path: root/fs/xfs
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-28Merge tag 'xfs-for-linus-v3.14-rc1-2' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull second xfs update from Ben Myers: "Allow logical sector sized direct io on 'advanced format' 4k/512 disk" * tag 'xfs-for-linus-v3.14-rc1-2' of git://oss.sgi.com/xfs/xfs: xfs: allow logical-sector sized O_DIRECT xfs: rename xfs_buftarg structure members xfs: clean up xfs_buftarg
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "Assorted stuff; the biggest pile here is Christoph's ACL series. Plus assorted cleanups and fixes all over the place... There will be another pile later this week" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits) __dentry_path() fixes vfs: Remove second variable named error in __dentry_path vfs: Is mounted should be testing mnt_ns for NULL or error. Fix race when checking i_size on direct i/o read hfsplus: remove can_set_xattr nfsd: use get_acl and ->set_acl fs: remove generic_acl nfs: use generic posix ACL infrastructure for v3 Posix ACLs gfs2: use generic posix ACL infrastructure jfs: use generic posix ACL infrastructure xfs: use generic posix ACL infrastructure reiserfs: use generic posix ACL infrastructure ocfs2: use generic posix ACL infrastructure jffs2: use generic posix ACL infrastructure hfsplus: use generic posix ACL infrastructure f2fs: use generic posix ACL infrastructure ext2/3/4: use generic posix ACL infrastructure btrfs: use generic posix ACL infrastructure fs: make posix_acl_create more useful fs: make posix_acl_chmod more useful ...
2014-01-25xfs: use generic posix ACL infrastructureChristoph Hellwig
Also don't bother to set up a .get_acl method for symlinks as we do not support access control (ACLs or even mode bits) for symlinks in Linux, and create inodes with the proper mode instead of fixing it up later. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_create more usefulChristoph Hellwig
Rename the current posix_acl_created to __posix_acl_create and add a fully featured helper to set up the ACLs on file creation that uses get_acl(). Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_chmod more usefulChristoph Hellwig
Rename the current posix_acl_chmod to __posix_acl_chmod and add a fully featured ACL chmod helper that uses the ->set_acl inode operation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25xfs: switch to kfree_put_link()Al Viro
don't bother open-coding it... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-24xfs: allow logical-sector sized O_DIRECTEric Sandeen
Some time ago, mkfs.xfs started picking the storage physical sector size as the default filesystem "sector size" in order to avoid RMW costs incurred by doing IOs at logical sector size alignments. However, this means that for a filesystem made with i.e. a 4k sector size on an "advanced format" 4k/512 disk, 512-byte direct IOs are no longer allowed. This means that XFS has essentially turned this AF drive into a hard 4K device, from the filesystem on up. XFS's mkfs-specified "sector size" is really just controlling the minimum size & alignment of filesystem metadata. There is no real need to tightly couple XFS's minimal metadata size to the minimum allowed direct IO size; XFS can continue doing metadata in optimal sizes, but still allow smaller DIOs for apps which issue them, for whatever reason. This patch adds a new field to the xfs_buftarg, so that we now track 2 sizes: 1) The metadata sector size, which is the minimum unit and alignment of IO which will be performed by metadata operations. 2) The device logical sector size The first is used internally by the file system for metadata alignment and IOs. The second is used for the minimum allowed direct IO alignment. This has passed xfstests on filesystems made with 4k sectors, including when run under the patch I sent to ignore XFS_IOC_DIOINFO, and issue 512 DIOs anyway. I also directly tested end of block behavior on preallocated, sparse, and existing files when we do a 512 IO into a 4k file on a 4k-sector filesystem, to be sure there were no unexpected behaviors. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2014-01-24xfs: rename xfs_buftarg structure membersEric Sandeen
In preparation for adding new members to the structure, give these old ones more descriptive names: bt_ssize -> bt_meta_sectorsize bt_smask -> bt_meta_sectormask Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2014-01-24xfs: clean up xfs_buftargEric Sandeen
Clean up the xfs_buftarg structure a bit: - remove bt_bsize which is never used - replace bt_sshift with bt_ssize; we only ever shift it back Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2014-01-10xfs: Calling destroy_work_on_stack() to pair with INIT_WORK_ONSTACK()Chuansheng Liu
In case CONFIG_DEBUG_OBJECTS_WORK is defined, it is needed to call destroy_work_on_stack() which frees the debug object to pair with INIT_WORK_ONSTACK(). Signed-off-by: Liu, Chuansheng <chuansheng.liu@intel.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 6f96b3063cdd473c68664a190524ed966ac0cd92)
2014-01-10xfs: fix off-by-one error in xfs_attr3_rmt_verifyJie Liu
With CRC check is enabled, if trying to set an attributes value just equal to the maximum size of XATTR_SIZE_MAX would cause the v3 remote attr write verification procedure failure, which would yield the back trace like below: <snip> XFS (sda7): Internal error xfs_attr3_rmt_write_verify at line 191 of file fs/xfs/xfs_attr_remote.c <snip> Call Trace: [<ffffffff816f0042>] dump_stack+0x45/0x56 [<ffffffffa0d99c8b>] xfs_error_report+0x3b/0x40 [xfs] [<ffffffffa0d96edd>] ? _xfs_buf_ioapply+0x6d/0x390 [xfs] [<ffffffffa0d99ce5>] xfs_corruption_error+0x55/0x80 [xfs] [<ffffffffa0dbef6b>] xfs_attr3_rmt_write_verify+0x14b/0x1a0 [xfs] [<ffffffffa0d96edd>] ? _xfs_buf_ioapply+0x6d/0x390 [xfs] [<ffffffffa0d97315>] ? xfs_bdstrat_cb+0x55/0xb0 [xfs] [<ffffffffa0d96edd>] _xfs_buf_ioapply+0x6d/0x390 [xfs] [<ffffffff81184cda>] ? vm_map_ram+0x31a/0x460 [<ffffffff81097230>] ? wake_up_state+0x20/0x20 [<ffffffffa0d97315>] ? xfs_bdstrat_cb+0x55/0xb0 [xfs] [<ffffffffa0d9726b>] xfs_buf_iorequest+0x6b/0xc0 [xfs] [<ffffffffa0d97315>] xfs_bdstrat_cb+0x55/0xb0 [xfs] [<ffffffffa0d97906>] xfs_bwrite+0x46/0x80 [xfs] [<ffffffffa0dbfa94>] xfs_attr_rmtval_set+0x334/0x490 [xfs] [<ffffffffa0db84aa>] xfs_attr_leaf_addname+0x24a/0x410 [xfs] [<ffffffffa0db8893>] xfs_attr_set_int+0x223/0x470 [xfs] [<ffffffffa0db8b76>] xfs_attr_set+0x96/0xb0 [xfs] [<ffffffffa0db13b2>] xfs_xattr_set+0x42/0x70 [xfs] [<ffffffff811df9b2>] generic_setxattr+0x62/0x80 [<ffffffff811e0213>] __vfs_setxattr_noperm+0x63/0x1b0 [<ffffffff81307afe>] ? evm_inode_setxattr+0xe/0x10 [<ffffffff811e0415>] vfs_setxattr+0xb5/0xc0 [<ffffffff811e054e>] setxattr+0x12e/0x1c0 [<ffffffff811c6e82>] ? final_putname+0x22/0x50 [<ffffffff811c708b>] ? putname+0x2b/0x40 [<ffffffff811cc4bf>] ? user_path_at_empty+0x5f/0x90 [<ffffffff811bdfd9>] ? __sb_start_write+0x49/0xe0 [<ffffffff81168589>] ? vm_mmap_pgoff+0x99/0xc0 [<ffffffff811e07df>] SyS_setxattr+0x8f/0xe0 [<ffffffff81700c2d>] system_call_fastpath+0x1a/0x1f Tests: setfattr -n user.longxattr -v `perl -e 'print "A"x65536'` testfile This patch fix it to check the remote EA size is greater than the XATTR_SIZE_MAX rather than more than or equal to it, because it's valid if the specified EA value size is equal to the limitation as per VFS setxattr interface. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 85dd0707f0cad26d60f2dc574d17a5ab948d10f7)
2014-01-09Merge branch 'xfs-extent-list-locking-fixes' into for-nextBen Myers
A set of fixes which makes sure we are taking the ilock whenever accessing the extent list. This was associated with "Access to block zero" messages which may result in extent list corruption.
2014-01-09Merge branch 'xfs-misc' into for-nextBen Myers
A bugfix for an off-by-one in the remote attribute verifier, and a fix for a missing destroy_work_on_stack() in the allocation worker.
2014-01-09xfs: Calling destroy_work_on_stack() to pair with INIT_WORK_ONSTACK()Chuansheng Liu
2014-01-06xfs: fix off-by-one error in xfs_attr3_rmt_verifyJie Liu
2013-12-31Merge tag 'v3.13-rc6' into for-3.14/coreJens Axboe
Needed to bring blk-mq uptodate, since changes have been going in since for-3.14/core was established. Fixup merge issues related to the immutable biovec changes. Signed-off-by: Jens Axboe <axboe@kernel.dk> Conflicts: block/blk-flush.c fs/btrfs/check-integrity.c fs/btrfs/extent_io.c fs/btrfs/scrub.c fs/logfs/dev_bdev.c
2013-12-18xfs: assert that we hold the ilock for extent map accessChristoph Hellwig
Make sure that xfs_bmapi_read has the ilock held in some way, and that xfs_bmapi_write, xfs_bmapi_delay, xfs_bunmapi and xfs_iread_extents are called with the ilock held exclusively. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-18xfs: use xfs_ilock_attr_map_shared in xfs_attr_list_intChristoph Hellwig
We might not have read in the extent list at this point, so make sure we take the ilock exclusively if we have to do so. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-18xfs: use xfs_ilock_attr_map_shared in xfs_attr_getChristoph Hellwig
2013-12-18xfs: use xfs_ilock_data_map_shared in xfs_qm_dqiterateChristoph Hellwig
2013-12-18xfs: use xfs_ilock_data_map_shared in xfs_qm_dqtobpChristoph Hellwig
2013-12-18xfs: take the ilock around xfs_bmapi_read in xfs_zero_remaining_bytesChristoph Hellwig
2013-12-18xfs: reinstate the ilock in xfs_readdirBen Myers
Although it was removed in commit 051e7cd44ab8, ilock needs to be taken in xfs_readdir because we might have to read the extent list in from disk. This keeps other threads from reading from or writing to the extent list while it is being read in and is still in a transitional state. This has been associated with "Access to block zero" messages on directories with large numbers of extents resulting from excessive filesytem fragmentation, as well as extent list corruption. Unfortunately no test case at this point. Signed-off-by: Ben Myers <bpm@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2013-12-18xfs: add xfs_ilock_attr_map_sharedChristoph Hellwig
Equivalent to xfs_ilock_data_map_shared, except for the attribute fork. Make xfs_getbmap use it if called for the attribute fork instead of xfs_ilock_data_map_shared. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-18xfs: rename xfs_ilock_map_sharedChristoph Hellwig
Make it clear that we're only locking against the extent map on the data fork. Also clean the function up a little bit. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-18xfs: remove xfs_iunlock_map_sharedChristoph Hellwig
We can just use xfs_iunlock without any loss of clarity. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-18xfs: no need to lock the inode in xfs_find_handleChristoph Hellwig
Both the inode number and the generation do not change on a live inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-18Merge branch 'xfs-for-linus-v3.13-rc5' into for-nextBen Myers
2013-12-17xfs: abort metadata writeback on permanent errorsDave Chinner
If we are doing aysnc writeback of metadata, we can get write errors but have nobody to report them to. At the moment, we simply attempt to reissue the write from io completion in the hope that it's a transient error. When it's not a transient error, the buffer is stuck forever in this loop, and we cannot break out of it. Eventually, unmount will hang because the AIL cannot be emptied and everything goes downhill from them. To solve this problem, only retry the write IO once before aborting it. We don't throw the buffer away because some transient errors can last minutes (e.g. FC path failover) or even hours (thin provisioned devices that have run out of backing space) before they go away. Hence we really want to keep trying until we can't try any more. Because the buffer was not cleaned, however, it does not get removed from the AIL and hence the next pass across the AIL will start IO on it again. As such, we still get the "retry forever" semantics that we currently have, but we allow other access to the buffer in the mean time. Meanwhile the filesystem can continue to modify the buffer and relog it, so the IO errors won't hang the log or the filesystem. Now when we are pushing the AIL, we can see all these "permanent IO error" buffers and we can issue a warning about failures before we retry the IO. We can also catch these buffers when unmounting an issue a corruption warning, too. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-17xfs: swalloc doesn't align allocations properlyDave Chinner
When swalloc is specified as a mount option, allocations are supposed to be aligned to the stripe width rather than the stripe unit of the underlying filesystem. However, it does not do this. What the implementation does is round up the allocation size to a stripe width, hence ensuring that all allocations span a full stripe width. It does not, however, ensure that that allocation is aligned to a stripe width, and hence the allocations can span multiple underlying stripes and so still see RMW cycles for things like direct IO on MD RAID. So, if the swalloc mount option is set, change the allocation alignment in xfs_bmap_btalloc() to use the stripe width rather than the stripe unit. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-17xfs: remove xfsbdstrat errorChristoph Hellwig
The xfsbdstrat helper is a small but useless wrapper for xfs_buf_iorequest that handles the case of a shut down filesystem. Most of the users have private, uncached buffers that can just be freed in this case, but the complex error handling in xfs_bioerror_relse messes up the case when it's called without a locked buffer. Remove xfsbdstrat and opencode the error handling in the callers. All but one can simply return an error and don't need to deal with buffer state, and the one caller that cares about the buffer state could do with a major cleanup as well, but we'll defer that to later. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-12-17xfs: align initial file allocations correctlyDave Chinner
The function xfs_bmap_isaeof() is used to indicate that an allocation is occurring at or past the end of file, and as such should be aligned to the underlying storage geometry if possible. Commit 27a3f8f ("xfs: introduce xfs_bmap_last_extent") changed the behaviour of this function for empty files - it turned off allocation alignment for this case accidentally. Hence large initial allocations from direct IO are not getting correctly aligned to the underlying geometry, and that is cause write performance to drop in alignment sensitive configurations. Fix it by considering allocation into empty files as requiring aligned allocation again. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit f9b395a8ef8f34d19cae2cde361e19c96e097fad)
2013-12-17xfs: fix infinite loop by detaching the group/project hints from user dquotJie Liu
xfs_quota(8) will hang up if trying to turn group/project quota off before the user quota is off, this could be 100% reproduced by: # mount -ouquota,gquota /dev/sda7 /xfs # mkdir /xfs/test # xfs_quota -xc 'off -g' /xfs <-- hangs up # echo w > /proc/sysrq-trigger # dmesg SysRq : Show Blocked State task PC stack pid father xfs_quota D 0000000000000000 0 27574 2551 0x00000000 [snip] Call Trace: [<ffffffff81aaa21d>] schedule+0xad/0xc0 [<ffffffff81aa327e>] schedule_timeout+0x35e/0x3c0 [<ffffffff8114b506>] ? mark_held_locks+0x176/0x1c0 [<ffffffff810ad6c0>] ? call_timer_fn+0x2c0/0x2c0 [<ffffffffa0c25380>] ? xfs_qm_shrink_count+0x30/0x30 [xfs] [<ffffffff81aa3306>] schedule_timeout_uninterruptible+0x26/0x30 [<ffffffffa0c26155>] xfs_qm_dquot_walk+0x235/0x260 [xfs] [<ffffffffa0c059d8>] ? xfs_perag_get+0x1d8/0x2d0 [xfs] [<ffffffffa0c05805>] ? xfs_perag_get+0x5/0x2d0 [xfs] [<ffffffffa0b7707e>] ? xfs_inode_ag_iterator+0xae/0xf0 [xfs] [<ffffffffa0c22280>] ? xfs_trans_free_dqinfo+0x50/0x50 [xfs] [<ffffffffa0b7709f>] ? xfs_inode_ag_iterator+0xcf/0xf0 [xfs] [<ffffffffa0c261e6>] xfs_qm_dqpurge_all+0x66/0xb0 [xfs] [<ffffffffa0c2497a>] xfs_qm_scall_quotaoff+0x20a/0x5f0 [xfs] [<ffffffffa0c2b8f6>] xfs_fs_set_xstate+0x136/0x180 [xfs] [<ffffffff8136cf7a>] do_quotactl+0x53a/0x6b0 [<ffffffff812fba4b>] ? iput+0x5b/0x90 [<ffffffff8136d257>] SyS_quotactl+0x167/0x1d0 [<ffffffff814cf2ee>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81abcd19>] system_call_fastpath+0x16/0x1b It's fine if we turn user quota off at first, then turn off other kind of quotas if they are enabled since the group/project dquot refcount is decreased to zero once the user quota if off. Otherwise, those dquots refcount is non-zero due to the user dquot might refer to them as hint(s). Hence, above operation cause an infinite loop at xfs_qm_dquot_walk() while trying to purge dquot cache. This problem has been around since Linux 3.4, it was introduced by: [ b84a3a9675 xfs: remove the per-filesystem list of dquots ] Originally we will release the group dquot pointers because the user dquots maybe carrying around as a hint via xfs_qm_detach_gdquots(). However, with above change, there is no such work to be done before purging group/project dquot cache. In order to solve this problem, this patch introduces a special routine xfs_qm_dqpurge_hints(), and it would release the group/project dquot pointers the user dquots maybe carrying around as a hint, and then it will proceed to purge the user dquot cache if requested. Cc: stable@vger.kernel.org Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit df8052e7dae00bde6f21b40b6e3e1099770f3afc)
2013-12-17xfs: fix assertion failure at xfs_setattr_nonsizeJie Liu
For CRC enabled v5 super block, change a file's ownership can simply trigger an ASSERT failure at xfs_setattr_nonsize() if both group and project quota are enabled, i.e, [ 305.337609] XFS: Assertion failed: !XFS_IS_PQUOTA_ON(mp), file: fs/xfs/xfs_iops.c, line: 621 [ 305.339250] Kernel BUG at ffffffffa0a7fa32 [verbose debug info unavailable] [ 305.383939] Call Trace: [ 305.385536] [<ffffffffa0a7d95a>] xfs_setattr_nonsize+0x69a/0x720 [xfs] [ 305.387142] [<ffffffffa0a7dea9>] xfs_vn_setattr+0x29/0x70 [xfs] [ 305.388727] [<ffffffff811ca388>] notify_change+0x1a8/0x350 [ 305.390298] [<ffffffff811ac39d>] chown_common+0xfd/0x110 [ 305.391868] [<ffffffff811ad6bf>] SyS_fchownat+0xaf/0x110 [ 305.393440] [<ffffffff811ad760>] SyS_lchown+0x20/0x30 [ 305.394995] [<ffffffff8170f7dd>] system_call_fastpath+0x1a/0x1f [ 305.399870] RIP [<ffffffffa0a7fa32>] assfail+0x22/0x30 [xfs] This fix adjust the assertion to check if the super block support both quota inodes or not. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 5a01dd54f4a7fb513062070c5acef20d13cad980)
2013-12-17xfs: fix false assertion at xfs_qm_vop_create_dqattachJie Liu
After the previous fix, there still has another ASSERT failure if turning off any type of quota while fsstress is running at the same time. Backtrace in this case: [ 50.867897] XFS: Assertion failed: XFS_IS_GQUOTA_ON(mp), file: fs/xfs/xfs_qm.c, line: 2118 [ 50.867924] ------------[ cut here ]------------ ... <snip> [ 50.867957] Kernel BUG at ffffffffa0b55a32 [verbose debug info unavailable] [ 50.867999] invalid opcode: 0000 [#1] SMP [ 50.869407] Call Trace: [ 50.869446] [<ffffffffa0bc408a>] xfs_qm_vop_create_dqattach+0x19a/0x2d0 [xfs] [ 50.869512] [<ffffffffa0b9cc45>] xfs_create+0x5c5/0x6a0 [xfs] [ 50.869564] [<ffffffffa0b5307c>] xfs_vn_mknod+0xac/0x1d0 [xfs] [ 50.869615] [<ffffffffa0b531d6>] xfs_vn_mkdir+0x16/0x20 [xfs] [ 50.869655] [<ffffffff811becd5>] vfs_mkdir+0x95/0x130 [ 50.869689] [<ffffffff811bf63a>] SyS_mkdirat+0xaa/0xe0 [ 50.869723] [<ffffffff811bf689>] SyS_mkdir+0x19/0x20 [ 50.869757] [<ffffffff8170f7dd>] system_call_fastpath+0x1a/0x1f [ 50.869793] Code: 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 <snip> [ 50.870003] RIP [<ffffffffa0b55a32>] assfail+0x22/0x30 [xfs] [ 50.870050] RSP <ffff88002941fd60> [ 50.879251] ---[ end trace c93a2b342341c65b ]--- We're hitting the ASSERT(XFS_IS_*QUOTA_ON(mp)) in xfs_qm_vop_create_dqattach(), however the assertion itself is not right IMHO. While performing quota off, we firstly clear the XFS_*QUOTA_ACTIVE bit(s) from struct xfs_mount without taking any special locks, see xfs_qm_scall_quotaoff(). Hence there is no guarantee that the desired quota is still active. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 37eb9706ebf5b99d14c6086cdeef2c2f73f9c9fb)
2013-12-17xfs: fix memory leak in xfs_dir2_node_removenameMark Tinguely
Fix the leak of kernel memory in xfs_dir2_node_removename() when xfs_dir2_leafn_remove() returns an error code. Signed-off-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit ef701600fd26cace9d513ee174688a2b83832126)
2013-12-13Merge branch 'xfs-factor-icluster-macros' into for-nextBen Myers
2013-12-13xfs: use xfs_icluster_size_fsb in xfs_imapJie Liu
Use xfs_icluster_size_fsb() in xfs_imap(). Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: use xfs_icluster_size_fsb in xfs_ifree_clusterJie Liu
Use xfs_icluster_size_fsb() in xfs_ifree_cluster(), rename variable ninodes to inodes_per_cluster, the latter is more meaningful. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: use xfs_icluster_size_fsb in xfs_ialloc_inode_initJie Liu
Use xfs_icluster_size_fsb() in xfs_ialloc_inode_init(), rename variable ninodes to inodes_per_cluster, the latter is more meaningful. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: use xfs_icluster_size_fsb in xfs_bulkstatJie Liu
Use xfs_icluster_size_fsb() in xfs_bulkstat(), make the related variables more meaningful and remove an unused variable nimask from it. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: introduce a common helper xfs_icluster_size_fsbJie Liu
Introduce a common routine xfs_icluster_size_fsb() to calculate and return the number of file system blocks per inode cluster. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: get rid of XFS_IALLOC_BLOCKS macrosJie Liu
Get rid of XFS_IALLOC_BLOCKS() marcos, use mp->m_ialloc_blks directly. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: get rid of XFS_INODE_CLUSTER_SIZE macrosJie Liu
Get rid of XFS_INODE_CLUSTER_SIZE() macros, use mp->m_inode_cluster_size directly. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: get rid of XFS_IALLOC_INODES macrosJie Liu
Get rid of XFS_IALLOC_INODES() marcos, use mp->m_ialloc_inos directly. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: remove the quotaoff log format from the quotaoff log itemChristoph Hellwig
This one doesn't save a whole lot of memory, but still makes the code simpler. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: remove the dquot log format from the dquot log itemChristoph Hellwig
No need to keep the dquot log format around all the time, we can easily generate it at iop_format time. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: remove the inode log format from the inode log itemChristoph Hellwig
No need to keep the inode log format around all the time, we can easily generate it at iop_format time. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2013-12-13xfs: format logged extents directly into the CILChristoph Hellwig
With the new iop_format scheme there is no need to have a temporary buffer to format logged extents into, we can do so directly into the CIL. This also allows to remove the shortcut for big endian systems that probably hasn't gotten a lot of test coverage for a long time. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
