git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6:
eCryptfs: Flush dirty pages in setattr
eCryptfs: Handle failed metadata read in lookup
eCryptfs: Add reference counting to lower files
eCryptfs: dput dentries returned from dget_parent
eCryptfs: Remove extra d_delete in ecryptfs_rmdir
Now that the whole dcache_hash_bucket crap is gone, go all the way and
also remove the weird locking layering violations for locking the hash
buckets. Add hlist_bl_lock/unlock helpers to move the locking into the
list abstraction instead of requiring each caller to open code it.
After all allowing for the bit locks is the whole point of these helpers
over the plain hlist variant.
After 57db4e8d73ef2b5e94a3f412108dff2576670a8a changed eCryptfs to
write-back caching, eCryptfs page writeback updates the lower inode
times due to the use of vfs_write() on the lower file.
To preserve inode metadata changes, such as 'cp -p' does with
utimensat(), we need to flush all dirty pages early in
ecryptfs_setattr() so that the user-updated lower inode metadata isn't
clobbered later in writeback.
https://bugzilla.kernel.org/show_bug.cgi?id=33372
Reported-by: Rocko <rockorequin@hotmail.com>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
When failing to read the lower file's crypto metadata during a lookup,
eCryptfs must continue on without throwing an error. For example, there
may be a plaintext file in the lower mount point that the user wants to
delete through the eCryptfs mount.
If an error is encountered while reading the metadata in lookup(), the
eCryptfs inode's size could be incorrect. We must be sure to reread the
plaintext inode size from the metadata when performing an open() or
setattr(). The metadata is already being read in those paths, so this
adds minimal performance overhead.
This patch introduces a flag which will track whether or not the
plaintext inode size has been read so that an incorrect i_size can be
fixed in the open() or setattr() paths.
https://bugs.launchpad.net/bugs/509180
Cc: <stable@kernel.org>
For any given lower inode, eCryptfs keeps only one lower file open and
multiplexes all eCryptfs file operations through that lower file. The
lower file was considered "persistent" and stayed open from the first
lookup through the lifetime of the inode.
This patch keeps the notion of a single, per-inode lower file, but adds
reference counting around the lower file so that it is closed when not
currently in use. If the reference count is at 0 when an operation (such
as open, create, etc.) needs to use the lower file, a new lower file is
opened. Since the file is no longer persistent, all references to the
term persistent file are changed to lower file.
Locking is added around the sections of code that opens the lower file
and assign the pointer in the inode info, as well as the code the fputs
the lower file when all eCryptfs users are done with it.
This patch is needed to fix issues, when mounted on top of the NFSv3
client, where the lower file is left silly renamed until the eCryptfs
inode is destroyed.
Call dput on the dentries previously returned by dget_parent() in
ecryptfs_rename(). This is needed for supported eCryptfs mounts on top
of the NFSv3 client.
vfs_rmdir() already calls d_delete() on the lower dentry. That was being
duplicated in ecryptfs_rmdir() and caused a NULL pointer dereference
when NFSv3 was the lower filesystem.
* dcache-cleanup:
vfs: get rid of insane dentry hashing rules
* 'for-linus' of git://git.infradead.org/ubifs-2.6:
UBIFS: fix master node recovery
UBIFS: fix false assertion warning in case of I/O failures
UBIFS: fix false space checking failure
The dentry hashing rules have been really quite complicated for a long
while, in odd ways. That made functions like __d_drop() very fragile
and non-obvious.
In particular, whether a dentry was hashed or not was indicated with an
explicit DCACHE_UNHASHED bit. That's despite the fact that the hash
abstraction that the dentries use actually have a 'is this entry hashed
or not' model (which is a simple test of the 'pprev' pointer).
The reason that was done is because we used the normal 'is this entry
unhashed' model to mark whether the dentry had _ever_ been hashed in the
dentry hash tables, and that logic goes back many years (commit
b3423415fbc2: "dcache: avoid RCU for never-hashed dentries").
That, in turn, meant that __d_drop had totally different unhashing logic
for the dentry hash table case and for the anonymous dcache case,
because in order to use the "is this dentry hashed" logic as a flag for
whether it had ever been on the RCU hash table, we had to unhash such a
dentry differently so that we'd never think that it wasn't 'unhashed'
and wouldn't be free'd correctly.
That's just insane. It made the logic really hard to follow, when there
were two different kinds of "unhashed" states, and one of them (the one
that used "list_bl_unhashed()") really had nothing at all to do with
being unhashed per se, but with a very subtle lifetime rule instead.
So turn all of it around, and make it logical.
Instead of having a DENTRY_UNHASHED bit in d_flags to indicate whether
the dentry is on the hash chains or not, use the hash chain unhashed
logic for that. Suddenly "d_unhashed()" just uses "list_bl_unhashed()",
and everything makes sense.
And for the lifetime rule, just use an explicit DENTRY_RCUACCEES bit.
If we ever insert the dentry into the dentry hash table so that it is
visible to RCU lookup, we mark it DENTRY_RCUACCESS to show that it now
needs the RCU lifetime rules. Now suddently that test at dentry free
time makes sense too.
And because unhashing now is sane and doesn't depend on where the dentry
got unhashed from (because the dentry hash chain details doesn't have
some subtle side effects), we can re-unify the __d_drop() logic and use
common code for the unhashing.
Also fix one more open-coded hash chain bit_spin_lock() that I missed in
the previous chain locking cleanup commit.
It's a useless abstraction for 'hlist_bl_head', and it doesn't actually
help anything - quite the reverse. All the users end up having to know
about the hlist_bl_head details anyway, using 'struct hlist_bl_node *'
etc. So it just makes the code look confusing.
And the cost of it is extra '&b->head' syntactic noise, but more
importantly it spuriously makes the hash table dentry list look
different from the per-superblock DCACHE_DISCONNECTED dentry list.
As a result, the code ended up using ad-hoc locking for one case and
special helper functions for what is really another totally identical
case in the very same function.
Make it all look and work the same.
* 'for-linus' of git://oss.sgi.com/xfs/xfs:
xfs: fix duplicate message output
For some reason generic_setxattr() did not pass flags (XATTR_CREATE,
XATTR_REPLACE) to the filesystem specific helper. This caused that
setxattr(2) syscall just ignored these flags.
Fix the bug by passing flags correctly.
Acked-by: Christoph Hellwig <hch@lst.de>
This patch fixes the following symptoms:
1. Unmount UBIFS cleanly.
2. Start mounting UBIFS R/W and have a power cut immediately
3. Start mounting UBIFS R/O, this succeeds
4. Try to re-mount UBIFS R/W - this fails immediately or later on,
because UBIFS will write the master node to the flash area
which has been written before.
The analysis of the problem:
1. UBIFS is unmounted cleanly, both copies of the master node are clean.
2. UBIFS is being mounter R/W, starts changing master node copy 1, and
a power cut happens. The copy N1 becomes corrupted.
3. UBIFS is being mounted R/O. It notices the copy N1 is corrupted and
reads copy N2. Copy N2 is clean.
4. Because of R/O mode, UBIFS cannot recover copy 1.
5. The mount code (ubifs_mount()) sees that the master node is clean,
so it decides that no recovery is needed.
6. We are re-mounting R/W. UBIFS believes no recovery is needed and
starts updating the master node, but copy N1 is still corrupted
and was not recovered!
Fix this problem by marking the master node as dirty every time we
recover it and we are in R/O mode. This forces further recovery and
the UBIFS cleans-up the corruptions and recovers the copy N1 when
re-mounting R/W later.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Cc: stable@kernel.org
When UBIFS switches to R/O mode because it detects I/O failures, then
when we unmount, we still may have allocated budget, and the assertions
which verify that we have not budget will fire. But it is expected to
have the budget in case of I/O failures, so the assertion warnings will
be false. Suppress them for the I/O failure case.
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux:
Open with O_CREAT flag set fails to open existing files on non writable directories
nfsd4: Fix filp leak
nfsd4: fix struct file leak on delegation
Commit 957935dc ("xfs: fix xfs_debug warnings" broke the logic in
__xfs_printk(). Instead of only printing one of two possible output
strings based on whether the fs has a name or not, it outputs both.
Fix it to only output one message again.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Alex Elder <aelder@sgi.com>
This patch fixes UBIFS mount failure when the debugging support is enabled,
we are recovering from a power cut, we were first mounter R/O and we are
re-mounting R/W. In this case we should not assume that the amount of free
space before we have re-mounted R/W and after are equivalent, because
when we have mounted R/O the file-system is in a non-committed state so
the amount of free space is slightly smaller, due to the fact that we cannot
predict the amount of free space precisely before we commit.
This patch fixes the issue by skipping the debugging check in case of
recovery. This issue was reported by Caizhiyong <caizhiyong@huawei.com>
here: http://thread.gmane.org/gmane.linux.drivers.mtd/34350/focus=34387
Reported-by: Caizhiyong <caizhiyong@huawei.com>
Cc: stable@kernel.org [2.6.30+]
directories
An open on a NFS4 share using the O_CREAT flag on an existing file for
which we have permissions to open but contained in a directory with no
write permissions will fail with EACCES.
A tcpdump shows that the client had set the open mode to UNCHECKED which
indicates that the file should be created if it doesn't exist and
encountering an existing flag is not an error. Since in this case the
file exists and can be opened by the user, the NFS server is wrong in
attempting to check create permissions on the parent directory.
The patch adds a conditional statement to check for create permissions
only if the file doesn't exist.
Signed-off-by: Sachin S. Prabhu <sprabhu@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
23fcf2ec93fb8573a653408316af599939ff9a8e (nfsd4: fix oops on lock failure)
The above patch breaks free path for stp->st_file. If stp was inserted
into sop->so_stateids, we have to free stp->st_file refcount. Because
stp->st_file refcount itself is taken whether or not any refcounts are
taken on the stp->st_file->fi_fds[].
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes:
GFS2: filesystem hang caused by incorrect lock order
GFS2: Don't try to deallocate unlinked inodes when mounted ro
GFS2: directly write blocks past i_size
GFS2: write_end error path fails to unlock transaction lock
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (24 commits)
Btrfs: fix free space cache leak
Btrfs: avoid taking the chunk_mutex in do_chunk_alloc
Btrfs end_bio_extent_readpage should look for locked bits
Btrfs: don't force chunk allocation in find_free_extent
Btrfs: Check validity before setting an acl
Btrfs: Fix incorrect inode nlink in btrfs_link()
Btrfs: Check if btrfs_next_leaf() returns error in btrfs_real_readdir()
Btrfs: Check if btrfs_next_leaf() returns error in btrfs_listxattr()
Btrfs: make uncache_state unconditional
btrfs: using cached extent_state in set/unlock combinations
Btrfs: avoid taking the trans_mutex in btrfs_end_transaction
Btrfs: fix subvolume mount by name problem when default mount subvolume is set
fix user annotation in ioctl.c
Btrfs: check for duplicate iov_base's when doing dio reads
btrfs: properly handle overlapping areas in memmove_extent_buffer
Btrfs: fix memory leaks in btrfs_new_inode()
Btrfs: reuse the extent_map we found when calling btrfs_get_extent
Btrfs: do not use async submit for small DIO io's
Btrfs: don't split dio bios if we don't have to
Rather than pass in some random truncated offset to the pid-related
functions, check that the offset is in range up-front.
This is just cleanup, the previous commit fixed the real problem.
Introduced by acfdf5c383b38f7f4dddae41b97c97f1ae058f49.
Reported-by: Gerhard Heift <ml-nfs-linux-20110412-ef47@gheift.de>
This patch fixes a deadlock in GFS2 where two processes are trying
to reclaim an unlinked dinode:
One holds the inode glock and calls gfs2_lookup_by_inum trying to look
up the inode, which it can't, due to I_FREEING. The other has set
I_FREEING from vfs and is at the beginning of gfs2_delete_inode
waiting for the glock, which is held by the first. The solution is to
add a new non_block parameter to the gfs2_iget function that causes it
to return -ENOENT if the inode is being freed.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
This adds a couple of missing tests to avoid read-only nodes
from attempting to deallocate unlinked inodes.
Reported-by: Michel Andre de la Porte <madelaporte@ubi.com>
GFS2 was relying on the writepage code to write out the zeroed data for
fallocate. However, with FALLOC_FL_KEEP_SIZE set, this may be past i_size.
If it is, it will be ignored. To work around this, gfs2 now calls
write_dirty_buffer directly on the buffer_heads when FALLOC_FL_KEEP_SIZE
is set, and it's writing past i_size.
This version is just a cleanup of my last version
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
I did an audit of gfs2's transaction glock for bugzilla bug
658619 and ran across this:
In function gfs2_write_end, in the unlikely event that
gfs2_meta_inode_buffer returns an error, the code may forget
to unlock the transaction lock because the "failed" label
appears after the call to function gfs2_trans_end.
The free space caching code was recently reworked to
cache all the pages it needed instead of using find_get_page everywhere.
One loop was missed though, so it ended up leaking pages. This fixes
it to use our page array instead of find_get_page.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
While checking unregister_filesystem for saftey vs extra calls for
"ext4: register ext2 and ext3 alias after ext4" I realized that
the synchronize_rcu() was called on the error path but not on
the success path.
Cc: stable (2.6.38)
Signed-off-by: Milton Miller <miltonm@bga.com>
[ This probably won't really make a difference since commit d863b50ab013
("vfs: call rcu_barrier after ->kill_sb()"), but it's the right thing
to do. - Linus ]
Everytime we try to allocate disk space we try and see if we can pre-emptively
allocate a chunk, but in the common case we don't allocate anything, so there is
no sense in taking the chunk_mutex at all. So instead if we are allocating a
chunk, mark it in the space_info so we don't get two people trying to allocate
at the same time. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
Reviewed-by: Liu Bo <liubo2009@cn.fujitsu.com>
A recent commit caches the extent state in end_bio_extent_readpage,
but the search it does should look for locked extents. This
fixes things to make it more effective.
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
net/9p: nwname should be an unsigned int
9p: Fix sparse error
fs/9p: Fix error reported by coccicheck
9p: revert tsyncfs related changes
fs/9p: Use write_inode for data sync on server
fs/9p: Fix revalidate to return correct value
During RCU walk in path_lookupat and path_openat, the rcu lookup
frequently failed if looking up an absolute path, because when root
directory was looked up, seq number was not properly set in nameidata.
We dropped out of RCU walk in nameidata_drop_rcu due to mismatch in
directory entry's seq number. We reverted to slow path walk that need
to take references.
With the following patch, I saw a 50% increase in an exim mail server
benchmark throughput on a 4-socket Nehalem-EX system.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: stable@kernel.org (v2.6.38)
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Now that we use write_inode to flush server
cache related to fid, we don't need tsyncfs either fort dotl or dotu
protocols. For dotu this helps to do a more efficient server flush.
revalidate should return > 0 on success. Also return 0 on ENOENT
to force do_revalidate to return NULL dentry;
find_free_extent likes to allocate in contiguous clusters,
which makes writeback faster, especially on SSD storage. As
the FS fragments, these clusters become harder to find and we have
to decide between allocating a new chunk to make more clusters
or giving up on the cluster to allocate from the free space
we have.
Right now it creates too many chunks, and you can end up with
a whole FS that is mostly empty metadata chunks. This commit
changes the allocation code to be more strict and only
allocate new chunks when we've made good use of the chunks we
already have.
* 'linux-next' of git://git.infradead.org/ubifs-2.6:
UBIFS: fix compilation warnings when compiling with gcc 4.5
UBIFS: fix oops when R/O file-system is fsync'ed
The case we should be verifying when updating the dentry name is that
the _parent_ inode (the directory) semaphore is held, not the semaphore
for the dentry itself. It's the directory locking that rename and
readdir() etc all care about.
The comment just above even says so - but then the BUG_ON() still
checked the dentry inode itself.
Very few people noticed, because this helper function really isn't used
for very much, so you had to be using ncpfs to ever hit it.
I think I should just remove the BUG_ON (the function really has just
one user), but let's run with it fixed for a while before getting rid of
it entirely.
Reported-and-tested-by: Bongani Hlope <bonganih@bankservafrica.com>
Reported-and-tested-by: Bernd Feige <bernd.feige@uniklinik-freiburg.de>
Cc: Petr Vandrovec <petr@vandrovec.name>,
Cc: Nick Piggin <npiggin@kernel.dk>
On no-mmu arch, there is a memleak during shmem test. The cause of this
memleak is ramfs_nommu_expand_for_mapping() added page refcount to 2
which makes iput() can't free that pages.
The simple test file is like this:
int main(void)
int i;
key_t k = ftok("/etc", 42);
for ( i=0; i<100; ++i) {
int id = shmget(k, 10000, 0644|IPC_CREAT);
if (id == -1) {
printf("shmget error\n");
if(shmctl(id, IPC_RMID, NULL ) == -1) {
printf("shm rm error\n");
return -1;
printf("run ok...\n");
return 0;
And the result:
root:/> free
total used free shared buffers
Mem: 60320 17912 42408 0 0
-/+ buffers: 17912 42408
root:/> shmem
run ok...
root:/> free
Mem: 60320 19096 41224 0 0
-/+ buffers: 19096 41224
root:/> shmem
run ok...
root:/> free
Mem: 60320 20296 40024 0 0
-/+ buffers: 20296 40024
After this patch the test result is:(no memleak anymore)
root:/> free
Mem: 60320 16668 43652 0 0
-/+ buffers: 16668 43652
root:/> shmem
run ok...
root:/> free
Signed-off-by: Bob Liu <lliubbo@gmail.com>
force_o_largefile() on ia64 is defined in <asm/fcntl.h> and requires
<linux/personality.h>.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
5520e89 ("brk: fix min_brk lower bound computation for COMPAT_BRK")
tried to get the whole logic of brk randomization for legacy
(libc5-based) applications finally right.
It turns out that the way to detect whether brk has actually been
randomized in the end or not introduced by that patch still doesn't work
for those binaries, as reported by Geert:
: /sbin/init from my old m68k ramdisk exists prematurely.
: Before the patch:
: | brk(0x80005c8e) = 0x80006000
: After the patch:
: | brk(0x80005c8e) = 0x80005c8e
: Old libc5 considers brk() to have failed if the return value is not
: identical to the requested value.
I don't like it, but currently see no better option than a bit flag in
task_struct to catch the CONFIG_COMPAT_BRK && randomize_va_space == 2
case.
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
The kernel automatically evaluates partition tables of storage devices.
The code for evaluating LDM partitions (in fs/partitions/ldm.c) contains
a bug that causes a kernel oops on certain corrupted LDM partitions.
A kernel subsystem seems to crash, because, after the oops, the kernel no
longer recognizes newly connected storage devices.
The patch validates the value of vblk_size.
Signed-off-by: Timo Warns <warns@pre-sense.de>
Cc: Eugene Teo <eugeneteo@kernel.sg>
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Richard Russon <rich@flatcap.org>
When compiling UBIFS with CONFIG_UBIFS_FS_DEBUG not set,
gcc-4.5.2 generates a slew of "warning: statement with no effect"
on references to non-void functions defined as 0.
To avoid these warnings, replace #defines with dummy inline functions.
Artem: massage the patch a bit, also remove the duplicate
'dbg_check_lprops()' prototype.
Signed-off-by: Maksim Rayskiy <maksim.rayskiy@gmail.com>
This patch fixes severe UBIFS bug: UBIFS oopses when we 'fsync()' an
file on R/O-mounter file-system. We (the UBIFS authors) incorrectly
thought that VFS would not propagate 'fsync()' down to the file-system
if it is read-only, but this is not the case.
It is easy to exploit this bug using the following simple perl script:
use strict;
use File::Sync qw(fsync sync);
die "File path is not specified" if not defined $ARGV[0];
my $path = $ARGV[0];
open FILE, "<", "$path" or die "Cannot open $path: $!";
fsync(\*FILE) or die "cannot fsync $path: $!";
close FILE or die "Cannot close $path: $!";
Thanks to Reuben Dowle <Reuben.Dowle@navico.com> for reporting about this
issue.
Reported-by: Reuben Dowle <Reuben.Dowle@navico.com>
Call posix_acl_valid() to check if an acl is valid or not.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Link count of the inode is not decreased if btrfs_set_inode_index()
fails.
Singed-off-by: Li Zefan <lizf@cn.fujitsu.com>
btrfs_next_leaf() can return -errno, and we should propagate
it to userspace.
This also simplifies how we walk the btree path.
