path: root/fs/xfs/xfs_dir2_block.c
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-18[XFS] Put the correct offset in dirent d_offLachlan McIlroy
The recent filldir regression fix was not putting the correct d_off in each dirent. This was resulting in incorrect cookies being passed to dmapi ioctls and the wrong offset appearing in the dirents. readdir was unaffected as the filp->f_pos was being updated with the correct offset and this was being written into the last dirent in each buffer. Fix the XFS code to do the right thing. SGI-PV: 973746 SGI-Modid: xfs-linux-melb:xfs-kern:30240a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2007-10-15[XFS] Radix tree based inode cachingDavid Chinner
One of the perpetual scaling problems XFS has is indexing it's incore inodes. We currently uses hashes and the default hash sizes chosen can only ever be a tradeoff between memory consumption and the maximum realistic size of the cache. As a result, anyone who has millions of inodes cached on a filesystem needs to tunes the size of the cache via the ihashsize mount option to allow decent scalability with inode cache operations. A further problem is the separate inode cluster hash, whose size is based on the ihashsize but is smaller, and so under certain conditions (sparse cluster cache population) this can become a limitation long before the inode hash is causing issues. The following patchset removes the inode hash and cluster hash and replaces them with radix trees to avoid the scalability limitations of the hashes. It also reduces the size of the inodes by 3 pointers.... SGI-PV: 969561 SGI-Modid: xfs-linux-melb:xfs-kern:29481a Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-10-15[XFS] use filldir internallyChristoph Hellwig
Currently xfs has a rather complicated internal scheme to allow for different directory formats in IRIX. This patch rips all code related to this out and pushes useage of the Linux filldir callback into the lowlevel directory code. This does not make the code any less portable because filldir can be used to create dirents of all possible variations (including the IRIX ones as proved by the IRIX binary emulation code under arch/mips/). This patch get rid of an unessecary copy in the readdir path, about 400 lines of code and one of the last two users of the uio structure. This version is updated to deal with dmapi aswell which greatly simplifies the get_dirattrs code. The dmapi part has been tested using the get_dirattrs tools from the xfstest dmapi suite1 with various small and large directories. SGI-PV: 968563 SGI-Modid: xfs-linux-melb:xfs-kern:29478a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-07-14[XFS] Reduce shouting by removing unnecessary macros from dir2 code.Christoph Hellwig
SGI-PV: 966505 SGI-Modid: xfs-linux-melb:xfs-kern:28947a Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2007-05-08[XFS] the "aendp" arg to xfs_dir2_data_freescan is always NULL, remove it.Eric Sandeen
Patch provided by Eric Sandeen. SGI-PV: 961694 SGI-Modid: xfs-linux-melb:xfs-kern:28204a Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com> Signed-off-by: Tim Shimmin <tes@sgi.com>
2006-06-20[XFS] Remove version 1 directory code. Never functioned on Linux, justNathan Scott
pure bloat. SGI-PV: 952969 SGI-Modid: xfs-linux-melb:xfs-kern:26251a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-06-09[XFS] endianess annotations for xfs_dir2_data_entry_t Christoph Hellwig
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25806a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-29[XFS] We really suck at spulling. Thanks to Chris Pascoe for fixing allNathan Scott
these typos. SGI-PV: 904196 SGI-Modid: xfs-linux-melb:xfs-kern:25539a Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] remove bogus INT_GET on u8 variables in xfs_dir2_block.c Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25496a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_da_blkinfo_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25495a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for XFS_DIR2_DATA_ENTRY_TAG_P Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25494a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_leaf_entry_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25493a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_leaf_hdr_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25492a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_block_tail_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25491a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for XFS_DIR2_DATA_UNUSED_TAG_P Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25490a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_data_unused_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25489a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_leaf_tail_t Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25487a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for XFS_DIR2_LEAF_BESTS_P Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25486a Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nathan Scott <nathans@sgi.com>
2006-03-17[XFS] endianess annotations for xfs_dir2_data_hdr structure.Nathan Scott
SGI-PV: 943272 SGI-Modid: xfs-linux-melb:xfs-kern:25484a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Update license/copyright notices to match the prefered SGINathan Scott
boilerplate. SGI-PV: 913862 SGI-Modid: xfs-linux:xfs-kern:23903a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Remove xfs_macros.c, xfs_macros.h, rework headers a whole lot.Nathan Scott
SGI-PV: 943122 SGI-Modid: xfs-linux:xfs-kern:23901a Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-11-02[XFS] Fix up an internal sort function name collision issue.Nathan Scott
SGI-PV: 942986 SGI-Modid: xfs-linux:xfs-kern:23859a Signed-off-by: Nathan Scott <nathans@sgi.com>
