path: root/fs/xfs/xfs_vnodeops.h
2012-03-15xfs: remove remaining scraps of struct xfs_iomapDave Chinner
Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-01-03xfs: propagate umode_tAl Viro
2011-07-08xfs: split xfs_setattrChristoph Hellwig
Split up xfs_setattr into two functions, one for the complex truncate handling, and one for the trivial attribute updates. Also move both new routines to xfs_iops.c as they are fairly Linux-specific. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com> Reviewed-by: Dave Chinner <dchinner@redhat.com>
2011-03-26xfs: preallocation transactions do not need to be synchronousDave Chinner
Preallocation and hole punch transactions are currently synchronous and this is causing performance problems in some cases. The transactions don't need to be synchronous as we don't need to guarantee the preallocation is persistent on disk until a fdatasync, fsync, sync operation occurs. If the file is opened O_SYNC or O_DATASYNC, only then should the transaction be issued synchronously. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Alex Elder <aelder@sgi.com>
2010-10-18xfs: remove xfs_cred.hChristoph Hellwig
We're not actually passing around credentials inside XFS for a while now, so remove all xfs_cred.h with it's cred_t typedef and all instances of it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-01xfs: kill xfs_lrw.hChristoph Hellwig
Move the two declarations to better fitting headers now that xfs_lrw.c is gone. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-01xfs: remove wrapper for the fsync file operationChristoph Hellwig
Currently the fsync file operation is divided into a low-level routine doing all the work and one that implements the Linux file operation and does minimal argument wrapping. This is a leftover from the days of the vnode operations layer and can be removed to simplify the code a bit, as well as preparing for the implementation of an optimized fdatasync which needs to look at the Linux inode state. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-03-01xfs: merge xfs_lrw.c into xfs_file.cChristoph Hellwig
Currently the code to implement the file operations is split over two small files. Merge the content of xfs_lrw.c into xfs_file.c to have it in one place. Note that I haven't done various cleanups that are possible after this yet, they will follow in the next patch. Also the function xfs_dev_is_read_only which was in xfs_lrw.c before really doesn't fit in here at all and was moved to xfs_mount.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-01-20xfs: convert attr to use unsigned namesDave Chinner
To be consistent with the directory code, the attr code should use unsigned names. Convert the names from the vfs at the highest level to unsigned, and ænsure they are consistenly used as unsigned down to disk. Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2009-12-11xfs: simplify inode teardownChristoph Hellwig
Currently the reclaim code for the case where we don't reclaim the final reclaim is overly complicated. We know that the inode is clean but instead of just directly reclaiming the clean inode we go through the whole process of marking the inode reclaimable just to directly reclaim it from the calling context. Besides being overly complicated this introduces a race where iget could recycle an inode between marked reclaimable and actually being reclaimed leading to panics. This patch gets rid of the existing reclaim path, and replaces it with a simple call to xfs_ireclaim if the inode was clean. While we're at it we also use the slightly more lax xfs_inode_clean check we'd use later to determine if we need to flush the inode here. Finally get rid of xfs_reclaim function and place the remaining small bits of reclaim code directly into xfs_fs_destroy_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Patrick Schreurs <patrick@news-service.com> Reported-by: Tommy van Leeuwen <tommy@news-service.com> Tested-by: Patrick Schreurs <patrick@news-service.com> Reviewed-by: Alex Elder <aelder@sgi.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-06-10xfs: use generic Posix ACL codeChristoph Hellwig
This patch rips out the XFS ACL handling code and uses the generic fs/posix_acl.c code instead. The ondisk format is of course left unchanged. This also introduces the same ACL caching all other Linux filesystems do by adding pointers to the acl and default acl in struct xfs_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2009-02-09xfs: merge xfs_mkdir into xfs_createChristoph Hellwig
xfs_create and xfs_mkdir only have minor differences, so merge both of them into a sigle function. While we're at it also make the error handling code more straight-forward. Signed-off-by: Christoph Hellwig <hch@lst.de> Dave Chinner <david@fromorbit.com>
2009-02-04xfs: merge xfs_inode_flush into xfs_fs_write_inodeChristoph Hellwig
Splitting the task for a VFS-induced inode flush into two functions doesn't make any sense, so merge the two functions dealing with it. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Reviewed-by: Dave Chinner <david@fromorbit.com>
2008-12-29[XFS] Fix merge failuresLachlan McIlroy
Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: fs/xfs/linux-2.6/xfs_cred.h fs/xfs/linux-2.6/xfs_globals.h fs/xfs/linux-2.6/xfs_ioctl.c fs/xfs/xfs_vnodeops.h Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-11[XFS] add a FMODE flag to make XFS invisible I/O less hackyChristoph Hellwig
XFS has a mode called invisble I/O that doesn't update any of the timestamps. It's used for HSM-style applications and exposed through the nasty open by handle ioctl. Instead of doing directly assignment of file operations that set an internal flag for it add a new FMODE_NOCMTIME flag that we can check in the normal file operations. (addition of the generic VFS flag has been ACKed by Al as an interims solution) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-01[XFS] fix error inversion problems with data flushingDave Chinner
XFS gets the sign of the error wrong in several places when gathering the error from generic linux functions. These functions return negative error values, while the core XFS code returns positive error values. Hence when XFS inverts the error to be returned to the VFS, it can incorrectly invert a negative error and this error will be ignored by the syscall return. Fix all the problems related to calling filemap_* functions. Problem initially identified by Nick Piggin in xfs_fsync(). Signed-off-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-12-01[XFS] wire up ->open for directoriesChristoph Hellwig
Currently there's no ->open method set for directories on XFS. That means we don't perform any check for opening too large directories without O_LARGEFILE, we don't check for shut down filesystems, and we don't actually do the readahead for the first block in the directory. Instead of just setting the directories open routine to xfs_file_open we merge the shutdown check directly into xfs_file_open and create a new xfs_dir_open that first calls xfs_file_open and then performs the readahead for block 0. (First sent on September 29th) Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Niv Sardi <xaiki@sgi.com>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-30[XFS] kill sys_credChristoph Hellwig
capable_cred has been unused for a while so we can kill it and sys_cred. That also means the cred argument to xfs_setattr and xfs_change_file_space can be removed now. SGI-PV: 988918 SGI-Modid: xfs-linux-melb:xfs-kern:32412a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Now that xfs_setattr is only used for attributes set from ->setattrChristoph Hellwig
it can be switched to take struct iattr directly and thus simplify the implementation greatly. Also rename the ATTR_ flags to XFS_ATTR_ to not conflict with the ATTR_ flags used by the VFS. SGI-PV: 984565 SGI-Modid: xfs-linux-melb:xfs-kern:31678a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Merge xfs_rmdir into xfs_removeChristoph Hellwig
xfs_remove and xfs_rmdir are almost the same with a little more work performed in xfs_rmdir due to the . and .. entries. This patch merges xfs_rmdir into xfs_remove and performs these actions conditionally. Also clean up the error handling which was a nightmare in both versions before. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31335a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-07-28[XFS] Return case-insensitive match for dentry cacheBarry Naujok
This implements the code to store the actual filename found during a lookup in the dentry cache and to avoid multiple entries in the dcache pointing to the same inode. To avoid polluting the dcache, we implement a new directory inode operations for lookup. xfs_vn_ci_lookup() stores the correct case name in the dcache. The "actual name" is only allocated and returned for a case- insensitive match and not an actual match. Another unusual interaction with the dcache is not storing negative dentries like other filesystems doing a d_add(dentry, NULL) when an ENOENT is returned. During the VFS lookup, if a dentry returned has no inode, dput is called and ENOENT is returned. By not doing a d_add, this actually removes it completely from the dcache to be reused. create/rename have to be modified to support unhashed dentries being passed in. SGI-PV: 981521 SGI-Modid: xfs-linux-melb:xfs-kern:31208a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org>
2008-05-23[XFS] Fix fsync() b0rkage.David Chinner
xfs_fsync() fails to wait for data I/O completion before checking if the inode is dirty or clean to decide whether to log the inode or not. This misses inode size updates when the data flushed by the fsync() is extending the file. Hence, like fdatasync(), we need to wait for I/o completion first, then check the inode for cleanliness. Doing so makes the behaviour of xfs_fsync() identical for fsync and fdatasync and we *always* use synchronous semantics if the inode is dirty. Therefore also kill the differences and remove the unused flags from the xfs_fsync function and callers. SGI-PV: 981296 SGI-Modid: xfs-linux-melb:xfs-kern:31033a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] remove sendfile leftoversChristoph Hellwig
Remove the last sendfile leftovers in mainline. This code is already gone in CVS. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] Cleanup xfs_attr a bit with xfs_name and remove credBarry Naujok
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30913a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] remove manual lookup from xfs_rename and simplify lockingChristoph Hellwig
->rename already gets the target inode passed if it exits. Pass it down to xfs_rename so that we can avoid looking it up again. Also simplify locking as the first lock section in xfs_rename can go away now: the isdir is an invariant over the lifetime of the inode, and new_parent and the nlink check are namespace topology protected by i_mutex in the VFS. The projid check needs to move into the second lock section anyway to not be racy. Also kill the now unused xfs_dir_lookup_int and remove the now-unused first_locked argumet to xfs_lock_inodes. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30903a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-29[XFS] kill xfs_getattrChristoph Hellwig
It's currently used by the ACL code to read di_mode/di_uid, but these are simple 32bit scalar values we can just read directly without locking. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30897a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] remove bhv_vname_t and xfs_rename codeBarry Naujok
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30804a Signed-off-by: Barry Naujok <bnaujok@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] cleanup vnode use in xfs_lookupChristoph Hellwig
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30550a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] cleanup vnode use in xfs_symlink and xfs_renameChristoph Hellwig
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30548a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] cleanup vnode use in xfs_linkChristoph Hellwig
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30547a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] cleanup vnode use in xfs_create/mknod/mkdirChristoph Hellwig
SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30546a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] kill xfs_rwlock/xfs_rwunlockChristoph Hellwig
We can just use xfs_ilock/xfs_iunlock instead and get rid of the ugly bhv_vrwlock_t. SGI-PV: 976035 SGI-Modid: xfs-linux-melb:xfs-kern:30533a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] use generic_permissionChristoph Hellwig
Now that all direct caller of xfs_iaccess are gone we can kill xfs_iaccess and xfs_access and just use generic_permission with a check_acl callback. This is required for the per-mount read-only patchset in -mm to work properly with XFS. SGI-PV: 971186 SGI-Modid: xfs-linux-melb:xfs-kern:30370a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-02-07[XFS] Cleanup various fid related bits:Christoph Hellwig
- merge xfs_fid2 into it's only caller xfs_dm_inode_to_fh. - remove xfs_vget and opencode it in the two callers, simplifying both of them by avoiding the awkward calling convetion. - assign directly to the dm_fid_t members in various places in the dmapi code instead of casting them to xfs_fid_t first (which is identical to dm_fid_t) SGI-PV: 974747 SGI-Modid: xfs-linux-melb:xfs-kern:30258a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Vlad Apostolov <vapo@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-19[XFS] cleanup fid types messChristoph Hellwig
Currently XFs has three different fid types: struct fid, struct xfs_fid and struct xfs_fid2 with hte latter two beeing identicaly and the first one beeing the same size but an unstructured array with the same size. This patch consolidates all this to alway uuse struct xfs_fid. This patch is required for an upcoming patch series from me that revamps the nfs exporting code and introduces a Linux-wide struct fid. SGI-PV: 970336 SGI-Modid: xfs-linux-melb:xfs-kern:29651a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-16[XFS] simplify xfs_create/mknod/symlink prototypeChristoph Hellwig
Simplify the prototype for xfs_create/xfs_mkdir/xfs_symlink by not passing down a bhv_vattr_t that just hogs stack space. Instead pass down the mode in a mode_t and in case of xfs_create the rdev as a scalar type as well. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29794a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] decontaminate vnode operations from behavior detailsChristoph Hellwig
All vnode ops now take struct xfs_inode pointers and the behaviour related glue is split out into methods of it's own. This required fixing xfs_create/mkdir/symlink to not mess with the inode pointer but rather use a separate boolean for error handling. Thanks to Dave Chinner for that fix. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29492a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
