path: root/fs/xfs/xfs_sb.h
2006-09-28[XFS] Remove several macros that are no longer used anywhereEric Sandeen
SGI-PV: 955302 SGI-Modid: xfs-linux-melb:xfs-kern:26749a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-01-11[XFS] Sort out cosmetic differences between user and kernel copies of someNathan Scott
sources. SGI-PV: 907752 SGI-Modid: xfs-linux-melb:xfs-kern:24659a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Ondisk format extension for extended attributes (attr2). Basically,Nathan Scott
the data/attr forks now grow up/down from either end of the literal area, rather than dividing the literal area into two chunks and growing both upward. Means we can now make much more efficient use of the attribute space, incl. fitting DMF attributes inline in 256 byte inodes, and large jumps in dbench3 performance numbers. It is self enabling, but can be forced on/off via the attr2/noattr2 mount options. SGI-PV: 941645 SGI-Modid: xfs-linux:xfs-kern:23835a Signed-off-by: Nathan Scott <nathans@sgi.com>
