path: root/fs
2014-03-05NFSv4.1 Fail data server I/O if stateid represents a lost lockAndy Adamson
Signed-off-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-05NFSv4: Fix the return value of nfs4_select_rw_stateidTrond Myklebust
In commit 5521abfdcf4d6 (NFSv4: Resend the READ/WRITE RPC call if a stateid change causes an error), we overloaded the return value of nfs4_select_rw_stateid() to cause it to return -EWOULDBLOCK if an RPC call is outstanding that would cause the NFSv4 lock or open stateid to change. That is all redundant when we actually copy the stateid used in the read/write RPC call that failed, and check that against the current stateid. It is doubly so, when we consider that in the NFSv4.1 case, we also set the stateid's seqid to the special value '0', which means 'match the current valid stateid'. Reported-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-05NFSv4: nfs4_stateid_is_current should return 'true' for an invalid stateidTrond Myklebust
When nfs4_set_rw_stateid() can fails by returning EIO to indicate that the stateid is completely invalid, then it makes no sense to have it trigger a retry of the READ or WRITE operation. Instead, we should just have it fall through and attempt a recovery. This fixes an infinite loop in which the client keeps replaying the same bad stateid back to the server. Reported-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Cc: stable@vger.kernel.org # 3.10+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-02NFS: Fix a delegation callback raceTrond Myklebust
The clean-up in commit 36281caa839f ended up removing a NULL pointer check that is needed in order to prevent an Oops in nfs_async_inode_return_delegation(). Reported-by: "Yan, Zheng" <zheng.z.yan@intel.com> Link: http://lkml.kernel.org/r/5313E9F6.2020405@intel.com Fixes: 36281caa839f (NFSv4: Further clean-ups of delegation stateid validation) Cc: stable@vger.kernel.org # 3.4+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-01NFSv4: Fix another nfs4_sequence corruptorTrond Myklebust
nfs4_release_lockowner needs to set the rpc_message reply to point to the nfs4_sequence_res in order to avoid another Oopsable situation in nfs41_assign_slot. Fixes: fbd4bfd1d9d21 (NFS: Add nfs4_sequence calls for RELEASE_LOCKOWNER) Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-19NFS fix error return in nfs4_select_rw_stateidAndy Adamson
Do not return an error when nfs4_copy_delegation_stateid succeeds. Signed-off-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1392737765-41942-1-git-send-email-andros@netapp.com Fixes: ef1820f9be27b (NFSv4: Don't try to recover NFSv4 locks when...) Cc: NeilBrown <neilb@suse.de> Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-17NFSv4: Use the correct net namespace in nfs4_update_serverTrond Myklebust
We need to use the same net namespace that was used to resolve the hostname and sockaddr arguments. Fixes: 32e62b7c3ef09 (NFS: Add nfs4_update_server) Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-10NFS: Do not set NFS_INO_INVALID_LABEL unless server supports labeled NFSTrond Myklebust
Commit aa9c2669626c (NFS: Client implementation of Labeled-NFS) introduces a performance regression. When nfs_zap_caches_locked is called, it sets the NFS_INO_INVALID_LABEL flag irrespectively of whether or not the NFS server supports security labels. Since that flag is never cleared, it means that all calls to nfs_revalidate_inode() will now trigger an on-the-wire GETATTR call. This patch ensures that we never set the NFS_INO_INVALID_LABEL unless the server advertises support for labeled NFS. It also causes nfs_setsecurity() to clear NFS_INO_INVALID_LABEL when it has successfully set the security label for the inode. Finally it gets rid of the NFS_INO_INVALID_LABEL cruft from nfs_update_inode, which has nothing to do with labeled NFS. Reported-by: Neil Brown <neilb@suse.de> Cc: stable@vger.kernel.org # 3.11+ Tested-by: Neil Brown <neilb@suse.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes, both -stable fodder. The O_SYNC bug is fairly old..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fix a kmap leak in virtio_console fix O_SYNC|O_APPEND syncing the wrong range on write()
2014-02-09fix O_SYNC|O_APPEND syncing the wrong range on write()Al Viro
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support) when sync_page_range() had been introduced; generic_file_write{,v}() correctly synced pos_after_write - written .. pos_after_write - 1 but generic_file_aio_write() synced pos_before_write .. pos_before_write + written - 1 instead. Which is not the same thing with O_APPEND, obviously. A couple of years later correct variant had been killed off when everything switched to use of generic_file_aio_write(). All users of generic_file_aio_write() are affected, and the same bug has been copied into other instances of ->aio_write(). The fix is trivial; the only subtle point is that generic_write_sync() ought to be inlined to avoid calculations useless for the majority of calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is a small collection of fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix data corruption when reading/updating compressed extents Btrfs: don't loop forever if we can't run because of the tree mod log btrfs: reserve no transaction units in btrfs_ioctl_set_features btrfs: commit transaction after setting label and features Btrfs: fix assert screwup for the pending move stuff
2014-02-08Btrfs: fix data corruption when reading/updating compressed extentsFilipe David Borba Manana
When using a mix of compressed file extents and prealloc extents, it is possible to fill a page of a file with random, garbage data from some unrelated previous use of the page, instead of a sequence of zeroes. A simple sequence of steps to get into such case, taken from the test case I made for xfstests, is: _scratch_mkfs _scratch_mount "-o compress-force=lzo" $XFS_IO_PROG -f -c "pwrite -S 0x06 -b 18670 266978 18670" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "falloc 26450 665194" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "truncate 542872" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foobar This results in the following file items in the fs tree: item 4 key (257 INODE_ITEM 0) itemoff 15879 itemsize 160 inode generation 6 transid 6 size 542872 block group 0 mode 100600 item 5 key (257 INODE_REF 256) itemoff 15863 itemsize 16 inode ref index 2 namelen 6 name: foobar item 6 key (257 EXTENT_DATA 0) itemoff 15810 itemsize 53 extent data disk byte 0 nr 0 gen 6 extent data offset 0 nr 24576 ram 266240 extent compression 0 item 7 key (257 EXTENT_DATA 24576) itemoff 15757 itemsize 53 prealloc data disk byte 12849152 nr 241664 gen 6 prealloc data offset 0 nr 241664 item 8 key (257 EXTENT_DATA 266240) itemoff 15704 itemsize 53 extent data disk byte 12845056 nr 4096 gen 6 extent data offset 0 nr 20480 ram 20480 extent compression 2 item 9 key (257 EXTENT_DATA 286720) itemoff 15651 itemsize 53 prealloc data disk byte 13090816 nr 405504 gen 6 prealloc data offset 0 nr 258048 The on disk extent at offset 266240 (which corresponds to 1 single disk block), contains 5 compressed chunks of file data. Each of the first 4 compress 4096 bytes of file data, while the last one only compresses 3024 bytes of file data. Therefore a read into the file region [285648 ; 286720[ (length = 4096 - 3024 = 1072 bytes) should always return zeroes (our next extent is a prealloc one). The solution here is the compression code path to zero the remaining (untouched) bytes of the last page it uncompressed data into, as the information about how much space the file data consumes in the last page is not known in the upper layer fs/btrfs/extent_io.c:__do_readpage(). In __do_readpage we were correctly zeroing the remainder of the page but only if it corresponds to the last page of the inode and if the inode's size is not a multiple of the page size. This would cause not only returning random data on reads, but also permanently storing random data when updating parts of the region that should be zeroed. For the example above, it means updating a single byte in the region [285648 ; 286720[ would store that byte correctly but also store random data on disk. A test case for xfstests follows soon. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08Btrfs: don't loop forever if we can't run because of the tree mod logJosef Bacik
A user reported a 100% cpu hang with my new delayed ref code. Turns out I forgot to increase the count check when we can't run a delayed ref because of the tree mod log. If we can't run any delayed refs during this there is no point in continuing to look, and we need to break out. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08btrfs: reserve no transaction units in btrfs_ioctl_set_featuresDavid Sterba
Added in patch "btrfs: add ioctls to query/change feature bits online" modifications to superblock don't need to reserve metadata blocks when starting a transaction. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08btrfs: commit transaction after setting label and featuresJeff Mahoney
The set_fslabel ioctl uses btrfs_end_transaction, which means it's possible that the change will be lost if the system crashes, same for the newly set features. Let's use btrfs_commit_transaction instead. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08Btrfs: fix assert screwup for the pending move stuffJosef Bacik
Wang noticed that he was failing btrfs/030 even though me and Filipe couldn't reproduce. Turns out this is because Wang didn't have CONFIG_BTRFS_ASSERT set, which meant that a key part of Filipe's original patch was not being built in. This appears to be a mess up with merging Filipe's patch as it does not exist in his original patch. Fix this by changing how we make sure del_waiting_dir_move asserts that it did not error and take the function out of the ifdef check. This makes btrfs/030 pass with the assert on or off. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Reviewed-by: Filipe Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-08Merge tag 'jfs-3.14-rc2' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from David Kleikamp: "Fix regression" * tag 'jfs-3.14-rc2' of git://github.com/kleikamp/linux-shaggy: jfs: fix generic posix ACL regression
2014-02-08jfs: fix generic posix ACL regressionDave Kleikamp
I missed a couple errors in reviewing the patches converting jfs to use the generic posix ACL function. Setting ACL's currently fails with -EOPNOTSUPP. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Reported-by: Michael L. Semon <mlsemon35@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2014-02-07Merge tag 'driver-core-3.14-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fix from Greg KH: "Here is a single kernfs fix to resolve a much-reported lockdep issue with the removal of entries in sysfs" * tag 'driver-core-3.14-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: kernfs: make kernfs_deactivate() honor KERNFS_LOCKDEP flag
2014-02-06mm: __set_page_dirty uses spin_lock_irqsave instead of spin_lock_irqKOSAKI Motohiro
To use spin_{un}lock_irq is dangerous if caller disabled interrupt. During aio buffer migration, we have a possibility to see the following call stack. aio_migratepage [disable interrupt] migrate_page_copy clear_page_dirty_for_io set_page_dirty __set_page_dirty_buffers __set_page_dirty spin_lock_irq This mean, current aio migration is a deadlockable. spin_lock_irqsave is a safer alternative and we should use it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: David Rientjes rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-06ocfs2: free allocated clusters if error occurs after ocfs2_claim_clustersZongxun Wang
Even if using the same jbd2 handle, we cannot rollback a transaction. So once some error occurs after successfully allocating clusters, the allocated clusters will never be used and it means they are lost. For example, call ocfs2_claim_clusters successfully when expanding a file, but failed in ocfs2_insert_extent. So we need free the allocated clusters if they are not used indeed. Signed-off-by: Zongxun Wang <wangzongxun@huawei.com> Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-05execve: use 'struct filename *' for executable name passingLinus Torvalds
This changes 'do_execve()' to get the executable name as a 'struct filename', and to free it when it is done. This is what the normal users want, and it simplifies and streamlines their error handling. The controlled lifetime of the executable name also fixes a use-after-free problem with the trace_sched_process_exec tracepoint: the lifetime of the passed-in string for kernel users was not at all obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize the pathname allocation lifetime with the execve() having finished, which in turn meant that the trace point that happened after mm_release() of the old process VM ended up using already free'd memory. To solve the kernel string lifetime issue, this simply introduces "getname_kernel()" that works like the normal user-space getname() function, except with the source coming from kernel memory. As Oleg points out, this also means that we could drop the tcomm[] array from 'struct linux_binprm', since the pathname lifetime now covers setup_new_exec(). That would be a separate cleanup. Reported-by: Igor Zhbanov <i.zhbanov@samsung.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-05kernfs: make kernfs_deactivate() honor KERNFS_LOCKDEP flagTejun Heo
kernfs_deactivate() forgot to check whether KERNFS_LOCKDEP is set before performing lockdep annotations and ends up feeding uninitialized lockdep_map to lockdep triggering warning like the following on USB stick hotunplug. usb 1-2: USB disconnect, device number 2 INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. CPU: 1 PID: 62 Comm: khubd Not tainted 3.13.0-work+ #82 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 ffff880065ca7f60 ffff88013a4ffa08 ffffffff81cfb6bd 0000000000000002 ffff88013a4ffac8 ffffffff810f8530 ffff88013a4fc710 0000000000000002 ffff880100000000 ffffffff82a3db50 0000000000000001 ffff88013a4fc710 Call Trace: [<ffffffff81cfb6bd>] dump_stack+0x4e/0x7a [<ffffffff810f8530>] __lock_acquire+0x1910/0x1e70 [<ffffffff810f931a>] lock_acquire+0x9a/0x1d0 [<ffffffff8127c75e>] kernfs_deactivate+0xee/0x130 [<ffffffff8127d4c8>] kernfs_addrm_finish+0x38/0x60 [<ffffffff8127d701>] kernfs_remove_by_name_ns+0x51/0xa0 [<ffffffff8127b4f1>] remove_files.isra.1+0x41/0x80 [<ffffffff8127b7e7>] sysfs_remove_group+0x47/0xa0 [<ffffffff8127b873>] sysfs_remove_groups+0x33/0x50 [<ffffffff8177d66d>] device_remove_attrs+0x4d/0x80 [<ffffffff8177e25e>] device_del+0x12e/0x1d0 [<ffffffff819722c2>] usb_disconnect+0x122/0x1a0 [<ffffffff819749b5>] hub_thread+0x3c5/0x1290 [<ffffffff810c6a6d>] kthread+0xed/0x110 [<ffffffff81d0a56c>] ret_from_fork+0x7c/0xb0 Fix it by making kernfs_deactivate() perform lockdep annotations only if KERNFS_LOCKDEP is set. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Fabio Estevam <festevam@gmail.com> Reported-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Jiri Kosina <jkosina@suse.cz> Reported-by: Dave Jones <davej@redhat.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Filipe is fixing compile and boot problems with our crc32c rework, and Josef has disabled snapshot aware defrag for now. As the number of snapshots increases, we're hitting OOM. For the short term we're disabling things until a bigger fix is ready" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: use late_initcall instead of module_init Btrfs: use btrfs_crc32c everywhere instead of libcrc32c Btrfs: disable snapshot aware defrag for now
2014-02-04Merge tag 'nfs-for-3.14-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights: - Fix NFSv3 acl regressions - Fix NFSv4 memory corruption due to slot table abuse in nfs4_proc_open_confirm - nfs4_destroy_session must call rpc_destroy_waitqueue" * tag 'nfs-for-3.14-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: fs: get_acl() must be allowed to return EOPNOTSUPP NFSv3: Fix return value of nfs3_proc_setacls NFSv3: Remove unused function nfs3_proc_set_default_acl NFSv4.1: nfs4_destroy_session must call rpc_destroy_waitqueue NFSv4: Fix memory corruption in nfs4_proc_open_confirm nfs: fix setting of ACLs on file creation.
2014-02-03Merge branch 'acl_fixes' into linux-nextTrond Myklebust
2014-02-03fs: get_acl() must be allowed to return EOPNOTSUPPTrond Myklebust
posix_acl_xattr_get requires get_acl() to return EOPNOTSUPP if the filesystem cannot support acls. This is needed for NFS, which can't know whether or not the server supports acls until it tries to get/set one. This patch converts posix_acl_chmod and posix_acl_create to deal with EOPNOTSUPP return values from get_acl(). Reported-by: Russell King <linux@arm.linux.org.uk> Link: http://lkml.kernel.org/r/20140130140834.GW15937@n2100.arm.linux.org.uk Cc: Al Viro viro@zeniv.linux.org.uk> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-03NFSv3: Fix return value of nfs3_proc_setaclsTrond Myklebust
nfs3_proc_setacls is used internally by the NFSv3 create operations to set the acl after the file has been created. If the operation fails because the server doesn't support acls, then it must return '0', not -EOPNOTSUPP. Reported-by: Russell King <linux@arm.linux.org.uk> Link: http://lkml.kernel.org/r/20140201010328.GI15937@n2100.arm.linux.org.uk Cc: Christoph Hellwig <hch@lst.de> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-03NFSv3: Remove unused function nfs3_proc_set_default_aclTrond Myklebust
Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-03Btrfs: use late_initcall instead of module_initFilipe David Borba Manana
It seems that when init_btrfs_fs() is called, crc32c/crc32c-intel might not always be already initialized, which results in the call to crypto_alloc_shash() returning -ENOENT, as experienced by Ahmet who reported this. Therefore make sure init_btrfs_fs() is called after crc32c is initialized (which is at initialization level 6, module_init), by using late_initcall (which is at initialization level 7) instead of module_init for btrfs. Reported-and-Tested-by: Ahmet Inan <ainan@mathematik.uni-freiburg.de> Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-03Btrfs: use btrfs_crc32c everywhere instead of libcrc32cFilipe David Borba Manana
After the commit titled "Btrfs: fix btrfs boot when compiled as built-in", LIBCRC32C requirement was removed from btrfs' Kconfig. This made it not possible to build a kernel with btrfs enabled (either as module or built-in) if libcrc32c is not enabled as well. So just replace all uses of libcrc32c with the equivalent function in btrfs hash.h - btrfs_crc32c. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-03Btrfs: disable snapshot aware defrag for nowJosef Bacik
It's just broken and it's taking a lot of effort to fix it, so for now just disable it so people can defrag in peace. Thanks, Cc: stable@vger.kernel.org Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com>
2014-02-02hpfs: optimize quad buffer loadingMikulas Patocka
HPFS needs to load 4 consecutive 512-byte sectors when accessing the directory nodes or bitmaps. We can't switch to 2048-byte block size because files are allocated in the units of 512-byte sectors. Previously, the driver would allocate a 2048-byte area using kmalloc, copy the data from four buffers to this area and eventually copy them back if they were modified. In the current implementation of the buffer cache, buffers are allocated in the pagecache. That means that 4 consecutive 512-byte buffers are stored in consecutive areas in the kernel address space. So, we don't need to allocate extra memory and copy the content of the buffers there. This patch optimizes the code to avoid copying the buffers. It checks if the four buffers are stored in contiguous memory - if they are not, it falls back to allocating a 2048-byte area and copying data there. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-02hpfs: remember free spaceMikulas Patocka
Previously, hpfs scanned all bitmaps each time the user asked for free space using statfs. This patch changes it so that hpfs scans the bitmaps only once, remembes the free space and on next invocation of statfs it returns the value instantly. New versions of wine are hammering on the statfs syscall very heavily, making some games unplayable when they're stored on hpfs, with load times in minutes. This should be backported to the stable kernels because it fixes user-visible problem (excessive level load times in wine). Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-01NFSv4.1: nfs4_destroy_session must call rpc_destroy_waitqueueTrond Myklebust
There may still be timers active on the session waitqueues. Make sure that we kill them before freeing the memory. Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-01NFSv4: Fix memory corruption in nfs4_proc_open_confirmTrond Myklebust
nfs41_wake_and_assign_slot() relies on the task->tk_msg.rpc_argp and task->tk_msg.rpc_resp always pointing to the session sequence arguments. nfs4_proc_open_confirm tries to pull a fast one by reusing the open sequence structure, thus causing corruption of the NFSv4 slot table. Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-01afs: proc cells and rootcell are writeablePali Rohár
Both proc files are writeable and used for configuring cells. But there is missing correct mode flag for writeable files. Without this patch both proc files are read only. [ It turns out they aren't really read-only, since root can write to them even if the write bit isn't set due to CAP_DAC_OVERRIDE ] Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-01Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "A set of cifs fixes (mostly for symlinks, and SMB2 xattrs) and cleanups" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: cifs: Fix check for regular file in couldbe_mf_symlink() [CIFS] Fix SMB2 mounts so they don't try to set or get xattrs via cifs CIFS: Cleanup cifs open codepath CIFS: Remove extra indentation in cifs_sfu_type CIFS: Cleanup cifs_mknod CIFS: Cleanup CIFSSMBOpen cifs: Add support for follow_link on dfs shares under posix extensions cifs: move unix extension call to cifs_query_symlink() cifs: Re-order M-F Symlink code cifs: Add create MFSymlinks to protocol ops struct cifs: use protocol specific call for query_mf_symlink() cifs: Rename MF symlink function names cifs: Rename and cleanup open_query_close_cifs_symlink() cifs: Fix memory leak in cifs_hardlink()
2014-02-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Several obvious fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Fix mountpoint reference leakage in linkat hfsplus: use xattr handlers for removexattr Typo in compat_sys_lseek() declaration fs/super.c: sync ro remount after blocking writers vfs: unexport the getname() symbol
2014-01-31nfs: fix setting of ACLs on file creation.Noah Massey
nfs3_get_acl() tries to skip posix equivalent ACLs, but misinterprets the return value of posix_acl_equiv_mode(). Fix it. This is a regression introduced by "nfs: use generic posix ACL infrastructure for v3 Posix ACLs" CC: Christoph Hellwig <hch@infradead.org> CC: linux-nfs@vger.kernel.org CC: linux-fsdevel@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-31Merge tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights: - Fix several races in nfs_revalidate_mapping - NFSv4.1 slot leakage in the pNFS files driver - Stable fix for a slot leak in nfs40_sequence_done - Don't reject NFSv4 servers that support ACLs with only ALLOW aces" * tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs: initialize the ACL support bits to zero. NFSv4.1: Cleanup NFSv4.1: Clean up nfs41_sequence_done NFSv4: Fix a slot leak in nfs40_sequence_done NFSv4.1 free slot before resending I/O to MDS nfs: add memory barriers around NFS_INO_INVALID_DATA and NFS_INO_INVALIDATING NFS: Fix races in nfs_revalidate_mapping sunrpc: turn warn_gssd() log message into a dprintk() NFS: fix the handling of NFS_INO_INVALID_DATA flag in nfs_revalidate_mapping nfs: handle servers that support only ALLOW ACE type.
2014-01-31Fix mountpoint reference leakage in linkatOleg Drokin
Recent changes to retry on ESTALE in linkat (commit 442e31ca5a49e398351b2954b51f578353fdf210) introduced a mountpoint reference leak and a small memory leak in case a filesystem link operation returns ESTALE which is pretty normal for distributed filesystems like lustre, nfs and so on. Free old_path in such a case. [AV: there was another missing path_put() nearby - on the previous goto retry] Signed-off-by: Oleg Drokin: <green@linuxhacker.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31hfsplus: use xattr handlers for removexattrChristoph Hellwig
hfsplus was already using the handlers for get and set operations, and with the removal of can_set_xattr we've now allow operations that wouldn't otherwise be allowed. With this we can also centralize the special-casing of the osx. attrs that don't have prefixes on disk in the osx xattr handlers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31fs/super.c: sync ro remount after blocking writersAndrew Ruder
Move sync_filesystem() after sb_prepare_remount_readonly(). If writers sneak in anywhere from sync_filesystem() to sb_prepare_remount_readonly() it can cause inodes to be dirtied and writeback to occur well after sys_mount() has completely successfully. This was spotted by corrupted ubifs filesystems on reboot, but appears that it can cause issues with any filesystem using writeback. Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> CC: Richard Weinberger <richard@nod.at> Co-authored-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31vfs: unexport the getname() symbolJeff Layton
Leaving getname() exported when putname() isn't is a bad idea. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-31Merge tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from David Kleikamp: "Minor bug fix for linux-3.14" * tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggy: jfs: fix xattr value size overflow in __jfs_setxattr
2014-01-31ceph: fix missing dput in ceph_set_aclSage Weil
Add matching dput() for d_find_alias(). Move d_find_alias() down a bit at Julia's suggestion. [ Introduced by commit 72466d0b92e0: "ceph: fix posix ACL hooks" ] Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-31cifs: Fix check for regular file in couldbe_mf_symlink()Sachin Prabhu
MF Symlinks are regular files containing content in a specified format. The function couldbe_mf_symlink() checks the mode for a set S_IFREG bit as a test to confirm that it is a regular file. This bit is also set for other filetypes and simply checking for this bit being set may return false positives. We ensure that we are actually checking for a regular file by using the S_ISREG macro to test instead. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reported-by: Neil Brown <neilb@suse.de> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steve French <smfrench@gmail.com>
2014-01-31nfs: initialize the ACL support bits to zero.Malahal Naineni
Avoid returning incorrect acl mask attributes when the server doesn't support ACLs. Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
