path: root/fs
2011-08-23Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: fix tracing builds inside the source tree xfs: remove subdirectories xfs: don't expect xfs headers to be in subdirectories
2011-08-22xfs: fix tracing builds inside the source treeChristoph Hellwig
The code really requires the current source directory to be in the header search path. We already do this if building with an object tree separate from the source, but it needs to be added manually if building inside the source. The cflags addition for it accidentally got removed when collapsing the xfs directory structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-21Btrfs: fix 64 bit divide problemJosef Bacik
This fixes a regression introduced by commit cdcb725c05fe ("Btrfs: check if there is enough space for balancing smarter"). We can't do 64-bit divides on 32-bit architectures. In cases where we need to divide/multiply by 2 we should just left/right shift respectively, and in cases where theres N number of devices use do_div. Also make the counters u64 to match up with rw_devices. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Acked-and-tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: flush any pending end_io requests before DIO reads w/dioread_nolock ext4: fix nomblk_io_submit option so it correctly converts uninit blocks ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN. ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inode ext4: Fix ext4_should_writeback_data() for no-journal mode
2011-08-19ext4: flush any pending end_io requests before DIO reads w/dioread_nolockJiaying Zhang
There is a race between ext4 buffer write and direct_IO read with dioread_nolock mount option enabled. The problem is that we clear PageWriteback flag during end_io time but will do uninitialized-to-initialized extent conversion later with dioread_nolock. If an O_direct read request comes in during this period, ext4 will return zero instead of the recently written data. This patch checks whether there are any pending uninitialized-to-initialized extent conversion requests before doing O_direct read to close the race. Note that this is just a bandaid fix. The fundamental issue is that we clear PageWriteback flag before we really complete an IO, which is problem-prone. To fix the fundamental issue, we may need to implement an extent tree cache that we can use to look up pending to-be-converted extents. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-18Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4.1: Return NFS4ERR_BADSESSION to callbacks during session resets NFSv4.1: Fix the callback 'highest_used_slotid' behaviour pnfs-obj: Fix the comp_index != 0 case pnfs-obj: Bug when we are running out of bio nfs: add missing prefetch.h include
2011-08-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: set i_size properly when fallocating and we already btrfs: unlock on error in btrfs_file_llseek() btrfs: btrfs_permission's RO check shouldn't apply to device nodes Btrfs: truncate pages from clone ioctl target range Btrfs: fix uninitialized sync_pending Btrfs: fix wrong free space information btrfs: memory leak in btrfs_add_inode_defrag() Btrfs: use plain page_address() in header fields setget functions Btrfs: forced readonly when btrfs_drop_snapshot() fails Btrfs: check if there is enough space for balancing smarter Btrfs: fix a bug of balance on full multi-disk partitions Btrfs: fix an oops of log replay Btrfs: detect wether a device supports discard Btrfs: force unplugs when switching from high to regular priority bios
2011-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: update cifs version to 1.75 [CIFS] possible memory corruption on mount cifs: demote cERROR in build_path_from_dentry to cFYI
2011-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: fat16 support maximum 4GB file/vol size as WinXP or 7. fat: fix utf8 iocharset warning message fat: fix build warning
2011-08-18update cifs version to 1.75Steve French
Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-18[CIFS] possible memory corruption on mountSteve French
CIFS cleanup_volume_info_contents() looks like having a memory corruption problem. When UNCip is set to "&vol->UNC[2]" in cifs_parse_mount_options(), it should not be kfree()-ed in cleanup_volume_info_contents(). Introduced in commit b946845a9dc523c759cae2b6a0f6827486c3221a Signed-off-by: J.R. Okajima <hooanon05@yahoo.co.jp> Reviewed-by: Jeff Layton <jlayton@redhat.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-18Merge branch 'btrfs-3.0' into for-linusChris Mason
2011-08-18Btrfs: set i_size properly when fallocating and we alreadyJosef Bacik
xfstests exposed a problem with preallocate when it fallocates a range that already has an extent. We don't set the new i_size properly because we see that we already have an extent. This isn't right and we should update i_size if the space already exists. With this patch we now pass xfstests 075. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-18btrfs: unlock on error in btrfs_file_llseek()Dan Carpenter
There were some unlocks on error missing in a recent patch to btrfs_file_llseek(). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-18btrfs: btrfs_permission's RO check shouldn't apply to device nodesJeff Mahoney
This patch tightens the read-only access checks in btrfs_permission to match the constraints in inode_permission. Currently, even though the device node itself will be unmodified, read-write access to device nodes is denied to when the device node resides on a read-only subvolume or a is a file that has been marked read-only by the btrfs conversion utility. With this patch applied, the check only affects regular files, directories, and symlinks. It also restructures the code a bit so that we don't duplicate the MAY_WRITE check for both tests. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-17befs: Validate length of long symbolic links.Timo Warns
Signed-off-by: Timo Warns <warns@pre-sense.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17fat: fat16 support maximum 4GB file/vol size as WinXP or 7.Namjae Jeon
FAT16 support maximum 4GB vol/file size with 64KB cluster size. Win NT/XP/7 increased the maximum cluster size to 64KB, and file/vol size increased 4GB also. Although increasing, the file size of linux FAT is still limited at 2GB. I found that it is limited by sb->maxbytes(0x7fffffff) when partition is formatted by FAT16. sb->s_maxbytes in fill_super should be set to 0xffffffff like fat32. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix utf8 iocharset warning messageMihai Moldovan
The fat_msg function already formats the given message and appends a newline to it - we don't need to do this in the passed message string as well, or will end up with a blank line printed in the kernel log ring buffer. Also change the loglevel from error to warning. Signed-off-by: Mihai Moldovan <ionic@ionic.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix build warningJonas Aberg
This fixes a compile warning (unititialized variable) in the fat filesystem code. Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-16Btrfs: truncate pages from clone ioctl target rangeSage Weil
We need to truncate page cache pages for the clone ioctl target range or else we'll confuse ourselves to no end. If the old data was cached, we used to still see it (until remount). If the page was partially updated we used to get a mix of old and new data. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix uninitialized sync_pendingMiao Xie
sync_pending is uninitialized before it be used, fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix wrong free space informationMiao Xie
Btrfs subtracted the size of the allocated space twice when it allocated the space from the bitmap in the cluster, it broke the free space information and led to oops finally. And this patch also fixes the bug that ctl->free_space was subtracted without lock. Reported-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16btrfs: memory leak in btrfs_add_inode_defrag()Dan Carpenter
We don't use the defrag struct on this path. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: use plain page_address() in header fields setget functionsLi Zefan
We've stopped using highmem for extent buffers. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: forced readonly when btrfs_drop_snapshot() failsTsutomu Itoh
The filesystem turns readonly instead of returning the error to the caller when detected error in btrfs_drop_snapshot(). and, because the caller doesn't check the error, the function type is changed to 'void'. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: check if there is enough space for balancing smarterliubo
When checking if there is enough space for balancing a block group, since we do not take raid types into consideration, we do not account corrent amounts of space that we needed. This makes us do some extra work before we get ENOSPC. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix a bug of balance on full multi-disk partitionsliubo
When balancing, we'll first try to shrink devices for some space, but if it is working on a full multi-disk partition with raid protection, we may encounter a bug, that is, while shrinking, total_bytes may be less than bytes_used, and btrfs may allocate a dev extent that accesses out of device's bounds. Then we will not be able to write or read the data which stores at the end of the device, and get the followings: device fsid 0939f071-7ea3-46c8-95df-f176d773bfb6 devid 1 transid 10 /dev/sdb5 Btrfs detected SSD devices, enabling SSD mode btrfs: relocating block group 476315648 flags 9 btrfs: found 4 extents attempt to access beyond end of device sdb5: rw=145, want=546176, limit=546147 attempt to access beyond end of device sdb5: rw=145, want=546304, limit=546147 attempt to access beyond end of device sdb5: rw=145, want=546432, limit=546147 attempt to access beyond end of device sdb5: rw=145, want=546560, limit=546147 attempt to access beyond end of device Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: fix an oops of log replayliubo
When btrfs recovers from a crash, it may hit the oops below: ------------[ cut here ]------------ kernel BUG at fs/btrfs/inode.c:4580! [...] RIP: 0010:[<ffffffffa03df251>] [<ffffffffa03df251>] btrfs_add_link+0x161/0x1c0 [btrfs] [...] Call Trace: [<ffffffffa03e7b31>] ? btrfs_inode_ref_index+0x31/0x80 [btrfs] [<ffffffffa04054e9>] add_inode_ref+0x319/0x3f0 [btrfs] [<ffffffffa0407087>] replay_one_buffer+0x2c7/0x390 [btrfs] [<ffffffffa040444a>] walk_down_log_tree+0x32a/0x480 [btrfs] [<ffffffffa0404695>] walk_log_tree+0xf5/0x240 [btrfs] [<ffffffffa0406cc0>] btrfs_recover_log_trees+0x250/0x350 [btrfs] [<ffffffffa0406dc0>] ? btrfs_recover_log_trees+0x350/0x350 [btrfs] [<ffffffffa03d18b2>] open_ctree+0x1442/0x17d0 [btrfs] [...] This comes from that while replaying an inode ref item, we forget to check those old conflicting DIR_ITEM and DIR_INDEX items in fs/file tree, then we will come to conflict corners which lead to BUG_ON(). Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Tested-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16Btrfs: detect wether a device supports discardJosef Bacik
We have a problem where if a user specifies discard but doesn't actually support it we will return EOPNOTSUPP from btrfs_discard_extent. This is a problem because this gets called (in a fashion) from the tree log recovery code, which has a nice little BUG_ON(ret) after it, which causes us to fail the tree log replay. So instead detect wether our devices support discard when we're adding them and then don't issue discards if we know that the device doesn't support it. And just for good measure set ret = 0 in btrfs_issue_discard just in case we still get EOPNOTSUPP so we don't screw anybody up like this again. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-08-16cifs: demote cERROR in build_path_from_dentry to cFYIJeff Layton
Running the cthon tests on a recent kernel caused this message to pop occasionally: CIFS VFS: did not end path lookup where expected namelen is 0 Some added debugging showed that namelen and dfsplen were both 0 when this occurred. That means that the read_seqretry returned true. Assuming that the comment inside the if statement is true, this should be harmless and just means that we raced with a rename. If that is the case, then there's no need for alarm and we can demote this to cFYI. While we're at it, print the dfsplen too so that we can see what happened here if the message pops during debugging. Cc: stable@kernel.org Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: jfs: flush journal completely before releasing metadata inodes
2011-08-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: Do not set cifs/ntfs acl using a file handle (try #4) [CIFS] Cleanup use of CONFIG_CIFS_STATS2 ifdef to make transport routines more readable
2011-08-13ext4: fix nomblk_io_submit option so it correctly converts uninit blocksTheodore Ts'o
Bug discovered by Jan Kara: Finally, commit 1449032be17abb69116dbc393f67ceb8bd034f92 returned back the old IO submission code but apparently it forgot to return the old handling of uninitialized buffers so we unconditionnaly call block_write_full_page() without specifying end_io function. So AFAICS we never convert unwritten extents to written in some cases. For example when I mount the fs as: mount -t ext4 -o nomblk_io_submit,dioread_nolock /dev/ubdb /mnt and do int fd = open(argv[1], O_RDWR | O_CREAT | O_TRUNC, 0600); char buf[1024]; memset(buf, 'a', sizeof(buf)); fallocate(fd, 0, 0, 16384); write(fd, buf, sizeof(buf)); I get a file full of zeros (after remounting the filesystem so that pagecache is dropped) instead of seeing the first KB contain 'a's. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN.Tao Ma
EXT4_IO_END_UNWRITTEN flag set and the increase of i_aiodio_unwritten should be done simultaneously since ext4_end_io_nolock always clear the flag and decrease the counter in the same time. We don't increase i_aiodio_unwritten when setting EXT4_IO_END_UNWRITTEN so it will go nagative and causes some process to wait forever. Part of the patch came from Eric in his e-mail, but it doesn't fix the problem met by Michael actually. http://marc.info/?l=linux-ext4&m=131316851417460&w=2 Reported-and-Tested-by: Michael Tokarev<mjt@tls.msk.ru> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inodeJiaying Zhang
Flush inode's i_completed_io_list before calling ext4_io_wait to prevent the following deadlock scenario: A page fault happens while some process is writing inode A. During page fault, shrink_icache_memory is called that in turn evicts another inode B. Inode B has some pending io_end work so it calls ext4_ioend_wait() that waits for inode B's i_ioend_count to become zero. However, inode B's ioend work was queued behind some of inode A's ioend work on the same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten thread on that cpu is processing inode A's ioend work, it tries to grab inode A's i_mutex lock. Since the i_mutex lock of inode A is still hold before the page fault happened, we enter a deadlock. Also moves ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode() to ext4_evict_inode(). During inode deleteion, ext4_evict_inode() is called before ext4_destroy_inode() and in ext4_evict_inode(), we may call ext4_truncate() without holding i_mutex lock. As a result, there is a race between flush_completed_IO that is called from ext4_ext_truncate() and ext4_end_io_work, which may cause corruption on an io_end structure. This change moves ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode() to ext4_evict_inode() to resolve the race between ext4_truncate() and ext4_end_io_work during inode deletion. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: Fix ext4_should_writeback_data() for no-journal modeCurt Wohlgemuth
ext4_should_writeback_data() had an incorrect sequence of tests to determine if it should return 0 or 1: in particular, even in no-journal mode, 0 was being returned for a non-regular-file inode. This meant that, in non-journal mode, we would use ext4_journalled_aops for directories, symlinks, and other non-regular files. However, calling journalled aop callbacks when there is no valid handle, can cause problems. This would cause a kernel crash with Jan Kara's commit 2d859db3e4 ("ext4: fix data corruption in inodes with journalled data"), because we now dereference 'handle' in ext4_journalled_write_end(). I also added BUG_ONs to check for a valid handle in the obviously journal-only aops callbacks. I tested this running xfstests with a scratch device in these modes: - no-journal - data=ordered - data=writeback - data=journal All work fine; the data=journal run has many failures and a crash in xfstests 074, but this is no different from a vanilla kernel. Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-12Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: replace xfs_buf_geterror() with bp->b_error xfs: Check the return value of xfs_buf_read() for NULL "xfs: fix error handling for synchronous writes" revisited xfs: set cursor in xfs_ail_splice() even when AIL was empty xfs: Remove the macro XFS_BUFTARG_NAME xfs: Remove the macro XFS_BUF_TARGET xfs: Remove the macro XFS_BUF_SET_TARGET Replace the macro XFS_BUF_ISPINNED with helper xfs_buf_ispinned xfs: Remove the macro XFS_BUF_SET_PTR xfs: Remove the macro XFS_BUF_PTR xfs: Remove macro XFS_BUF_SET_START xfs: Remove macro XFS_BUF_HOLD xfs: Remove macro XFS_BUF_BUSY and family xfs: Remove the macro XFS_BUF_ERROR and family xfs: Remove the macro XFS_BUF_BFLAGS
2011-08-12xfs: remove subdirectoriesChristoph Hellwig
Use the move from Linux 2.6 to Linux 3.x as an excuse to kill the annoying subdirectories in the XFS source code. Besides the large amount of file rename the only changes are to the Makefile, a few files including headers with the subdirectory prefix, and the binary sysctl compat code that includes a header under fs/xfs/ from kernel/. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: don't expect xfs headers to be in subdirectoriesAlex Elder
Fix up some #include directives in preparation for moving a few header files out of xfs source subdirectories. Note that "xfs_linux.h" also got its quoting convention for included files switched. Signed-off-by: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2011-08-12xfs: replace xfs_buf_geterror() with bp->b_errorChandra Seetharaman
Since we just checked bp for NULL, it is ok to replace xfs_buf_geterror() with bp->b_error in these places. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12xfs: Check the return value of xfs_buf_read() for NULLChandra Seetharaman
Check the return value of xfs_buf_read() for NULL and return ENOMEM if it is NULL. This is necessary in a few spots to avoid subsequent code blindly dereferencing the null buffer pointer. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2011-08-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) e1000e: increase driver version number e1000e: alternate MAC address update e1000e: do not disable receiver on 82574/82583 e1000e: alternate MAC address does not work on device id 0x1060 PCnet: Fix section mismatch bnx2x: disable dcb on 578xx since not supported yet bnx2x: properly clean indirect addresses bnx2x: prevent race between undi_unload and load flows bnx2x: fix select_queue when FCoE is disabled bnx2x: init FCOE FP only once ipv4: some rt_iif -> rt_route_iif conversions net/bridge/netfilter/ebtables.c: use available error handling code net/netlabel/netlabel_kapi.c: add missing cleanup code net/irda: sh_sir: tidyup compile warning net/irda: sh_sir: add missing header net/irda: sh_irda: add missing header slcan: ldisc generated skbs are received in softirq context scm: Capture the full credentials of the scm sender tcp: initialize variable ecn_ok in syncookies path drivers/net/wireless/wl1251: add missing kfree ...
2011-08-11pnfs: Automatically select blocks & objects layoutsBoaz Harrosh
Just like files-layout, blocks & objects layouts are part of the NFS 4.1 protocol and should be automatically selected if NFS_4_1 is selected. The small problem is that these depend on other Kernel support being present, while files only depends on NFS itself. This patch removes from the user choice the presence of objects and blocks layout. But makes sure these are selected only if the depended subsystems are present in the Kernel. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Peng Tao <peng_tao@emc.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11ext4: Properly count journal credits for long symlinksEric Sandeen
Commit df5e6223407e ("ext4: fix deadlock in ext4_symlink() in ENOSPC conditions") recalculated the number of credits needed for a long symlink, in the process of splitting it into two transactions. However, the first credit calculation under-counted because if selinux is enabled, credits are needed to create the selinux xattr as well. Overrunning the reservation will result in an OOPS in jbd2_journal_dirty_metadata() due to this assert: J_ASSERT_JH(jh, handle->h_buffer_credits > 0); Fix this by increasing the reservation size. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11ext3: Properly count journal credits for long symlinksEric Sandeen
Commit ae54870a1dc9 ("ext3: Fix lock inversion in ext3_symlink()") recalculated the number of credits needed for a long symlink, in the process of splitting it into two transactions. However, the first credit calculation under-counted because if selinux is enabled, credits are needed to create the selinux xattr as well. Overrunning the reservation will result in an OOPS in journal_dirty_metadata() due to this assert: J_ASSERT_JH(jh, handle->h_buffer_credits > 0); Fix this by increasing the reservation size. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-11cifs: Do not set cifs/ntfs acl using a file handle (try #4)Shirish Pargaonkar
Set security descriptor using path name instead of a file handle. We can't be sure that the file handle has adequate permission to set a security descriptor (to modify DACL). Function set_cifs_acl_by_fid() has been removed since we can't be sure how a file was opened for writing, a valid request can fail if the file was not opened with two above mentioned permissions. We could have opted to add on WRITE_DAC and WRITE_OWNER permissions to file opens and then use that file handle but adding addtional permissions such as WRITE_DAC and WRITE_OWNER could cause an any open to fail. And it was incorrect to look for read file handle to set a security descriptor anyway. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-08-11[CIFS] Cleanup use of CONFIG_CIFS_STATS2 ifdef to make transport routines ↵Steve French
more readable Christoph had requested that the stats related code (in CONFIG_CIFS_STATS2) be moved into helpers to make code flow more readable. This patch should help. For example the following section from transport.c spin_unlock(&GlobalMid_Lock); atomic_inc(&ses->server->num_waiters); wait_event(ses->server->request_q, atomic_read(&ses->server->inFlight) < cifs_max_pending); atomic_dec(&ses->server->num_waiters); spin_lock(&GlobalMid_Lock); becomes simpler (with the patch below): spin_unlock(&GlobalMid_Lock); cifs_num_waiters_inc(server); wait_event(server->request_q, atomic_read(&server->inFlight) < cifs_max_pending); cifs_num_waiters_dec(server); spin_lock(&GlobalMid_Lock); Reviewed-by: Jeff Layton <jlayton@redhat.com> CC: Christoph Hellwig <hch@infradead.org> Signed-off-by: Steve French <sfrench@us.ibm.com> Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
2011-08-11NFS41: make PNFS_BLOCK selectablePeng Tao
PNFS_BLOCK needs BLK_DEV_DM/MD, which is not a dependency for other pnfs layout drivers. Seperate it out so others can still build when BLK_DEV_DM/MD is not enabled. Also change select to depends on to avoid build failures. Reported-and-tested-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Peng Tao <peng_tao@emc.com> Acked-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-10"xfs: fix error handling for synchronous writes" revisitedAjeet Yadav
xfs: fix for hang during synchronous buffer write error If removed storage while synchronous buffer write underway, "xfslogd" hangs. Detailed log http://oss.sgi.com/archives/xfs/2011-07/msg00740.html Related work bfc60177f8ab509bc225becbb58f7e53a0e33e81 "xfs: fix error handling for synchronous writes" Given that xfs_bwrite actually does the shutdown already after waiting for the b_iodone completion and given that we actually found that calling xfs_force_shutdown from inside xfs_buf_iodone_callbacks was a major contributor the problem it better to drop this call. Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
