path: root/fs
2005-06-30[PATCH] fatfs sectioning fixAndrew Morton
Fixup for the recent slab leak fix Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] reiserfs: handle_attrs() fixAndrew Morton
Fix a use-uninitialised bug. Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] freevxfs: minor cleanupsPekka Enberg
This patch addresses the following minor issues: - Typo in printk - Redundant casts - Use C99 struct initializers instead of memset - Parenthesis around return value - Use inline instead of __inline__ Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] freevxfs: remove 2.4 compatabilityPekka Enberg
This patch removes 2.4 compatability header from freevxfs. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] freevxfs: fix buffer_head leakPekka Enberg
- fix a buffer_head leak in vxfs_getfsh() - s/SLAB_KERNEL/GFP_KERNEL/ - check sb_bread() return value - drop pointless buffer-mapped() test. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] udf_find_entry() cleanupChristoph Hellwig
udf_find_entry can never be called with a NULL argument, so we shouldn't check for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] fat: fix slab cache leakPekka J Enberg
This patch plugs a slab cache leak in fat module initialization. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-29[PATCH] reiserfs: enable attrs by default if safJeff Mahoney
The following patch enables attrs by default if the reiserfs_attrs_cleared bit is set in the superblock. This allows chattr-type attrs to be used without any further action by the user. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-29[PATCH] reiserfs: Check if attrs are enabled for attr ioctlsJeff Mahoney
ReiserFS currently will allow the user to set/get attrs for files regardless if they are enabled. The patch checks to see if they are enabled, and returns -NOTTY if they are not. ext[23] doesn't need this check because attrs are always enabled. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] ext3: reduce allocate-with-reservation lock latenciesMingming Cao
Currently in ext3 block reservation code, the global filesystem reservation tree lock (rsv_block) is hold during the process of searching for a space to make a new reservation window, including while scaning the block bitmap to verify if the avalible window has a free block. Holding the lock during bitmap scan is unnecessary and could possibly cause scalability issue and latency issues. This patch tries to address this by dropping the lock before scan the bitmap. Before that we need to reserve the open window in case someone else is targetting at the same window. Question was should we reserve the whole free reservable space or just the window size we need. Reserve the whole free reservable space will possibly force other threads which intended to do block allocation nearby move to another block group(cause bad layout). In this patch, we just reserve the desired size before drop the lock and scan the block bitmap. This patch fixed a ext3 reservation latency issue seen on a cvs check out test. Patch is tested with many fsx, tiobench, dbench and untar a kernel test. Signed-Off-By: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] coverity: fs/ext3/super.c: match_int return checkKAMBAROV, ZAUR
The return value of "match_int" is checked 27 out of 28 times In lib/parser.c 142 /** 143 * match_int: - scan a decimal representation of an integer from a substring_t 144 * @s: substring_t to be scanned 145 * @result: resulting integer on success 146 * 147 * Description: Attempts to parse the &substring_t @s as a decimal integer. On 148 * success, sets @result to the integer represented by the string and returns 0. 149 * Returns either -ENOMEM or -EINVAL on failure. 150 */ 151 int match_int(substring_t *s, int *result) 152 { 153 return match_number(s, result, 0); 154 } Signed-off-by: Zaur Kambarov <zkambarov@coverity.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] coverity: fs/udf/namei.c null checkKAMBAROV, ZAUR
"dir" was dereferenced before null check Signed-off-by: Zaur Kambarov <zkambarov@coverity.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] aio-retry-fix: fix aio retry work queueingSébastien Dugu
In the case of buffered AIO, in the aio retry path (aio_run_iocb), when the retry method returns EIOCBRETRY the kicked iocb is added to the context run list but is never queued onto the work queue. The request therefore is never completed. This patch fixes that by adding the appropriate call to aio_queue_work in aio_run_aiocb so that subsequent retries will be handled by the aio worker thread. Signed-off-by: Sébastien Dugué <sebastien.dugue@bull.net> Acked-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] really remove xattr_acl.hChristoph Hellwig
Looks like it sneaked back with the NFS ACL merge.. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] rename wakeup_bdflush to wakeup_pdflushPekka J Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] fix semaphore handling in __unregister_chrdev_regionWen-chien Jesse Sung
This up() should be down() instead. Signed-off-by: Wen-chien Jesse Sung <jesse@cola.voip.idv.tw> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-26[PATCH] jffs2 build fixAndrew Morton
Missed conversion in the swsusp cleanup. Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25Merge Christoph's freeze cleanup patchLinus Torvalds
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] list_for_each_entry: fs-dquot.cDomen Puncer
Make code more readable with list_for_each_entry_safe. Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] fs/ncpfs/: remove unused #ifdef USE_OLD_SLOW_DIRECTORY_LISTING codeAdrian Bunk
This patch removes some unused #ifdef USE_OLD_SLOW_DIRECTORY_LISTING code. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] fs/jffs/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - provide some debugging helper functions only for appropriate values of CONFIG_JFFS_FS_VERBOSE Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] small partitions/msdos cleanupsAdrian Bunk
This patch makes the following changes to the msdos partition code: - remove CONFIG_NEC98_PARTITION leftovers - make parse_bsd static This patch was already ACK'ed by Andries Brouwer. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Parse elf32 headers and export through /proc/vmcoreVivek Goyal
o Adds support for parsing core ELF32 headers. o I am expecting ELF32 support to go away down the line. This patch has been introduced for testing purposes as gdb can not parse ELF64 headers for i386. When a decent user space solution is available, ELF32 support can go away. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Access dump file in elf format (/proc/vmcore)Vivek Goyal
From: "Vivek Goyal" <vgoyal@in.ibm.com> o Support for /proc/vmcore interface. This interface exports elf core image either in ELF32 or ELF64 format, depending on the format in which elf headers have been stored by crashed kernel. o Added support for CONFIG_VMCORE config option. o Removed the dependency on /proc/kcore. From: "Eric W. Biederman" <ebiederm@xmission.com> This patch has been refactored to more closely match the prevailing style in the affected files. And to clearly indicate the dependency between /proc/kcore and proc/vmcore.c From: Hariprasad Nellitheertha <hari@in.ibm.com> This patch contains the code that provides an ELF format interface to the previous kernel's memory post kexec reboot. Signed off by Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] reiserfs: do not ignore i/io error on readpageQu Fuping
Reiserfs's readpage does not notice i/o errors. This patch makes reiserfs_readpage to return -EIO when i/o error appears. This patch makes reiserfs to not ignore I/O error on readpage. Signed-off-by: Qu Fuping <fs@ercist.iscas.ac.cn> Signed-off-by: Vladimir V. Saveliev <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] fix fsync(dir) return value for ram-based filesystemsHugh Dickins
Any filesystem which is using simple_dir_operations will retunr -EINVAL for fsync() on a directory. Make it return zero instead. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] fs/qnx4/*: fix sparse warningsAlexey Dobriyan
This patch fixes sparse warnings in the qnx4fs (and might even make qnx4fs work on big-endian boxes) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: reduce code duplicationCarsten Otte
This patch reworks filemap_xip.c with the goal to reduce code duplication from mm/filemap.c. It applies agains 2.6.12-rc6-mm1. Instead of implementing the aio functions, this one implements the synchronous read/write functions only. For readv and writev, the generic fallback is used. For aio, we rely on the application doing the fallback. Since our "synchronous" function does memcpy immediately anyway, there is no performance difference between using the fallbacks or implementing each operation. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: ext2: execute in placeCarsten Otte
These are the ext2 related parts. Ext2 now uses the xip_* file operations along with the get_xip_page aop when mounted with -o xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: fs/mm: execute in placeCarsten Otte
- generic_file* file operations do no longer have a xip/non-xip split - filemap_xip.c implements a new set of fops that require get_xip_page aop to work proper. all new fops are exported GPL-only (don't like to see whatever code use those except GPL modules) - __xip_unmap now uses page_check_address, which is no longer static in rmap.c, and defined in linux/rmap.h - mm/filemap.h is now much more clean, plainly having just Linus' inline funcs moved here from filemap.c - fix includes in filemap_xip to make it build cleanly on i386 Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] DocBook: update commentsMartin Waitz
This patch updates some comments to match code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4 reboot dirname fixNeilBrown
Set the recovery directory via /proc/fs/nfsd/nfs4recoverydir. It may be changed any time, but is used only on startup. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: reboot recoveryNeilBrown
This patch adds the code to create and remove client subdirectories from the recovery directory, as described in the previous patch comment. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: initialize recovery directoryNeilBrown
NFSv4 clients are required to know what state they have on the server so that they can reclaim it on server reboot. However, it is possible for pathalogical combinations of server reboots and network partitions to leave a client in a state where it cannot know whether it has lost its state on the server. For this reason, rfc3530 requires that we store some information about clients to stable storage. So we maintain a directory /var/lib/nfs/v4recovery with a subdirectory for each client with active state. We leave open the possibility of including files underneath each such subdirectory with information about the client, but for now the subdirectories are empty. We create a client subdirectory whenever a client makes its first non-reclaim open_confirm. We remove a client subdirectory whenever either a) its lease expires, or b) the grace period ends without it reclaiming anything. When handling reclaims, we allow the reclaim if and only if the client doing the reclaim has a subdirectory. This patch adds just the code to scan the recovery directory on nfsd startup. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: remove cb_parsedNeilBrown
The cb_parsed field is only used by probe_callback, to determine whether the callback information has been filled in by setclientid. But there is no way that probe_callback() can be called without that having already happened, so that check is superfluous, as is cb_parsed. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: allow multiple lockownersNeilBrown
>From the language of rfc3530 section 8.1.3 (e.g., the suggestion that a "process id" might be a reasonable lockowner value) it's conceivable that a client might want to use the same lockowner string on multiple files, so we may as well allow that. We expect each use of open_to_lockowner to create a distinct seqid stream, though. For now we're also allowing multiple uses of open_to_lockowner with the same open, though it seems unlikely clients would actually do that. Also add a comment reminding myself of some very non-scalable data structures. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: rename state list fieldsNeilBrown
Trivial renaming patch: I can never remember, while looking at various lists relating the nfsd4 state structures, which are the "heads" and which are items on other lists, or which structures are actually on the various lists. The following convention helps me: given structures foo and bar, with foo containing the head of a list of bars, use "bars" for the name of the head of the list contained in the struct foo, and use "per_foo" for the entries in the struct bars. Already done for struct nfs4_file; go ahead and do it for the other nfsd4 state structures. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: miscellaneous setclientid_confirm cleanupNeilBrown
Minor cleanup, remove some unnecessary printk's. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: setclientid_confirm commentsNeilBrown
Trivial whitespace and comment fixes. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: setclientid_confirm gotoectomyNeilBrown
Change from "goto" to "else if" format in setclientid_confirm. From: Fred Isaman Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: fix setclientid_confirm error returnNeilBrown
NFS4_INVAL is not a valid error for setclientid_confirm, and INUSE is the more logical error here anyway. From: Fred Isaman Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: fix setclientid_confirm casesNeilBrown
Setclientid_confirm code confused states 1 and 3 (numbering from the IMPLEMENTATION section of rfc3530, section 14.2.33). Fix this. State 1 allows the client to change the callback channel on the fly. We don't implement this currently, so just turn off the callback channel in this case. From: Fred Isaman Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: fix uncomfirmed listNeilBrown
Setclientid code assumes there is only one match in unconfirmed list. Make sure that assumption holds. From: Fred Isaman Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: make needlessly global code staticNeilBrown
This patch contains the following possible cleanups: - make needlessly global code static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: grace period endNeilBrown
For the purposes of reboot recovery, we want to do some work during the transition period at the end of the grace period. Some of that work must be guaranteed to have a certain relationship with the end of the grace period, so we want to control the transition there. Our approach is to modify the in_grace() checks to consult a global variable instead of checking the time directly, to schedule the first run of the laundromat thread at the end of the grace period, and to set the global end-of-grace-period there. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: add find_{un}conf_by_str functions to simplify setclientidNeilBrown
Minor setclientid cleanup Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: reboot hashNeilBrown
For the purposes of reboot recovery we keep a directory with subdirectories each having a name that is the ascii hex representation of the md5 sum of a client identifier for an active client. This adds the code to calculate that name. We also use it for the purposes of comparing clients, so if someone ever manages to find two client names that are md5 collisions, then we'll return clid_inuse to the second. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
