path: root/fs
2009-01-18nfs: remove redundant tests on reading new pagesWu Fengguang
commit 136221fc3219b3805c48db5da065e8e3467175d4 upstream. aops->readpages() and its NFS helper readpage_async_filler() will only be called to do readahead I/O for newly allocated pages. So it's not necessary to test for the always 0 dirty/uptodate page flags. The removal of nfs_wb_page() call also fixes a readahead bug: the NFS readahead has been synchronous since 2.6.23, because that call will clear PG_readahead, which is the reminder for asynchronous readahead. More background: the PG_readahead page flag is shared with PG_reclaim, one for read path and the other for write path. clear_page_dirty_for_io() unconditionally clears PG_readahead to prevent possible readahead residuals, assuming itself to be always called in the write path. However, NFS is one and the only exception in that it _always_ calls clear_page_dirty_for_io() in the read path, i.e. for readpages()/readpage(). Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18fs: symlink write_begin allocation context fixNick Piggin
commit 54566b2c1594c2326a645a3551f9d989f7ba3c5e upstream. With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18fix switch_names() breakage in short-to-short caseAl Viro
commit dc711ca35f9d95a1eec02118e0c298b5e3068315 upstream. We want ->name.len to match the resulting name on *both* source and target Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18eCryptfs: check readlink result was not an error before using itDuane Griffin
commit a17d5232de7b53d34229de79ec22f4bb04adb7e4 upstream. The result from readlink is being used to index into the link name buffer without checking whether it is a valid length. If readlink returns an error this will fault or cause memory corruption. Cc: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Cc: Dustin Kirkland <kirkland@canonical.com> Cc: ecryptfs-devel@lists.launchpad.net Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 33Heiko Carstens
commit 2b66421995d2e93c9d1a0111acf2581f8529c6e5 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 32Heiko Carstens
commit d4e82042c4cfa87a7d51710b71f568fe80132551 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 31Heiko Carstens
commit 836f92adf121f806e9beb5b6b88bd5c9c4ea3f24 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 30Heiko Carstens
commit 6559eed8ca7db0531a207cd80be5e28cd6f213c5 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 29Heiko Carstens
commit 2e4d0924eb0c403ce4014fa139d1d61bf2c44fee upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 28Heiko Carstens
commit 938bb9f5e840eddbf54e4f62f6c5ba9b3ae12c9d upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 27Heiko Carstens
commit 1e7bfb2134dfec37ce04fb3a4ca89299e892d10c upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 23Heiko Carstens
commit 5a8a82b1d306a325d899b67715618413657efda4 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 21Heiko Carstens
commit 20f37034fb966a1c35894f9fe529fda0b6440101 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 20Heiko Carstens
commit 3cdad42884bbd95d5aa01297e8236ea1bad70053 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 19Heiko Carstens
commit 003d7ab479168132a2b2c6700fe682b08f08ab0c upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 17Heiko Carstens
commit ca013e945b1ba5828b151ee646946f1297b67a4c upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 16Heiko Carstens
commit 002c8976ee537724b20a5e179d9b349309438836 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 15Heiko Carstens
commit a26eab2400f0477bfac0255600552394855016f7 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 14Heiko Carstens
commit 3480b25743cb7404928d57efeaa3d085708b04c2 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 13Heiko Carstens
commit 6a6160a7b5c27b3c38651baef92a14fa7072b3c1 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 12Heiko Carstens
commit 64fd1de3d821659ac0a3004fd5ee1de59e64af30 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 11Heiko Carstens
commit 257ac264d69017270fbc3cf5536953525db4076c upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 10Heiko Carstens
commit bdc480e3bef6eb0e7071770834cbdda7e30a5436 upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrappers part 09Heiko Carstens
commit a5f8fa9e9ba5ef3305e147f41ad6e1e84ac1f0bd upstream. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18System call wrapper special casesHeiko Carstens
commit 6673e0c3fbeaed2cd08e2fd4a4aa97382d6fedb0 upstream. System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18Make sys_pselect7 staticHeiko Carstens
commit c9da9f2129d6a421c32e334a83770a9e67f7feac upstream. Not a single architecture has wired up sys_pselect7 plus it is the only system call with seven parameters. Just make it static and rename it to do_pselect which will do the work for sys_pselect6. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18Remove __attribute__((weak)) from sys_pipe/sys_pipe2Heiko Carstens
commit 1134723e96f6e2abcf8bfd7a2d1c96fcc323ef35 upstream. Remove __attribute__((weak)) from common code sys_pipe implemantation. IA64, ALPHA, SUPERH (32bit) and SPARC (32bit) have own implemantations with the same name. Just rename them. For sys_pipe2 there is no architecture specific implementation. Cc: Richard Henderson <rth@twiddle.net> Cc: David S. Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18Rename old_readdir to sys_old_readdirHeiko Carstens
commit e55380edf68796d75bf41391a781c68ee678587d upstream. This way it matches the generic system call name convention. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18Convert all system calls to return a longHeiko Carstens
commit 2ed7c03ec17779afb4fcfa3b8c61df61bd4879ba upstream. Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18inotify: fix type errors in interfacesMichael Kerrisk
commit 4ae8978cf92a96257cd8998a49e781be83571d64 upstream. The problems lie in the types used for some inotify interfaces, both at the kernel level and at the glibc level. This mail addresses the kernel problem. I will follow up with some suggestions for glibc changes. For the sys_inotify_rm_watch() interface, the type of the 'wd' argument is currently 'u32', it should be '__s32' . That is Robert's suggestion, and is consistent with the other declarations of watch descriptors in the kernel source, in particular, the inotify_event structure in include/linux/inotify.h: struct inotify_event { __s32 wd; /* watch descriptor */ __u32 mask; /* watch mask */ __u32 cookie; /* cookie to synchronize two events */ __u32 len; /* length (including nulls) of name */ char name[0]; /* stub for possible name */ }; The patch makes the changes needed for inotify_rm_watch(). Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Robert Love <rlove@google.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-18minix: fix add link's wrong position calculationEvgeniy Dushistov
commit d6b54841f4ddd836c886d1e6ac381cf309ee98a3 upstream. Fix the add link method. The oosition in the directory was calculated in wrong way - it had the incorrect shift direction. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13XFS: Fix hang after disallowed rename across directory quota domainsDave Chinner
commit 576a488a27f267af203f3ea69c700a1612335e9f upstream. When project quota is active and is being used for directory tree quota control, we disallow rename outside the current directory tree. This requires a check to be made after all the inodes involved in the rename are locked. We fail to unlock the inodes correctly if we disallow the rename when the target is outside the current directory tree. This results in a hang on the next access to the inodes involved in failed rename. Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Dave Chinner <david@fromorbit.com> Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13cifs: fix a regression in cifs umount codepathJeff Layton
backport of 469ee614aaa367d9cde01cbdd2027212f56c6cc6 upstream. Several cifs patches were added to 2.6.27.8 to fix some races in the mount/umount codepath. When this was done, a couple of prerequisite patches were missed causing a minor regression. When the last cifs mount to a server goes away, the kthread that manages the socket is supposed to come down. The patches that went into 2.6.27.8 removed the kthread_stop calls that used to take down these threads, but left the thread function expecting them. This made the thread stay up even after the last mount was gone. This patch should fix up this regression and also prevent a possible race where a dead task could be signalled. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13tracehook: exec double-reporting fixRoland McGrath
commit 85f334666a771680472722eee43ae0fc8730a619 upstream. The patch 6341c39 "tracehook: exec" introduced a small regression in 2.6.27 regarding binfmt_misc exec event reporting. Since the reporting is now done in the common search_binary_handler() function, an exec of a misc binary will result in two (or possibly multiple) exec events being reported, instead of just a single one, because the misc handler contains a recursive call to search_binary_handler. To add to the confusion, if PTRACE_O_TRACEEXEC is not active, the multiple SIGTRAP signals will in fact cause only a single ptrace intercept, as the signals are not queued. However, if PTRACE_O_TRACEEXEC is on, the debugger will actually see multiple ptrace intercepts (PTRACE_EVENT_EXEC). The test program included below demonstrates the problem. This change fixes the bug by calling tracehook_report_exec() only in the outermost search_binary_handler() call (bprm->recursion_depth == 0). The additional change to restore bprm->recursion_depth after each binfmt load_binary call is actually superfluous for this bug, since we test the value saved on entry to search_binary_handler(). But it keeps the use of of the depth count to its most obvious expected meaning. Depending on what binfmt handlers do in certain cases, there could have been false-positive tests for recursion limits before this change. /* Test program using PTRACE_O_TRACEEXEC. This forks and exec's the first argument with the rest of the arguments, while ptrace'ing. It expects to see one PTRACE_EVENT_EXEC stop and then a successful exit, with no other signals or events in between. Test for kernel doing two PTRACE_EVENT_EXEC stops for a binfmt_misc exec: $ gcc -g traceexec.c -o traceexec $ sudo sh -c 'echo :test:M::foobar::/bin/cat: > /proc/sys/fs/binfmt_misc/register' $ echo 'foobar test' > ./foobar $ chmod +x ./foobar $ ./traceexec ./foobar; echo $? ==> good <== foobar test 0 $ ==> bad <== foobar test unexpected status 0x4057f != 0 3 $ */ #include <stdio.h> #include <sys/types.h> #include <sys/wait.h> #include <sys/ptrace.h> #include <unistd.h> #include <signal.h> #include <stdlib.h> static void wait_for (pid_t child, int expect) { int status; pid_t p = wait (&status); if (p != child) { perror ("wait"); exit (2); } if (status != expect) { fprintf (stderr, "unexpected status %#x != %#x\n", status, expect); exit (3); } } int main (int argc, char **argv) { pid_t child = fork (); if (child < 0) { perror ("fork"); return 127; } else if (child == 0) { ptrace (PTRACE_TRACEME); raise (SIGUSR1); execv (argv[1], &argv[1]); perror ("execve"); _exit (127); } wait_for (child, W_STOPCODE (SIGUSR1)); if (ptrace (PTRACE_SETOPTIONS, child, 0L, (void *) (long) PTRACE_O_TRACEEXEC) != 0) { perror ("PTRACE_SETOPTIONS"); return 4; } if (ptrace (PTRACE_CONT, child, 0L, 0L) != 0) { perror ("PTRACE_CONT"); return 5; } wait_for (child, W_STOPCODE (SIGTRAP | (PTRACE_EVENT_EXEC << 8))); if (ptrace (PTRACE_CONT, child, 0L, 0L) != 0) { perror ("PTRACE_CONT"); return 6; } wait_for (child, W_EXITCODE (0, 0)); return 0; } Reported-by: Arnd Bergmann <arnd@arndb.de> CC: Ulrich Weigand <ulrich.weigand@de.ibm.com> Signed-off-by: Roland McGrath <roland@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13Allow recursion in binfmt_script and binfmt_miscKirill A. Shutemov
commit bf2a9a39639b8b51377905397a5005f444e9a892 upstream. binfmt_script and binfmt_misc disallow recursion to avoid stack overflow using sh_bang and misc_bang. It causes problem in some cases: $ echo '#!/bin/ls' > /tmp/t0 $ echo '#!/tmp/t0' > /tmp/t1 $ echo '#!/tmp/t1' > /tmp/t2 $ chmod +x /tmp/t* $ /tmp/t2 zsh: exec format error: /tmp/t2 Similar problem with binfmt_misc. This patch introduces field 'recursion_depth' into struct linux_binprm to track recursion level in binfmt_misc and binfmt_script. If recursion level more then BINPRM_MAX_RECURSION it generates -ENOEXEC. [akpm@linux-foundation.org: make linux_binprm.recursion_depth a uint] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13pagemap: fix 32-bit pagemap regressionMatt Mackall
commit 49c50342c728344b79c8f9e8293637fe80ef5ad5 upstream. The large pages fix from bcf8039ed45 broke 32-bit pagemap by pulling the pagemap entry code out into a function with the wrong return type. Pagemap entries are 64 bits on all systems and unsigned long is only 32 bits on 32-bit systems. Signed-off-by: Matt Mackall <mpm@selenic.com> Reported-by: Doug Graham <dgraham@nortel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13jbd: test BH_Write_EIO to detect errors on metadata buffersHidehiro Kawai
commit 9f818b4ac04f53458d0354950b4f229f54be4dbf upstream. __try_to_free_cp_buf(), __process_buffer(), and __wait_cp_io() test BH_Uptodate flag to detect write I/O errors on metadata buffers. But by commit 95450f5a7e53d5752ce1a0d0b8282e10fe745ae0 "ext3: don't read inode block if the buffer has a write error"(*), BH_Uptodate flag can be set to inode buffers with BH_Write_EIO in order to avoid reading old inode data. So now, we have to test BH_Write_EIO flag of checkpointing inode buffers instead of BH_Uptodate. This patch does it. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13jbd: fix error handling for checkpoint ioHidehiro Kawai
commit 4afe978530702c934dfdb11f54073136818b2119 upstream. When a checkpointing IO fails, current JBD code doesn't check the error and continue journaling. This means latest metadata can be lost from both the journal and filesystem. This patch leaves the failed metadata blocks in the journal space and aborts journaling in the case of log_do_checkpoint(). To achieve this, we need to do: 1. don't remove the failed buffer from the checkpoint list where in the case of __try_to_free_cp_buf() because it may be released or overwritten by a later transaction 2. log_do_checkpoint() is the last chance, remove the failed buffer from the checkpoint list and abort the journal 3. when checkpointing fails, don't update the journal super block to prevent the journaled contents from being cleaned. For safety, don't update j_tail and j_tail_sequence either 4. when checkpointing fails, notify this error to the ext3 layer so that ext3 don't clear the needs_recovery flag, otherwise the journaled contents are ignored and cleaned in the recovery phase 5. if the recovery fails, keep the needs_recovery flag 6. prevent cleanup_journal_tail() from being called between __journal_drop_transaction() and journal_abort() (a race issue between journal_flush() and __log_wait_for_space() Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13Fix a race condition in FASYNC handlingJonathan Corbet
commit 218d11a8b071b23b76c484fd5f72a4fe3306801e upstream. Changeset a238b790d5f99c7832f9b73ac8847025815b85f7 (Call fasync() functions without the BKL) introduced a race which could leave file->f_flags in a state inconsistent with what the underlying driver/filesystem believes. Revert that change, and also fix the same races in ioctl_fioasync() and ioctl_fionbio(). This is a minimal, short-term fix; the real fix will not involve the BKL. Reported-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05jbd: ordered data integrity fixHidehiro Kawai
commit 960a22ae60c8a723bd17da3b929fe0bcea6d007e upstream. In ordered mode, if a file data buffer being dirtied exists in the committing transaction, we write the buffer to the disk, move it from the committing transaction to the running transaction, then dirty it. But we don't have to remove the buffer from the committing transaction when the buffer couldn't be written out, otherwise it would miss the error and the committing transaction would not abort. This patch adds an error check before removing the buffer from the committing transaction. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext3: fix ext3 block reservation early ENOSPC issueMingming Cao
commit 46d01a225e694f1a4343beea44f1e85105aedd7e upstream. We could run into ENOSPC error on ext3, even when there is free blocks on the filesystem. The problem is triggered in the case the goal block group has 0 free blocks , and the rest block groups are skipped due to the check of "free_blocks < windowsz/2". Current code could fall back to non reservation allocation to prevent early ENOSPC after examing all the block groups with reservation on , but this code was bypassed if the reservation window is turned off already, which is true in this case. This patch fixed two issues: 1) We don't need to turn off block reservation if the goal block group has 0 free blocks left and continue search for the rest of block groups. Current code the intention is to turn off the block reservation if the goal allocation group has a few (some) free blocks left (not enough for make the desired reservation window),to try to allocation in the goal block group, to get better locality. But if the goal blocks have 0 free blocks, it should leave the block reservation on, and continues search for the next block groups,rather than turn off block reservation completely. 2) we don't need to check the window size if the block reservation is off. The problem was originally found and fixed in ext4. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext2: fix ext2 block reservation early ENOSPC issueMingming Cao
commit d707d31c972b657dfc2efefd0b99cc4e14223dab upstream. We could run into ENOSPC error on ext2, even when there is free blocks on the filesystem. The problem is triggered in the case the goal block group has 0 free blocks , and the rest block groups are skipped due to the check of "free_blocks < windowsz/2". Current code could fall back to non reservation allocation to prevent early ENOSPC after examing all the block groups with reservation on , but this code was bypassed if the reservation window is turned off already, which is true in this case. This patch fixed two issues: 1) We don't need to turn off block reservation if the goal block group has 0 free blocks left and continue search for the rest of block groups. Current code the intention is to turn off the block reservation if the goal allocation group has a few (some) free blocks left (not enough for make the desired reservation window),to try to allocation in the goal block group, to get better locality. But if the goal blocks have 0 free blocks, it should leave the block reservation on, and continues search for the next block groups,rather than turn off block reservation completely. 2) we don't need to check the window size if the block reservation is off. The problem was originally found and fixed in ext4. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext3: don't try to resize if there are no reserved gdt blocks leftJosef Bacik
commit 972fbf779832e5ad15effa7712789aeff9224c37 upstream. When trying to resize a ext3 fs and you run out of reserved gdt blocks, you get an error that doesn't actually tell you what went wrong, it just says that the gdb it picked is not correct, which is the case since you don't have any reserved gdt blocks left. This patch adds a check to make sure you have reserved gdt blocks to use, and if not prints out a more relevant error. Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Andreas Dilger <adilger@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext3: Fix duplicate entries returned from getdents() system callTheodore Ts'o
commit 8c9fa93d51123c5540762b1a9e1919d6f9c4af7c upstream. Fix a regression caused by commit 6a897cf4, "ext3: fix ext3_dx_readdir hash collision handling", where deleting files in a large directory (requiring more than one getdents system call), results in some filenames being returned twice. This was caused by a failure to update info->curr_hash and info->curr_minor_hash, so that if the directory had gotten modified since the last getdents() system call (as would be the case if the user is running "rm -r" or "git clean"), a directory entry would get returned twice to the userspace. This patch fixes the bug reported by Markus Trippelsdorf at: http://bugzilla.kernel.org/show_bug.cgi?id=11844 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext3: fix ext3_dx_readdir hash collision handlingEugene Dashevsky
commit 6a897cf447a83c9c3fd1b85a1e525c02d6eada7d upstream. This fixes a bug where readdir() would return a directory entry twice if there was a hash collision in an hash tree indexed directory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eugene Dashevsky <eugene@ibrix.com> Signed-off-by: Mike Snitzer <msnitzer@ibrix.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext4: add checksum calculation when clearing UNINIT flag in ext4_new_inodeFrederic Bohe
(cherry picked from commit 23712a9c28b9f80a8cf70c8490358d5f562d2465) When initializing an uninitialized block group in ext4_new_inode(), its block group checksum must be re-calculated. This fixes a race when several threads try to allocate a new inode in an UNINIT'd group. There is some question whether we need to be initializing the block bitmap in ext4_new_inode() at all, but for now, if we are going to init the block group, let's eliminate the race. Signed-off-by: Frederic Bohe <frederic.bohe@bull.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext4: Mark the buffer_heads as dirty and uptodate after prepare_writeAneesh Kumar K.V
(cherry picked from commit ed9b3e3379731e9f9d2f73f3d7fd9e7d2ce3df4a) We need to make sure we mark the buffer_heads as dirty and uptodate so that block_write_full_page write them correctly. This fixes mmap corruptions that can occur in low memory situations. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext4: calculate journal credits correctlyTheodore Ts'o
(cherry picked from commit ac51d83705c2a38c71f39cde99708b14e6212a60) This fixes a 2.6.27 regression which was introduced in commit a02908f1. We weren't passing the chunk parameter down to the two subections, ext4_indirect_trans_blocks() and ext4_ext_index_trans_blocks(), with the result that massively overestimate the amount of credits needed by ext4_da_writepages, especially in the non-extents case. This causes failures especially on /boot partitions, which tend to be small and non-extent using since GRUB doesn't handle extents. This patch fixes the bug reported by Joseph Fannin at: http://bugzilla.kernel.org/show_bug.cgi?id=11964 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext4: wait on all pending commits in ext4_sync_fs()Theodore Ts'o
(cherry picked from commit 14ce0cb411c88681ab8f3a4c9caa7f42e97a3184) In ext4_sync_fs, we only wait for a commit to finish if we started it, but there may be one already in progress which will not be synced. In the case of a data=ordered umount with pending long symlinks which are delayed due to a long list of other I/O on the backing block device, this causes the buffer associated with the long symlinks to not be moved to the inode dirty list in the second phase of fsync_super. Then, before they can be dirtied again, kjournald exits, seeing the UMOUNT flag and the dirty pages are never written to the backing block device, causing long symlink corruption and exposing new or previously freed block data to userspace. To ensure all commits are synced, we flush all journal commits now when sync_fs'ing ext4. Signed-off-by: Arthur Jones <ajones@riverbed.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-05ext4: Convert to host order before using the values.Aneesh Kumar K.V
(cherry picked from commit d94e99a64c3beece22dbfb2b335771a59184eb0a) Use le16_to_cpu to read the s_reserved_gdt_blocks values from super block. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
