path: root/fs
2009-01-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix ioctl arg size (userland incompatible change!) Btrfs: Clear the device->running_pending flag before bailing on congestion
2009-01-16Btrfs: fix ioctl arg size (userland incompatible change!)Chris Mason
The structure used to send device in btrfs ioctl calls was not properly aligned, and so 32 bit ioctls would not work properly on 64 bit kernels. We could fix this with compat ioctls, but we're just one byte away and it doesn't make sense at this stage to carry about the compat ioctls forever at this stage in the project. This patch brings the ioctl arg up to an evenly aligned 4k. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-16Btrfs: Clear the device->running_pending flag before bailing on congestionChris Mason
Btrfs maintains a queue of async bio submissions so the checksumming threads don't have to wait on get_request_wait. In order to avoid extra wakeups, this code has a running_pending flag that is used to tell new submissions they don't need to wake the thread. When the threads notice congestion on a single device, they may decide to requeue the job and move on to other devices. This makes sure the running_pending flag is cleared before the job is requeued. It should help avoid IO stalls by making sure the task is woken up when new submissions come in. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-15ext2: also update the inode on disk when dir is IS_DIRSYNCJan Kara
We used to just write changed page for IS_DIRSYNC inodes. But we also have to update the directory inode itself just for the case that we've allocated a new block and changed i_size. [akpm@linux-foundation.org: still sync the data page] Signed-off-by: Jan Kara <jack@suse.cz> Tested-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15btrfs & squashfs: Move btrfs and squashfsto's magic number to <linux/magic.h>Qinghuang Feng
Use the standard magic.h for btrfs and squashfs. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14Merge branch 'syscalls' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'syscalls' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (44 commits) [CVE-2009-0029] s390 specific system call wrappers [CVE-2009-0029] System call wrappers part 33 [CVE-2009-0029] System call wrappers part 32 [CVE-2009-0029] System call wrappers part 31 [CVE-2009-0029] System call wrappers part 30 [CVE-2009-0029] System call wrappers part 29 [CVE-2009-0029] System call wrappers part 28 [CVE-2009-0029] System call wrappers part 27 [CVE-2009-0029] System call wrappers part 26 [CVE-2009-0029] System call wrappers part 25 [CVE-2009-0029] System call wrappers part 24 [CVE-2009-0029] System call wrappers part 23 [CVE-2009-0029] System call wrappers part 22 [CVE-2009-0029] System call wrappers part 21 [CVE-2009-0029] System call wrappers part 20 [CVE-2009-0029] System call wrappers part 19 [CVE-2009-0029] System call wrappers part 18 [CVE-2009-0029] System call wrappers part 17 [CVE-2009-0029] System call wrappers part 16 [CVE-2009-0029] System call wrappers part 15 ...
2009-01-14[CVE-2009-0029] System call wrappers part 33Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 32Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 31Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 30Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 29Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 28Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 27Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 23Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 21Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 20Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 19Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 17Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 16Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 15Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 14Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 13Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 12Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 11Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 10Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 09Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrapper special casesHeiko Carstens
System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Make sys_pselect7 staticHeiko Carstens
Not a single architecture has wired up sys_pselect7 plus it is the only system call with seven parameters. Just make it static and rename it to do_pselect which will do the work for sys_pselect6. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Remove __attribute__((weak)) from sys_pipe/sys_pipe2Heiko Carstens
Remove __attribute__((weak)) from common code sys_pipe implemantation. IA64, ALPHA, SUPERH (32bit) and SPARC (32bit) have own implemantations with the same name. Just rename them. For sys_pipe2 there is no architecture specific implementation. Cc: Richard Henderson <rth@twiddle.net> Cc: David S. Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Rename old_readdir to sys_old_readdirHeiko Carstens
This way it matches the generic system call name convention. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into ↵Lachlan McIlroy
for-linus
2009-01-13Fix timeouts in sys_pselect7Bernd Schmidt
Since we (Analog Devices) updated our Blackfin kernel to 2.6.28, we've seen occasional 5-second hangs from telnet. telnetd calls select with a NULL timeout, but with the new kernel, the system call occasionally returns 0, which causes telnet to call sleep (5). This did not happen with earlier kernels. The code in sys_pselect7 looks a bit strange, in particular the variable "to" is initialized to NULL, then changed if a non-null timeout was passed in, but not used further. It needs to be passed to core_sys_select instead of &end_time. This bug was introduced by 8ff3e8e85fa6c312051134b3953e397feb639f51 ("select: switch select() and poll() over to hrtimers"). Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Reviewed-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: change rsbtbl rwlock to spinlock dlm: fix seq_file usage in debugfs lock dump
2009-01-10btrfs: fix for write_super_lockfs/unlockfs error handlingLinus Torvalds
Commit c4be0c1dc4cdc37b175579be1460f15ac6495e9a added the ability for write_super_lockfs to return errors, and renamed them to match. But btrfs didn't get converted. Do the minimal conversion to make it compile again. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09filesystem freeze: remove XFS specific ioctl interfaces for freeze featureTakashi Sato
It removes XFS specific ioctl interfaces and request codes for freeze feature. This patch has been supplied by David Chinner. Signed-off-by: Dave Chinner <dgc@sgi.com> Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Cc: Dave Chinner <david@fromorbit.com> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09filesystem freeze: implement generic freeze featureTakashi Sato
The ioctls for the generic freeze feature are below. o Freeze the filesystem int ioctl(int fd, int FIFREEZE, arg) fd: The file descriptor of the mountpoint FIFREEZE: request code for the freeze arg: Ignored Return value: 0 if the operation succeeds. Otherwise, -1 o Unfreeze the filesystem int ioctl(int fd, int FITHAW, arg) fd: The file descriptor of the mountpoint FITHAW: request code for unfreeze arg: Ignored Return value: 0 if the operation succeeds. Otherwise, -1 Error number: If the filesystem has already been unfrozen, errno is set to EINVAL. [akpm@linux-foundation.org: fix CONFIG_BLOCK=n] Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Masayuki Hamaguchi <m-hamaguchi@ys.jp.nec.com> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09filesystem freeze: add error handling of write_super_lockfs/unlockfsTakashi Sato
Currently, ext3 in mainline Linux doesn't have the freeze feature which suspends write requests. So, we cannot take a backup which keeps the filesystem's consistency with the storage device's features (snapshot and replication) while it is mounted. In many case, a commercial filesystem (e.g. VxFS) has the freeze feature and it would be used to get the consistent backup. If Linux's standard filesystem ext3 has the freeze feature, we can do it without a commercial filesystem. So I have implemented the ioctls of the freeze feature. I think we can take the consistent backup with the following steps. 1. Freeze the filesystem with the freeze ioctl. 2. Separate the replication volume or create the snapshot with the storage device's feature. 3. Unfreeze the filesystem with the unfreeze ioctl. 4. Take the backup from the separated replication volume or the snapshot. This patch: VFS: Changed the type of write_super_lockfs and unlockfs from "void" to "int" so that they can return an error. Rename write_super_lockfs and unlockfs of the super block operation freeze_fs and unfreeze_fs to avoid a confusion. ext3, ext4, xfs, gfs2, jfs: Changed the type of write_super_lockfs and unlockfs from "void" to "int" so that write_super_lockfs returns an error if needed, and unlockfs always returns 0. reiserfs: Changed the type of write_super_lockfs and unlockfs from "void" to "int" so that they always return 0 (success) to keep a current behavior. Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Masayuki Hamaguchi <m-hamaguchi@ys.jp.nec.com> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09CORE_DUMP_DEFAULT_ELF_HEADERS depends on ELF_COREDavid Brownell
Kernels that don't support ELF coredumps at all surely can't be supporting new partial-segment flavored ELF coredumps ... don't make folk answer Kconfig questions about that flavor. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async-2Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async-2: async: make async a command line option for now partial revert of asynchronous inode delete
2009-01-09Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [JFFS2] remove junk prototypes
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: MAINTAINERS: squashfs entry Squashfs: documentation Squashfs: initrd support Squashfs: Kconfig entry Squashfs: Makefiles Squashfs: header files Squashfs: block operations Squashfs: cache operations Squashfs: uid/gid lookup operations Squashfs: fragment block operations Squashfs: export operations Squashfs: super block operations Squashfs: symlink operations Squashfs: regular file operations Squashfs: directory readdir operations Squashfs: directory lookup operations Squashfs: inode operations
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-09partial revert of asynchronous inode deleteArjan van de Ven
let the core of this one bake in -next as well, but leave some of the infrastructure in place. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-09[JFFS2] remove junk prototypesArtem Bityutskiy
'rb_prev()', 'rb_next()' and 'rb_replace_node()' are declared in include/linux/rbtree.h, no need for JFFS2 to re-declare them. I believe these are left-overs from the old days when the common RB tree code did not have those call and JFFS2 had private implementation. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (864 commits) Btrfs: explicitly mark the tree log root for writeback Btrfs: Drop the hardware crc32c asm code Btrfs: Add Documentation/filesystem/btrfs.txt, remove old COPYING Btrfs: kmap_atomic(KM_USER0) is safe for btrfs_readpage_end_io_hook Btrfs: Don't use kmap_atomic(..., KM_IRQ0) during checksum verifies Btrfs: tree logging checksum fixes Btrfs: don't change file extent's ram_bytes in btrfs_drop_extents Btrfs: Use btrfs_join_transaction to avoid deadlocks during snapshot creation Btrfs: drop remaining LINUX_KERNEL_VERSION checks and compat code Btrfs: drop EXPORT symbols from extent_io.c Btrfs: Fix checkpatch.pl warnings Btrfs: Fix free block discard calls down to the block layer Btrfs: avoid orphan inode caused by log replay Btrfs: avoid potential super block corruption Btrfs: do not call kfree if kmalloc failed in btrfs_sysfs_add_super Btrfs: fix a memory leak in btrfs_get_sb Btrfs: Fix typo in clear_state_cb Btrfs: Fix memset length in btrfs_file_write Btrfs: update directory's size when creating subvol/snapshot Btrfs: add permission checks to the ioctls ...
2009-01-09Merge branch 'for-2.6.29' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.29' of git://git.kernel.dk/linux-2.6-block: block: fix bug in ptbl lookup cache
2009-01-09block: fix bug in ptbl lookup cacheNeil Brown
Neil writes: Hi Jens, I've found a little bug for you. It was introduced by a6f23657d3072bde6844055bbc2290e497f33fbc block: add one-hit cache for disk partition lookup and has the effect of killing my machine whenever I try to assemble an md array :-( One of the devices in the array has partitions, and mdadm always deletes partitions before putting a whole-device in an array (as it can cause confusion). The next IO to that device locks the machine. I don't really understand exactly why it locks up, but it happens in disk_map_sector_rcu(). This patch fixes it. Which is due to a missing clear of the (now) stale partition lookup data. So clear that when we delete a partition. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
* git://git.infradead.org/mtd-2.6: (67 commits) [MTD] [MAPS] Fix printk format warning in nettel.c [MTD] [NAND] add cmdline parsing (mtdparts=) support to cafe_nand [MTD] CFI: remove major/minor version check for command set 0x0002 [MTD] [NAND] ndfc driver [MTD] [TESTS] Fix some size_t printk format warnings [MTD] LPDDR Makefile and KConfig [MTD] LPDDR extended physmap driver to support LPDDR flash [MTD] LPDDR added new pfow_base parameter [MTD] LPDDR Command set driver [MTD] LPDDR PFOW definition [MTD] LPDDR QINFO records definitions [MTD] LPDDR qinfo probing. [MTD] [NAND] pxa3xx: convert from ns to clock ticks more accurately [MTD] [NAND] pxa3xx: fix non-page-aligned reads [MTD] [NAND] fix nandsim sched.h references [MTD] [NAND] alauda: use USB API functions rather than constants [MTD] struct device - replace bus_id with dev_name(), dev_set_name() [MTD] fix m25p80 64-bit divisions [MTD] fix dataflash 64-bit divisions [MTD] [NAND] Set the fsl elbc ECCM according the settings in bootloader. ... Fixed up trivial debug conflicts in drivers/mtd/devices/{m25p80.c,mtd_dataflash.c}
2009-01-09Btrfs: explicitly mark the tree log root for writebackChris Mason
Each subvolume has an extent_state_tree used to mark metadata that needs to be sent to disk while syncing the tree. This is used in addition to the dirty bits on the pages themselves so that a single subvolume can be sent to disk efficiently in disk order. Normally this marking happens in btrfs_alloc_free_block, which also does special recording of dirty tree blocks for the tree log roots. Yan Zheng noticed that when the root of the log tree is allocated, it is added to the wrong writeback list. The fix used here is to explicitly set it dirty as part of tree log creation. Signed-off-by: Chris Mason <chris.mason@oracle.com>
