Pull jfs fix from David Kleikamp:
"Minor bug fix for linux-3.14"
* tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggy:
jfs: fix xattr value size overflow in __jfs_setxattr
Add matching dput() for d_find_alias(). Move d_find_alias() down a bit
at Julia's suggestion.
[ Introduced by commit 72466d0b92e0: "ceph: fix posix ACL hooks" ]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"This is a pretty big pull, and most of these changes have been
floating in btrfs-next for a long time. Filipe's properties work is a
cool building block for inheriting attributes like compression down on
a per inode basis.
Jeff Mahoney kicked in code to export filesystem info into sysfs.
Otherwise, lots of performance improvements, cleanups and bug fixes.
Looks like there are still a few other small pending incrementals, but
I wanted to get the bulk of this in first"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits)
Btrfs: fix spin_unlock in check_ref_cleanup
Btrfs: setup inode location during btrfs_init_inode_locked
Btrfs: don't use ram_bytes for uncompressed inline items
Btrfs: fix btrfs_search_slot_for_read backwards iteration
Btrfs: do not export ulist functions
Btrfs: rework ulist with list+rb_tree
Btrfs: fix memory leaks on walking backrefs failure
Btrfs: fix send file hole detection leading to data corruption
Btrfs: add a reschedule point in btrfs_find_all_roots()
Btrfs: make send's file extent item search more efficient
Btrfs: fix to catch all errors when resolving indirect ref
Btrfs: fix protection between walking backrefs and root deletion
btrfs: fix warning while merging two adjacent extents
Btrfs: fix infinite path build loops in incremental send
btrfs: undo sysfs when open_ctree() fails
Btrfs: fix snprintf usage by send's gen_unique_name
btrfs: fix defrag 32-bit integer overflow
btrfs: sysfs: list the NO_HOLES feature
btrfs: sysfs: don't show reserved incompat feature
btrfs: call permission checks earlier in ioctls and return EPERM
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull some further ceph acl cleanups from Sage Weil:
"I do have a couple patches on top of what's in your tree, though, that
clean up a couple duplicated lines in your fix and apply Christoph's
cleanup"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: simplify ceph_{get,init}_acl
ceph: remove duplicate declaration of ceph_setattr
- ->get_acl only gets called after we checked for a cached ACL, so no
need to call get_cached_acl again.
- no need to check IS_POSIXACL in ->get_acl, without that it should
never get set as all the callers that set it already have the check.
- you should be able to use the full posix_acl_create in CEPH
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Pull block IO driver changes from Jens Axboe:
- bcache update from Kent Overstreet.
- two bcache fixes from Nicholas Swenson.
- cciss pci init error fix from Andrew.
- underflow fix in the parallel IDE pg_write code from Dan Carpenter.
I'm sure the 1 (or 0) users of that are now happy.
- two PCI related fixes for sx8 from Jingoo Han.
- floppy init fix for first block read from Jiri Kosina.
- pktcdvd error return miss fix from Julia Lawall.
- removal of IRQF_SHARED from the SEGA Dreamcast CD-ROM code from
Michael Opdenacker.
- comment typo fix for the loop driver from Olaf Hering.
- potential oops fix for null_blk from Raghavendra K T.
- two fixes from Sam Bradshaw (Micron) for the mtip32xx driver, fixing
an OOM problem and a problem with handling security locked conditions
* 'for-3.14/drivers' of git://git.kernel.dk/linux-block: (47 commits)
mg_disk: Spelling s/finised/finished/
null_blk: Null pointer deference problem in alloc_page_buffers
mtip32xx: Correctly handle security locked condition
mtip32xx: Make SGL container per-command to eliminate high order dma allocation
drivers/block/loop.c: fix comment typo in loop_config_discard
drivers/block/cciss.c:cciss_init_one(): use proper errnos
drivers/block/paride/pg.c: underflow bug in pg_write()
drivers/block/sx8.c: remove unnecessary pci_set_drvdata()
drivers/block/sx8.c: use module_pci_driver()
floppy: bail out in open() if drive is not responding to block0 read
bcache: Fix auxiliary search trees for key size > cacheline size
bcache: Don't return -EINTR when insert finished
bcache: Improve bucket_prio() calculation
bcache: Add bch_bkey_equal_header()
bcache: update bch_bkey_try_merge
bcache: Move insert_fixup() to btree_keys_ops
bcache: Convert sorting to btree_keys
bcache: Convert debug code to btree_keys
bcache: Convert btree_iter to struct btree_keys
bcache: Refactor bset_tree sysfs stats
Pull core block IO changes from Jens Axboe:
"The major piece in here is the immutable bio_ve series from Kent, the
rest is fairly minor. It was supposed to go in last round, but
various issues pushed it to this release instead. The pull request
contains:
- Various smaller blk-mq fixes from different folks. Nothing major
here, just minor fixes and cleanups.
- Fix for a memory leak in the error path in the block ioctl code
from Christian Engelmayer.
- Header export fix from CaiZhiyong.
- Finally the immutable biovec changes from Kent Overstreet. This
enables some nice future work on making arbitrarily sized bios
possible, and splitting more efficient. Related fixes to immutable
bio_vecs:
- dm-cache immutable fixup from Mike Snitzer.
- btrfs immutable fixup from Muthu Kumar.
- bio-integrity fix from Nic Bellinger, which is also going to stable"
* 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits)
xtensa: fixup simdisk driver to work with immutable bio_vecs
block/blk-mq-cpu.c: use hotcpu_notifier()
blk-mq: for_each_* macro correctness
block: Fix memory leak in rw_copy_check_uvector() handling
bio-integrity: Fix bio_integrity_verify segment start bug
block: remove unrelated header files and export symbol
blk-mq: uses page->list incorrectly
blk-mq: use __smp_call_function_single directly
btrfs: fix missing increment of bi_remaining
Revert "block: Warn and free bio if bi_end_io is not set"
blk-mq: fix initializing request's start time
block: blk-mq: don't export blk_mq_free_queue()
block: blk-mq: make blk_sync_queue support mq
block: blk-mq: support draining mq queue
dm cache: increment bi_remaining when bi_end_io is restored
block: fixup for generic bio chaining
block: Really silence spurious compiler warnings
block: Silence spurious compiler warnings
block: Kill bio_pair_split()
Pull nfsd updates from Bruce Fields:
- Handle some loose ends from the vfs read delegation support.
(For example nfsd can stop breaking leases on its own in a
fewer places where it can now depend on the vfs to.)
- Make life a little easier for NFSv4-only configurations
(thanks to Kinglong Mee).
- Fix some gss-proxy problems (thanks Jeff Layton).
- miscellaneous bug fixes and cleanup
* 'for-3.14' of git://linux-nfs.org/~bfields/linux: (38 commits)
nfsd: consider CLAIM_FH when handing out delegation
nfsd4: fix delegation-unlink/rename race
nfsd4: delay setting current_fh in open
nfsd4: minor nfs4_setlease cleanup
gss_krb5: use lcm from kernel lib
nfsd4: decrease nfsd4_encode_fattr stack usage
nfsd: fix encode_entryplus_baggage stack usage
nfsd4: simplify xdr encoding of nfsv4 names
nfsd4: encode_rdattr_error cleanup
nfsd4: nfsd4_encode_fattr cleanup
minor svcauth_gss.c cleanup
nfsd4: better VERIFY comment
nfsd4: break only delegations when appropriate
NFSD: Fix a memory leak in nfsd4_create_session
sunrpc: get rid of use_gssp_lock
sunrpc: fix potential race between setting use_gss_proxy and the upcall rpc_clnt
sunrpc: don't wait for write before allowing reads from use-gss-proxy file
nfsd: get rid of unused function definition
Define op_iattr for nfsd4_open instead using macro
NFSD: fix compile warning without CONFIG_NFSD_V3
Chris Mason reported a NULL pointer derefernence in generic_getxattr()
that was due to sb->s_xattr being NULL.
The reason is that the nfs #ifdef's for ACL support were misplaced, and
the nfs3 inode operations had the xattr operation pointers set up, even
though xattrs were not actually supported. As a result, the xattr code
was being called without the infrastructure having been set up.
Move the #ifdef's appropriately.
Reported-and-tested-by: Chris Mason <clm@fb.com>
Acked-by: Al Viro viro@zeniv.linux.org.uk>
Signed-off-by: Peter Rosin <peda@lysator.liu.se>
Merge random fixes from Andrew Morton:
"Random fixes.
I have one batch remaining for -rc1, mainly zram changes which await a
merge of Jens's trees"
* emailed patches fron Andrew Morton akpm@linux-foundation.org>:
MAINTAINERS: ADI Linux development mailing lists: change to the new server
Documentation: fix multiple typo occurences s/KenelVersion/KernelVersion/
dma-debug: fix overlap detection
memblock: add limit checking to memblock_virt_alloc
mm/readahead.c: fix do_readahead() for no readpage(s)
mm/slub.c: do not VM_BUG_ON_PAGE() for temporary on-stack pages
slab: fix wrong retval on kmem_cache_create_memcg error path
s390/compat: change parameter types from unsigned long to compat_ulong_t
fs/compat: fix lookup_dcookie() parameter handling
fs/compat: fix parameter handling for compat readv/writev syscalls
mm/mempolicy.c: convert to pr_foo()
mm: numa: initialise numa balancing after jump label initialisation
mm/page-writeback.c: do not count anon pages as dirtyable memory
mm/page-writeback.c: fix dirty_balance_reserve subtraction from dirtyable memory
mm: document improved handling of swappiness==0
lib/genalloc.c: add check gen_pool_dma_alloc() if dma pointer is not NULL
Commit d5dc77bfeeab ("consolidate compat lookup_dcookie()") coverted all
architectures to the new compat_sys_lookup_dcookie() syscall.
The "len" paramater of the new compat syscall must have the type
compat_size_t in order to enforce zero extension for architectures where
the ABI requires that the caller of a function performed zero and/or
sign extension to 64 bit of all parameters.
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> [v3.10+]
We got a report that the pwritev syscall does not work correctly in
compat mode on s390.
It turned out that with commit 72ec35163f9f ("switch compat readv/writev
variants to COMPAT_SYSCALL_DEFINE") we lost the zero extension of a
couple of syscall parameters because the some parameter types haven't
been converted from unsigned long to compat_ulong_t.
This is needed for architectures where the ABI requires that the caller
of a function performed zero and/or sign extension to 64 bit of all
parameters.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull fanotify use-after-free fixes from Jan Kara:
"Three fixes for the fanotify use after free problems guys were
reporting.
I have ended up with different lifetime rules for struct
fanotify_event_info depending on whether it is for permission event or
normal event which isn't ideal. My plan is to split these into two
different structures (as permission events need larger struct anyway)
which will make the rules trivial again. But that can wait for later
I guess (but I can add the patch to the pile if you want), now I
wanted to make -rc1 boot for these guys"
[ "These guys" being Jiri Kosina and Dave Jones that reported the slab
corruption issues due to incorrect object lifetimes ]
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
fanotify: Fix use after free for permission events
fsnotify: Do not return merged event from fsnotify_add_notify_event()
fanotify: Fix use after free in mask checking
The merge of commit 7221fe4c2ed7 ("ceph: add acl for cephfs") raced with
upstream changes in the generic POSIX ACL code (eg commit 2aeccbe957d0
"fs: add generic xattr_acl handlers" and others).
Some of the fallout was fixed in commit 4db658ea0ca ("ceph: Fix up after
semantic merge conflict"), but it was incomplete: the set_acl
inode_operation wasn't getting set, and the prototype needed to be
adjusted a bit (it doesn't take a dentry anymore).
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Our goto out should have gone a little farther.
Signed-off-by: Chris Mason <clm@fb.com>
We have a race during inode init because the BTRFS_I(inode)->location is setup
after the inode hash table lock is dropped. btrfs_find_actor uses the location
field, so our search might not find an existing inode in the hash table if we
race with the inode init code.
This commit changes things to setup the location field sooner. Also the find actor now
uses only the location objectid to match inodes. For inode hashing, we just
need a unique and stable test, it doesn't have to reflect the inode numbers we
show to userland.
CC: stable@vger.kernel.org
If we truncate an uncompressed inline item, ram_bytes isn't updated to reflect
the new size. The fixe uses the size directly from the item header when
reading uncompressed inlines, and also fixes truncate to update the
size as it goes.
Reported-by: Jens Axboe <axboe@fb.com>
If the current path's leaf slot is 0, we do search for the previous
leaf (via btrfs_prev_leaf) and set the new path's leaf slot to a
value corresponding to the number of items - 1 of the former leaf.
Fix this by using the slot set by btrfs_prev_leaf, decrementing it
by 1 if it's equal to the leaf's number of items.
Use of btrfs_search_slot_for_read() for backward iteration is used in
particular by the send feature, which could miss items when the input
leaf has less items than its previous leaf.
This could be reproduced by running btrfs/007 from xfstests in a loop.
Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com>
There are not any users that use ulist except Btrfs,don't
export them.
Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com>
Reviewed-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Josef Bacik <jbacik@fb.com>
We are really suffering from now ulist's implementation, some developers
gave their try, and i just gave some of my ideas for things:
1. use list+rb_tree instead of arrary+rb_tree
2. add cur_list to iterator rather than ulist structure.
3. add seqnum into every node when they are added, this is
used to do selfcheck when iterating node.
I noticed Zach Brown's comments before, long term is to kick off
ulist implementation, however, for now, we need at least avoid
arrary from ulist.
Cc: Liu Bo <bo.li.liu@oracle.com>
Cc: Josef Bacik <jbacik@fb.com>
Cc: Zach Brown <zab@redhat.com>
When walking backrefs, we may iterate every inode's extent
and add/merge them into ulist, and the caller will free memory
from ulist.
However, if we fail to allocate inode's extents element
memory or ulist_add() fail to allocate memory, we won't
add allocated memory into ulist, and the caller won't
free some allocated memory thus memory leaks happen.
There was a case where file hole detection was incorrect and it would
cause an incremental send to override a section of a file with zeroes.
This happened in the case where between the last leaf we processed which
contained a file extent item for our current inode and the leaf we're
currently are at (and has a file extent item for our current inode) there
are only leafs containing exclusively file extent items for our current
inode, and none of them was updated since the previous send operation.
The file hole detection code would incorrectly consider the file range
covered by these leafs as a hole.
A test case for xfstests follows soon.
I can easily trigger the following warnings when enabling quota
in my virtual machine(running Opensuse), Steps are firstly creating
a subvolume full of fragment extents, and then create many snapshots
(500 in my test case).
[ 2362.808459] BUG: soft lockup - CPU#0 stuck for 22s! [btrfs-qgroup-re:1970]
[ 2362.809023] task: e4af8450 ti: e371c000 task.ti: e371c000
[ 2362.809026] EIP: 0060:[<fa38f4ae>] EFLAGS: 00000246 CPU: 0
[ 2362.809049] EIP is at __merge_refs+0x5e/0x100 [btrfs]
[ 2362.809051] EAX: 00000000 EBX: cfadbcf0 ECX: 00000000 EDX: cfadbcb0
[ 2362.809052] ESI: dd8d3370 EDI: e371dde0 EBP: e371dd6c ESP: e371dd5c
[ 2362.809054] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 2362.809055] CR0: 80050033 CR2: ac454d50 CR3: 009a9000 CR4: 001407d0
[ 2362.809099] Stack:
[ 2362.809100] 00000001 e371dde0 dfcc6890 f29f8000 e371de28 fa39016d 00000011 00000001
[ 2362.809105] 99bfc000 00000000 93928000 00000000 00000001 00000050 e371dda8 00000001
[ 2362.809109] f3a31000 f3413000 00000001 e371ddb8 000040a8 00000202 00000000 00000023
[ 2362.809113] Call Trace:
[ 2362.809136] [<fa39016d>] find_parent_nodes+0x34d/0x1280 [btrfs]
[ 2362.809156] [<fa391172>] btrfs_find_all_roots+0xb2/0x110 [btrfs]
[ 2362.809174] [<fa3934a8>] btrfs_qgroup_rescan_worker+0x358/0x7a0 [btrfs]
[ 2362.809180] [<c024d0ce>] ? lock_timer_base.isra.39+0x1e/0x40
[ 2362.809199] [<fa3648df>] worker_loop+0xff/0x470 [btrfs]
[ 2362.809204] [<c027a88a>] ? __wake_up_locked+0x1a/0x20
[ 2362.809221] [<fa3647e0>] ? btrfs_queue_worker+0x2b0/0x2b0 [btrfs]
[ 2362.809225] [<c025ebbc>] kthread+0x9c/0xb0
[ 2362.809229] [<c06b487b>] ret_from_kernel_thread+0x1b/0x30
[ 2362.809233] [<c025eb20>] ? kthread_create_on_node+0x110/0x110
By adding a reschedule point at the end of btrfs_find_all_roots(), i no longer
hit these warnings.
Instead of looking for a file extent item, process it, release the path
and do a btree search for the next file extent item, just process all
file extent items in a leaf without intermediate btree searches. This way
we save cpu and we're not blocking other tasks or affecting concurrency on
the btree, because send's paths use the commit root and skip btree node/leaf
locking.
We can only tolerate ENOENT here, for other errors, we should
return directly.
There is a race condition between resolving indirect ref and root deletion,
and we should gurantee that root can not be destroyed to avoid accessing
broken tree here.
Here we fix it by holding @subvol_srcu, and we will release it as soon
as we have held root node lock.
When we have two adjacent extents in relink_extent_backref,
we try to merge them. When we use btrfs_search_slot to locate the
slot for the current extent, we shouldn't set "ins_len = 1",
because we will merge it into the previous extent rather than
insert a new item. Otherwise, we may happen to create a new leaf
in btrfs_search_slot and path->slot[0] will be 0. Then we try to
fetch the previous item using "path->slots[0]--", and it will cause
a warning as follows:
[ 145.713385] WARNING: CPU: 3 PID: 1796 at fs/btrfs/extent_io.c:5043 map_private_extent_buffer+0xd4/0xe0
[ 145.713387] btrfs bad mapping eb start 5337088 len 4096, wanted 167772306 8
[ 145.713462] [<ffffffffa034b1f4>] map_private_extent_buffer+0xd4/0xe0
[ 145.713476] [<ffffffffa030097a>] ? btrfs_free_path+0x2a/0x40
[ 145.713485] [<ffffffffa0340864>] btrfs_get_token_64+0x64/0xf0
[ 145.713498] [<ffffffffa033472c>] relink_extent_backref+0x41c/0x820
[ 145.713508] [<ffffffffa0334d69>] btrfs_finish_ordered_io+0x239/0xa80
I encounter this warning when running defrag having mkfs.btrfs
with option -M. At the same time there are read/writes & snapshots
running at background.
Signed-off-by: Gui Hecheng <guihc.fnst@cn.fujitsu.com>
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
The send operation processes inodes by their ascending number, and assumes
that any rename/move operation can be successfully performed (sent to the
caller) once all previous inodes (those with a smaller inode number than the
one we're currently processing) were processed.
This is not true when an incremental send had to process an hierarchical change
between 2 snapshots where the parent-children relationship between directory
inodes was reversed - that is, parents became children and children became
parents. This situation made the path building code go into an infinite loop,
which kept allocating more and more memory that eventually lead to a krealloc
warning being displayed in dmesg:
WARNING: CPU: 1 PID: 5705 at mm/page_alloc.c:2477 __alloc_pages_nodemask+0x365/0xad0()
Modules linked in: btrfs raid6_pq xor pci_stub vboxpci(O) vboxnetadp(O) vboxnetflt(O) vboxdrv(O) snd_hda_codec_hdmi snd_hda_codec_realtek joydev radeon snd_hda_intel snd_hda_codec snd_hwdep snd_seq_midi snd_pcm psmouse i915 snd_rawmidi serio_raw snd_seq_midi_event lpc_ich snd_seq snd_timer ttm snd_seq_device rfcomm drm_kms_helper parport_pc bnep bluetooth drm ppdev snd soundcore i2c_algo_bit snd_page_alloc binfmt_misc video lp parport r8169 mii hid_generic usbhid hid
CPU: 1 PID: 5705 Comm: btrfs Tainted: G O 3.13.0-rc7-fdm-btrfs-next-18+ #3
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./Z77 Pro4, BIOS P1.50 09/04/2012
[ 5381.660441] 00000000000009ad ffff8806f6f2f4e8 ffffffff81777434 0000000000000007
[ 5381.660447] 0000000000000000 ffff8806f6f2f528 ffffffff8104a9ec ffff8807038f36f0
[ 5381.660452] 0000000000000000 0000000000000206 ffff8807038f2490 ffff8807038f36f0
[ 5381.660457] Call Trace:
[ 5381.660464] [<ffffffff81777434>] dump_stack+0x4e/0x68
[ 5381.660471] [<ffffffff8104a9ec>] warn_slowpath_common+0x8c/0xc0
[ 5381.660476] [<ffffffff8104aa3a>] warn_slowpath_null+0x1a/0x20
[ 5381.660480] [<ffffffff81144995>] __alloc_pages_nodemask+0x365/0xad0
[ 5381.660487] [<ffffffff8108313f>] ? local_clock+0x4f/0x60
[ 5381.660491] [<ffffffff811430e8>] ? free_one_page+0x98/0x440
[ 5381.660495] [<ffffffff8108313f>] ? local_clock+0x4f/0x60
[ 5381.660502] [<ffffffff8113fae4>] ? __get_free_pages+0x14/0x50
[ 5381.660508] [<ffffffff81095fb8>] ? trace_hardirqs_off_caller+0x28/0xd0
[ 5381.660515] [<ffffffff81183caf>] alloc_pages_current+0x10f/0x1f0
[ 5381.660520] [<ffffffff8113fae4>] ? __get_free_pages+0x14/0x50
[ 5381.660524] [<ffffffff8113fae4>] __get_free_pages+0x14/0x50
[ 5381.660530] [<ffffffff8115dace>] kmalloc_order_trace+0x3e/0x100
[ 5381.660536] [<ffffffff81191ea0>] __kmalloc_track_caller+0x220/0x230
[ 5381.660560] [<ffffffffa0729fdb>] ? fs_path_ensure_buf.part.12+0x6b/0x200 [btrfs]
[ 5381.660564] [<ffffffff8178085c>] ? retint_restore_args+0xe/0xe
[ 5381.660569] [<ffffffff811580ef>] krealloc+0x6f/0xb0
[ 5381.660586] [<ffffffffa0729fdb>] fs_path_ensure_buf.part.12+0x6b/0x200 [btrfs]
[ 5381.660601] [<ffffffffa072a208>] fs_path_prepare_for_add+0x98/0xb0 [btrfs]
[ 5381.660615] [<ffffffffa072a2bc>] fs_path_add_path+0x2c/0x60 [btrfs]
[ 5381.660628] [<ffffffffa072c55c>] get_cur_path+0x7c/0x1c0 [btrfs]
Even without this loop, the incremental send couldn't succeed, because it would attempt
to send a rename/move operation for the lower inode before the highest inode number was
renamed/move. This issue is easy to trigger with the following steps:
$ mkfs.btrfs -f /dev/sdb3
$ mount /dev/sdb3 /mnt/btrfs
$ mkdir -p /mnt/btrfs/a/b/c/d
$ mkdir /mnt/btrfs/a/b/c2
$ btrfs subvol snapshot -r /mnt/btrfs /mnt/btrfs/snap1
$ mv /mnt/btrfs/a/b/c/d /mnt/btrfs/a/b/c2/d2
$ mv /mnt/btrfs/a/b/c /mnt/btrfs/a/b/c2/d2/cc
$ btrfs subvol snapshot -r /mnt/btrfs /mnt/btrfs/snap2
$ btrfs send -p /mnt/btrfs/snap1 /mnt/btrfs/snap2 > /tmp/incremental.send
The structure of the filesystem when the first snapshot is taken is:
. (ino 256)
|-- a (ino 257)
|-- b (ino 258)
|-- c (ino 259)
| |-- d (ino 260)
|-- c2 (ino 261)
And its structure when the second snapshot is taken is:
. (ino 256)
|-- a (ino 257)
|-- b (ino 258)
|-- c2 (ino 261)
|-- d2 (ino 260)
|-- cc (ino 259)
Before the move/rename operation is performed for the inode 259, the
move/rename for inode 260 must be performed, since 259 is now a child
of 260.
A test case for xfstests, with a more complex scenario, will follow soon.
Currently struct fanotify_event_info has been destroyed immediately
after reporting its contents to userspace. However that is wrong for
permission events because those need to stay around until userspace
provides response which is filled back in fanotify_event_info. So change
to code to free permission events only after we have got the response
from userspace.
Reported-and-tested-by: Jiri Kosina <jkosina@suse.cz>
Reported-and-tested-by: Dave Jones <davej@fedoraproject.org>
The event returned from fsnotify_add_notify_event() cannot ever be used
safely as the event may be freed by the time the function returns (after
dropping notification_mutex). So change the prototype to just return
whether the event was added or merged into some existing event.
We cannot use the event structure returned from
fsnotify_add_notify_event() because that event can be freed by the time
that function returns. Use the mask argument passed into the event
handler directly instead. This also fixes a possible problem when we
could unnecessarily wait for permission response for a normal fanotify
event which got merged with a permission event.
We also disallow merging of permission event with any other event so
that we know the permission event which we just created is the one on
which we should wait for permission response.
Pull MTD updates from Brian Norris:
- Add me (Brian Norris) as an additional MTD maintainer (it'd be nice to get
David's "ack" for this; I'm sure he approves, but he's been pretty silent
lately)
- Add Ezequiel Garcie as maintainer for the pxa3xx NAND driver
- Last (?) round of pxa3xx improvements for supporting Armada 370/XP
- Typical churn in driver boilerplate (OOM messages, printk()'s, devm_*, etc.)
- Quad read mode support for SPI NOR driver (m25p80)
- Update Davinci NAND driver to prepare for use on new platforms
- Begin to kill off NAND_MAX_{PAGE,OOB}SIZE macros; more work is pending
- Miscellaneous NAND device support (new IDs)
- Add READ RETRY support for Micron MLC NAND
- Support new GPMI NAND ECC layout device-tree binding
- Avoid mapping stack/vmalloc() memory for GPMI NAND DMA
* tag 'for-linus-20140127' of git://git.infradead.org/linux-mtd: (151 commits)
mtd: gpmi: add sanity check when mapping DMA for read_buf/write_buf
mtd: gpmi: allocate a proper buffer for non ECC read/write
mtd: m25p80: Set rx_nbits for Quad SPI transfers
mtd: m25p80: Enable Quad SPI read transfers for s25fl512s
mtd: s3c2410: Merge plat/regs-nand.h into s3c2410.c
mtd: mtdram: add missing 'const'
mtd: m25p80: assign default read command
mtd: nuc900_nand: remove redundant return value check of platform_get_resource()
mtd: plat_nand: remove redundant return value check of platform_get_resource()
mtd: nand: add Intel manufacturer ID
mtd: nand: add SanDisk manufacturer ID
mtd: nand: add support for Samsung K9LCG08U0B
mtd: nand: pxa3xx: Add support for 2048 bytes page size devices
mtd: m25p80: Use OPCODE_QUAD_READ_4B for 4-byte addressing
mtd: nand: don't use {read,write}_buf for 8-bit transfers
mtd: nand: use __packed shorthand
mtd: nand: support Micron READ RETRY
mtd: nand: add generic READ RETRY support
mtd: nand: add ONFI vendor block for Micron
mtd: nand: localize ECC failures per page
Pull second xfs update from Ben Myers:
"Allow logical sector sized direct io on 'advanced format' 4k/512 disk"
* tag 'xfs-for-linus-v3.14-rc1-2' of git://oss.sgi.com/xfs/xfs:
xfs: allow logical-sector sized O_DIRECT
xfs: rename xfs_buftarg structure members
xfs: clean up xfs_buftarg
The previous ceph-client merge resulted in ceph not even building,
because there was a merge conflict that wasn't visible as an actual data
conflict: commit 7221fe4c2ed7 ("ceph: add acl for cephfs") added support
for POSIX ACL's into Ceph, but unluckily we also had the VFS tree change
a lot of the POSIX ACL helper functions to be much more helpful to
filesystems (see for example commits 2aeccbe957d0 "fs: add generic
xattr_acl handlers", 5bf3258fd2ac "fs: make posix_acl_chmod more useful"
and 37bc15392a23 "fs: make posix_acl_create more useful")
The reason this conflict wasn't obvious was many-fold: because it was a
semantic conflict rather than a data conflict, it wasn't visible in the
git merge as a conflict. And because the VFS tree hadn't been in
linux-next, people hadn't become aware of it that way. And because I
was at jury duty this morning, I was using my laptop and as a result not
doing constant "allmodconfig" builds.
Anyway, this fixes the build and generally removes a fair chunk of the
Ceph POSIX ACL support code, since the improved helpers seem to match
really well for Ceph too. But I don't actually have any way to *test*
the end result, and I was really hoping for some ACK's for this. Oh,
well.
Not compiling certainly doesn't make things easier to test, so I'm
committing this without the acks after having waited for four hours...
Plus it's what I would have done for the merge had I noticed the
semantic conflict..
Reported-by: Dave Jones <davej@redhat.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Guangliang Zhao <lucienchao@gmail.com>
Cc: Li Wang <li.wang@ubuntykylin.com>
reproducer:
mkfs.btrfs -f /dev/sdb &&\
mount /dev/sdb /btrfs &&\
btrfs dev add -f /dev/sdc /btrfs &&\
umount /btrfs &&\
wipefs -a /dev/sdc &&\
mount -o degraded /dev/sdb /btrfs
//above mount fails so try with RO
mount -o degraded,ro /dev/sdb /btrfs
sysfs: cannot create duplicate filename '/fs/btrfs/3f48c79e-5ed0-4e87-b189-86e749e503f4'
dump_stack+0x49/0x5e
warn_slowpath_common+0x87/0xb0
warn_slowpath_fmt+0x41/0x50
strlcat+0x69/0x80
sysfs_warn_dup+0x87/0xa0
sysfs_add_one+0x40/0x50
create_dir+0x76/0xc0
sysfs_create_dir_ns+0x7a/0xc0
kobject_add_internal+0xad/0x220
kobject_add_varg+0x38/0x60
kobject_init_and_add+0x53/0x70
mutex_lock+0x11/0x40
__free_pages+0x25/0x30
free_pages+0x41/0x50
selinux_sb_copy_data+0x14e/0x1e0
mount_fs+0x3e/0x1a0
vfs_kern_mount+0x71/0x120
do_mount+0x3f7/0x980
SyS_mount+0x8b/0xe0
system_call_fastpath+0x16/0x1b
further 'modprobe -r btrfs' fails as well
Signed-off-by: Anand Jain <anand.jain@oracle.com>
The buffer size argument passed to snprintf must account for the
trailing null byte added by snprintf, and it returns a value >= then
sizeof(buffer) when the string can't fit in the buffer.
Since our buffer has a size of 64 characters, and the maximum orphan
name we can generate is 63 characters wide, we must pass 64 as the
buffer size to snprintf, and not 63.
When defragging a very large file, the cluster variable can wrap its 32-bit
signed int type and become negative, which eventually gets passed to
btrfs_force_ra() as a very large unsigned long value. On 32-bit platforms,
this eventually results in an Oops from the SLAB allocator.
Change the cluster and max_cluster signed int variables to unsigned long to
match the readahead functions. This also allows the min() comparison in
btrfs_defrag_file() to work as intended.
Signed-off-by: David Sterba <dsterba@suse.cz>
The COMPRESS_LZOv2 incompat featue is currently not implemented, the bit
is only reserved, no point to list it in sysfs.
The owner and capability checks in IOC_SUBVOL_SETFLAGS and
SET_RECEIVED_SUBVOL should be called before any other checks are done.
Also unify the error code to EPERM.
Currently, any user can snapshot any subvolume if the path is accessible and
thus indirectly create and keep files he does not own under his direcotries.
This is not possible with traditional directories.
In security context, a user can snapshot root filesystem and pin any
potentially buggy binaries, even if the updates are applied.
All the snapshots are visible to the administrator, so it's possible to
verify if there are suspicious snapshots.
Another more practical problem is that any user can pin the space used
by eg. root and cause ENOSPC.
Original report:
https://bugs.launchpad.net/ubuntu/+source/apparmor/+bug/484786
We allocate the free space from the former block group, not the current
one, so should use the former one to output the trace information.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
used_block_group is just used for the space cluster which doesn't
belong to the current block group, the other place needn't use it.
Or the logic of code seems unclear.
cache miss
It is better that the position of the lock is close to the data which is
protected by it, because they may be in the same cache line, we will load
less cache lines when we access them. So we rearrange the members' position
of btrfs_space_info structure to make the lock be closer to the its data.
To search tree root without transaction protection, we should neither search commit
root nor skip locking here, fix it.
logging csum
The performance of fsync dropped down suddenly sometimes, the main reason
of this problem was that we might only flush part dirty pages in a ordered
extent, then got that ordered extent, wait for the csum calcucation. But if
no task flushed the left part, we would wait until the flusher flushed them,
sometimes we need wait for several seconds, it made the performance drop
down suddenly. (On my box, it drop down from 56MB/s to 4-10MB/s)
This patch improves the above problem by flushing left dirty pages aggressively.
Test Environment:
CPU: 2CPU * 2Cores
Memory: 4GB
Partition: 20GB(HDD)
Test Command:
# sysbench --num-threads=8 --test=fileio --file-num=1 \
> --file-total-size=8G --file-block-size=32768 \
> --file-io-mode=sync --file-fsync-freq=100 \
> --file-fsync-end=no --max-requests=10000 \
> --file-test-mode=rndwr run
Steps to reproduce:
# mkfs.btrfs -f /dev/sda8
# mount /dev/sda8 /mnt -o flushoncommit
# dd if=/dev/zero of=/mnt/data bs=4k count=102400 &
# mount /dev/sda8 /mnt -o remount, ro
When remounting RW to RO, the logic is to firstly set flag
to RO and then commit transaction, however with option
flushoncommit enabled,we will do RO check within committing
transaction, so we get a transaction abortion here.
Actually,here check is wrong, we should check if FS_STATE_ERROR
is set, fix it.
Reported-by: Qu Wenruo <quwenruo@cn.fujitsu.com>
Suggested-by: Miao Xie <miaox@cn.fujitsu.com>
When we are looking for file extent items that intersect the cloning
range, for each one that falls completely outside the range, don't
release the path and do another full tree search - just move on
to the next slot and copy the file extent item into our buffer only
if the item intersects the cloning range.
