We used to have rather schizophrenic set of checks for NULL ->i_op even
though it had been eliminated years ago. You'd need to go out of your
way to set it to NULL explicitly _and_ a bunch of code would die on
such inodes anyway. After killing two remaining places that still
did that bogosity, all that crap can go away.
it's already set to empty table (and no, ntfs doesn't have any explicit
checks for NULL ->i_op or NULL ->i_fop)
for one thing it never happens, for another we check that inode
is a directory right after that place anyway (and we'd already
checked that reading it from disk has not failed).
it is already set to empty table and should never be NULL
This patch fixes a race condition in lseek. While it is expected that
unpredictable behaviour may result while repositioning the offset of a
file descriptor concurrently with reading/writing to the same file
descriptor, this should not happen when merely *reading* the file
descriptor's offset.
Unfortunately, the only portable way in Unix to read a file
descriptor's offset is lseek(fd, 0, SEEK_CUR); however executing this
concurrently with read/write may mess up the position.
[with fixes from akpm]
Signed-off-by: Alain Knaff <alain@knaff.lu>
* 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits)
x86: setup_per_cpu_areas() cleanup
cpumask: fix compile error when CONFIG_NR_CPUS is not defined
cpumask: use alloc_cpumask_var_node where appropriate
cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t
x86: use cpumask_var_t in acpi/boot.c
x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids
sched: put back some stack hog changes that were undone in kernel/sched.c
x86: enable cpus display of kernel_max and offlined cpus
ia64: cpumask fix for is_affinity_mask_valid()
cpumask: convert RCU implementations, fix
xtensa: define __fls
mn10300: define __fls
m32r: define __fls
h8300: define __fls
frv: define __fls
cris: define __fls
cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS
cpumask: zero extra bits in alloc_cpumask_var_node
cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/
cpumask: convert mm/
... just make it a binfmt handler like #! one.
They are actually alpha vs. i386/arm/m68k i.e. ecoff vs. aout.
In the only place where we actually tried to handle arm and i386/m68k in
different ways (START_DATA() in coredump handling), the arm variant
works for all of them (i386 and m68k have u.start_code set to 0).
it's been used only in sunos compat
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (33 commits)
UBIFS: add more useful debugging prints
UBIFS: print debugging messages properly
UBIFS: fix numerous spelling mistakes
UBIFS: allow mounting when short of space
UBIFS: fix writing uncompressed files
UBIFS: fix checkpatch.pl warnings
UBIFS: fix sparse warnings
UBIFS: simplify make_free_space
UBIFS: do not lie about used blocks
UBIFS: restore budg_uncommitted_idx
UBIFS: always commit on unmount
UBIFS: use ubi_sync
UBIFS: always commit in sync_fs
UBIFS: fix file-system synchronization
UBIFS: fix constants initialization
UBIFS: avoid unnecessary calculations
UBIFS: re-calculate min_idx_size after the commit
UBIFS: use nicer 64-bit math
UBIFS: fix available blocks count
UBIFS: various comment improvements and fixes
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm
* 'kvm-updates/2.6.29' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (140 commits)
KVM: MMU: handle large host sptes on invlpg/resync
KVM: Add locking to virtual i8259 interrupt controller
KVM: MMU: Don't treat a global pte as such if cr4.pge is cleared
MAINTAINERS: Maintainership changes for kvm/ia64
KVM: ia64: Fix kvm_arch_vcpu_ioctl_[gs]et_regs()
KVM: x86: Rework user space NMI injection as KVM_CAP_USER_NMI
KVM: VMX: Fix pending NMI-vs.-IRQ race for user space irqchip
KVM: fix handling of ACK from shared guest IRQ
KVM: MMU: check for present pdptr shadow page in walk_shadow
KVM: Consolidate userspace memory capability reporting into common code
KVM: Advertise the bug in memory region destruction as fixed
KVM: use cpumask_var_t for cpus_hardware_enabled
KVM: use modern cpumask primitives, no cpumask_t on stack
KVM: Extract core of kvm_flush_remote_tlbs/kvm_reload_remote_mmus
KVM: set owner of cpu and vm file operations
anon_inodes: use fops->owner for module refcount
x86: KVM guest: kvm_get_tsc_khz: return khz, not lpj
KVM: MMU: prepopulate the shadow on invlpg
KVM: MMU: skip global pgtables on sync due to cr3 switch
KVM: MMU: collapse remote TLB flushes on root sync
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Signed-off-by: Alan Cox <alan@redhat.com>
fs/devpts/inode.c:324: warning: 'compare_init_pts_sb' defined but not used
Just nail the oddments now while this code is being touched
To support containers, allow multiple instances of devpts filesystem, such
that indices of ptys allocated in one instance are independent of ptys
allocated in other instances of devpts.
But to preserve backward compatibility, enable this support for multiple
instances only if:
- CONFIG_DEVPTS_MULTIPLE_INSTANCES is set to Y, and
- '-o newinstance' mount option is specified while mounting devpts
To use multi-instance mount, a container startup script could:
$ ns_exec -cm /bin/bash
$ umount /dev/pts
$ mount -t devpts -o newinstance lxcpts /dev/pts
$ mount -o bind /dev/pts/ptmx /dev/ptmx
$ /usr/sbin/sshd -p 1234
where 'ns_exec -cm /bin/bash' is calls clone() with CLONE_NEWNS flag and execs
/bin/bash in the child process. A pty created by the sshd is not visible in
the original mount of /dev/pts.
USER-SPACE-IMPACT:
- See Documentation/fs/devpts.txt (included in next patch) for user-
space impact in multi-instance and mixed-mode operation.
TODO:
- Update mount(8), pts(4) man pages. Highlight impact of not
redirecting /dev/ptmx to /dev/pts/ptmx after a multi-instance mount.
Changelog[v6]:
- [Dave Hansen] Use new get_init_pts_sb() interface
- [Serge Hallyn] Don't bother displaying 'newinstance' in show_options
- [Serge Hallyn] Use macros (PARSE_REMOUNT/PARSE_MOUNT) instead of 0/1.
- [Serge Hallyn] Check error return from get_sb_single() (now
get_init_pts_sb())
- devpts_pty_kill(): don't dput error dentries
Changelog[v5]:
- Move get_sb_ref() definition to earlier patch
- Move usage info to Documentation/filesystems/devpts.txt (next patch)
- Make ptmx node even in init_pts_ns, now that default mode is 0000
(defined in earlier patch, enabled here).
- Cache ptmx dentry and use to update mode during remount
- Bugfix: explicitly ignore newinstance on remount (if newinstance was
specified on remount of initial mount, it would be ignored but
/proc/mounts would imply that the option was set)
Changelog[v4]:
- Update patch description to address H. Peter Anvin's comments
- Consolidate multi-instance mode code under new config token,
CONFIG_DEVPTS_MULTIPLE_INSTANCE.
- Move usage-details from patch description to
Changelog[v3]:
- Rename new mount option to 'newinstance'
- Create ptmx nodes only in 'newinstance' mounts
- Bugfix: parse_mount_options() modifies @data but since we need to
parse the @data twice (once in devpts_get_sb() and once during
do_remount_sb()), parse a local copy of @data in devpts_get_sb().
(restructured code in devpts_get_sb() to fix this)
Changelog[v2]:
- Support both single-mount and multiple-mount semantics and
provide '-onewmnt' option to select the semantics.
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
See comments in the function header for details. The new interface will
be used in a follow-on patch.
Changelog [v2]:
[Dave Hansen] Replace get_sb_ref() in fs/super.c with get_init_pts_sb()
and make the new interface private to devpts
/dev/ptmx is closely tied to the devpts filesystem. An open of /dev/ptmx,
allocates the next pty index and the associated device shows up in the
devpts fs as /dev/pts/n.
Wih multiple instancs of devpts filesystem, during an open of /dev/ptmx
we would be unable to determine which instance of the devpts is being
accessed.
So we move the 'ptmx' node into /dev/pts and use the inode of the 'ptmx'
node to identify the superblock and hence the devpts instance. This patch
adds ability for the kernel to internally create the [ptmx, c, 5:2] device
when mounting devpts filesystem. Since the ptmx node in devpts is new and
may surprise some userspace scripts, the default permissions for the new
node is 0000. These permissions can be changed either using chmod or by
remounting with the new '-o ptmxmode=0666' mount option.
Changelog[v5]:
- [Serge Hallyn bugfix]: Letting new_inode() assign inode number to
ptmx can collide with hand-assigning inode numbers to ptys. So,
hand-assign specific inode number to ptmx node also.
- [Serge Hallyn]: Maybe safer to grab root dentry mutex while creating
ptmx node
- [Bugfix with Serge Hallyn] Replace lookup_one_len() in mknod_ptmx()
wih d_alloc_name() (lookup during ->get_sb() locks up system). To
simplify patchset, fold the ptmx_dentry patch into this.
Changelog[v4]:
- Change default permissions of pts/ptmx node to 0000.
- Move code for ptmxmode under #ifdef CONFIG_DEVPTS_MULTIPLE_INSTANCES.
Changelog[v3]:
- Rename ptmx_mode to ptmxmode (for consistency with 'newinstance')
Changelog[v2]:
- [H. Peter Anvin] Remove mknod() system call support and create the
ptmx node internally.
Changelog[v1]:
- Earlier version of this patch enabled creating /dev/pts/tty as
well. As pointed out by Al Viro and H. Peter Anvin, that is not
really necessary.
Move code to parse mount options into a separate function so it can
(later) be shared between mount and remount operations.
With support for multiple mounts of devpts, the 'config' structure really
represents per-mount options rather than config parameters. Rename 'config'
structure to 'pts_mount_opts' and store it in the super-block.
To enable multiple mounts of devpts, 'allocated_ptys' must be a per-mount
variable rather than a global variable. Move 'allocated_ptys' into the
super_block's s_fs_info.
Changelog[v2]:
Define and use DEVPTS_SB() wrapper.
Remove the 'devpts_root' global variable and find the root dentry using
the super_block. The super-block can be found from the device inode, using
the new wrapper, pts_sb_from_inode().
Changelog: This patch is based on an earlier patchset from Serge Hallyn
and Matt Helsley.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (34 commits)
nfsd race fixes: jfs
nfsd race fixes: reiserfs
nfsd race fixes: ext4
nfsd race fixes: ext3
nfsd race fixes: ext2
nfsd/create race fixes, infrastructure
filesystem notification: create fs/notify to contain all fs notification
fs/block_dev.c: __read_mostly improvement and sb_is_blkdev_sb utilization
kill ->dir_notify()
filp_cachep can be static in fs/file_table.c
fix f_count description in Documentation/filesystems/files.txt
make INIT_FS use the __RW_LOCK_UNLOCKED initialization
take init_fs to saner place
kill vfs_permission
pass a struct path * to may_open
kill walk_init_root
remove incorrect comment in inode_permission
expand some comments (d_path / seq_path)
correct wrong function name of d_put in kernel document and source comment
fix switch_names() breakage in short-to-short case
jfs version of Al Viro's nfsd race patches
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
... and the same for reiserfs. The difference here is that we need
insert_inode_locked4() to match iget5_locked().
ext3 analog of the previous patch
* make ext2_new_inode() put the inode into icache in locked state
* do not unlock until the inode is fully set up; otherwise nfsd
might pick it in half-baked state.
* make sure that ext2_new_inode() does *not* lead to two inodes with the
same inumber hashed at the same time; otherwise a bogus fhandle coming
from nfsd might race with inode creation:
nfsd: iget_locked() creates inode
nfsd: try to read from disk, block on that.
ext2_new_inode(): allocate inode with that inumber
ext2_new_inode(): insert it into icache, set it up and dirty
ext2_write_inode(): get the relevant part of inode table in cache,
set the entry for our inode (and start writing to disk)
nfsd: get CPU again, look into inode table, see nice and sane on-disk
inode, set the in-core inode from it
oops - we have two in-core inodes with the same inumber live in icache,
both used for IO. Welcome to fs corruption...
new helpers - insert_inode_locked() and insert_inode_locked4().
Hash new inode, making sure that there's no such inode in icache
already. If there is and it does not end up unhashed (as would
happen if we have nfsd trying to resolve a bogus fhandle), fail.
Otherwise insert our inode into hash and succeed.
In either case have i_state set to new+locked; cleanup ends up
being simpler with such calling conventions.
Creating a generic filesystem notification interface, fsnotify, which will be
used by inotify, dnotify, and eventually fanotify is really starting to
clutter the fs directory. This patch simply moves inotify and dnotify into
fs/notify/inotify and fs/notify/dnotify respectively to make both current fs/
and future notification tidier.
Signed-off-by: Eric Paris <eparis@redhat.com>
- iget5_locked in bdget really needs blockdev_superblock, instead of
bd_mnt, so bd_mnt could be just a local variable;
- blockdev_superblock really needs __read_mostly, while local var bd_mnt
not;
- make use of sb_is_blkdev_sb in bd_forget, instead of direct reference
to blockdev_superblock.
Signed-off-by: Denis ChengRq <crquan@gmail.com>
Remove the hopelessly misguided ->dir_notify(). The only instance (cifs)
has been broken by design from the very beginning; the objects it creates
are never destroyed, keep references to struct file they can outlive, nothing
that could possibly evict them exists on close(2) path *and* no locking
whatsoever is done to prevent races with close(), should the previous, er,
deficiencies someday be dealt with.
Instead of creating the "filp" kmem_cache in vfs_caches_init(),
we can do it a litle be later in files_init(), so that filp_cachep
is static to fs/file_table.c
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
[AV: rediffed on top of unification of init_fs]
Initialization of init_fs still uses the deprecated RW_LOCK_UNLOCKED macro.
This patch updates it to use the __RW_LOCK_UNLOCKED(lock) macro.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
With all the nameidata removal there's no point anymore for this helper.
Of the three callers left two will go away with the next lookup series
anyway.
Also add proper kerneldoc to inode_permission as this is the main
permission check routine now.
No need for the nameidata in may_open - a struct path is enough.
walk_init_root is a tiny helper that is marked __always_inline, has just
one caller and an unused argument. Just merge it into the caller.
We now pass on all MAY_ flags to the filesystems permission routines,
so remove the comment stating the contrary.
Explain that you really need to use the return value of d_path rather than
the buffer you passed into it.
Also fix the comment for seq_path(), the function arguments changed
recently but the comment hadn't been updated in sync.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
no function named d_put(), it should be dput().
Impact: fix document and comment, no functionality changed
Signed-off-by: Zhao Lei <zhaolei@cn.fuijtsu.com>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
We want ->name.len to match the resulting name on *both*
source and target
Ensure fast symlink targets are NUL-terminated, even if corrupted
on-disk.
Cc: Sergey S. Kostyliov <rathamahata@php4.ru>
Signed-off-by: Duane Griffin <duaneg@dghda.com>
on-disk.
on-disk.
on-disk.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: adilger@sun.com
Cc: linux-ext4@vger.kernel.org
on-disk.
Cc: Stephen Tweedie <sct@redhat.com>
on-disk.
On-disk data corruption could cause a page link to have its i_size set
to PAGE_SIZE (or a multiple thereof) and its contents all non-NUL.
NUL-terminate the link name to ensure this doesn't cause further
problems for the kernel.
The result from readlink is being used to index into the link name
buffer without checking whether it is a valid length. If readlink
returns an error this will fault or cause memory corruption.
Cc: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
Cc: Dustin Kirkland <kirkland@canonical.com>
Cc: ecryptfs-devel@lists.launchpad.net
Acked-by: Michael Halcrow <mhalcrow@us.ibm.com>
Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
The extra semicolon serves no purpose.
Reviewed-by: Richard Genoud <richard.genoud@gmail.com>
