path: root/fs
2008-05-14clarify return value of cifs_convert_flags()Jeff Layton
cifs_convert_flags returns 0x20197 in the default case. It's not immediately evident where that number comes from, so change it to be an or'ed set of flags. The compiler will boil it down anyway. (Thanks to Guenter Kukkukk for clarifying the flags). Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-13[CIFS] don't explicitly do a FindClose on rewind when directory search has endedSteve French
Do the following series of operations on a CIFS share: opendir(dir) readdir(dir) unlink(file in dir) rewinddir(dir) readdir(dir) If the readdir read all entries in the directory this will make CIFS throw an error like this: CIFS VFS: Send error in FindClose = -9 CIFS requests "Close at end of search" of the server by setting this bit when issuing FindFirst or FindNext. Therefore when all search entries are returned, the server may return "end of search" and close the search implicitly when this bit is set by the client on the request. We check for this when a readdir is explicitly closed - but when the client notices that a directory has changed after the last operation, we attempt to close the directory before reopening by reissuing a second FindFirst. But, the directory may already been implicitly closed (due to end of search) because the first readdir finished. So we only want to issue a FindClose call in this case when we don't expect it to already be closed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-13[CIFS] cleanup old checkpatch warningsSteve French
2008-05-13[CIFS] CIFSSMBPosixLock should return -EINVAL on errorMarcin Slusarz
all other codepaths in this function return negative values on errors Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-13fix memory leak in CIFSFindNextJeff Layton
When CIFSFindNext gets back an -EBADF from a call, it sets the return code of the function to 0 and eventually exits. Doing this makes the cleanup at the end of the function skip freeing the SMB buffer, so we need to make sure we free the buffer explicitly when doing this. If we don't you end up with errors like this when unplugging the cifs kernel module: slab error in kmem_cache_destroy(): cache `cifs_request': Can't free all objects [<c046bdbf>] kmem_cache_destroy+0x61/0xf3 [<e0f03045>] cifs_destroy_request_bufs+0x14/0x28 [cifs] [<e0f2016e>] exit_cifs+0x1e/0x80 [cifs] [<c043aeae>] sys_delete_module+0x192/0x1b8 [<c04451fd>] audit_syscall_entry+0x14b/0x17d [<c0405413>] syscall_call+0x7/0xb ======================= Signed-off-by: Jeff Layton <jlayton@redhat.com>
2008-05-12[CIFS] CIFS currently allows for permissions to be changed on files, evenJeff Layton
when unix extensions and cifsacl support are disabled. These permissions changes are "ephemeral" however. They are lost whenever a share is mounted and unmounted, or when memory pressure forces the inode out of the cache. Because of this, we'd like to introduce a behavior change to make CIFS behave more like local DOS/Windows filesystems. When unix extensions and cifsacl support aren't enabled, then don't silently ignore changes to permission bits that can't be reflected on the server. Still, there may be people relying on the current behavior for certain applications. This patch adds a new "dynperm" (and a corresponding "nodynperm") mount option that will be intended to make the client fall back to legacy behavior when setting these modes. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] don't allow demultiplex thread to exit until kthread_stop is called [CIFS] when not using unix extensions, check for and set ATTR_READONLY on create and mkdir [CIFS] add local struct inode pointer to cifs_setattr [CIFS] cifs_find_tcp_session cleanup
2008-05-11Add new 'cond_resched_bkl()' helper functionLinus Torvalds
It acts exactly like a regular 'cond_resched()', but will not get optimized away when CONFIG_PREEMPT is set. Normal kernel code is already preemptable in the presense of CONFIG_PREEMPT, so cond_resched() is optimized away (see commit 02b67cc3ba36bdba351d6c3a00593f4ec550d9d3 "sched: do not do cond_resched() when CONFIG_PREEMPT"). But when wanting to conditionally reschedule while holding a lock, you need to use "cond_sched_lock(lock)", and the new function is the BKL equivalent of that. Also make fs/locks.c use it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-11[CIFS] don't allow demultiplex thread to exit until kthread_stop is calledSteve French
cifs_demultiplex_thread can exit under several conditions: 1) if it's signaled 2) if there's a problem with session setup 3) if kthread_stop is called on it The first two are problems. If kthread_stop is called on the thread, there is no guarantee that it will still be up. We need to have the thread stay up until kthread_stop is called on it. One option would be to not even try to tear things down until after kthread_stop is called. However, in the case where there is a problem setting up the session, there's no real reason to try continuing the loop. This patch allows the thread to clean up and prepare for exit under all three conditions, but it has the thread go to sleep until kthread_stop is called. This allows us to simplify the shutdown code somewhat since we can be reasonably sure that the thread won't exit after being signaled but before kthread_stop is called. It also removes the places where the thread itself set the tsk variable since it appeared that it could have a potential race where the thread might never be shut down. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-11[CIFS] when not using unix extensions, check for and set ATTR_READONLY on ↵Jeff Layton
create and mkdir When creating a directory on a CIFS share without POSIX extensions, and the given mode has no write bits set, set the ATTR_READONLY bit. When creating a file, set ATTR_READONLY if the create mode has no write bits set and we're not using unix extensions. There are some comments about this being problematic due to the VFS splitting creates into 2 parts. I'm not sure what that's actually talking about, but I'm assuming that it has something to do with how mknod is implemented. In the simple case where we have no unix extensions and we're just creating a regular file, there's no reason we can't set ATTR_READONLY. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-11[CIFS] add local struct inode pointer to cifs_setattrJeff Layton
Clean up cifs_setattr a bit by adding a local inode pointer, and changing all of the direntry->d_inode references to it. This also adds a bit of micro-optimization. d_inode shouldn't change over the life of this function, so we only need to dereference it once. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-11[CIFS] cifs_find_tcp_session cleanupCyrill Gorcunov
This patch cleans up cifs_find_tcp_session so it become less indented. Also the error of skipping IPv6 matched addresses fixed. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] fix build warning [CIFS] Fixed build warning in is_ip [CIFS] cleanup cifsd completion [CIFS] Remove over-indented code in find_unc(). [CIFS] fix typo [CIFS] Remove duplicate call to mode_to_acl [CIFS] convert usage of implicit booleans to bool [CIFS] fixed compatibility issue with samba refferal request [CIFS] Fix statfs formatting [CIFS] Adds to dns_resolver checking if the server name is an IP addr and skipping upcall in this case. [CIFS] Fix spelling mistake [CIFS] Update cifs version number
2008-05-09[CIFS] fix build warningSteve French
2008-05-08[CIFS] Fixed build warning in is_ipIgor Mammedov
Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-08fs/proc/task_mmu.c: remove duplicated include filesHuang Weiyi
Removed duplicated include files <linux/ptrace.h> and <linux/seq_file.h> in fs/proc/task_mmu.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: Revert "relay: fix splice problem" docbook: fix bio missing parameter block: use unitialized_var() in bio_alloc_bioset() block: avoid duplicate calls to get_part() in disk stat code cfq-iosched: make io priorities inherit CPU scheduling class as well as nice block: optimize generic_unplug_device() block: get rid of likely/unlikely predictions in merge logic vfs: splice remove_suid() cleanup cfq-iosched: fix RCU race in the cfq io_context destructor handling block: adjust tagging function queue bit locking block: sysfs store function needs to grab queue_lock and use queue_flag_*()
2008-05-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: udf: Fix memory corruption when fs mounted with noadinicb option udf: Make udf exportable udf: fs/udf/partition.c:udf_get_pblock() mustn't be inline
2008-05-08sys_pipe(): fix file descriptor leaksUlrich Drepper
Remember to close the files if copy_to_user() failed. Spotted by dm.n9107@gmail.com. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: DM <dm.n9107@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08Revert "relay: fix splice problem"Jens Axboe
This reverts commit c3270e577c18b3d0e984c3371493205a4807db9d.
2008-05-07docbook: fix bio missing parameterRandy Dunlap
Fix fs/bio.c kernel-doc parameter warning: Warning(linux-2.6.25-git14//fs/bio.c:972): No description found for parameter 'reading' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07block: use unitialized_var() in bio_alloc_bioset()Jens Axboe
Better than setting idx to some random value and it silences the same bogus gcc warning. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-07udf: Fix memory corruption when fs mounted with noadinicb optionJan Kara
When UDF filesystem is mounted with noadinicb mount option, it happens that we extend an empty directory with a block. A code in udf_add_entry() didn't count with this possibility and used uninitialized data leading to memory and filesystem corruption. Add a check whether file already has some extents before operating on them. Signed-off-by: Jan Kara <jack@suse.cz>
2008-05-07udf: Make udf exportableRasmus Rohde
Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Rasmus Rohde <rohde@duff.dk> Signed-off-by: Jan Kara <jack@suse.cz>
2008-05-07vfs: splice remove_suid() cleanupMiklos Szeredi
generic_file_splice_write() duplicates remove_suid() just because it doesn't hold i_mutex. But it grabs i_mutex inside splice_from_pipe() anyway, so this is rather pointless. Move locking to generic_file_splice_write() and call remove_suid() and __splice_from_pipe() instead. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-06[CIFS] cleanup cifsd completionSteve French
Was a holdover from the old kernel_thread based cifsd code. We needed to know that the thread had set the task variable before proceeding. Now that kthread_run returns the new task, this doesn't appear to be needed anymore. As best I can tell, this sleep was intended to try to prevent cifs_umount from freeing the cifsSesInfo struct before cifsd had exited. Now that cifsd is using the kthread API, we know that when kthread_stop returns that cifsd has exited, so I don't think this is needed any longer. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Christop Hellwig <hch@infradead.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-06[CIFS] Remove over-indented code in find_unc().Steve French
2008-05-06VFS: fix unused variable warningLinus Torvalds
Commit 33dcdac2df54e66c447ae03f58c95c7251aa5649 ("kill ->put_inode") removed the final use of i_op->put_inode, but left the now totally unused "op" variable in iput(). Get rid of it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-06[PATCH] fix SMP ordering hole in fcntl_setlk()Al Viro
fcntl_setlk()/close() race prevention has a subtle hole - we need to make sure that if we *do* have an fcntl/close race on SMP box, the access to descriptor table and inode->i_flock won't get reordered. As it is, we get STORE inode->i_flock, LOAD descriptor table entry vs. STORE descriptor table entry, LOAD inode->i_flock with not a single lock in common on both sides. We do have BKL around the first STORE, but check in locks_remove_posix() is outside of BKL and for a good reason - we don't want BKL on common path of close(2). Solution is to hold ->file_lock around fcheck() in there; that orders us wrt removal from descriptor table that preceded locks_remove_posix() on close path and we either come first (in which case eviction will be handled by the close side) or we'll see the effect of close and do eviction ourselves. Note that even though it's read-only access, we do need ->file_lock here - rcu_read_lock() won't be enough to order the things. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-06Merge branch 'master' of /pub/scm/linux/kernel/git/torvalds/linux-2.6Steve French
2008-05-06[PATCH] kill ->put_inodeChristoph Hellwig
And with that last patch to affs killing the last put_inode instance we can finally, after many years of transition kill this racy and awkward interface. (It's kinda funny that even the description in Documentation/filesystems/vfs.txt was entirely wrong..) Also remove a very misleading comment above the defintion of struct super_operations. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-06[PATCH] fix reservation discarding in affsRoman Zippel
- remove affs_put_inode, so preallocations aren't discared unnecessarily often. - remove affs_drop_inode, it's called with a spinlock held, so it can't use a mutex. - make i_opencnt atomic - avoid direct b_count manipulations - a few allocation failure fixes, so that these are more gracefully handled now. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-04task_nommu: fix compile failing bug because of spilt file.hBryan Wu
CC fs/proc/task_nommu.o fs/proc/task_nommu.c: In function ‘task_mem’: fs/proc/task_nommu.c:55: error: dereferencing pointer to incomplete type make[2]: *** [fs/proc/task_nommu.o] Error 1 make[1]: *** [fs/proc] Error 2 make: *** [fs] Error 2 Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) rose: Wrong list_lock argument in rose_node seqops netns: Fix reassembly timer to use the right namespace netns: Fix device renaming for sysfs bnx2: Update version to 1.7.5. bnx2: Update RV2P firmware for 5709. bnx2: Zero out context memory for 5709. bnx2: Fix register test on 5709. bnx2: Fix remote PHY initial link state. bnx2: Refine remote PHY locking. bridge: forwarding table information for >256 devices tg3: Update version to 3.92 tg3: Add link state reporting to UMP firmware tg3: Fix ethtool loopback test for 5761 BX devices tg3: Fix 5761 NVRAM sizes tg3: Use constant 500KHz MI clock on adapters with a CPMU hci_usb.h: fix hard-to-trigger race dccp: ccid2.c, ccid3.c use clamp(), clamp_t() net: remove NR_CPUS arrays in net/core/dev.c net: use get/put_unaligned_* helpers bluetooth: use get/put_unaligned_* helpers ...
2008-05-02[CIFS] fix typoSteve French
2008-05-02Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: ocfs2: Use GFP_NOFS in kmalloc during localalloc window move ocfs2: Allow uid/gid/perm changes of symlinks ocfs2/dlm: dlmdebug.c: make 2 functions static ocfs2: make struct o2cb_stack_ops static ocfs2: make struct ocfs2_control_device static ocfs2: Correct merge of 52f7c21 (Move /sys/o2cb to /sys/fs/o2cb)
2008-05-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] fix sysctl_nr_open bugs [PATCH] sanitize anon_inode_getfd() [PATCH] split linux/file.h [PATCH] make osf_select() use core_sys_select() [PATCH] remove horrors with irix tty ioctls handling [PATCH] fix file and descriptor handling in perfmon
2008-05-02netns: assign PDE->data before gluing entry into /proc treeDenis V. Lunev
In this unfortunate case, proc_mkdir_mode wrapper can't be used anymore and this is no way to reuse proc_create_data due to nlinks assignment. So, copy the code from proc_mkdir and assign PDE->data at the appropriate moment. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-01Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [MTD][NOR] Add physical address to point() method [JFFS2] Track parent inode for directories (for NFS export) [JFFS2] Invert last argument of jffs2_gc_fetch_inode(), make it boolean. [JFFS2] Quiet lockdep false positive. [JFFS2] Clean up jffs2_alloc_inode() and jffs2_i_init_once() [MTD] Delete long-unused jedec.h header file. [MTD] [NAND] at91_nand: use at91_nand_{en,dis}able consistently.
2008-05-01[MTD][NOR] Add physical address to point() methodJared Hulbert
Adding the ability to get a physical address from point() in addition to virtual address. This physical address is required for XIP of userspace code from flash. Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Reviewed-by: Jörn Engel <joern@logfs.org> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01[JFFS2] Track parent inode for directories (for NFS export)David Woodhouse
To support NFS export, we need to know the parent inode of directories. Rather than growing the jffs2_inode_cache structure, share space with the nlink field -- which was always set to 1 for directories anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01[PATCH] fix sysctl_nr_open bugsAl Viro
* if luser with root sets it to something that is not a multiple of BITS_PER_LONG, the system is screwed. * if it gets decreased at the wrong time, we can get expand_files() returning success and _not_ increasing the size of table as asked. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] sanitize anon_inode_getfd()Al Viro
a) none of the callers even looks at inode or file returned by anon_inode_getfd() b) any caller that would try to look at those would be racy, since by the time it returns we might have raced with close() from another thread and that file would be pining for fjords. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] make osf_select() use core_sys_select()Al Viro
... instead of open-coding it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[JFFS2] Invert last argument of jffs2_gc_fetch_inode(), make it boolean.David Woodhouse
We don't actually care about nlink; we only care whether the inode in question is unlinked or not. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01fuse: use clamp() rather than nested min/maxHarvey Harrison
clamp() exists for this use. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01autofs: path_{get,put}() cleanupsJan Blunck
Here are some more places where path_{get,put}() can be used instead of dput()/mntput() pair. Besides that it fixes a bug in autofs4_mount_busy() where mntput() was called before dput(). Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01autofs4: fix incorrect return from root.c:try_to_fill_dentry()Jeff Moyer
Jeff Moyer has identified a case where the autofs4 function root.c:try_to_fill_dentry() can return -EBUSY when it should return 0. Jeff's description of the way this happens is: "automount starts an expire for directory d. after the callout to the daemon, but before the rmdir, another process tries to walk into the same directory. It puts itself onto the waitq, pending the expiration. When the expire finishes, the second process is woken up. In try_to_fill_dentry, it does this check: status = d_invalidate(dentry); if (status != -EBUSY) return -EAGAIN; And status is EBUSY. The dentry still has a non-zero d_inode, and the flags do not contain LOOKUP_CONTINUE or LOOKUP_DIRECTORY So, we fall through and return -EBUSY to the caller." Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
