path: root/fs
2009-12-15hfs: fix a potential buffer overflowAmerigo Wang
A specially-crafted Hierarchical File System (HFS) filesystem could cause a buffer overflow to occur in a process's kernel stack during a memcpy() call within the hfs_bnode_read() function (at fs/hfs/bnode.c:24). The attacker can provide the source buffer and length, and the destination buffer is a local variable of a fixed length. This local variable (passed as "&entry" from fs/hfs/dir.c:112 and allocated on line 60) is stored in the stack frame of hfs_bnode_read()'s caller, which is hfs_readdir(). Because the hfs_readdir() function executes upon any attempt to read a directory on the filesystem, it gets called whenever a user attempts to inspect any filesystem contents. [amwang@redhat.com: modify this patch and fix coding style problems] Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Eugene Teo <eteo@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Anderson <anderson@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: udf: Avoid IO in udf_clear_inode udf: Try harder when looking for VAT inode udf: Fix compilation with UDFFS_DEBUG enabled
2009-12-14udf: Avoid IO in udf_clear_inodeJan Kara
It is not very good to do IO in udf_clear_inode. First, VFS does not really expect inode to become dirty there and thus we have to write it ourselves, second, memory reclaim gets blocked waiting for IO when it does not really expect it, third, the IO pattern (e.g. on umount) resulting from writes in udf_clear_inode is bad and it slows down writing a lot. The reason why UDF needed to do IO in udf_clear_inode is that UDF standard mandates extent length to exactly match inode size. But when we allocate extents to a file or directory, we don't really know what exactly the final file size will be and thus temporarily set it to block boundary and later truncate it to exact length in udf_clear_inode. Now, this is changed to truncate to final file size in udf_release_file for regular files. For directories and symlinks, we do the truncation at the moment when learn what the final file size will be. Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-14udf: Try harder when looking for VAT inodeJan Kara
Some disks do not contain VAT inode in the last recorded block as required by the standard but a few blocks earlier (or the number of recorded blocks is wrong). So look for the VAT inode a bit before the end of the media. Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-14udf: Fix compilation with UDFFS_DEBUG enabledJan Kara
2009-12-14Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (27 commits) md: add 'recovery_start' per-device sysfs attribute md: rcu_read_lock() walk of mddev->disks in md_do_sync() md: integrate spares into array at earliest opportunity. md: move compat_ioctl handling into md.c md: revise Kconfig help for MD_MULTIPATH md: add MODULE_DESCRIPTION for all md related modules. raid: improve MD/raid10 handling of correctable read errors. md/raid10: print more useful messages on device failure. md/bitmap: update dirty flag when bitmap bits are explicitly set. md: Support write-intent bitmaps with externally managed metadata. md/bitmap: move setting of daemon_lastrun out of bitmap_read_sb md: support updating bitmap parameters via sysfs. md: factor out parsing of fixed-point numbers md: support bitmap offset appropriate for external-metadata arrays. md: remove needless setting of thread->timeout in raid10_quiesce md: change daemon_sleep to be in 'jiffies' rather than 'seconds'. md: move offset, daemon_sleep and chunksize out of bitmap structure md: collect bitmap-specific fields into one structure. md/raid1: add takeover support for raid5->raid1 md: add honouring of suspend_{lo,hi} to raid1. ...
2009-12-14Merge git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (75 commits) NFS: Fix nfs_migrate_page() rpc: remove unneeded function parameter in gss_add_msg() nfs41: Invoke RECLAIM_COMPLETE on all new client ids SUNRPC: IS_ERR/PTR_ERR confusion NFSv41: Fix a potential state leakage when restarting nfs4_close_prepare nfs41: Handle NFSv4.1 session errors in the delegation recall code nfs41: Retry delegation return if it failed with session error nfs41: Handle session errors during delegation return nfs41: Mark stateids in need of reclaim if state manager gets stale clientid NFS: Fix up the declaration of nfs4_restart_rpc when NFSv4 not configured nfs41: Don't clear DRAINING flag on NFS4ERR_STALE_CLIENTID nfs41: nfs41_setup_state_renewal NFSv41: More cleanups NFSv41: Fix up some bugs in the NFS4CLNT_SESSION_DRAINING code NFSv41: Clean up slot table management NFSv41: Fix nfs4_proc_create_session nfs41: Invoke RECLAIM_COMPLETE nfs41: RECLAIM_COMPLETE functionality nfs41: RECLAIM_COMPLETE XDR functionality Cleanup some NFSv4 XDR decode comments ...
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-14md: move compat_ioctl handling into md.cArnd Bergmann
The RAID ioctls are only implemented in md.c, so the handling for them should also be moved there from fs/compat_ioctl.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Neil Brown <neilb@suse.de> Cc: Andre Noll <maan@systemlinux.org> Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-13Merge branch 'nfs-for-2.6.33'Trond Myklebust
2009-12-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (151 commits) powerpc: Fix usage of 64-bit instruction in 32-bit altivec code MAINTAINERS: Add PowerPC patterns powerpc/pseries: Track previous CPPR values to correctly EOI interrupts powerpc/pseries: Correct pseries/dlpar.c build break without CONFIG_SMP powerpc: Make "intspec" pointers in irq_host->xlate() const powerpc/8xx: DTLB Miss cleanup powerpc/8xx: Remove DIRTY pte handling in DTLB Error. powerpc/8xx: Start using dcbX instructions in various copy routines powerpc/8xx: Restore _PAGE_WRITETHRU powerpc/8xx: Add missing Guarded setting in DTLB Error. powerpc/8xx: Fixup DAR from buggy dcbX instructions. powerpc/8xx: Tag DAR with 0x00f0 to catch buggy instructions. powerpc/8xx: Update TLB asm so it behaves as linux mm expects. powerpc/8xx: Invalidate non present TLBs powerpc/pseries: Serialize cpu hotplug operations during deactivate Vs deallocate pseries/pseries: Add code to online/offline CPUs of a DLPAR node powerpc: stop_this_cpu: remove the cpu from the online map. powerpc/pseries: Add kernel based CPU DLPAR handling sysfs/cpu: Add probe/release files powerpc/pseries: Kernel DLPAR Infrastructure ...
2009-12-11Merge branch 'compat-ioctl-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/playground * 'compat-ioctl-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/playground: usbdevfs: move compat_ioctl handling to devio.c lp: move compat_ioctl handling into lp.c compat_ioctl: pass compat pointer directly to handlers compat_ioctl: simplify lookup table compat_ioctl: simplify calling of handlers compat_ioctl: inline all conversion handlers compat_ioctl: Remove BKL compat_ioctl: remove all VT ioctl handling
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (58 commits) tty: split the lock up a bit further tty: Move the leader test in disassociate tty: Push the bkl down a bit in the hangup code tty: Push the lock down further into the ldisc code tty: push the BKL down into the handlers a bit tty: moxa: split open lock tty: moxa: Kill the use of lock_kernel tty: moxa: Fix modem op locking tty: moxa: Kill off the throttle method tty: moxa: Locking clean up tty: moxa: rework the locking a bit tty: moxa: Use more tty_port ops tty: isicom: fix deadlock on shutdown tty: mxser: Use the new locking rules to fix setserial properly tty: mxser: use the tty_port_open method tty: isicom: sort out the board init logic tty: isicom: switch to the new tty_port_open helper tty: tty_port: Add a kref object to the tty port tty: istallion: tty port open/close methods tty: stallion: Convert to the tty_port_open/close methods ...
2009-12-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (21 commits) ext3: PTR_ERR return of wrong pointer in setup_new_group_blocks() ext3: Fix data / filesystem corruption when write fails to copy data ext4: Support for 64-bit quota format ext3: Support for vfsv1 quota format quota: Implement quota format with 64-bit space and inode limits quota: Move definition of QFMT_OCFS2 to linux/quota.h ext2: fix comment in ext2_find_entry about return values ext3: Unify log messages in ext3 ext2: clear uptodate flag on super block I/O error ext2: Unify log messages in ext2 ext3: make "norecovery" an alias for "noload" ext3: Don't update the superblock in ext3_statfs() ext3: journal all modifications in ext3_xattr_set_handle ext2: Explicitly assign values to on-disk enum of filetypes quota: Fix WARN_ON in lookup_one_len const: struct quota_format_ops ubifs: remove manual O_SYNC handling afs: remove manual O_SYNC handling kill wait_on_page_writeback_range vfs: Implement proper O_SYNC semantics ...
2009-12-11Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: Fix error return for fallocate() on XFS xfs: cleanup dmapi macros in the umount path xfs: remove incorrect sparse annotation for xfs_iget_cache_miss xfs: kill the STATIC_INLINE macro xfs: uninline xfs_get_extsz_hint xfs: rename xfs_attr_fetch to xfs_attr_get_int xfs: simplify xfs_buf_get / xfs_buf_read interfaces xfs: remove IO_ISAIO xfs: Wrapped journal record corruption on read at recovery xfs: cleanup data end I/O handlers xfs: use WRITE_SYNC_PLUG for synchronous writeout xfs: reset the i_iolock lock class in the reclaim path xfs: I/O completion handlers must use NOFS allocations xfs: fix mmap_sem/iolock inversion in xfs_free_eofblocks xfs: simplify inode teardown
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (27 commits) Driver core: fix race in dev_driver_string Driver Core: Early platform driver buffer sysfs: sysfs_setattr remove unnecessary permission check. sysfs: Factor out sysfs_rename from sysfs_rename_dir and sysfs_move_dir sysfs: Propagate renames to the vfs on demand sysfs: Gut sysfs_addrm_start and sysfs_addrm_finish sysfs: In sysfs_chmod_file lazily propagate the mode change. sysfs: Implement sysfs_getattr & sysfs_permission sysfs: Nicely indent sysfs_symlink_inode_operations sysfs: Update s_iattr on link and unlink. sysfs: Fix locking and factor out sysfs_sd_setattr sysfs: Simplify iattr time assignments sysfs: Simplify sysfs_chmod_file semantics sysfs: Use dentry_ops instead of directly playing with the dcache sysfs: Rename sysfs_d_iput to sysfs_dentry_iput sysfs: Update sysfs_setxattr so it updates secdata under the sysfs_mutex debugfs: fix create mutex racy fops and private data Driver core: Don't remove kobjects in device_shutdown. firmware_class: make request_firmware_nowait more useful Driver-Core: devtmpfs - set root directory mode to 0755 ...
2009-12-11devpts_get_tty() should validate inodeSukadev Bhattiprolu
devpts_get_tty() assumes that the inode passed in is associated with a valid pty. But if the only reference to the pty is via a bind-mount, the inode passed to devpts_get_tty() while valid, would refer to a pty that no longer exists. With a lot of debug effort, Grzegorz Nosek developed a small program (see below) to reproduce a crash on recent kernels. This crash is a regression introduced by the commit: commit 527b3e4773628b30d03323a2cb5fb0d84441990f Author: Sukadev Bhattiprolu <sukadev@us.ibm.com> Date: Mon Oct 13 10:43:08 2008 +0100 To fix, ensure that the dentry associated with the inode has not yet been deleted/unhashed by devpts_pty_kill(). See also: https://lists.linux-foundation.org/pipermail/containers/2009-July/019273.html tty-bug.c: #define _GNU_SOURCE #include <fcntl.h> #include <sched.h> #include <stdlib.h> #include <sys/mount.h> #include <sys/signal.h> #include <unistd.h> #include <stdio.h> #include <linux/fs.h> void dummy(int sig) { } static int child(void *unused) { int fd; signal(SIGINT, dummy); signal(SIGHUP, dummy); pause(); /* cheesy synchronisation to wait for /dev/pts/0 to appear */ mount("/dev/pts/0", "/dev/console", NULL, MS_BIND, NULL); sleep(2); fd = open("/dev/console", O_RDWR); dup(0); dup(0); write(1, "Hello world!\n", sizeof("Hello world!\n")-1); return 0; } int main(void) { pid_t pid; char *stack; stack = malloc(16384); pid = clone(child, stack+16384, CLONE_NEWNS|SIGCHLD, NULL); open("/dev/ptmx", O_RDWR|O_NOCTTY|O_NONBLOCK); unlockpt(fd); grantpt(fd); sleep(2); kill(pid, SIGHUP); sleep(1); return 0; /* exit before child opens /dev/console */ } Reported-by: Grzegorz Nosek <root@localdomain.pl> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11xfs: Fix error return for fallocate() on XFSJason Gunthorpe
Noticed that through glibc fallocate would return 28 rather than -1 and errno = 28 for ENOSPC. The xfs routines uses XFS_ERROR format positive return error codes while the syscalls use negative return codes. Fixup the two cases in xfs_vn_fallocate syscall to convert to negative. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: cleanup dmapi macros in the umount pathChristoph Hellwig
Stop the flag saving as we never mangle those in the unmount path, and hide all the weird arguents to the dmapi code inside the XFS_SEND_PREUNMOUNT / XFS_SEND_UNMOUNT macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: remove incorrect sparse annotation for xfs_iget_cache_missChristoph Hellwig
xfs_iget_cache_miss does not get called with the pag_ici_lock held, so the __releases annotation is incorrect. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: kill the STATIC_INLINE macroChristoph Hellwig
Remove our own STATIC_INLINE macro. For small function inside implementation files just use STATIC and let gcc inline it, and for those in headers do the normal static inline - they are all small enough to be inlined for debug builds, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: uninline xfs_get_extsz_hintChristoph Hellwig
This function is too large to efficiently be inlined. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: rename xfs_attr_fetch to xfs_attr_get_intChristoph Hellwig
Using a totally different name for the low-level get operation does not fit the _int convention used in the rest of the attr code, so rename it. While we're at it also fix the prototype to use the normal convention and mark it static as it's never used outside of xfs_attr.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: simplify xfs_buf_get / xfs_buf_read interfacesChristoph Hellwig
Currently the low-level buffer cache interfaces are highly confusing as we have a _flags variant of each that does actually respect the flags, and one without _flags which has a flags argument that gets ignored and overriden with a default set. Given that very few places use the default arguments get rid of the duplication and convert all callers to pass the flags explicitly. Also remove the now confusing _flags postfix. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: remove IO_ISAIOChristoph Hellwig
We set the IO_ISAIO flag for all read/write I/O since early Linux 2.6.x. Remove it as it has lost it's purpose long ago. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: Wrapped journal record corruption on read at recoveryAndy Poling
Summary of problem: If a journal record wraps at the physical end of the journal, it has to be read in two parts in xlog_do_recovery_pass(): a read at the physical end and a read at the physical beginning. If xlog_bread() has to re-align the first read, the second read request does not take that re-alignment into account. If the first read was re-aligned, the second read over-writes the end of the data from the first read, effectively corrupting it. This can happen either when reading the record header or reading the record data. The first sanity check in xlog_recover_process_data() is to check for a valid clientid, so that is the error reported. Summary of fix: If there was a first read at the physical end, XFS_BUF_PTR() returns where the data was requested to begin. Conversely, because it is the result of xlog_align(), offset indicates where the requested data for the first read actually begins - whether or not xlog_bread() has re-aligned it. Using offset as the base for the calculation of where to place the second read data ensures that it will be correctly placed immediately following the data from the first read instead of sometimes over-writing the end of it. The attached patch has resolved the reported problem of occasional inability to recover the journal (reporting "bad clientid"). Signed-off-by: Andy Poling <andy@realbig.com> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: cleanup data end I/O handlersChristoph Hellwig
Currently we have different end I/O handlers for read vs the different types of write I/O. But they are all very similar so we could just use one with a few conditionals and reduce code size a lot. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: use WRITE_SYNC_PLUG for synchronous writeoutChristoph Hellwig
The VM and I/O schedulers now expect us to use WRITE_SYNC_PLUG for synchronous writeout. Right now I can't see any changes in performance numbers with this, but we're getting some beating for not using it, and the knowledge definitely could help the block code to make better decisions. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: reset the i_iolock lock class in the reclaim pathChristoph Hellwig
The iolock is used for protecting reads, writes and block truncates against each other. We have two classes of callers, the first one is induced by a file operation and requires a reference to the inode be held and not dropped after the operation is done: - xfs_vm_vmap, xfs_vn_fallocate, xfs_read, xfs_write, xfs_splice_read, xfs_splice_write and xfs_setattr are all implementations of VFS methods that require a live inode - xfs_getbmap and xfs_swap_extents are ioctl subcommand for which the same is true - xfs_truncate_file is only called on quota inodes just returned from xfs_iget - xfs_sync_inode_data does the lock just after an igrab() - xfs_filestream_associate and xfs_filestream_new_ag take the iolock on the parent inode of an inode which by VFS rules must be referenced And we have various calls to truncate blocks past EOF or the whole file when dropping the last reference to an inode. Unfortunately lockdep complains when we do memory allocations that can recurse into the filesystem in the first class because the second class happens to take the same lock. To avoid this re-init the iolock in the beginning of xfs_fs_clear_inode to get a new lock class. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: I/O completion handlers must use NOFS allocationsChristoph Hellwig
When completing I/O requests we must not allow the memory allocator to recurse into the filesystem, as we might deadlock on waiting for the I/O completion otherwise. The only thing currently allocating normal GFP_KERNEL memory is the allocation of the transaction structure for the unwritten extent conversion. Add a memflags argument to _xfs_trans_alloc to allow controlling the allocator behaviour. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Thomas Neumann <tneumann@users.sourceforge.net> Tested-by: Thomas Neumann <tneumann@users.sourceforge.net> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: fix mmap_sem/iolock inversion in xfs_free_eofblocksChristoph Hellwig
When xfs_free_eofblocks is called from ->release the VM might already hold the mmap_sem, but in the write path we take the iolock before taking the mmap_sem in the generic write code. Switch xfs_free_eofblocks to only trylock the iolock if called from ->release and skip trimming the prellocated blocks in that case. We'll still free them later on the final iput. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: simplify inode teardownChristoph Hellwig
Currently the reclaim code for the case where we don't reclaim the final reclaim is overly complicated. We know that the inode is clean but instead of just directly reclaiming the clean inode we go through the whole process of marking the inode reclaimable just to directly reclaim it from the calling context. Besides being overly complicated this introduces a race where iget could recycle an inode between marked reclaimable and actually being reclaimed leading to panics. This patch gets rid of the existing reclaim path, and replaces it with a simple call to xfs_ireclaim if the inode was clean. While we're at it we also use the slightly more lax xfs_inode_clean check we'd use later to determine if we need to flush the inode here. Finally get rid of xfs_reclaim function and place the remaining small bits of reclaim code directly into xfs_fs_destroy_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Patrick Schreurs <patrick@news-service.com> Reported-by: Tommy van Leeuwen <tommy@news-service.com> Tested-by: Patrick Schreurs <patrick@news-service.com> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (49 commits) nilfs2: separate wait function from nilfs_segctor_write nilfs2: add iterator for segment buffers nilfs2: hide nilfs_write_info struct in segment buffer code nilfs2: relocate io status variables to segment buffer nilfs2: do not return io error for bio allocation failure nilfs2: use list_splice_tail or list_splice_tail_init nilfs2: replace mark_inode_dirty as nilfs_mark_inode_dirty nilfs2: delete mark_inode_dirty in nilfs_delete_entry nilfs2: delete mark_inode_dirty in nilfs_commit_chunk nilfs2: change return type of nilfs_commit_chunk nilfs2: split nilfs_unlink as nilfs_do_unlink and nilfs_unlink nilfs2: delete redundant mark_inode_dirty nilfs2: expand inode_inc_link_count and inode_dec_link_count nilfs2: delete mark_inode_dirty from nilfs_set_link nilfs2: delete mark_inode_dirty in nilfs_new_inode nilfs2: add norecovery mount option nilfs2: add helper to get if volume is in a valid state nilfs2: move recovery completion into load_nilfs function nilfs2: apply readahead for recovery on mount nilfs2: clean up get/put function of a segment usage ...
2009-12-11sysfs: sysfs_setattr remove unnecessary permission check.Eric W. Biederman
inode_change_ok already clears the SGID bit when necessary so there is no reason for sysfs_setattr to carry code to do the same, and it is good to kill the extra copy because when I moved the code last in certain corner cases the code will look at the wrong gid. Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Factor out sysfs_rename from sysfs_rename_dir and sysfs_move_dirEric W. Biederman
These two functions do 90% of the same work and it doesn't significantly obfuscate the function to allow both the parent dir and the name to change at the same time. So merge them together to simplify maintenance, and increase testing. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Propagate renames to the vfs on demandEric W. Biederman
By teaching sysfs_revalidate to hide a dentry for a sysfs_dirent if the sysfs_dirent has been renamed, and by teaching sysfs_lookup to return the original dentry if the sysfs dirent has been renamed. I can show the results of renames correctly without having to update the dcache during the directory rename. This massively simplifies the rename logic allowing a lot of weird sysfs special cases to be removed along with a lot of now unnecesary helper code. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Gut sysfs_addrm_start and sysfs_addrm_finishEric W. Biederman
With lazy inode updates and dentry operations bringing everything into sync on demand there is no longer any need to immediately update the vfs or grab i_mutex to protect those updates as we make changes to sysfs. Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: In sysfs_chmod_file lazily propagate the mode change.Eric W. Biederman
Now that sysfs_getattr and sysfs_permission refresh the vfs inode there is no need to immediatly push the mode change into the vfs cache. Reducing the amount of work needed and simplifying the locking. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Implement sysfs_getattr & sysfs_permissionEric W. Biederman
With the implementation of sysfs_getattr and sysfs_permission sysfs becomes able to lazily propogate inode attribute changes from the sysfs_dirents to the vfs inodes. This paves the way for deleting significant chunks of now unnecessary code. While doing this we did not reference sysfs_setattr from sysfs_symlink_inode_operations so I added along with sysfs_getattr and sysfs_permission. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Nicely indent sysfs_symlink_inode_operationsEric W. Biederman
Lining up the functions in sysfs_symlink_inode_operations follows the pattern in the rest of sysfs and makes things slightly more readable. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Update s_iattr on link and unlink.Eric W. Biederman
Currently sysfs updates the timestamps on the vfs directory inode when we create or remove a directory entry but doesn't update the cached copy on the sysfs_dirent, fix that oversight. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Fix locking and factor out sysfs_sd_setattrEric W. Biederman
Cleanly separate the work that is specific to setting the attributes of a sysfs_dirent from what is needed to update the attributes of a vfs inode. Additionally grab the sysfs_mutex to keep any nasties from surprising us when updating the sysfs_dirent. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Simplify iattr time assignmentsEric W. Biederman
The granularity of sysfs time when we keep it is 1 ns. Which when passed to timestamp_trunc results in a nop. So remove the unnecessary function call making sysfs_setattr slightly easier to read. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Simplify sysfs_chmod_file semanticsEric W. Biederman
Currently every caller of sysfs_chmod_file happens at either file creation time to set a non-default mode or in response to a specific user requested space change in policy. Making timestamps of when the chmod happens and notification of a file changing mode uninteresting. Remove the unnecessary time stamp and filesystem change notification, and removes the last of the explicit inotify and donitfy support from sysfs. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Use dentry_ops instead of directly playing with the dcacheEric W. Biederman
Calling d_drop unconditionally when a sysfs_dirent is deleted has the potential to leak mounts, so instead implement dentry delete and revalidate operations that cause sysfs dentries to be removed at the appropriate time. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Rename sysfs_d_iput to sysfs_dentry_iputEric W. Biederman
Using dentry instead of d in the function name is what several other filesystems are doing and it seems to be a more readable convention. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Update sysfs_setxattr so it updates secdata under the sysfs_mutexEric W. Biederman
The sysfs_mutex is required to ensure updates are and will remain atomic with respect to other inode iattr updates, that do not happen through the filesystem. Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11debugfs: fix create mutex racy fops and private dataMathieu Desnoyers
Setting fops and private data outside of the mutex at debugfs file creation introduces a race where the files can be opened with the wrong file operations and private data. It is easy to trigger with a process waiting on file creation notification. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: mark a locally-only used function staticStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: David P. Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-10usbdevfs: move compat_ioctl handling to devio.cArnd Bergmann
Half the compat_ioctl handling is in devio.c, the other half is in fs/compat_ioctl.c. This moves everything into one place for consistency. As a positive side-effect, push down the BKL into the ioctl methods. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Oliver Neukum <oliver@neukum.org> Cc: Alon Bar-Lev <alon.barlev@gmail.com> Cc: David Vrabel <david.vrabel@csr.com> Cc: linux-usb@vger.kernel.org
