commit fa65653e575fbd958bdf5fb9c4a71a324e39510d upstream.
Detect when a directory entry is (possibly partially) beyond directory
size and return EIO in that case since it means the filesystem is
corrupted. Otherwise directory operations can further corrupt the
directory and possibly also oops the kernel.
CC: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
CC: stable@vger.kernel.org
Reported-and-tested-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
[ Upstream commit 116e5258e4115aca0c64ac0bf40ded3b353ed626 ]
Currently when UDF filesystem is recorded without uid / gid (ids are set
to -1), we will assign INVALID_[UG]ID to vfs inode unless user uses uid=
and gid= mount options. In such case filesystem could not be modified in
any way as VFS refuses to modify files with invalid ids (even by root).
This is confusing to users and not very useful default since such media
mode is generally used for removable media. Use overflow[ug]id instead
so that at least root can modify the filesystem.
Reported-by: Steve Kenton <skenton@ou.edu>
Reviewed-by: Pali Rohár <pali.rohar@gmail.com>
commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit 44f06ba8297c7e9dfd0e49b40cbe119113cca094 upstream.
OSTA UDF specification does not mention whether the CS0 charset in case
of two bytes per character encoding should be treated in UTF-16 or
UCS-2. The sample code in the standard does not treat UTF-16 surrogates
in any special way but on systems such as Windows which work in UTF-16
internally, filenames would be treated as being in UTF-16 effectively.
In Linux it is more difficult to handle characters outside of Base
Multilingual plane (beyond 0xffff) as NLS framework works with 2-byte
characters only. Just make sure we don't leak UTF-16 surrogates into the
resulting string when loading names from the filesystem for now.
CC: stable@vger.kernel.org # >= v4.6
Reported-by: Mingye Wang <arthur200126@gmail.com>
[ Upstream commit abdc0eb06964fe1d2fea6dd1391b734d0590365d ]
When session starts beyond offset 2^31 the arithmetics in
udf_check_vsd() would overflow. Make sure the computation is done in
large enough type.
Reported-by: Cezary Sliwa <sliwa@ifpan.edu.pl>
commit f2e95355891153f66d4156bf3a142c6489cd78c6 upstream.
udf_setsize() called truncate_setsize() with i_data_sem held. Thus
truncate_pagecache() called from truncate_setsize() could lock a page
under i_data_sem which can deadlock as page lock ranks below
i_data_sem - e. g. writeback can hold page lock and try to acquire
i_data_sem to map a block.
Fix the problem by moving truncate_setsize() calls from under
i_data_sem. It is safe for us to change i_size without holding
i_data_sem as all the places that depend on i_size being stable already
hold inode_lock.
Fixes: 7e49b6f2480cb9a9e7322a91592e56a5c85361f5
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
This is trivial to do:
- add flags argument to foo_rename()
- check if flags doesn't have any other than RENAME_NOREPLACE
- assign foo_rename() to .rename2 instead of .rename
Filesystems converted:
affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos,
nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat.
Acked-by: Boaz Harrosh <ooo@electrozaur.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: Bob Copeland <me@bobcopeland.com>
Acked-by: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
... it would get converted to regular if such had been attempted
As Al properly points out, len is guaranteed to be smaller than
PAGE_SIZE when we reach udf_adinicb_write_begin() as otherwise we would
have converted the file to the normal format.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Pull block driver updates from Jens Axboe:
"This branch also contains core changes. I've come to the conclusion
that from 4.9 and forward, I'll be doing just a single branch. We
often have dependencies between core and drivers, and it's hard to
always split them up appropriately without pulling core into drivers
when that happens.
That said, this contains:
- separate secure erase type for the core block layer, from
Christoph.
- set of discard fixes, from Christoph.
- bio shrinking fixes from Christoph, as a followup up to the
op/flags change in the core branch.
- map and append request fixes from Christoph.
- NVMeF (NVMe over Fabrics) code from Christoph. This is pretty
exciting!
- nvme-loop fixes from Arnd.
- removal of ->driverfs_dev from Dan, after providing a
device_add_disk() helper.
- bcache fixes from Bhaktipriya and Yijing.
- cdrom subchannel read fix from Vchannaiah.
- set of lightnvm updates from Wenwei, Matias, Johannes, and Javier.
- set of drbd updates and fixes from Fabian, Lars, and Philipp.
- mg_disk error path fix from Bart.
- user notification for failed device add for loop, from Minfei.
- NVMe in general:
+ NVMe delay quirk from Guilherme.
+ SR-IOV support and command retry limits from Keith.
+ fix for memory-less NUMA node from Masayoshi.
+ use UINT_MAX for discard sectors, from Minfei.
+ cancel IO fixes from Ming.
+ don't allocate unused major, from Neil.
+ error code fixup from Dan.
+ use constants for PSDT/FUSE from James.
+ variable init fix from Jay.
+ fabrics fixes from Ming, Sagi, and Wei.
+ various fixes"
* 'for-4.8/drivers' of git://git.kernel.dk/linux-block: (115 commits)
nvme/pci: Provide SR-IOV support
nvme: initialize variable before logical OR'ing it
block: unexport various bio mapping helpers
scsi/osd: open code blk_make_request
target: stop using blk_make_request
block: simplify and export blk_rq_append_bio
block: ensure bios return from blk_get_request are properly initialized
virtio_blk: use blk_rq_map_kern
memstick: don't allow REQ_TYPE_BLOCK_PC requests
block: shrink bio size again
block: simplify and cleanup bvec pool handling
block: get rid of bio_rw and READA
block: don't ignore -EOPNOTSUPP blkdev_issue_write_same
block: introduce BLKDEV_DISCARD_ZERO to fix zeroout
NVMe: don't allocate unused nvme_major
nvme: avoid crashes when node 0 is memoryless node.
nvme: Limit command retries
loop: Make user notify for adding loop device failed
nvme-loop: fix nvme-loop Kconfig dependencies
nvmet: fix return value check in nvmet_subsys_alloc()
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
These two are confusing leftover of the old world order, combining
values of the REQ_OP_ and REQ_ namespaces. For callers that don't
special case we mostly just replace bi_rw with bio_data_dir or
op_is_write, except for the few cases where a switch over the REQ_OP_
values makes more sense. Any check for READA is replaced with an
explicit check for REQ_RAHEAD. Also remove the READA alias for
REQ_RAHEAD.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Mike Christie <mchristi@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This has ll_rw_block users pass in the operation and flags separately,
so ll_rw_block can setup the bio op and bi_rw flags on the bio that
is submitted.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
UDF/OSTA terminology is confusing. Partition Numbers (PNs) are arbitrary
16-bit values, one for each physical partition in the volume. Partition
Reference Numbers (PRNs) are indices into the the Partition Map Table
and do not necessarily equal the PN of the mapped partition.
The current metadata code mistakenly uses the PN instead of the PRN when
mapping metadata blocks to physical/sparable blocks. Windows-created
UDF 2.5 discs for some reason use large, arbitrary PNs, resulting in
mount failure and KASAN read warnings in udf_read_inode().
For example, a NetBSD UDF 2.5 partition might look like this:
PRN PN Type
0 0 Sparable
1 0 Metadata
Since PRN == PN, we are fine.
But Windows could gives us:
PRN PN Type
0 8192 Sparable
1 8192 Metadata
So udf_read_inode() will start out by checking the partition length in
sbi->s_partmaps[8192], which is obviously out of bounds.
Fix this by creating a new field (s_phys_partition_ref) in struct
udf_meta_data, referencing whatever physical or sparable map has the
same partition number as the metadata partition.
[JK: Add comment about s_phys_partition_ref, change its name]
Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com>
Currently when udf_get_pblock_meta25() fails to map a block using the
primary metadata file, it will attempt to load the mirror file entry by
calling udf_find_metadata_inode_efe(). That function will return a ERR_PTR
if it fails, but the return value is only checked against NULL. Test the
return value using IS_ERR() and change it to NULL if needed.
Currently, if a metadata partition map is missing its partition descriptor,
then udf_get_pblock_meta25() will BUG() out the first time it is called.
This is rather drastic for a corrupted filesystem, so just treat this case
as an invalid mapping instead.
Pull vfs cleanups from Al Viro:
"More cleanups from Christoph"
* 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
nfsd: use RWF_SYNC
fs: add RWF_DSYNC aand RWF_SYNC
ceph: use generic_write_sync
fs: simplify the generic_write_sync prototype
fs: add IOCB_SYNC and IOCB_DSYNC
direct-io: remove the offset argument to dio_complete
direct-io: eliminate the offset argument to ->direct_IO
xfs: eliminate the pos variable in xfs_file_dio_aio_write
filemap: remove the pos argument to generic_file_direct_write
filemap: remove pos variables in generic_file_read_iter
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull UDF fixes from Jan Kara:
"A fix for UDF crash on corrupted media and one UDF header fixup"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
udf: Export superblock magic to userspace
udf: Prevent stack overflow on corrupted filesystem mount
Backmerge to resolve a conflict in ovl_lookup_real();
"ovl_lookup_real(): use lookup_one_len_unlocked()" instead,
but it was too late in the cycle to rebase.
The rest of work.xattr stuff isn't needed for this branch
The kiocb already has the new position, so use that. The only interesting
case is AIO, where we currently don't bother updating ki_pos. We're about
to free the kiocb after we're done, so we might as well update it to make
everyone's life simpler.
While we're at it also return the bytes written argument passed in if
we were successful so that the boilerplate error switch code in the
callers can go away.
This will allow us to do per-I/O sync file writes, as required by a lot
of fileservers or storage targets.
XXX: Will need a few additional audits for O_DSYNC
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually
work, so eliminate the superflous argument.
Currently UDF superblock magic doesn't appear in any userspace header
files and thus userspace apps have hard time checking for this fs. Let's
export the magic to userspace as with any other filesystem.
Presently, a corrupted or malicious UDF filesystem containing a very large
number (or cycle) of Logical Volume Integrity Descriptor extent
indirections may trigger a stack overflow and kernel panic in
udf_load_logicalvolint() on mount.
Replace the unnecessary recursion in udf_load_logicalvolint() with
simple iteration. Set an arbitrary limit of 1000 indirections (which would
have almost certainly overflowed the stack without this fix), and treat
such cases as if there were no LVID.
Commit 9293fcfbc1812a22ad5ce1b542eb90c1bbe01be1
("udf: Remove struct ustr as non-needed intermediate storage"),
while getting rid of 'struct ustr', does not take any special care
of 'dstring' fields and effectively use fixed field length instead
of actual string length, encoded in the last byte of the field.
Also, commit 484a10f49387e4386bf2708532e75bf78ffea2cb
("udf: Merge linux specific translation into CS0 conversion function")
introduced checking of the length of the string being converted,
requiring proper alignment to number of bytes constituing each
character.
The UDF volume identifier is represented as a 32-bytes 'dstring',
and needs to be converted from CS0 to UTF8, while mounting UDF
filesystem. The changes in mentioned commits can in some cases
lead to incorrect handling of volume identifier:
- if the actual string in 'dstring' is of maximal length and
does not have zero bytes separating it from dstring encoded
length in last byte, that last byte may be included in conversion,
thus making incorrect resulting string;
- if the identifier is encoded with 2-bytes characters (compression
code is 16), the length of 31 bytes (32 bytes of field length minus
1 byte of compression code), taken as the string length, is reported
as an incorrect (unaligned) length, and the conversion fails, which
in its turn leads to volume mounting failure.
This patch introduces handling of 'dstring' encoded length field
in udf_CS0toUTF8 function, that is used in all and only cases
when 'dstring' fields are converted. Currently these cases are
processing of Volume Identifier and Volume Set Identifier fields.
The function is also renamed to udf_dstrCS0toUTF8 to distinctly
indicate that it handles 'dstring' input.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
... and neither can ever be NULL
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Current implementation of udf_translate_to_linux function does not
support multi-bytes characters at all: it counts bytes while calculating
extension length, when inserting CRC inside the name it doesn't
take into account inter-character boundaries and can break into
the middle of the character.
The most efficient way to properly support multi-bytes characters is
merging of translation operations directly into conversion function.
This can help to avoid extra passes along the string or parsing
the multi-bytes character back into unicode to find out it's length.
Although 'struct ustr' tries to structurize the data by combining
the string and its length, it doesn't actually make much benefit,
since it saves only one parameter, but introduces an extra copying
of the whole buffer, serving as an intermediate storage. It looks
quite inefficient and not actually needed.
This commit gets rid of the struct ustr by changing the parameters
of some functions appropriately.
Also, it removes using 'dstring' type, since it doesn't make much
sense too.
Just using the occasion, add a 'const' qualifier to udf_get_filename
to make consistent parameters sets.
Code in udf_find_entry() and udf_readdir() used the same buffer for
storing filename that was split among blocks and for the resulting
filename in utf8. This worked because udf_get_filename() first
internally copied the name into a different buffer and only then
performed a conversion into the destination buffer. However we want to
get rid of intermediate buffers so use separate buffer for converted
name and name split between blocks so that we don't have the same source
and destination buffer when converting split names.
Actual name length restriction is 254 bytes, this is used in 'ustr'
structure, and this is what fits into UDF File Ident structures.
And in most cases the constant is used as UDF_NAME_LEN-2.
So, it's better to just modify the constant to make it closer
to reality.
Also, in some cases it's useful to have a separate constant for
the maximum length of file name field in CS0 encoding in UDF File
Ident structures.
Also, remove the unused UDF_PATH_LEN constant.
There is no much sense to have separate functions for UTF8 and
NLS conversions, since UTF8 encoding is actually the special case
of NLS.
However, although UTF8 is also supported by general NLS framework,
it would be good to have separate UTF8 character conversion functions
(char2uni and uni2char) locally in UDF code, so that they could be
used even if NLS support is not enabled in the kernel configuration.
Make the desired output length a parameter rather than have it
hard-coded to UDF_NAME_LEN. Although all call sites still have
this length the same, this parameterization will make the function
more universal and also consistent with udf_get_filename.
Pull final vfs updates from Al Viro:
- The ->i_mutex wrappers (with small prereq in lustre)
- a fix for too early freeing of symlink bodies on shmem (they need to
be RCU-delayed) (-stable fodder)
- followup to dedupe stuff merged this cycle
vfs: abort dedupe loop if fatal signals are pending
make sure that freeing shmem fast symlinks is RCU-delayed
wrappers for ->i_mutex access
lustre: remove unused declaration
There are many locations that do
if (memory_was_allocated_by_vmalloc)
vfree(ptr);
else
kfree(ptr);
but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory
using is_vmalloc_addr(). Unless callers have special reasons, we can
replace this branch with kvfree(). Please check and reply if you found
problems.
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Boris Petkov <bp@suse.de>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Pull UDF fixes and quota cleanups from Jan Kara:
"Several UDF fixes and some minor quota cleanups"
udf: Check output buffer length when converting name to CS0
udf: Prevent buffer overrun with multi-byte characters
quota: constify qtree_fmt_operations structures
udf: avoid uninitialized variable use
udf: Fix lost indirect extent block
udf: Factor out code for creating indirect extent
udf: limit the maximum number of indirect extents in a row
udf: limit the maximum number of TD redirections
fs: make quota/dquot.c explicitly non-modular
fs: make quota/netlink.c explicitly non-modular
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
If a name contains at least some characters with Unicode values
exceeding single byte, the CS0 output should have 2 bytes per character.
And if other input characters have single byte Unicode values, then
the single input byte is converted to 2 output bytes, and the length
of output becomes larger than the length of input. And if the input
name is long enough, the output length may exceed the allocated buffer
length.
All this means that conversion from UTF8 or NLS to CS0 requires
checking of output length in order to stop when it exceeds the given
output buffer size.
[JK: Make code return -ENAMETOOLONG instead of silently truncating the
name]
udf_CS0toUTF8 function stops the conversion when the output buffer
length reaches UDF_NAME_LEN-2, which is correct maximum name length,
but, when checking, it leaves the space for a single byte only,
while multi-bytes output characters can take more space, causing
buffer overflow.
Similar error exists in udf_CS0toNLS function, that restricts
the output length to UDF_NAME_LEN, while actual maximum allowed
length is UDF_NAME_LEN-2.
In these cases the output can override not only the current buffer
length field, causing corruption of the name buffer itself, but also
following allocation structures, causing kernel crash.
Adjust the output length checks in both functions to prevent buffer
overruns in case of multi-bytes UTF8 or NLS characters.
A new warning has come up from a recent cleanup:
fs/udf/inode.c: In function 'udf_setup_indirect_aext':
fs/udf/inode.c:1927:28: warning: 'adsize' may be used uninitialized in this function [-Wmaybe-uninitialized]
If the alloc_type is neither ICBTAG_FLAG_AD_SHORT nor
ICBTAG_FLAG_AD_LONG, the value of adsize is undefined. Currently,
callers of these functions make sure alloc_type is one of the two valid
ones but for future proofing make sure we handle the case of invalid
alloc type as well. This changes the code to return -EIOin that case.
Fixes: fcea62babc81 ("udf: Factor out code for creating indirect extent")
When inode ends with empty indirect extent block and we extended that
file, udf_do_extend_file() ended up just overwriting pointer to it with
another extent and thus effectively leaking the block and also
corruptiong length of allocation descriptors.
Fix the problem by properly following into next indirect extent when it
is present.
