path: root/fs/ufs/super.c
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25quota: move function-macros from quota.h to quotaops.hJan Kara
Move declarations of some macros, which should be in fact functions to quotaops.h. This way they can be later converted to inline functions because we can now use declarations from quota.h. Also add necessary includes of quotaops.h to a few files. [akpm@linux-foundation.org: fix JFS build] [akpm@linux-foundation.org: fix UFS build] [vegard.nossum@gmail.com: fix QUOTA=n build] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Arjen Pool <arjenpool@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24UFS: add const to parser token tableSteven Whitehouse
This patch adds a "const" to the parser token table. I've done an allmodconfig build to see if this produces any warnings/failures and the patch includes a fix for the only warning that was produced. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Alexander Viro <aviro@redhat.com> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08drop linux/ufs_fs.h from userspace export and relocate it to fs/ufs/ufs_fs.hMike Frysinger
Per previous discussions about cleaning up ufs_fs.h, people just want this straight up dropped from userspace export. The only remaining consumer (silo) has been fixed a while ago to not rely on this header. This allows use to move it completely from include/linux/ to fs/ufs/ seeing as how the only in-kernel consumer is fs/ufs/. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ufs: fix symlink creation on ufs2Evgeniy Dushistov
If we create symlink on UFS2 filesystem under Linux, it looks wrong under other OSes, because of max symlink length field was not initialized properly, and data blocks were not used to save short symlink names. [akpm@linux-foundation.org: add missing fs32_to_cpu()] Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Steven <stevenaaus@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop UFS from using iget() and read_inode()David Howells
Stop the UFS filesystem from using iget() and read_inode(). Replace ufs_read_inode() with ufs_iget(), and call that instead of iget(). ufs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ufs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05ufs: fix nexstep dir block sizeEvgeniy Dushistov
This patch fixes regression, introduced since 2.6.16. NextStep variant of UFS as OpenStep uses directory block size equals to 1024. Without this change, ufs_check_page fails in many cases. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Dave Bailey <dsbailey@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30revert "ufs: Fix mount check in ufs_fill_super()"Andrew Morton
Evgeniy said: I wonder on what type of UFS do you test this patch? NetBSD and FreeBSD do not use "fs_state", they use "fs_clean" flag, only Solaris does check like this: fs_state + fs_time == FSOK. That's why parentheses was like that. At now with linux-2.6.24-rc1-git1, I get: fs need fsck, but NetBSD's fsck says that's all ok. I suggest revert this patch. Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Satyam Sharma <satyam.sharma@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: Fix mount check in ufs_fill_super()Satyam Sharma
The current code skips the check to verify whether the filesystem was previously cleanly unmounted, if (flags & UFS_ST_MASK) == UFS_ST_44BSD or UFS_ST_OLD. This looks like an inadvertent bug that slipped in due to parantheses in the compound conditional to me, especially given that ufs_get_fs_state() handles the UFS_ST_44BSD case perfectly well. So, let's fix the compound condition appropriately. Signed-off-by: Satyam Sharma <satyam@infradead.org> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: implement show_optionsEvgeniy Dushistov
An implementation of show_options method for UFS. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add in SunOS 4.1.x compatible mode for UFSMark Fortescue
Add in support for SunOS 4.1.x flavor of BSD 4.2 UFS filing system Macros have been put in to alow suport for the old static table Cylinder Groups but this implementation does not use them yet. This also fixes Solaris UFS filing system access by disabling fast symbolic links as Sun's version of UFS does not support on-disk fast symbolic links. Tested by: Ppartitioning a new disk using SunOS 4.1.1, creating a UFS filing system on one of the partitions and writing some files to the filing system. Using Linux-2.6.22 (patched) to read the files and then write a shed load of files to the UFS partition. Using SunOS 4.1.1 to verify the filing system is OK and to check the files. The test host is a sun4c SS1 Clone. [akpm@linux-foundation.org: coding style fixes] [adobriyan@gmail.com: fix oops] Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-25ufs: fix sun stateEvgeniy Dushistov
Different types of ufs hold state in different places, to hide complexity of this, there is ufs_get_fs_state, it returns state according to "UFS_SB(sb)->s_flags", but during mount ufs_get_fs_state is called, before setting s_flags, this cause message for ufs types like sun ufs: "fs need fsck", and remount in readonly state. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16is_power_of_2: ufs/super.cvignesh babu
Replace (n & (n-1)) with is_power_of_2 Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ufs2 write: inodes writeEvgeniy Dushistov
This patch adds into write inode path function to write UFS2 inode, and modifys allocate inode path to allocate and init additional inode chunks. Also some cleanups: - remove not used parameters in some functions - remove i_gen field from ufs_inode_info structure, there is i_generation in inode structure with same purposes. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ufs2 write: mount as rwEvgeniy Dushistov
These series of patches add UFS2 write-support. UFS2 - is default file system for recent versions of FreeBSD. The main differences from UFS1 from write support point of view are: 1)Not all inodes are allocated during formatation of disk. 2)All meta-data(pointer to data blocks) are 64bit(in UFS1 they are 32bit). So patch series consist of 1)make possible mount UFS2 in read-write mode 2)code to write ufs2 inodes and code to initialize inodes chunks. 3)work with 64bit meta-data I made simple testing like create/deleting/writing/reading/truncating, also I ran fsx-linux and untar and build kernel on UFS1 and UFS2, after that FreeBSD fsck do not find any errors in fs. This patch makes possible to mount ufs2 "rw", and updates UFS2 documentation: remove note about bug(it fixed by reallocate blocks on the fly patch) and add me in the list of people who want receive bug reports. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] ufs: restore back support of openstepEvgeniy Dushistov
This is a fix of regression, which triggered by ~2.6.16. Patch with name ufs-directory-and-page-cache-from-blocks-to-pages.patch: in additional to conversation from block to page cache mechanism added new checks of directory integrity, one of them that directory entry do not across directory chunks. But some kinds of UFS: OpenStep UFS and Apple UFS (looks like these are the same filesystems) have different directory chunk size, then common UFSes(BSD and Solaris UFS). So this patch adds ability to works with variable size of directory chunks, and set it for ufstype=openstep to right size. Tested on darwin ufs. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] fs/*: trivial vsnprintf() conversionAlexey Dobriyan
It would very lame to get buffer overflow via one of the following. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate the quota codeArjan van de Ven
The quota code plays interesting games with the lock ordering; to quote Jan: | i_mutex of inode containing quota file is acquired after all other | quota locks. i_mutex of all other inodes is acquired before quota | locks. Quota code makes sure (by resetting inode operations and | setting special flag on inode) that noone tries to enter quota code | while holding i_mutex on a quota file... The good news is that all of this special case i_mutex grabbing happens in the (per filesystem) low level quota write function. For this special case we need a new I_MUTEX_* nesting level, since this just entirely outside any of the regular VFS locking rules for i_mutex. I trust Jan on his blue eyes that this is not ever going to deadlock; and based on that the patch below is what it takes to inform lockdep of these very interesting new locking rules. The new locking rule for the I_MUTEX_QUOTA nesting level is that this is the deepest possible level of nesting for i_mutex, and that this only should be used in quota write (and possibly read) function of filesystems. This makes the lock ordering of the I_MUTEX_* levels: I_MUTEX_PARENT -> I_MUTEX_CHILD -> I_MUTEX_NORMAL -> I_MUTEX_QUOTA Has no effect on non-lockdep kernels. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: make fsck -f happyEvgeniy Dushistov
ufs super block contains some statistic about file systems, like amount of directories, free blocks, inodes and so on. UFS1 hold this information in one location and uses 32bit integers for such information, UFS2 hold statistic in another location and uses 64bit integers. There is transition variant, if UFS1 has type 44BSD and flags field in super block has some special value this mean that we work with statistic like UFS2 does. and this also means that nobody care about old(UFS1) statistic. So if start fsck against such file system, after usage linux ufs driver, it found error: at now only UFS1 like statistic is updated. This patch should fix this. Also it contains some minor cleanup: CodingSytle and remove unused variables. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: one way to access super blockEvgeniy Dushistov
Super block of UFS usually has size >512, because of fragment size may be 512, this cause some problems. Currently, there are two methods to work with ufs super block: 1) split structure which describes ufs super blocks into structures with size <=512 2) use one structure which describes ufs super block, and hope that array of "buffer_head" which holds "super block", has such construction: bh[n]->b_data + bh[n]->b_size == bh[n + 1]->b_data The second variant may cause some problems in the future, and usage of two variants cause unnecessary code duplication. This patch remove the second variant. Also patch contains some CodingStyle fixes. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: printk warning fixesAndrew Morton
fs/ufs/super.c: In function `ufs_print_super_stuff': fs/ufs/super.c:103: warning: unsigned int format, different type arg (arg 2) fs/ufs/super.c: In function `ufs2_print_super_stuff': fs/ufs/super.c:147: warning: unsigned int format, different type arg (arg 2) fs/ufs/super.c: In function `ufs_print_cylinder_stuff': fs/ufs/super.c:175: warning: unsigned int format, different type arg (arg 2) Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: easy debugEvgeniy Dushistov
Currently to turn on debug mode "user" has to edit ~10 files, to turn off he has to do it again. This patch introduce such changes: 1)turn on(off) debug messages via ".config" 2)remove unnecessary duplication of code 3)make "UFSD" macros more similar to function 4)fix some compiler warnings Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: wrong type castEvgeniy Dushistov
There are two ugly macros in ufs code: #define UCPI_UBH ((struct ufs_buffer_head *)ucpi) #define USPI_UBH ((struct ufs_buffer_head *)uspi) when uspi looks like struct { struct ufs_buffer_head ; } and USPI_UBH has some sence, ucpi looks like struct { struct not_ufs_buffer_head; } To prevent bugs in future, this patch convert macros to inline function and fix "ucpi" structure. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24typo patch for fs/ufs/super.cMichael Owen
Quick and simple typo fix. neTXstep -> neXTstep Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] ufs: fix oops with `ufs1' typeEvgeniy Dushistov
"rm" command, on file system with "ufs1" type cause system hang up. This is, in fact, not so bad as it seems to be, because of after that in "kernel control path" there are 3-4 places which may cause "oops". So the first patch fix oopses, and the second patch fix "kernel hang up". "oops" appears because of reading of group's summary info partly wrong, and access to not first group's summary info cause "oops". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] ufs cleanupEvgeniy
Here is update of ufs cleanup patch, brought on by the recently fixed ubh_get_usb_second() bug that made some ugly code rather painfully obvious. It also includes - fix compilation warnings which appears if debug mode turn on - remove unnecessary duplication of code to support UFS2 I tested it on ufs1 and ufs2 file-systems. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] UFS: inode->i_sem is not released in error pathEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
