path: root/fs
2006-12-08[PATCH] struct path: make eCryptfs a user of struct pathJosef "Jeff" Sipek
Convert eCryptfs dentry-vfsmount pairs in dentry private data to struct path. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: move struct path from fs/namei.c into include/linuxJosef "Jeff" Sipek
Moved struct path from fs/namei.c to include/linux/namei.h. This allows many places in the VFS, as well as any stackable filesystem to easily keep track of dentry-vfsmount pairs. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: rename Reiserfs's struct pathJosef "Jeff" Sipek
Rename Reiserfs's struct path to struct treepath to prevent name collision between it and struct path from fs/namei.c. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] eCryptfs: Use fsstack's generic copy inode attr functionsJosef "Jeff" Sipek
Replace eCryptfs specific code & calls with the more generic fsstack equivalents and remove the eCryptfs specific functions. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] fsstack: Introduce fsstack_copy_{attr,inode}_*Josef "Jeff" Sipek
Introduce several fsstack_copy_* functions which allow stackable filesystems (such as eCryptfs and Unionfs) to easily copy over (currently only) inode attributes. This prevents code duplication and allows for code reuse. [akpm@osdl.org: Remove unneeded wrapper] [bunk@stusta.de: fs/stack.c should #include <linux/fs_stack.h>] Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] bdev: fix ->bd_part_count leakPeter Zijlstra
Don't leak a ->bd_part_count when the partition open fails with -ENXIO. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] lockdep: use mutex_lock_nested for bd_mutex to avoid lockdep warningNeilBrown
Now that the nesting in blkdev_{get,put} is simpler, adding mutex_lock_nested is trivial. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] lockdep: simplify some aspects of bd_mutex nestingNeilBrown
When we open (actually blkdev_get) a partition we need to also open (get) the whole device that holds the partition. The involves some limited recursion. This patch tries to simplify some aspects of this. As well as opening the whole device, we need to increment ->bd_part_count when a partition is opened (this is used by rescan_partitions to avoid a rescan if any partition is active, as that would be confusing). The main change this patch makes is to move the inc/dec of bd_part_count into blkdev_{get,put} for the whole rather than doing it in blkdev_{get,put} for the partition. More specifically, we introduce __blkdev_get and __blkdev_put which do exactly what blkdev_{get,put} did, only with an extra "for_part" argument (blkget_{get,put} then call the __ version with a '0' for the extra argument). If for_part is 1, then the blkdev is being get(put) because a partition is being opened(closed) for the first(last) time, and so bd_part_count should be updated (on success). The particular advantage of pushing this function down is that the bd_mutex lock (which is needed to update bd_part_count) is already held at the lower level. Note that this slightly changes the semantics of bd_part_count. Instead of updating it whenever a partition is opened or released, it is now only updated on the first open or last release. This is an adequate semantic as it is only ever tested for "== 0". Having introduced these functions we remove the current bd_part_count updates from do_open (which is really the body of blkdev_get) and call __blkdev_get(... 1). Similarly in blkget_put we remove the old bd_part_count updates and call __blkget_put(..., 1). This call is moved to the end of __blkdev_put to avoid nested locks of bd_mutex. Finally the mutex_lock on whole->bd_mutex in do_open can be removed. It was only really needed to protect bd_part_count, and that is now managed (and protected) within the recursive call. The observation that bd_part_count is central to the locking issues, and the modifications to create __blkdev_put are from Peter Zijlstra. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] lockdep: remove lock_key approach to managing nested bd_mutex locksNeilBrown
The extra call to get_gendisk is not good. It causes a ->probe and possible module load before it is really appropriate to do this. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] new bd_mutex lockdep annotationPeter Zijlstra
Use the gendisk partition number to set a lock class. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] remove the old bd_mutex lockdep annotationPeter Zijlstra
Remove the old complex and crufty bd_mutex annotation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] do_task_stat(): don't take tty_mutexOleg Nesterov
->signal->tty is protected by ->siglock, no need to take the global tty_mutex. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: ->signal->tty lockingPeter Zijlstra
Fix the locking of signal->tty. Use ->sighand->siglock to protect ->signal->tty; this lock is already used by most other members of ->signal/->sighand. And unless we are 'current' or the tasklist_lock is held we need ->siglock to access ->signal anyway. (NOTE: sys_unshare() is broken wrt ->sighand locking rules) Note that tty_mutex is held over tty destruction, so while holding tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys are governed by their open file handles. This leaves some holes for tty access from signal->tty (or any other non file related tty access). It solves the tty SLAB scribbles we were seeing. (NOTE: the change from group_send_sig_info to __group_send_sig_info needs to be examined by someone familiar with the security framework, I think it is safe given the SEND_SIG_PRIV from other __group_send_sig_info invocations) [schwidefsky@de.ibm.com: 3270 fix] [akpm@osdl.org: various post-viro fixes] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Fix linux banner utsname informationHerbert Poetzl
utsname information is shown in the linux banner, which also is used for /proc/version (which can have different utsname values inside a uts namespaces). this patch makes the varying data arguments and changes the string to a format string, using those arguments. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ext4 calls journal_stopRandy Dunlap
journal_stop() is not defined for ext4; change to ext4_journal_stop(). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
Conflicts: include/linux/sunrpc/xprt.h net/sunrpc/xprtsock.c Fix up conflicts with the workqueue changes.
2006-12-07Merge master.kernel.org:/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: (73 commits) [DLM] Clean up lowcomms [GFS2] Change gfs2_fsync() to use write_inode_now() [GFS2] Fix indent in recovery.c [GFS2] Don't flush everything on fdatasync [GFS2] Add a comment about reading the super block [GFS2] Mount problem with the GFS2 code [GFS2] Remove gfs2_check_acl() [DLM] fix format warnings in rcom.c and recoverd.c [GFS2] lock function parameter [DLM] don't accept replies to old recovery messages [DLM] fix size of STATUS_REPLY message [GFS2] fs/gfs2/log.c:log_bmap() fix printk format warning [DLM] fix add_requestqueue checking nodes list [GFS2] Fix recursive locking in gfs2_getattr [GFS2] Fix recursive locking in gfs2_permission [GFS2] Reduce number of arguments to meta_io.c:getbuf() [GFS2] Move gfs2_meta_syncfs() into log.c [GFS2] Fix journal flush problem [GFS2] mark_inode_dirty after write to stuffed file [GFS2] Fix glock ordering on inode creation ...
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4: Eliminate inline functionsAvantika Mathur
Removes all inline keywords, since the compiler will make static functions inline when it is appropriate. Signed-off-by: Avantika Mathur <mathur@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4: kmalloc to kzallocAvantika Mathur
Performs kmalloc to kzalloc conversion Signed-off-by: Avantika Mathur <mathur@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4: if expression formatAvantika Mathur
changes instances of if ((lhs = expression)) { to the preferred coding style lhs=expression; if (lhs) { Signed-off-by: Avantika Mathur <mathur@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3 balloc: fix _with_rsv freezeHugh Dickins
Port fix to the off-by-one in find_next_usable_block's memscan from ext2 to ext3; but it didn't cause a serious problem for ext3 because the additional ext3_test_allocatable check rescued it from the error. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3 balloc: use io_error labelHugh Dickins
ext3_new_blocks has a nice io_error label for setting -EIO, so goto that in the one place that doesn't already use it. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3 balloc: say rb_entry not list_entryHugh Dickins
The reservations tree is an rb_tree not a list, so it's less confusing to use rb_entry() than list_entry() - though they're both just container_of(). Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3 balloc: fix off-by-one against rsv_endHugh Dickins
rsv_end is the last block within the reservation, so alloc_new_reservation should accept start_block == rsv_end as success. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3 balloc: fix off-by-one against grp_goalHugh Dickins
grp_goal 0 is a genuine goal (unlike -1), so ext3_try_to_allocate_with_rsv should treat it as such. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3 balloc: reset windowsz when fullHugh Dickins
ext3_new_blocks should reset the reservation window size to 0 when squeezing the last blocks out of an almost full filesystem, so the retry doesn't skip any groups with less than half that free, reporting ENOSPC too soon. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4: fix credit calculation in ext4_ext_calc_credits_for_insertJohann Lombardi
Fix a nit in ext4_ext_calc_credits_for_insert(). Besides, credits for the new root are already added in the index split accounting. Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Alex Tomas <alex@clusterfs.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] aio: remove ki_retried debugging memberBenjamin LaHaise
Remove the ki_retried member from struct kiocb. I think the idea was bounced around a while back, but Arnaldo pointed out another reason that we should dig it up when he pointed out that the last cacheline of struct kiocb only contains 4 bytes. By removing the debugging member, we save more than the 8 byte on 64 bit machines. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Acked-by: Ken Chen <kenneth.w.chen@intel.com> Acked-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] aio: kill pointless ki_nbytes assignment in aio_setup_single_vectorChen, Kenneth W
io_submit_one assigns ki_left = ki_nbytes = iocb->aio_nbytes, then calls down to aio_setup_iocb, then to aio_setup_single_vector. In there, ki_nbytes is reassigned to the same value it got two call stack above it. There is no need to do so. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Acked-by: Zach Brown <zach.brown@oracle.com> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] do_coredump() and not stopping rewrite attacks?Alexey Dobriyan
On Sat, Dec 02, 2006 at 11:47:44PM +0300, Alexey Dobriyan wrote: > David Binderman compiled 2.6.19 with icc and grepped for "was set but never > used". Many warnings are on > http://coderock.org/kj/unused-2.6.19-fs Heh, the very first line: fs/exec.c(1465): remark #593: variable "flag" was set but never used fs/exec.c: 1477 /* 1478 * We cannot trust fsuid as being the "true" uid of the 1479 * process nor do we know its entire history. We only know it 1480 * was tainted so we dump it as root in mode 2. 1481 */ 1482 if (mm->dumpable == 2) { /* Setuid core dump mode */ 1483 flag = O_EXCL; /* Stop rewrite attacks */ 1484 current->fsuid = 0; /* Dump root private */ 1485 } And then filp_open follows with "flag" totally ignored. (akpm: this restores the code to Alan's original version. Andi's "Support piping into commands in /proc/sys/kernel/core_pattern" (cset d025c9db) broke it). Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <stable@kerenl.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fs: make nls_cp936.c handle some U00XY characters and U20AC correctlyJun Chen
Twenty characters in cp936 are not correctly handled. They're all in the U00 plane. nls_cp936 converts all U00XY to XY but this is not correct for some characters.(e.g. U00B7 -> A1A4, U00A8 -> A1A7). This problem is fixed by generating u2c_00 based on all c2u_xx and changing uni2char() to give U00 plane a special handling. The "€"(U20AC,80 in cp936) is also be handled properly. Acked-by: Gang Chen <cgdlut@gmail.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] jffs: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] affs: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] remove NFSD_OPTIMIZE_SPACEAdrian Bunk
This patch removes the unused NFSD_OPTIMIZE_SPACE. Additionally, it does differently what NFSD_OPTIMIZE_SPACE was supposed to do: Nowadays, gcc knows best when to inline code, and CONFIG_CC_OPTIMIZE_FOR_SIZE even tells gcc globally whether to optimize for size or for speed. Therefore, this patch also removes all inline's from these files. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fs: remove unused variableDavid Rientjes
Removed unused 'have_pt_gnu_stack' variable. Reported by David Binderman <dcb314@hotmail.com> Signed-off-by: David Rientjes <rientjes@cs.washington.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext3/4: don't do orphan processing on readonly devicesEric Sandeen
If you do something like: # touch foo # tail -f foo & # rm foo # <take snapshot> # <mount snapshot> you'll panic, because ext3/4 tries to do orphan list processing on the readonly snapshot device, and: kernel: journal commit I/O error kernel: Assertion failure in journal_flush_Rsmp_e2f189ce() at journal.c:1356: "!journal->j_checkpoint_transactions" kernel: Kernel panic: Fatal exception for a truly readonly underlying device, it's reasonable and necessary to just skip orphan list processing. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fs: ufs add missing bracketMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] proper prototype for remove_inode_dquot_ref()Adrian Bunk
Add a proper prototype for remove_inode_dquot_ref() in include/linux/quotaops.h Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fs/sysv/: doc cleanupAdrian Bunk
Remove two different changelog files from fs/sysv/ and merges the INTRO file into Documentation/filesystems/sysv-fs.txt Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] autofs: fix error code path in autofs_fill_sb()Jiri Kosina
When kernel is compiled with old version of autofs (CONFIG_AUTOFS_FS), and new (observed at least with 5.x.x) automount deamon is started, kernel correctly reports incompatible version of kernel and userland daemon, but then screws things up instead of correct handling of the error: autofs: kernel does not match daemon version ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- automount/4199 is trying to release lock (&type->s_umount_key) at: [<c0163b9e>] get_sb_nodev+0x76/0xa4 but there are no more locks to release! other info that might help us debug this: no locks held by automount/4199. stack backtrace: [<c0103b15>] dump_trace+0x68/0x1b2 [<c0103c77>] show_trace_log_lvl+0x18/0x2c [<c01041db>] show_trace+0xf/0x11 [<c010424d>] dump_stack+0x12/0x14 [<c012e02c>] print_unlock_inbalance_bug+0xe7/0xf3 [<c012fd4f>] lock_release+0x8d/0x164 [<c012b452>] up_write+0x14/0x27 [<c0163b9e>] get_sb_nodev+0x76/0xa4 [<c0163689>] vfs_kern_mount+0x83/0xf6 [<c016373e>] do_kern_mount+0x2d/0x3e [<c017513f>] do_mount+0x607/0x67a [<c0175224>] sys_mount+0x72/0xa4 [<c0102b96>] sysenter_past_esp+0x5f/0x99 DWARF2 unwinder stuck at sysenter_past_esp+0x5f/0x99 Leftover inexact backtrace: ======================= and then deadlock comes. The problem: autofs_fill_super() returns EINVAL to get_sb_nodev(), but before that, it calls kill_anon_super() to destroy the superblock which won't be needed. This is however way too soon to call kill_anon_super(), because get_sb_nodev() has to perform its own cleanup of the superblock first (deactivate_super(), etc.). The correct time to call kill_anon_super() is in the autofs_kill_sb() callback, which is called by deactivate_super() at proper time, when the superblock is ready to be killed. I can see the same faulty codepath also in autofs4. This patch solves issues in both filesystems in a same way - it postpones the kill_anon_super() until the proper time is signalized by deactivate_super() calling the kill_sb() callback. [raven@themaw.net: update comment] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Ian Kent <raven@themaw.net> Cc: <stable@kernel.org> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4 balloc: fix _with_rsv freezeHugh Dickins
Port fix to the off-by-one in find_next_usable_block's memscan from ext2 to ext4; but it didn't cause a serious problem for ext4 because the additional ext4_test_allocatable check rescued it from the error. [akpm@osdl.org: build fix] Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4 balloc: use io_error labelHugh Dickins
ext4_new_blocks has a nice io_error label for setting -EIO, so goto that in the one place that doesn't already use it. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4 balloc: say rb_entry not list_entryHugh Dickins
2006-12-07[PATCH] ext4 balloc: fix off-by-one against rsv_endHugh Dickins
2006-12-07[PATCH] ext4 balloc: fix off-by-one against grp_goalHugh Dickins
grp_goal 0 is a genuine goal (unlike -1), so ext4_try_to_allocate_with_rsv should treat it as such. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext4 balloc: reset windowsz when fullHugh Dickins
ext4_new_blocks should reset the reservation window size to 0 when squeezing the last blocks out of an almost full filesystem, so the retry doesn't skip any groups with less than half that free, reporting ENOSPC too soon. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] jbd2: wait for already submitted t_sync_datalist buffer to completeHisashi Hifumi
In the current jbd code, if a buffer on BJ_SyncData list is dirty and not locked, the buffer is refiled to BJ_Locked list, submitted to the IO and waited for IO completion. But the fsstress test showed the case that when a buffer was already submitted to the IO just before the buffer_dirty(bh) check, the buffer was not waited for IO completion. Following patch solves this problem. If it is assumed that a buffer is submitted to the IO before the buffer_dirty(bh) check and still being written to disk, this buffer is refiled to BJ_Locked list. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Jan Kara <jack@ucw.cz> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
