path: root/fs/xfs/xfs_rw.c
2009-12-11xfs: uninline xfs_get_extsz_hintChristoph Hellwig
This function is too large to efficiently be inlined. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-12-11xfs: simplify xfs_buf_get / xfs_buf_read interfacesChristoph Hellwig
Currently the low-level buffer cache interfaces are highly confusing as we have a _flags variant of each that does actually respect the flags, and one without _flags which has a flags argument that gets ignored and overriden with a default set. Given that very few places use the default arguments get rid of the duplication and convert all callers to pass the flags explicitly. Also remove the now confusing _flags postfix. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2009-09-01xfs: merge fsync and O_SYNC handlingChristoph Hellwig
The guarantees for O_SYNC are exactly the same as the ones we need to make for an fsync call (and given that Linux O_SYNC is O_DSYNC the equivalent is fdadatasync, but we treat both the same in XFS), except with a range data writeout. Jan Kara has started unifying these two path for filesystems using the generic helpers, and I've started to look at XFS. The actual transaction commited by xfs_fsync and xfs_write_sync_logforce has a different transaction number, but actually is exactly the same. We'll only use the fsync transaction going forward. One major difference is that xfs_write_sync_logforce never issues a cache flush unless we commit a transaction causing that as a side-effect, which is an obvious bug in the O_SYNC handling. Second all the locking and i_update_size vs i_update_core changes from 978b7237123d007b9fa983af6e0e2fa8f97f9934 never made it to xfs_write_sync_logforce, so we add them back. To make xfs_fsync easily usable from the O_SYNC path, the filemap_fdatawait call is moved up to xfs_file_fsync, so that we don't wait on the whole file after we already waited for our portion in xfs_write. We'll also use a plain call to filemap_write_and_wait_range instead of the previous sync_page_rang which did it in two steps including an half-hearted inode write out that doesn't help us. Once we're done with this also remove the now useless i_update_size tracking. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: Felix Blyakher <felixb@sgi.com>
2009-06-10xfs: use generic Posix ACL codeChristoph Hellwig
This patch rips out the XFS ACL handling code and uses the generic fs/posix_acl.c code instead. The ondisk format is of course left unchanged. This also introduces the same ACL caching all other Linux filesystems do by adding pointers to the acl and default acl in struct xfs_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2008-12-11[XFS] replace b_fspriv with b_mountChristoph Hellwig
Replace the b_fspriv pointer and it's ugly accessors with a properly types xfs_mount pointer. Also switch log reocvery over to it instead of using b_fspriv for the mount pointer. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-08-13[XFS] replace the XFS buf iodone semaphore with a completionDavid Chinner
The xfs_buf_t b_iodonesema is really just a semaphore that wants to be a completion. Change it to a completion and remove the last user of the sema_t from XFS. SGI-PV: 981498 SGI-Modid: xfs-linux-melb:xfs-kern:31815a Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Sanitise xfs_log_force error checking.David Chinner
xfs_log_force() is declared to return an error, but we almost never check it. We don't need to check it in most cases; if there's a log I/O error then we'll be shutting down the filesystem anyway and that means we'll catch the error somewhere else. However, on certain calls we should be returning an error - sync transactions, fsync, sync writes, etc. so this isn't a pure black and white distinction. Hence make xfs_log_force() a void function that issues a warning to the syslog on error, and call _xfs_log_force() in all the places where we actually care about the error status returned. SGI-PV: 980084 SGI-Modid: xfs-linux-melb:xfs-kern:30832a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Niv Sardi <xaiki@sgi.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-16[XFS] decontaminate vfs operations from behavior detailsChristoph Hellwig
All vfs ops now take struct xfs_mount pointers and the behaviour related glue is split out into methods of its own. SGI-PV: 969608 SGI-Modid: xfs-linux-melb:xfs-kern:29504a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] The last argument "lsn" of xfs_trans_commit() is always called withEric Sandeen
NULL. Patch provided by Eric Sandeen. SGI-PV: 961693 SGI-Modid: xfs-linux-melb:xfs-kern:28199a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-02-10[XFS] Remove unused header files for MAC and CAP checking functionality.Eric Sandeen
xfs_mac.h and xfs_cap.h provide definitions and macros that aren't used anywhere in XFS at all. They are left-overs from "to be implement at some point in the future" functionality that Irix XFS has. If this functionality ever goes into Linux, it will be provided at a different layer, most likely through the security hooks in the kernel so we will never need this functionality in XFS. Patch provided by Eric Sandeen (sandeen@sandeen.net). SGI-PV: 960895 SGI-Modid: xfs-linux-melb:xfs-kern:28036a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-19[XFS] Push some common code out of write path into core XFS code forNathan Scott
sharing. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:26248a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] Shutdown the filesystem if all device paths have gone. MadeNathan Scott
shutdown vop flags consistent with sync vop flags declarations too. SGI-PV: 939911 SGI-Modid: xfs-linux-melb:xfs-kern:26096a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-01-11[XFS] Complete the pagebuf -> xfs_buf naming convention transition,Nathan Scott
finally. SGI-PV: 947038 SGI-Modid: xfs-linux-melb:xfs-kern:24866a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Add format checking to cmn_err and icmn_errChristoph Hellwig
SGI-PV: 942243 SGI-Modid: xfs-linux:xfs-kern:198658a Signed-off-by: Christoph Hellwig <hch@sgi.com> Signed-off-by: Nathan Scott <nathans@sgi.com>
