This change is necessary for the SCSI target usb gadget composed with
configfs. In this case configfs will be used for two different purposes:
to compose a usb gadget and to configure the target part. If an instance
of tcm function is created in $CONFIGFS_ROOT/usb_gadget/<gadget>/functions
a tpg can be created in $CONFIGFS_ROOT/target/usb_gadget/<wwn>/, but after
a tpg is created the tcm function must not be removed until its
corresponding tpg is gone. While the configfs_depend/undepend_item() are
meant exactly for creating this kind of dependencies, they are not suitable
if the other kernel subsystem happens to be another subsystem in configfs,
so this patch adds unlocked versions meant for configfs callbacks.
Above description has been provided by:
Andrzej Pietrasiewicz <andrzej.p@samsung.com>
In configfs_depend_item() we have to consider two possible cases:
1) When we are called to depend another item in the same subsystem
as caller
In this case we should skip locking configfs root as we know
that configfs is in valid state and our subsystem will not
be unregistered during this call.
2) When we are called to depend item in different subsystem than
our caller
In this case we are also sure that configfs is in valid state
but we have to lock root of configfs to avoid unregistration
of target's subsystem. As it is other than caller's subsystem,
there may be nothing what protects us against unregistration
of that subsystem.
Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com>
configfs_depend_item() is quite complicated and should
be split up into smaller functions. This also allow to
share this code with other functions.
subsys parameter is never used by configfs_undepend_item()
so there is no point in passing it to this function.
Merge misc fixes from Andrew Morton:
"A bunch of fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
slub: mark the dangling ifdef #else of CONFIG_SLUB_DEBUG
slub: avoid irqoff/on in bulk allocation
slub: create new ___slab_alloc function that can be called with irqs disabled
mm: fix up sparse warning in gfpflags_allow_blocking
ocfs2: fix umask ignored issue
PM/OPP: add entry in MAINTAINERS
kernel/panic.c: turn off locks debug before releasing console lock
kernel/signal.c: unexport sigsuspend()
kasan: fix kmemleak false-positive in kasan_module_alloc()
fat: fix fake_offset handling on error path
mm/hugetlbfs: fix bugs in fallocate hole punch of areas with holes
mm/page-writeback.c: initialize m_dirty to avoid compile warning
various: fix pci_set_dma_mask return value checking
mm: loosen MADV_NOHUGEPAGE to enable Qemu postcopy on s390
mm: vmalloc: don't remove inexistent guard hole in remove_vm_area()
tools/vm/page-types.c: support KPF_IDLE
ncpfs: don't allow negative timeouts
configfs: allow dynamic group creation
MAINTAINERS: add Moritz as reviewer for FPGA Manager Framework
slab.h: sprinkle __assume_aligned attributes
New created file's mode is not masked with umask, and this makes umask not
work for ocfs2 volume.
Fixes: 702e5bc ("ocfs2: use generic posix ACL infrastructure")
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Gang He <ghe@suse.com>
Cc: Mark Fasheh <mfasheh@suse.de>
Cc: <stable@vger.kernel.org>
For the root directory, . and .. are faked (using dir_emit_dots()) and
ctx->pos is reset from 2 to 0.
A corrupted root directory could cause fat_get_entry() to fail, but
->iterate() (fat_readdir()) reports progress to the VFS (with ctx->pos
rewound to 0), so any following calls to ->iterate() continue to return
the same entries again and again.
The result is that userspace will never see the end of the directory,
causing e.g. 'ls' to hang in a getdents() loop.
[hirofumi@mail.parknet.co.jp: cleanup and make sure to correct fake_offset]
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Tested-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Richard Weinberger <richard.weinberger@gmail.com>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Hugh Dickins pointed out problems with the new hugetlbfs fallocate hole
punch code. These problems are in the routine remove_inode_hugepages and
mostly occur in the case where there are holes in the range of pages to be
removed. These holes could be the result of a previous hole punch or
simply sparse allocation. The current code could access pages outside the
specified range.
remove_inode_hugepages handles both hole punch and truncate operations.
Page index handling was fixed/cleaned up so that the loop index always
matches the page being processed. The code now only makes a single pass
through the range of pages as it was determined page faults could not race
with truncate. A cond_resched() was added after removing up to
PAGEVEC_SIZE pages.
Some totally unnecessary code in hugetlbfs_fallocate() that remained from
early development was also removed.
Tested with fallocate tests submitted here:
http://librelist.com/browser//libhugetlbfs/2015/6/25/patch-tests-add-tests-for-fallocate-system-call/
And, some ftruncate tests under development
Fixes: b5cec28d36f5 ("hugetlbfs: truncate_hugepages() takes a range of pages")
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: "Hillf Danton" <hillf.zj@alibaba-inc.com>
Cc: <stable@vger.kernel.org> [4.3]
This code causes a static checker warning because it's a user controlled
variable where we cap the upper bound but not the lower bound. Let's
return an -EINVAL for negative timeouts.
[akpm@linux-foundation.org: remove unneeded `else']
Reviewed-by: Jan Kara <jack@suse.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Jan Kara <jack@suse.cz>
This patchset introduces IIO software triggers, offers a way of configuring
them via configfs and adds the IIO hrtimer based interrupt source to be used
with software triggers.
The architecture is now split in 3 parts, to remove all IIO trigger specific
parts from IIO configfs core:
(1) IIO configfs - creates the root of the IIO configfs subsys.
(2) IIO software triggers - software trigger implementation, dynamically
creating /config/iio/triggers group.
(3) IIO hrtimer trigger - is the first interrupt source for software triggers
(with syfs to follow). Each trigger type can implement its own set of
attributes.
Lockdep seems to be happy with the locking in configfs patch.
This patch (of 5):
We don't want to hardcode default groups at subsystem
creation time. We export:
* configfs_register_group
* configfs_unregister_group
to allow drivers to programatically create/destroy groups
later, after module init time.
This is needed for IIO configfs support.
(akpm: the other 4 patches to be merged via the IIO tree)
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Suggested-by: Lars-Peter Clausen <lars@metafoo.de>
Acked-by: Joel Becker <jlbec@evilplan.org>
Cc: Hartmut Knaack <knaack.h@gmx.de>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Adriana Reus <adriana.reus@intel.com>
Cc: Cristina Opriceana <cristina.opriceana@gmail.com>
Cc: Peter Meerwald <pmeerw@pmeerw.net>
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
- A collection of crash and deadlock fixes for DAX that are also tagged
for -stable. We will look to re-enable DAX pmd mappings in 4.5, but
for now 4.4 and -stable should disable it by default.
- A fixup to ext2 and ext4 to mirror the same warning emitted by XFS
when mounting with "-o dax"
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
block: protect rw_page against device teardown
mm, dax: fix DAX deadlocks (COW fault)
dax: disable pmd mappings
ext2, ext4: warn when mounting with dax enabled
Fix use after free crashes like the following:
general protection fault: 0000 [#1] SMP
Call Trace:
[<ffffffffa0050216>] ? pmem_do_bvec.isra.12+0xa6/0xf0 [nd_pmem]
[<ffffffffa0050ba2>] pmem_rw_page+0x42/0x80 [nd_pmem]
[<ffffffff8128fd90>] bdev_read_page+0x50/0x60
[<ffffffff812972f0>] do_mpage_readpage+0x510/0x770
[<ffffffff8128fd20>] ? I_BDEV+0x20/0x20
[<ffffffff811d86dc>] ? lru_cache_add+0x1c/0x50
[<ffffffff81297657>] mpage_readpages+0x107/0x170
[<ffffffff8129058d>] blkdev_readpages+0x1d/0x20
[<ffffffff811d615f>] __do_page_cache_readahead+0x28f/0x310
[<ffffffff811d6039>] ? __do_page_cache_readahead+0x169/0x310
[<ffffffff811c5abd>] ? pagecache_get_page+0x2d/0x1d0
[<ffffffff811c76f6>] filemap_fault+0x396/0x530
[<ffffffff811f816e>] __do_fault+0x4e/0xf0
[<ffffffff811fce7d>] handle_mm_fault+0x11bd/0x1b50
Cc: Jens Axboe <axboe@fb.com>
Reported-by: kbuild test robot <lkp@intel.com>
Acked-by: Matthew Wilcox <willy@linux.intel.com>
[willy: symmetry fixups]
While dax pmd mappings are functional in the nominal path they trigger
kernel crashes in the following paths:
BUG: unable to handle kernel paging request at ffffea0004098000
IP: [<ffffffff812362f7>] follow_trans_huge_pmd+0x117/0x3b0
Call Trace:
[<ffffffff811f6573>] follow_page_mask+0x2d3/0x380
[<ffffffff811f6708>] __get_user_pages+0xe8/0x6f0
[<ffffffff811f7045>] get_user_pages_unlocked+0x165/0x1e0
[<ffffffff8106f5b1>] get_user_pages_fast+0xa1/0x1b0
kernel BUG at arch/x86/mm/gup.c:131!
Call Trace:
[<ffffffff8106f34c>] gup_pud_range+0x1bc/0x220
[<ffffffff8106f634>] get_user_pages_fast+0x124/0x1b0
BUG: unable to handle kernel paging request at ffffea0004088000
IP: [<ffffffff81235f49>] copy_huge_pmd+0x159/0x350
Call Trace:
[<ffffffff811fad3c>] copy_page_range+0x34c/0x9f0
[<ffffffff810a0daf>] copy_process+0x1b7f/0x1e10
[<ffffffff810a11c1>] _do_fork+0x91/0x590
All of these paths are interpreting a dax pmd mapping as a transparent
huge page and making the assumption that the pfn is covered by the
memmap, i.e. that the pfn has an associated struct page. PTE mappings
do not suffer the same fate since they have the _PAGE_SPECIAL flag to
cause the gup path to fault. We can do something similar for the PMD
path, or otherwise defer pmd support for cases where a struct page is
available. For now, 4.4-rc and -stable need to disable dax pmd support
by default.
For development the "depends on BROKEN" line can be removed from
CONFIG_FS_DAX_PMD.
Cc: Jan Kara <jack@suse.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Reported-by: Ross Zwisler <ross.zwisler@linux.intel.com>
fs/cachefiles/rdwr.c: In function ‘cachefiles_write_page’:
fs/cachefiles/rdwr.c:882: warning: ‘ret’ may be used uninitialized in
this function
If the jump to label "error" is taken, "ret" will indeed be
uninitialized, and random stack data may be printed by the debug code.
Fixes: 102f4d900c9c8f5e ("FS-Cache: Handle a write to the page immediately beyond the EOF marker")
Similar to XFS warn when mounting DAX while it is still considered under
development. Also, aspects of the DAX implementation, for example
synchronization against multiple faults and faults causing block
allocation, depend on the correct implementation in the filesystem. The
maturity of a given DAX implementation is filesystem specific.
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-ext4@vger.kernel.org
Reported-by: Dave Chinner <david@fromorbit.com>
Acked-by: Jan Kara <jack@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform
Pull chrome platform updates from Olof Johansson:
"Here's the branch of chrome platform changes for v4.4. Some have been
queued up for the full 4.3 release cycle since I forgot to send them
in for that round (rebased early on to deal with fixes conflicts).
Most of these enable EC communication stuff -- Pixel 2015 support,
enabling building for ARM64 platforms, and a few fixes for memory
leaks.
There's also a patch in here to allow reading/writing the verified
boot context, which depends on a sysfs patch acked by Greg"
* tag 'chrome-platform-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform:
platform/chrome: Fix i2c-designware adapter name
platform/chrome: Support reading/writing the vboot context
sysfs: Support is_visible() on binary attributes
platform/chrome: cros_ec: Fix possible leak in led_rgb_store()
platform/chrome: cros_ec: Fix leak in sequence_store()
platform/chrome: Enable Chrome platforms on 64-bit ARM
platform/chrome: cros_ec_dev - Add a platform device ID table
platform/chrome: cros_ec_lpc - Add support for Google Pixel 2
platform/chrome: cros_ec_lpc - Use existing function to check EC result
platform/chrome: Make depends on MFD_CROS_EC instead CROS_EC_PROTO
Revert "platform/chrome: Don't make CHROME_PLATFORMS depends on X86 || ARM"
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: use per-attribute show and store methods
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
Pull vfs xattr cleanups from Al Viro.
* 'for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
f2fs: xattr simplifications
squashfs: xattr simplifications
9p: xattr simplifications
xattr handlers: Pass handler to operations instead of flags
jffs2: Add missing capability check for listing trusted xattrs
hfsplus: Remove unused xattr handler list operations
ubifs: Remove unused security xattr handler
vfs: Fix the posix_acl_xattr_list return value
vfs: Check attribute names in posix acl xattr handers
- three fixes tagged for -stable including a crash fix, simple
performance tweak, and an invalid i/o error.
- build regression fix for the nvdimm unit tests
- nvdimm documentation update
dax: fix __dax_pmd_fault crash
libnvdimm: documentation clarifications
libnvdimm, pmem: fix size trim in pmem_direct_access()
libnvdimm, e820: fix numa node for e820-type-12 pmem ranges
tools/testing/nvdimm, acpica: fix flag rename build breakage
Now that the xattr handler is passed to the xattr handler operations, we
have access to the attribute name prefix, so simplify
f2fs_xattr_generic_list.
Also, f2fs_xattr_advise_list is only ever called for
f2fs_xattr_advise_handler; there is no need to double check for that.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: Changman Lee <cm224.lee@samsung.com>
Cc: Chao Yu <chao2.yu@samsung.com>
Cc: linux-f2fs-devel@lists.sourceforge.net
have access to the attribute name prefix, so simplify the squashfs xattr
handlers a bit.
Cc: Phillip Lougher <phillip@squashfs.org.uk>
can use the same get and set operations for the user, trusted, and security
xattr namespaces. In those namespaces, we can access the full attribute
name by "reattaching" the name prefix the vfs has skipped for us. Add a
xattr_full_name helper to make this obvious in the code.
For the "system.posix_acl_access" and "system.posix_acl_default"
attributes, handler->prefix is the full attribute name; the suffix is the
empty string.
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Cc: v9fs-developer@lists.sourceforge.net
The xattr_handler operations are currently all passed a file system
specific flags value which the operations can use to disambiguate between
different handlers; some file systems use that to distinguish the xattr
namespace, for example. In some oprations, it would be useful to also have
access to the handler prefix. To allow that, pass a pointer to the handler
to operations instead of the flags value alone.
The vfs checks if a task has the appropriate access for get and set
operations, but it cannot do that for the list operation; the file system
must check for that itself.
Cc: linux-mtd@lists.infradead.org
The list operations can never be called; they are even documented to be
unused.
Ubifs installs a security xattr handler in sb->s_xattr but doesn't use the
generic_{get,set,list,remove}xattr inode operations needed for processing
this list of attribute handlers; the handler is never called. Instead,
ubifs uses its own xattr handlers which also process security xattrs.
Remove the dead code.
Reviewed-by: Richard Weinberger <richard@nod.at>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Subodh Nijsure <snijsure@grid-net.com>
When a filesystem that contains POSIX ACLs is mounted without ACL support
(-o noacl), the appropriate behavior is not to list any existing POSIX ACL
xattrs. The return value for list xattr handlers in this case is 0, not an
error code: several filesystems that use the POSIX ACL xattr handlers do
not expect the list operation to fail.
Symlinks cannot have ACLs, so posix_acl_xattr_list will never be called for
symlinks in the first place.
The get and set operations of the POSIX ACL xattr handlers failed to check
the attribute names, so all names with "system.posix_acl_access" or
"system.posix_acl_default" as a prefix were accepted. Reject invalid names
from now on.
Pull SMB3 updates from Steve French:
"A collection of SMB3 patches adding some reliability features
(persistent and resilient handles) and improving SMB3 copy offload.
I will have some additional patches for SMB3 encryption and SMB3.1.1
signing (important security features), and also for improving SMB3
persistent handle reconnection (setting ChannelSequence number e.g.)
that I am still working on but wanted to get this set in since they
can stand alone"
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6:
Allow copy offload (CopyChunk) across shares
Add resilienthandles mount parm
[SMB3] Send durable handle v2 contexts when use of persistent handles required
[SMB3] Display persistenthandles in /proc/mounts for SMB3 shares if enabled
[SMB3] Enable checking for continuous availability and persistent handle support
[SMB3] Add parsing for new mount option controlling persistent handles
Allow duplicate extents in SMB3 not just SMB3.1.1
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes and cleanups from Chris Mason:
"Some of this got cherry-picked from a github repo this week, but I
verified the patches.
We have three small scrub cleanups and a collection of fixes"
* 'for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
btrfs: Use fs_info directly in btrfs_delete_unused_bgs
btrfs: Fix lost-data-profile caused by balance bg
btrfs: Fix lost-data-profile caused by auto removing bg
btrfs: Remove len argument from scrub_find_csum
btrfs: Reduce unnecessary arguments in scrub_recheck_block
btrfs: Use scrub_checksum_data and scrub_checksum_tree_block for scrub_recheck_block_checksum
btrfs: Reset sblock->xxx_error stats before calling scrub_recheck_block_checksum
btrfs: scrub: setup all fields for sblock_to_check
btrfs: scrub: set error stats when tree block spanning stripes
Btrfs: fix race when listing an inode's xattrs
Btrfs: fix race leading to BUG_ON when running delalloc for nodatacow
Btrfs: fix race leading to incorrect item deletion when dropping extents
Btrfs: fix sleeping inside atomic context in qgroup rescan worker
Btrfs: fix race waiting for qgroup rescan worker
btrfs: qgroup: exit the rescan worker during umount
Btrfs: fix extent accounting for partial direct IO writes
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph updates from Sage Weil:
"There are several patches from Ilya fixing RBD allocation lifecycle
issues, a series adding a nocephx_sign_messages option (and associated
bug fixes/cleanups), several patches from Zheng improving the
(directory) fsync behavior, a big improvement in IO for direct-io
requests when striping is enabled from Caifeng, and several other
small fixes and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
libceph: clear msg->con in ceph_msg_release() only
libceph: add nocephx_sign_messages option
libceph: stop duplicating client fields in messenger
libceph: drop authorizer check from cephx msg signing routines
libceph: msg signing callouts don't need con argument
libceph: evaluate osd_req_op_data() arguments only once
ceph: make fsync() wait unsafe requests that created/modified inode
ceph: add request to i_unsafe_dirops when getting unsafe reply
libceph: introduce ceph_x_authorizer_cleanup()
ceph: don't invalidate page cache when inode is no longer used
rbd: remove duplicate calls to rbd_dev_mapping_clear()
rbd: set device_type::release instead of device::release
rbd: don't free rbd_dev outside of the release callback
rbd: return -ENOMEM instead of pool id if rbd_dev_create() fails
libceph: use local variable cursor instead of &msg->cursor
libceph: remove con argument in handle_reply()
ceph: combine as many iovec as possile into one OSD request
ceph: fix message length computation
ceph: fix a comment typo
rbd: drop null test before destroy functions
Since 4.3 introduced devm_memremap_pages() the pfns handled by DAX may
optionally have a struct page backing. When a mapped pfn reaches
vmf_insert_pfn_pmd() it fails with a crash signature like the following:
kernel BUG at mm/huge_memory.c:905!
Call Trace:
[<ffffffff812a73ba>] __dax_pmd_fault+0x2ea/0x5b0
[<ffffffffa01a4182>] xfs_filemap_pmd_fault+0x92/0x150 [xfs]
[<ffffffff811fbe02>] handle_mm_fault+0x312/0x1b50
Fix this by falling back to 4K mappings in the pfn_valid() case. Longer
term, vmf_insert_pfn_pmd() needs to grow support for architectures that
can provide a 'pmd_special' capability.
Pull misc block fixes from Jens Axboe:
"Stuff that got collected after the merge window opened. This
contains:
- NVMe:
- Fix for non-striped transfer size setting for NVMe from
Sathyavathi.
- (Some) support for the weird Apple nvme controller in the
macbooks. From Stephan Günther.
- The error value leak for dax from Al.
- A few minor blk-mq tweaks from me.
- Add the new linux-block@vger.kernel.org mailing list to the
MAINTAINERS file.
- Discard fix for brd, from Jan.
- A kerneldoc warning for block core from Randy.
- An older fix from Vivek, converting a WARN_ON() to a rate limited
printk when a device is hot removed with dirty inodes"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: don't hardcode blk_qc_t -> tag mask
dax_io(): don't let non-error value escape via retval instead of EFAULT
block: fix blk-core.c kernel-doc warning
fs/block_dev.c: Remove WARN_ON() when inode writeback fails
NVMe: add support for Apple NVMe controller
NVMe: use split lo_hi_{read,write}q
blk-mq: mark __blk_mq_complete_request() static
MAINTAINERS: add reference to new linux-block list
NVMe: Increase the max transfer size when mdts is 0
brd: Refuse improperly aligned discard requests
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs updates from Dave Chinner:
"There is nothing really major here - the only significant addition is
the per-mount operation statistics infrastructure. Otherwises there's
various ACL, xattr, DAX, AIO and logging fixes, and a smattering of
small cleanups and fixes elsewhere.
Summary:
- per-mount operational statistics in sysfs
- fixes for concurrent aio append write submission
- various logging fixes
- detection of zeroed logs and invalid log sequence numbers on v5 filesystems
- memory allocation failure message improvements
- a bunch of xattr/ACL fixes
- fdatasync optimisation
- miscellaneous other fixes and cleanups"
* tag 'xfs-for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (39 commits)
xfs: give all workqueues rescuer threads
xfs: fix log recovery op header validation assert
xfs: Fix error path in xfs_get_acl
xfs: optimise away log forces on timestamp updates for fdatasync
xfs: don't leak uuid table on rmmod
xfs: invalidate cached acl if set via ioctl
xfs: Plug memory leak in xfs_attrmulti_attr_set
xfs: Validate the length of on-disk ACLs
xfs: invalidate cached acl if set directly via xattr
xfs: xfs_filemap_pmd_fault treats read faults as write faults
xfs: add ->pfn_mkwrite support for DAX
xfs: DAX does not use IO completion callbacks
xfs: Don't use unwritten extents for DAX
xfs: introduce BMAPI_ZERO for allocating zeroed extents
xfs: fix inode size update overflow in xfs_map_direct()
xfs: clear PF_NOFREEZE for xfsaild kthread
xfs: fix an error code in xfs_fs_fill_super()
xfs: stats are no longer dependent on CONFIG_PROC_FS
xfs: simplify /proc teardown & error handling
xfs: per-filesystem stats counter implementation
Pull nfsd updates from Bruce Fields:
"Apologies for coming a little late in the merge window. Fortunately
this is another fairly quiet one:
Mainly smaller bugfixes and cleanup. We're still finding some bugs
from the breakup of the big NFSv4 state lock in 3.17 -- thanks
especially to Andrew Elble and Jeff Layton for tracking down some of
the remaining races"
* tag 'nfsd-4.4' of git://linux-nfs.org/~bfields/linux:
svcrpc: document lack of some memory barriers
nfsd: fix race with open / open upgrade stateids
nfsd: eliminate sending duplicate and repeated delegations
nfsd: remove recurring workqueue job to clean DRC
SUNRPC: drop stale comment in svc_setup_socket()
nfsd: ensure that seqid morphing operations are atomic wrt to copies
nfsd: serialize layout stateid morphing operations
nfsd: improve client_has_state to check for unused openowners
nfsd: fix clid_inuse on mount with security change
sunrpc/cache: make cache flushing more reliable.
nfsd: move include of state.h from trace.c to trace.h
sunrpc: avoid warning in gss_key_timeout
lockd: get rid of reference-counted NSM RPC clients
SUNRPC: Use MSG_SENDPAGE_NOTLAST when calling sendpage()
lockd: create NSM handles per net namespace
nfsd: switch unsigned char flags in svc_fh to bools
nfsd: move svc_fh->fh_maxsize to just after fh_handle
nfsd: drop null test before destroy functions
nfsd: serialize state seqid morphing operations
Pull vfs update from Al Viro:
- misc stable fixes
- trivial kernel-doc and comment fixups
- remove never-used block_page_mkwrite() wrapper function, and rename
the function that is _actually_ used to not have double underscores.
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: 9p: cache.h: Add #define of include guard
vfs: remove stale comment in inode_operations
vfs: remove unused wrapper block_page_mkwrite()
binfmt_elf: Correct `arch_check_elf's description
fs: fix writeback.c kernel-doc warnings
fs: fix inode.c kernel-doc warning
fs/pipe.c: return error code rather than 0 in pipe_write()
fs/pipe.c: preserve alloc_file() error code
binfmt_elf: Don't clobber passed executable's file header
cachefiles: perform test on s_blocksize when opening cache file.
FS-Cache: Don't override netfs's primary_index if registering failed
FS-Cache: Increase reference of parent after registering, netfs success
debugfs: fix refcount imbalance in start_creating
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: stable@vger.kernel.org # 4.0+
Signed-off-by: Jens Axboe <axboe@fb.com>
If a block device is hot removed and later last reference to device
is put, we try to writeback the dirty inode. But device is gone and
that writeback fails.
Currently we do a WARN_ON() which does not seem to be the right thing.
Convert it to a ratelimited kernel warning.
Reported-by: Andi Kleen <andi@firstfloor.org>
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
[jmoyer@redhat.com: get rid of unnecessary name initialization, 80 cols]
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
The include file was intended to have an include guard, but the #define
part is missing.
Signed-off-by: Tzvetelin Katchov <katchov@gmail.com>
The function currently called "__block_page_mkwrite()" used to be called
"block_page_mkwrite()" until a wrapper for this function was added by:
commit 24da4fab5a61 ("vfs: Create __block_page_mkwrite() helper passing
error values back")
This wrapper, the current "block_page_mkwrite()", is currently unused.
__block_page_mkwrite() is used directly by ext4, nilfs2 and xfs.
Remove the unused wrapper, rename __block_page_mkwrite() back to
block_page_mkwrite() and update the comment above block_page_mkwrite().
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Correct `arch_check_elf's description, mistakenly copied and pasted from
`arch_elf_pt_proc'.
Signed-off-by: Maciej W. Rozycki <macro@imgtec.com>
Fix kernel-doc warnings in fs/fs-writeback.c by moving a #define macro
to after the function's opening brace. Also #undef this macro at the
end of the function.
..//fs/fs-writeback.c:1984: warning: Excess function parameter 'inode' description in 'I_DIRTY_INODE'
..//fs/fs-writeback.c:1984: warning: Excess function parameter 'flags' description in 'I_DIRTY_INODE'
Fix kernel-doc warning in fs/inode.c:
..//fs/inode.c:1606: warning: No description found for parameter 'inode'
pipe_write() would return 0 if it failed to merge the beginning of the
data to write with the last, partially filled pipe buffer. It should
return an error code instead. Userspace programs could be confused by
write() returning 0 when called with a nonzero 'count'.
The EFAULT error case was a regression from f0d1bec9d5 ("new helper:
copy_page_from_iter()"), while the ops->confirm() error case was a much
older bug.
Test program:
#include <assert.h>
#include <errno.h>
#include <unistd.h>
int main(void)
int fd[2];
char data[1] = {0};
assert(0 == pipe(fd));
assert(1 == write(fd[1], data, 1));
/* prior to this patch, write() returned 0 here */
assert(-1 == write(fd[1], NULL, 1));
assert(errno == EFAULT);
Cc: stable@vger.kernel.org # at least v3.15+
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
If sys_pipe() was unable to allocate a 'struct file', it always failed
with ENFILE, which means "The number of simultaneously open files in the
system would exceed a system-imposed limit." However, alloc_file()
actually returns an ERR_PTR value and might fail with other error codes.
Currently, in addition to ENFILE, it can fail with ENOMEM, potentially
when there are few open files in the system. Update sys_pipe() to
preserve this error code.
In a prior submission of a similar patch (1) some concern was raised
about introducing a new error code for sys_pipe(). However, for most
system calls, programs cannot assume that new error codes will never be
introduced. In addition, ENOMEM was, in fact, already a possible error
code for sys_pipe(), in the case where the file descriptor table could
not be expanded due to insufficient memory.
(1) http://comments.gmane.org/gmane.linux.kernel/1357942
Do not clobber the buffer space passed from `search_binary_handler' and
originally preloaded by `prepare_binprm' with the executable's file
header by overwriting it with its interpreter's file header. Instead
keep the buffer space intact and directly use the data structure locally
allocated for the interpreter's file header, fixing a bug introduced in
2.1.14 with loadable module support (linux-mips.org commit beb11695
[Import of Linux/MIPS 2.1.14], predating kernel.org repo's history).
Adjust the amount of data read from the interpreter's file accordingly.
This was not an issue before loadable module support, because back then
`load_elf_binary' was executed only once for a given ELF executable,
whether the function succeeded or failed.
With loadable module support supported and enabled, upon a failure of
`load_elf_binary' -- which may for example be caused by architecture
code rejecting an executable due to a missing hardware feature requested
in the file header -- a module load is attempted and then the function
reexecuted by `search_binary_handler'. With the executable's file
header replaced with its interpreter's file header the executable can
then be erroneously accepted in this subsequent attempt.
Cc: stable@vger.kernel.org # all the way back
Handle a write being requested to the page immediately beyond the EOF
marker on a cache object. Currently this gets an assertion failure in
CacheFiles because the EOF marker is used there to encode information about
a partial page at the EOF - which could lead to an unknown blank spot in
the file if we extend the file over it.
The problem is actually in fscache where we check the index of the page
being written against store_limit. store_limit is set to the number of
pages that we're allowed to store by fscache_set_store_limit() - which
means it's one more than the index of the last page we're allowed to store.
The problem is that we permit writing to a page with an index _equal_ to
the store limit - when we should reject that case.
Whilst we're at it, change the triggered assertion in CacheFiles to just
return -ENOBUFS instead.
The assertion failure looks something like this:
CacheFiles: Assertion failed
1000 < 7b1 is false
kernel BUG at fs/cachefiles/rdwr.c:962!
RIP: 0010:[<ffffffffa02c9e83>] [<ffffffffa02c9e83>] cachefiles_write_page+0x273/0x2d0 [cachefiles]
Cc: stable@vger.kernel.org # v2.6.31+; earlier - that + backport of a17754f (at least)
cachefiles requires that s_blocksize in the cache is not greater than
PAGE_SIZE, and performs the check every time a block is accessed.
Move the test to the place where the file is "opened", where other
file-validity tests are performed.
Signed-off-by: NeilBrown <neilb@suse.de>
Only override netfs->primary_index when registering success.
Cc: stable@vger.kernel.org # v2.6.30+
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
If netfs exist, fscache should not increase the reference of parent's
usage and n_children, otherwise, never be decreased.
v2: thanks David's suggest,
move increasing reference of parent if success
use kmem_cache_free() freeing primary_index directly
v3: don't move "netfs->primary_index->parent = &fscache_fsdef_index;"
