in find_delalloc_rangeJosef Bacik
This patch makes us cache the extent state we find in find_delalloc_range since we'll have to lock the extent later on in the function. This will keep us from re-searching for the rang when we try to lock the extent. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: change the ordered tree to use a spinlock instead of a mutexJosef Bacik
The ordered tree used to need a mutex, but currently all we use it for is to protect the rb_tree, and a spin_lock is just fine for that. Using a spin_lock instead makes dbench run a little faster, 58 mb/s instead of 51 mb/s, and have less latency, 3445.138 ms instead of 3820.633 ms. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: finish read pages in the order they are submittedChris Mason
The endio is done at reverse order of bio vectors. That means for a sequential read, the page first submitted will finish last in a bio. Considering we will do checksum (making cache hot) for every page, this does introduce delay (and chance to squeeze cache used soon) for pages submitted at the begining. I don't observe obvious performance difference with below patch at my simple test, but seems more natural to finish read in the order they are submitted. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15btrfs: fix btrfs_mkdir goto for no free objectidsMiao Xie
btrfs_mkdir() must jump to the place of ending transaction after btrfs_find_free_objectid() failed. Or this transaction can't end. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: flush data on snapshot creationSage Weil
Flush any delalloc extents when we create a snapshot, so that recently written file data is always included in the snapshot. A later commit will add the ability to snapshot without the flush, but most people expect flushing. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make df be a little bit more understandableJosef Bacik
The way we report df usage is way confusing for everybody, including some other utilities (bacula for one). So this patch makes df a little bit more understandable. First we make used actually count the total amount of used space in all space info's. This will give us a real view of how much disk space is in use. Second, for blocks available, only count data space. This makes things like bacula work because it says 0 when you can no longer write anymore data to the disk. I think this is a nice compromise, since you will end up with something like the following [root@alpha ~]# df -h Filesystem Size Used Avail Use% Mounted on /dev/mapper/VolGroup-lv_root 148G 30G 111G 21% / /dev/sda1 194M 116M 68M 64% /boot tmpfs 985M 12K 985M 1% /dev/shm /dev/mapper/VolGroup-LogVol02 145G 140G 0 100% /mnt/btrfs-test Compare this with btrfsctl -i output [root@alpha btrfs-progs-unstable]# ./btrfsctl -i /mnt/btrfs-test/ Metadata, DUP: total=4.62GB, used=2.46GB System, DUP: total=8.00MB, used=24.00KB Data: total=134.80GB, used=134.80GB Metadata: total=8.00MB, used=0.00 System: total=4.00MB, used=0.00 operation complete This way we show that there is no more data space to be used, but we have another 5GB of space left for metadata. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15btrfs: Update existing btrfs_device for renaming deviceTARUISI Hiroaki
When we scan devices in a multi-device filesystem, we memorize the original name. If the device gets a new name, later scans don't update the in-kernel structures related to it, and we're not able to mount the filesystem. This patch updates device name during scaning. Signed-off-by: TARUISI Hiroaki <taruishi.hiroak@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add new defrag-range ioctl.Chris Mason
The btrfs defrag ioctl was limited to doing the entire file. This commit adds a new interface that can defrag a specific range inside the file. It can also force compression on the file, allowing you to selectively compress individual files after they were created, even when mount -o compress isn't turned on. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: be more selective in the defrag ioctlChris Mason
The btrfs defrag ioctl had some bugs around delalloc accounting, and it wasn't properly skipping pages that were not in the mapping. It wasn't properly clearing the page checked flag, which could make the writeback code ignore the page forever while pinning it as dirty. This commit fixes those problems and makes defrag a little smarter. It skips holes and it doesn't waste time defragging large extents. If a tiny extent comes before a very large extent, it will defrag both of them to make sure the tiny extent ends up next to something big. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: run the backing dev more often in the submit_bio helperChris Mason
The submit_bio helper thread can decide to loop back around to service more bios. This commit forces it to unplug first, which helps reduce the latency seen by submitters. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make subvolid=0 mount the original default rootJosef Bacik
Since theres not a good way to make sure the user sees the original default root tree id, and not to mention it's 5 so is way different than any other volume, just make subvol=0 mount the original default root. This makes it a bit easier for users to handle in the long run. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add ioctl and incompat flag to set the default mount subvolJosef Bacik
This patch needs to go along with my previous patch. This lets us set the default dir item's location to whatever root we want to use as our default mounting subvol. With this we don't have to use mount -o subvol=<tree id> anymore to mount a different subvol, we can just set the new one and it will just magically work. I've done some moderate testing with this, mostly just switching the default mount around, mounting subvols and the default mount at the same time and such, everything seems to work. Thanks, Older kernels would generally be able to still mount the filesystem with the default subvolume set, but it would result in a different volume being mounted, which could be an even more unpleasant suprise for users. So if you set your default subvolume, you can't go back to older kernels. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: change how we mount subvolumesJosef Bacik
This work is in preperation for being able to set a different root as the default mounting root. There is currently a problem with how we mount subvolumes. We cannot currently mount a subvolume of a subvolume, you can only mount subvolumes/snapshots of the default subvolume. So say you take a snapshot of the default subvolume and call it snap1, and then take a snapshot of snap1 and call it snap2, so now you have / /snap1 /snap1/snap2 as your available volumes. Currently you can only mount / and /snap1, you cannot mount /snap1/snap2. To fix this problem instead of passing subvolid=<name> you must pass in subvolid=<treeid>, where <treeid> is the tree id that gets spit out via the subvolume listing you get from the subvolume listing patches (btrfs filesystem list). This allows us to mount /, /snap1 and /snap1/snap2 as the root volume. In addition to the above, we also now read the default dir item in the tree root to get the root key that it points to. For now this just points at what has always been the default subvolme, but later on I plan to change it to point at whatever root you want to be the new default root, so you can just set the default mount and not have to mount with -o subvolid=<treeid>. I tested this out with the above scenario and it worked perfectly. Thanks, mount -o subvol operates inside the selected subvolid. For example: mount -o subvol=snap1,subvolid=256 /dev/xxx /mnt /mnt will have the snap1 directory for the subvolume with id 256. mount -o subvol=snap /dev/xxx /mnt /mnt will be the snap directory of whatever the default subvolume is. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: make set/get functions for the super compat_ro flags use compat_roJosef Bacik
Our set/get functions for compat_ro_flags actually look at compat_flags. This will mess any attempt to use compat flags up. The fix is obvious. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add search and inode lookup ioctlsChris Mason
The search ioctl is a generic tool for doing btree searches from userland applications. The first user of the search ioctl is a subvolume listing feature, but we'll also use it to find new files in a subvolume. The search ioctl allows you to specify min and max keys to search for, along with min and max transid. It returns the items along with a header that includes the item key. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-15Btrfs: add a function to lookup a directory path by following backrefsTARUISI Hiroaki
This will be used by the inode lookup ioctl. Signed-off-by: TARUISI Hiroaki <taruishi.hiroak@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-08Btrfs: kfree correct pointer during mount option parsingJosef Bacik
We kstrdup the options string, but then strsep screws with the pointer, so when we kfree() it, we're not giving it the right pointer. Tested-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-03-08Btrfs: use RB_ROOT to intialize rb_trees instead of setting rb_node to NULLEric Paris
btrfs inialize rb trees in quite a number of places by settin rb_node = NULL; The problem with this is that 17d9ddc72fb8bba0d4f678 in the linux-next tree adds a new field to that struct which needs to be NULL for the new rbtree library code to work properly. This patch uses RB_ROOT as the intializer so all of the relevant fields will be NULL'd. Without the patch I get a panic. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-12Btrfs: btrfs_mark_extent_written uses the wrong slotShaohua Li
My test do: fallocate a big file and do write. The file is 512M, but after file write is done btrfs-debug-tree shows: item 6 key (257 EXTENT_DATA 0) itemoff 3516 itemsize 53 extent data disk byte 1103101952 nr 536870912 extent data offset 0 nr 399634432 ram 536870912 extent compression 0 Looks like a regression introducted by 6c7d54ac87f338c479d9729e8392eca3f76e11e1, where we set wrong slot. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: apply updated fallocate i_size fixAneesh Kumar K.V
This version of the i_size fix for fallocate makes sure we only update the i_size when the current fallocate is really operating outside of i_size. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: do not try and lookup the file extent when finishing ordered ioJosef Bacik
When running the following fio job [torrent] filename=torrent-test rw=randwrite size=4g filesize=4g bs=4k ioengine=sync you would see long stalls where no work was being done. That is because we were doing all this extra work to read in the file extent outside of the transaction, however in the random io case this ends up hurting us because the file extents are not there to begin with. So axe this logic, since we end up reading in the file extent when we go to update it anyway. This took the fio job from 11 mb/s with several ~10 second stalls to 24 mb/s to a couple of 1-2 second stalls. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: Fix oopsen when dropping empty tree.Yan, Zheng
When dropping a empty tree, walk_down_tree() skips checking extent information for the tree root. This will triggers a BUG_ON in walk_up_proc(). Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: remove BUG_ON() due to mounting bad filesystemMiao Xie
Mounting a bad filesystem caused a BUG_ON(). The following is steps to reproduce it. # mkfs.btrfs /dev/sda2 # mount /dev/sda2 /mnt # mkfs.btrfs /dev/sda1 /dev/sda2 (the program says that /dev/sda2 was mounted, and then exits. ) # umount /mnt # mount /dev/sda1 /mnt At the third step, mkfs.btrfs exited in the way of make filesystem. So the initialization of the filesystem didn't finish. So the filesystem was bad, and it caused BUG_ON() when mounting it. But BUG_ON() should be called by the wrong code, not user's operation, so I think it is a bug of btrfs. This patch fixes it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: make error return negative in btrfs_sync_file()Roel Kluin
It appears the error return should be negative Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-02-04Btrfs: fix race between allocate and release extent buffer.Yan, Zheng
Increase extent buffer's reference count while holding the lock. Otherwise it can race with try_release_extent_buffer. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: check total number of devices when removing missingJosef Bacik
If you have a disk failure in RAID1 and then add a new disk to the array, and then try to remove the missing volume, it will fail. The reason is the sanity check only looks at the total number of rw devices, which is just 2 because we have 2 good disks and 1 bad one. Instead check the total number of devices in the array to make sure we can actually remove the device. Tested this with a failed disk setup and with this test we can now run btrfs-vol -r missing /mount/point and it works fine. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: check return value of open_bdev_exclusive properlyJosef Bacik
Hit this problem while testing RAID1 failure stuff. open_bdev_exclusive returns ERR_PTR(), not NULL. So change the return value properly. This is important if you accidently specify a device that doesn't exist when trying to add a new device to an array, you will panic the box dereferencing bdev. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: do not mark the chunk as readonly if in degraded modeJosef Bacik
If a RAID setup has chunks that span multiple disks, and one of those disks has failed, btrfs_chunk_readonly will return 1 since one of the disks in that chunk's stripes is dead and therefore not writeable. So instead if we are in degraded mode, return 0 so we can go ahead and allocate stuff. Without this patch all of the block groups in a RAID1 setup will end up read-only, which will mean we can't add new disks to the array since we won't be able to make allocations. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: run orphan cleanup on default fs rootJosef Bacik
This patch revert's commit 6c090a11e1c403b727a6a8eff0b97d5fb9e95cb5 Since it introduces this problem where we can run orphan cleanup on a volume that can have orphan entries re-added. Instead of my original fix, Yan Zheng pointed out that we can just revert my original fix and then run the orphan cleanup in open_ctree after we look up the fs_root. I have tested this with all the tests that gave me problems and this patch fixes both problems. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: fix a memory leak in btrfs_init_aclYang Hongyang
In btrfs_init_acl() cloned acl is not released Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: Use correct values when updating inode i_size on fallocateAneesh Kumar K.V
commit f2bc9dd07e3424c4ec5f3949961fe053d47bc825 Author: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Date: Wed Jan 20 12:57:53 2010 +0530 Btrfs: Use correct values when updating inode i_size on fallocate Even though we allocate more, we should be updating inode i_size as per the arguments passed Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: remove tree_search() in extent_map.cMiao Xie
This patch removes tree_search() in extent_map.c because it is not called by anything. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-28Btrfs: Add mount -o compress-forceChris Mason
The default btrfs mount -o compress mode will quickly back off compressing a file if it notices that compression does not reduce the size of the data being written. This can save considerable CPU because all future writes to the file go through uncompressed. But some files are both very large and have mixed data stored in them. In that case, we want to add the ability to always try compressing data before writing it. This commit adds mount -o compress-force. A later commit will add a new inode flag that does the same thing. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs: fix possible panic on unmountJosef Bacik
We can race with the unmount of an fs and the stopping of a kthread where we will free the block group before we're done using it. The reason for this is because we do not hold a reference on the block group while its caching, since the allocator drops its reference once it exits or moves on to the next block group. This patch fixes the problem by taking a reference to the block group before we start caching and dropping it when we're done to make sure all accesses to the block group are safe. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs: deal with NULL acl sent to btrfs_set_aclChris Mason
It is legal for btrfs_set_acl to be sent a NULL acl. This makes sure we don't dereference it. A similar patch was sent by Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs: fix regression in orphan cleanupJosef Bacik
Currently orphan cleanup only ever gets triggered if we cross subvolumes during a lookup, which means that if we just mount a plain jane fs that has orphans in it, they will never get cleaned up. This results in panic's like these http://www.kerneloops.org/oops.php?number=1109085 where adding an orphan entry results in -EEXIST being returned and we panic. In order to fix this, we check to see on lookup if our root has had the orphan cleanup done, and if not go ahead and do it. This is easily reproduceable by running this testcase #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <string.h> #include <unistd.h> #include <stdio.h> int main(int argc, char **argv) { char data[4096]; char newdata[4096]; int fd1, fd2; memset(data, 'a', 4096); memset(newdata, 'b', 4096); while (1) { int i; fd1 = creat("file1", 0666); if (fd1 < 0) break; for (i = 0; i < 512; i++) write(fd1, data, 4096); fsync(fd1); close(fd1); fd2 = creat("file2", 0666); if (fd2 < 0) break; ftruncate(fd2, 4096 * 512); for (i = 0; i < 512; i++) write(fd2, newdata, 4096); close(fd2); i = rename("file2", "file1"); unlink("file1"); } return 0; } and then pulling the power on the box, and then trying to run that test again when the box comes back up. I've tested this locally and it fixes the problem. Thanks to Tomas Carnecky for helping me track this down initially. Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs: Fix race in btrfs_mark_extent_writtenYan, Zheng
Fix bug reported by Johannes Hirte. The reason of that bug is btrfs_del_items is called after btrfs_duplicate_item and btrfs_del_items triggers tree balance. The fix is check that case and call btrfs_search_slot when needed. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs, fix memory leaks in error pathsJiri Slaby
Stanse found 2 memory leaks in relocate_block_group and __btrfs_map_block. cluster and multi are not freed/assigned on all paths. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17Btrfs: align offsets for btrfs_ordered_update_i_sizeYan, Zheng
Some callers of btrfs_ordered_update_i_size can now pass in a NULL for the ordered extent to update against. This makes sure we properly align the offset they pass in when deciding how much to bump the on disk i_size. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-01-17btrfs: fix missing last-entry in readdir(3)Jan Engelhardt
parent 49313cdac7b34c9f7ecbb1780cfc648b1c082cd7 (v2.6.32-1-g49313cd) commit ff48c08e1c05c67e8348ab6f8a24de8034e0e34d Author: Jan Engelhardt <jengelh@medozas.de> Date: Wed Dec 9 22:57:36 2009 +0100 Btrfs: fix missing last-entry in readdir(3) When one does a 32-bit readdir(3), the last entry of a directory is missing. This is however not due to passing a large value to filldir, but it seems to have to do with glibc doing telldir or something quirky. In any case, this patch fixes it in practice. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: make sure fallocate properly starts a transactionChris Mason
The recent patch to make fallocate enospc friendly would send down a NULL trans handle to the allocator. This moves the transaction start to properly fix things. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: make metadata chunks smallerJosef Bacik
This patch makes us a bit less zealous about making sure we have enough free metadata space by pearing down the size of new metadata chunks to 256mb instead of 1gb. Also, we used to try an allocate metadata chunks when allocating data, but that sort of thing is done elsewhere now so we can just remove it. With my -ENOSPC test I used to have 3gb reserved for metadata out of 75gb, now I have 1.7gb. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Show discard option in /proc/mountsMatthew Wilcox
Christoph's patch e244a0aeb6a599c19a7c802cda6e2d67c847b154 doesn't display the discard option in /proc/mounts, leading to some confusion for me. Here's the missing bit. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: deny sys_link across subvolumes.TARUISI Hiroaki
I rebased Christian Parpart's patch to deny hard link across subvolumes. Original patch modifies also btrfs_rename, but I excluded it because we can move across subvolumes now and it make no problem. ----------------- Hard link across subvolumes should not allowed in Btrfs. btrfs_link checks root of 'to' directory is same as root of 'from' file. If not same, btrfs_link returns -EPERM. Signed-off-by: TARUISI Hiroaki <taruishi.hiroak@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: fail mount on bad mount optionsSage Weil
We shouldn't silently ignore unrecognized options. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: don't add extent 0 to the free space cache v2Yan, Zheng
If block group 0 is completely free, btrfs_read_block_groups will add extent [0, BTRFS_SUPER_INFO_OFFSET) to the free space cache. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Fix per root used space accountingYan, Zheng
The bytes_used field in root item was originally planned to trace the amount of used data and tree blocks. But it never worked right since we can't trace freeing of data accurately. This patch changes it to only trace the amount of tree blocks. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Fix btrfs_drop_extent_cache for skip pinned caseYan, Zheng
The check for skip pinned case is wrong, it may breaks the while loop too soon. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-12-17Btrfs: Add delayed iputYan, Zheng
iput() can trigger new transactions if we are dropping the final reference, so calling it in btrfs_commit_transaction may end up deadlock. This patch adds delayed iput to avoid the issue. Signed-off-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
