No need to keep the inode log format around all the time, we can
easily generate it at iop_format time.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
With the new iop_format scheme there is no need to have a temporary buffer
to format logged extents into, we can do so directly into the CIL. This
also allows to remove the shortcut for big endian systems that probably
hasn't gotten a lot of test coverage for a long time.
Instead of setting up pointers to memory locations in iop_format which then
get copied into the CIL linear buffer after return move the copy into
the individual inode items. This avoids the need to always have a memory
block in the exact same layout that gets written into the log around, and
allow the log items to be much more flexible in their in-memory layouts.
The only caveat is that we need to properly align the data for each
iovec so that don't have structures misaligned in subsequent iovecs.
Note that all log item format routines now need to be careful to modify
the copy of the item that was placed into the CIL after calls to
xlog_copy_iovec instead of the in-memory copy.
Add a helper to abstract out filling the log iovecs in the log item
format handlers. This will allow us to change the way we do the log
item formatting more easily.
The copy in the name is a bit confusing for now as it just assigns a
pointer and lets the CIL code perform the copy, but that will change
soon.
Split out a function to handle the data and attr fork, as well as a
helper for the really old v1 inodes.
Split out two helpers to size the data and attribute to make the
function more readable.
Currently the xfs_inode.h header has a dependency on the definition
of the BMAP btree records as the inode fork includes an array of
xfs_bmbt_rec_host_t objects in it's definition.
Move all the btree format definitions from xfs_btree.h,
xfs_bmap_btree.h, xfs_alloc_btree.h and xfs_ialloc_btree.h to
xfs_format.h to continue the process of centralising the on-disk
format definitions. With this done, the xfs inode definitions are no
longer dependent on btree header files.
The enables a massive culling of unnecessary includes, with close to
200 #include directives removed from the XFS kernel code base.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Ben Myers <bpm@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
xfs_trans.h has a dependency on xfs_log.h for a couple of
structures. Most code that does transactions doesn't need to know
anything about the log, but this dependency means that they have to
include xfs_log.h. Decouple the xfs_trans.h and xfs_log.h header
files and clean up the includes to be in dependency order.
In doing this, remove the direct include of xfs_trans_reserve.h from
xfs_trans.h so that we remove the dependency between xfs_trans.h and
xfs_mount.h. Hence the xfs_trans.h include can be moved to the
indicate the actual dependencies other header files have on it.
Note that these are kernel only header files, so this does not
translate to any userspace changes at all.
To begin optimising the CIL commit process, we need to have IOP_SIZE
return both the number of vectors and the size of the data pointed
to by the vectors. This enables us to calculate the size ofthe
memory allocation needed before the formatting step and reduces the
number of memory allocations per item by one.
While there, kill the IOP_SIZE macro.
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Add a new inode version with a larger core. The primary objective is
to allow for a crc of the inode, and location information (uuid and ino)
to verify it was written in the right place. We also extend it by:
a creation time (for Samba);
a changecount (for NFSv4);
a flush sequence (in LSN format for recovery);
an additional inode flags field; and
some additional padding.
These additional fields are not implemented yet, but already laid
out in the structure.
[dchinner@redhat.com] Added LSN and flags field, some factoring and rework to
capture all the necessary information in the crc calculation.
Remove the XFS_TRANS_DEBUG routines. They are no longer appropriate
and have not been used in years
Signed-off-by: Mark Tinguely <tinguely@sgi.com>
An inode in the AIL can be flush locked and marked stale if
a cluster free transaction occurs at the right time. The
inode item is then marked as flushing, which causes xfsaild
to spin and leaves the filesystem stalled. This is
reproduced by running xfstests 273 in a loop for an
extended period of time.
Check for stale inodes before the flush lock. This marks
the inode as pinned, leads to a log flush and allows the
filesystem to proceed.
Signed-off-by: Brian Foster <bfoster@redhat.com>
With the removal of xfs_rw.h and other changes over time, xfs_bit.h
is being included in many files that don't actually need it. Clean
up the includes as necessary.
Also move the only-used-once xfs_ialloc_find_free() static inline
function out of a header file that is widely included to reduce
the number of needless dependencies on xfs_bit.h.
Untangle the header file includes a bit by moving the definition of
xfs_agino_t to xfs_types.h. This removes the dependency that xfs_ag.h has on
xfs_inum.h, meaning we don't need to include xfs_inum.h everywhere we include
xfs_ag.h.
xfs_trans_ail_delete_bulk() can be called from different contexts so
if the item is not in the AIL we need different shutdown for each
context. Pass in the shutdown method needed so the correct action
can be taken.
Queue delwri buffers on a local on-stack list instead of a per-buftarg one,
and write back the buffers per-process instead of by waking up xfsbufd.
This is now easily doable given that we have very few places left that write
delwri buffers:
- log recovery:
Only done at mount time, and already forcing out the buffers
synchronously using xfs_flush_buftarg
- quotacheck:
Same story.
- dquot reclaim:
Writes out dirty dquots on the LRU under memory pressure. We might
want to look into doing more of this via xfsaild, but it's already
more optimal than the synchronous inode reclaim that writes each
buffer synchronously.
- xfsaild:
This is the main beneficiary of the change. By keeping a local list
of buffers to write we reduce latency of writing out buffers, and
more importably we can remove all the delwri list promotions which
were hitting the buffer cache hard under sustained metadata loads.
The implementation is very straight forward - xfs_buf_delwri_queue now gets
a new list_head pointer that it adds the delwri buffers to, and all callers
need to eventually submit the list using xfs_buf_delwi_submit or
xfs_buf_delwi_submit_nowait. Buffers that already are on a delwri list are
skipped in xfs_buf_delwri_queue, assuming they already are on another delwri
list. The biggest change to pass down the buffer list was done to the AIL
pushing. Now that we operate on buffers the trylock, push and pushbuf log
item methods are merged into a single push routine, which tries to lock the
item, and if possible add the buffer that needs writeback to the buffer list.
This leads to much simpler code than the previous split but requires the
individual IOP_PUSH instances to unlock and reacquire the AIL around calls
to blocking routines.
Given that xfsailds now also handle writing out buffers, the conditions for
log forcing and the sleep times needed some small changes. The most
important one is that we consider an AIL busy as long we still have buffers
to push, and the other one is that we do increment the pushed LSN for
buffers that are under flushing at this moment, but still count them towards
the stuck items for restart purposes. Without this we could hammer on stuck
items without ever forcing the log and not make progress under heavy random
delete workloads on fast flash storage devices.
[ Dave Chinner:
- rebase on previous patches.
- improved comments for XBF_DELWRI_Q handling
- fix XBF_ASYNC handling in queue submission (test 106 failure)
- rename delwri submit function buffer list parameters for clarity
- xfs_efd_item_push() should return XFS_ITEM_PINNED ]
Instead of writing the buffer directly from inside xfs_iflush return it to
the caller and let the caller decide what to do with the buffer. Also
remove the pincount check in xfs_iflush that all non-blocking callers already
implement and the now unused flags parameter.
Add an in-memory only flag to say we logged timestamps only, and use it to
check if fdatasync can optimize away the log force.
Add a new ili_fields member to the inode log item to isolate the in-memory
flags from the ones that actually go to the log. This will allow tracking
timestamp-only updates for fdatasync and O_DSYNC in the next patch and
prepares for divorcing the on-disk log format from the in-memory log item
a little further down the road.
Move all code messing with the inode log item flags into xfs_inode_item_format
to make sure xfs_inode_item_size really only calculates the the number of
vectors, but doesn't modify any state of the inode item.
Timestamps on regular files are the last metadata that XFS does not update
transactionally. Now that we use the delaylog mode exclusively and made
the log scode scale extremly well there is no need to bypass that code for
timestamp updates. Logging all updates allows to drop a lot of code, and
will allow for further performance improvements later on.
Note that this patch drops optimized handling of fdatasync - it will be
added back in a separate commit.
There is no reason to wake up log space waiters when unlocking inodes or
dquots, and the commit log has no explanation for this function either.
Given that we now have exact log space wakeups everywhere we can assume
the reason for this function was to paper over log space races in earlier
XFS versions.
Replace i_pin_wait, which is only used during synchronous inode flushing
with a bit waitqueue. This trades off a much smaller inode against
slightly slower wakeup performance, and saves 12 (32-bit) or 20 (64-bit)
bytes in the XFS inode.
Reviewed-by: Alex Elder <aelder@sgi.com>
We almost never block on i_flock, the exception is synchronous inode
flushing. Instead of bloating the inode with a 16/24-byte completion
that we abuse as a semaphore just implement it as a bitlock that uses
a bit waitqueue for the rare sleeping path. This primarily is a
tradeoff between a much smaller inode and a faster non-blocking
path vs faster wakeups, and we are much better off with the former.
A small downside is that we will lose lockdep checking for i_flock, but
given that it's always taken inside the ilock that should be acceptable.
Note that for example the inode writeback locking is implemented in a
very similar way.
We spent a lot of effort to maintain this field, but it always equals to the
fork size divided by the constant size of an extent. The prime use of it is
to assert that the two stay in sync. Just divide the fork size by the extent
size in the few places that we actually use it and remove the overhead
of maintaining it. Also introduce a few helpers to consolidate the places
where we actually care about the value.
Outside the now removed nodelaylog code this field is only used for
asserts and can be safely removed now.
The log item ops aren't nessecarily the biggest exploit vector, but marking
them const is easy enough. Also remove the unused xfs_item_ops_t typedef
while we're at it.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
Resolved conflicts:
fs/xfs/xfs_trans_priv.h:
- deleted struct xfs_ail field xa_flags
- kept field xa_log_flush in struct xfs_ail
fs/xfs/xfs_trans_ail.c:
- in xfsaild_push(), in XFS_ITEM_PUSHBUF case, replaced
"flush_log = 1" with "ailp->xa_log_flush++"
Signed-off-by: Alex Elder <aelder@sgi.com>
There is no reason to keep a reference to the inode even if we unlock
it during transaction commit because we never drop a reference between
the ijoin and commit. Also use this fact to merge xfs_trans_ijoin_ref
back into xfs_trans_ijoin - the third argument decides if an unlock
is needed now.
I'm actually starting to wonder if allowing inodes to be unlocked
at transaction commit really is worth the effort. The only real
benefit is that they can be unlocked earlier when commiting a
synchronous transactions, but that could be solved by doing the
log force manually after the unlock, too.
We need to check for pinned buffers even in .iop_pushbuf given that inode
items flush into the same buffers that may be pinned directly due operations
on the unlinked inode list operating directly on buffers. To do this add a
return value to .iop_pushbuf that tells the AIL push about this and use
the existing log force mechanisms to unpin it.
Reported-by: Stefan Priebe <s.priebe@profihost.ag>
Tested-by: Stefan Priebe <s.priebe@profihost.ag>
Remove the transaction pointer in the inode. It's only used to avoid
passing down an argument in the bmap code, and for a few asserts in
the transaction code right now.
Also use the local variable ip in a few more places in xfs_inode_item_unlock,
so that it isn't only used for debug builds after the above change.
When inodes are marked stale in a transaction, they are treated
specially when the inode log item is being inserted into the AIL.
It tries to avoid moving the log item forward in the AIL due to a
race condition with the writing the underlying buffer back to disk.
The was "fixed" in commit de25c18 ("xfs: avoid moving stale inodes
in the AIL").
To avoid moving the item forward, we return a LSN smaller than the
commit_lsn of the completing transaction, thereby trying to trick
the commit code into not moving the inode forward at all. I'm not
sure this ever worked as intended - it assumes the inode is already
in the AIL, but I don't think the returned LSN would have been small
enough to prevent moving the inode. It appears that the reason it
worked is that the lower LSN of the inodes meant they were inserted
into the AIL and flushed before the inode buffer (which was moved to
the commit_lsn of the transaction).
The big problem is that with delayed logging, the returning of the
different LSN means insertion takes the slow, non-bulk path. Worse
yet is that insertion is to a position -before- the commit_lsn so it
is doing a AIL traversal on every insertion, and has to walk over
all the items that have already been inserted into the AIL. It's
expensive.
To compound the matter further, with delayed logging inodes are
likely to go from clean to stale in a single checkpoint, which means
they aren't even in the AIL at all when we come across them at AIL
insertion time. Hence these were all getting inserted into the AIL
when they simply do not need to be as inodes marked XFS_ISTALE are
never written back.
Transactional/recovery integrity is maintained in this case by the
other items in the unlink transaction that were modified (e.g. the
AGI btree blocks) and committed in the same checkpoint.
So to fix this, simply unpin the stale inodes directly in
xfs_inode_item_committed() and return -1 to indicate that the AIL
insertion code does not need to do any further processing of these
inodes.
follow these guidelines:
- leave initialization in the declaration block if it fits the line
- move to the code where it's more suitable ('for' init block)
The last chunk was modified from David's original to be a correct
fix for what appeared to be a duplicate initialization.
Signed-off-by: David Sterba <dsterba@suse.cz>
When formatting an inode item, we have to allocate a separate buffer
to hold extents when there are delayed allocation extents on the
inode and it is in extent format. The allocation size is derived
from the in-core data fork representation, which accounts for
delayed allocation extents, while the on-disk representation does
not contain any delalloc extents.
As a result of this mismatch, the allocated buffer can be far larger
than needed to hold the real extent list which, due to the fact the
inode is in extent format, is limited to the size of the literal
area of the inode. However, we can have thousands of delalloc
extents, resulting in an allocation size orders of magnitude larger
than is needed to hold all the real extents.
Fix this by limiting the size of the buffer being allocated to the
size of the literal area of the inodes in the filesystem (i.e. the
maximum size an inode fork can grow to).
There is an ABBA deadlock between synchronous inode flushing in
xfs_reclaim_inode and xfs_icluster_free. xfs_icluster_free locks the
buffer, then takes inode ilocks, whilst synchronous reclaim takes
the ilock followed by the buffer lock in xfs_iflush().
To avoid this deadlock, separate the inode cluster buffer locking
semantics from the synchronous inode flush semantics, allowing
callers to attempt to lock the buffer but still issue synchronous IO
if it can get the buffer. This requires xfs_iflush() calls that
currently use non-blocking semantics to pass SYNC_TRYLOCK rather
than 0 as the flags parameter.
This allows xfs_reclaim_inode to avoid the deadlock on the buffer
lock and detect the failure so that it can drop the inode ilock and
restart the reclaim attempt on the inode. This allows
xfs_ifree_cluster to obtain the inode lock, mark the inode stale and
release it and hence defuse the deadlock situation. It also has the
pleasant side effect of avoiding IO in xfs_reclaim_inode when it
tries to next reclaim the inode as it is now marked stale.
When inode buffer IO completes, usually all of the inodes are removed from the
AIL. This involves processing them one at a time and taking the AIL lock once
for every inode. When all CPUs are processing inode IO completions, this causes
excessive amount sof contention on the AIL lock.
Instead, change the way we process inode IO completion in the buffer
IO done callback. Allow the inode IO done callback to walk the list
of IO done callbacks and pull all the inodes off the buffer in one
go and then process them as a batch.
Once all the inodes for removal are collected, take the AIL lock
once and do a bulk removal operation to minimise traffic on the AIL
lock.
When an inode has been marked stale because the cluster is being
freed, we don't want to (re-)insert this inode into the AIL. There
is a race condition where the cluster buffer may be unpinned before
the inode is inserted into the AIL during transaction committed
processing. If the buffer is unpinned before the inode item has been
committed and inserted, then it is possible for the buffer to be
released and hence processthe stale inode callbacks before the inode
is inserted into the AIL.
In this case, we then insert a clean, stale inode into the AIL which
will never get removed by an IO completion. It will, however, get
reclaimed and that triggers an assert in xfs_inode_free()
complaining about freeing an inode still in the AIL.
This race can be avoided by not moving stale inodes forward in the AIL
during transaction commit completion processing. This closes the
race condition by ensuring we never insert clean stale inodes into
the AIL. It is safe to do this because a dirty stale inode, by
definition, must already be in the AIL.
Under heavy multi-way parallel create workloads, the VFS struggles
to write back all the inodes that have been changed in age order.
The bdi flusher thread becomes CPU bound, spending 85% of it's time
in the VFS code, mostly traversing the superblock dirty inode list
to separate dirty inodes old enough to flush.
We already keep an index of all metadata changes in age order - in
the AIL - and continued log pressure will do age ordered writeback
without any extra overhead at all. If there is no pressure on the
log, the xfssyncd will periodically write back metadata in ascending
disk address offset order so will be very efficient.
Hence we can stop marking VFS inodes dirty during transaction commit
or when changing timestamps during transactions. This will keep the
inodes in the superblock dirty list to those containing data or
unlogged metadata changes.
However, the timstamp changes are slightly more complex than this -
there are a couple of places that do unlogged updates of the
timestamps, and the VFS need to be informed of these. Hence add a
new function xfs_trans_ichgtime() for transactional changes,
and leave xfs_ichgtime() for the non-transactional changes.
Commit 0fd7275cc42ab734eaa1a2c747e65479bd1e42af ("xfs: fix gcc 4.6
set but not read and unused statement warnings") failed to convert
some code inside XFS_NATIVE_HOST (big endian host code only) and
hence fails to build on such machines. Fix it.
[hch: dropped a few hunks that need structural changes instead]
xfs_iput is just a small wrapper for xfs_iunlock + IRELE. Having this
out of line wrapper means the trace events in those two can't track
their caller properly. So just remove the wrapper and opencode the
unlock + rele in the few callers.
By making this member a void pointer we can get rid of a lot of pointless
casts.
Currently we need to either call IHOLD or xfs_trans_ihold on an inode when
joining it to a transaction via xfs_trans_ijoin.
This patches instead makes xfs_trans_ijoin usable on it's own by doing
an implicity xfs_trans_ihold, which also allows us to drop the third
argument. For the case where we want to hold a reference on the inode
a xfs_trans_ijoin_ref wrapper is added which does the IHOLD and marks
the inode for needing an xfs_iput. In addition to the cleaner interface
to the caller this also simplifies the implementation.
Stop the function pointer casting madness and give all the li_cb instances
correct prototype.
Stop the function pointer casting madness and give all the xfs_item_ops the
correct prototypes.
The unpin_remove item operation instances always share most of the
implementation with the respective unpin implementation. So instead
of keeping two different entry points add a remove flag to the unpin
operation and share the code more easily.
Reviewed-by: Dave Chinner <david@fromorbit.com>
Dmapi support was never merged upstream, but we still have a lot of hooks
bloating XFS for it, all over the fast pathes of the filesystem.
This patch drops over 700 lines of dmapi overhead. If we'll ever get HSM
support in mainline at least the namespace events can be done much saner
in the VFS instead of the individual filesystem, so it's not like this
is much help for future work.
The staleness of a object being unpinned can be directly derived
from the object itself - there is no need to extract it from the
object then pass it as a parameter into IOP_UNPIN().
This means we can kill the XFS_LID_BUF_STALE flag - it is set,
checked and cleared in the same places XFS_BLI_STALE flag in the
xfs_buf_log_item so it is now redundant and hence safe to remove.
