path: root/fs/udf
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20switch udf_ioctl() to inode_permission()Al Viro
2011-05-28udf: remove unnecessary dentry_unhash from rmdir, dir renameSage Weil
udf does not have problems with references to unlinked directories. CC: Jan Kara <jack@suse.cz> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23udf: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: UDF: Fix compiler warning udf: Convert UDF to new truncate calling sequence
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-03udf: fix i_nlink limitAl Viro
(256 << sizeof(x)) - 1 is not the maximal possible value of x... In reality, the maximal allowed value for UDF FileLinkCount is 65535. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-23UDF: Fix compiler warningDirk Behme
Fix compiler warning fs/udf/balloc.c: In function 'udf_bitmap_new_block': fs/udf/balloc.c:273: warning: passing argument 1 of '_find_next_bit_le' from incompatible pointer type fs/udf/balloc.c:285: warning: passing argument 1 of '_find_next_bit_le' from incompatible pointer type fs/udf/balloc.c:311: warning: passing argument 1 of '_find_next_bit_le' from incompatible pointer type fs/udf/balloc.c:325: warning: passing argument 1 of '_find_next_bit_le' from incompatible pointer type The main fix is to add a cast in ext2_find_next_bit(). As all other usage locations of udf_find_next_one_bit() directly use bh->b_data (which is a char *), the useless (char *) cast in line 311 can be removed, too. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-23udf: Convert UDF to new truncate calling sequenceJan Kara
Use new truncation sequence in UDF and fix up error handling in the code. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: UDF: Close small mem leak in udf_find_entry() udf: Fix directory corruption after extent merging udf: Protect udf_file_aio_write from possible races udf: Remove unnecessary bkl usages udf: Use of s_alloc_mutex to serialize udf_relocate_blocks() execution udf: Replace bkl with the UDF_I(inode)->i_data_sem for protect udf_inode_info struct udf: Remove BKL from free space counting functions udf: Call udf_add_free_space() for more blocks at once in udf_free_blocks() udf: Remove BKL from udf_put_super() and udf_remount_fs() udf: Protect default inode credentials by rwlock udf: Protect all modifications of LVID with s_alloc_mutex udf: Move handling of uniqueID into a helper function and protect it by a s_alloc_mutex udf: Remove BKL from udf_update_inode udf: Convert UDF_SB(sb)->s_flags to use bitops fs/udf: Add printf format/argument verification fs/udf: Use vzalloc (Evil merge: this also removes the BKL dependency from the Kconfig file)
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06UDF: Close small mem leak in udf_find_entry()Jesper Juhl
Hi, There's a small memory leak in fs/udf/namei.c::udf_find_entry(). We dynamically allocate memory for 'fname' with kmalloc() and in most situations we free it before we leave the function, but there is one situation where we do not (but should). This patch closes the leak by jumping to the 'out_ok' label which does the correct cleanup rather than doing half the cleanup and returning directly. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Fix directory corruption after extent mergingJan Kara
If udf_bread() called from udf_add_entry() managed to merge created extent to an already existing one (or if previous extents could be merged), the code truncating the last extent to proper size would just overwrite the freshly allocated extent with an extent that used to be in that place. This obviously results in a directory corruption. Fix the problem by properly reloading the last extent. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Protect udf_file_aio_write from possible racesJan Kara
Code doing conversion from INICB file to a normal file in udf_file_aio_write() is not protected by any lock from other code modifying the inode. Use i_alloc_sem for that. Reported-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Remove unnecessary bkl usagesAlessio Igor Bogani
The udf_readdir(), udf_lookup(), udf_create(), udf_mknod(), udf_mkdir(), udf_rmdir(), udf_link(), udf_get_parent() and udf_unlink() seems already adequately protected by i_mutex held by VFS invoking calls. The udf_rename() instead should be already protected by lock_rename again by VFS. The udf_ioctl(), udf_fill_super() and udf_evict_inode() don't requires any further protection. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Use of s_alloc_mutex to serialize udf_relocate_blocks() executionAlessio Igor Bogani
2011-01-06udf: Replace bkl with the UDF_I(inode)->i_data_sem for protect ↵Alessio Igor Bogani
udf_inode_info struct Replace bkl with the UDF_I(inode)->i_data_sem rw semaphore in udf_release_file(), udf_symlink(), udf_symlink_filler(), udf_get_block(), udf_block_map(), and udf_setattr(). The rule now is that any operation on regular file's or symlink's extents (or generally allocation information including goal block) needs to hold i_data_sem. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Remove BKL from free space counting functionsJan Kara
udf_count_free_bitmap() does not need BKL because bitmaps are in a fixed place on disk and so we can count set bits without serialization. udf_count_free_table() is now protected by s_alloc_mutex instead of BKL to get a consistent view of free space extents. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Call udf_add_free_space() for more blocks at once in udf_free_blocks()Jan Kara
There's no need to call udf_add_free_space() for one block at a time. It saves us noticeable amount of work and yields different result from the original code only if the filesystem is corrupted and bitmap bit is already cleared. In such case counter of free blocks is probably wrong anyways so the change does not matter. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Remove BKL from udf_put_super() and udf_remount_fs()Jan Kara
udf_put_super() does not need BKL because the filesystem is shut down so there's nothing to race with. The credential changes in udf_remount_fs() and LVID changes are now protected by dedicated locks so we can remove BKL from this function as well. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Protect default inode credentials by rwlockJan Kara
Superblock carries credentials (uid, gid, etc.) which are used as default values in __udf_read_inode() when media does not provide these. These credentials can change during remount so we protect them by a rwlock so that each inode gets a consistent set of credentials. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Protect all modifications of LVID with s_alloc_mutexJan Kara
udf_open_lvid() and udf_close_lvid() were modifying LVID without s_alloc_mutex. Since they can be called from remount, the modification could race with other filesystem modifications of LVID so protect them by s_alloc_mutex just to be sure. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Move handling of uniqueID into a helper function and protect it by a ↵Jan Kara
s_alloc_mutex uniqueID handling has been duplicated in three places. Move it into a common helper. Since we modify an LVID buffer with uniqueID update, we take sbi->s_alloc_mutex to protect agaist other modifications of the structure. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Remove BKL from udf_update_inodeJan Kara
udf_update_inode() does not need BKL since on-disk inode modifications are protected by the buffer lock and reading of values of in-memory inode is safe without any lock. In some cases we can write inconsistent inode state to disk but in that case inode will be marked dirty and overwritten later. Also make unnecessarily global udf_sync_inode() static. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06udf: Convert UDF_SB(sb)->s_flags to use bitopsJan Kara
Use atomic bitops to manipulate with sb flags to make manipulation safe without any locking. Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06fs/udf: Add printf format/argument verificationJoe Perches
Add __attribute__((format... to udf_warning. All arguments matched formats, no other changes necessary. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-06fs/udf: Use vzallocJoe Perches
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09switch udf to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09add missing setattr methodsChristoph Hellwig
For the new truncate sequence every filesystem that wants to truncate on-disk state needs a seattr method. Convert the remaining filesystems that implement the truncate inode operation to have its own setattr method. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-02udf: super.c Fix warning: variable 'sbi' set but not usedJustin P. Mattock
This fixes this warning when building the kernel: CC fs/udf/super.o fs/udf/super.c: In function 'udf_load_sequence': fs/udf/super.c:1582:22: warning: variable 'sbi' set but not used Please have a look, when you have time and let me know. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-08-02udf: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in fs/udf/file.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert quota statistics to generic percpu_counter ext3 uses rb_node = NULL; to zero rb_root. quota: Fixup dquot_transfer reiserfs: Fix resuming of quotas on remount read-write pohmelfs: Remove dead quota code ufs: Remove dead quota code udf: Remove dead quota code quota: rename default quotactl methods to dquot_ quota: explicitly set ->dq_op and ->s_qcop quota: drop remount argument to ->quota_on and ->quota_off quota: move unmount handling into the filesystem quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers quota: move remount handling into the filesystem ocfs2: Fix use after free on remount read-only Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs/: do not fallback to default_llseek() when readdir() uses BKLjan Blunck
Do not use the fallback default_llseek() if the readdir operation of the filesystem still uses the big kernel lock. Since llseek() modifies file->f_pos of the directory directly it may need locking to not confuse readdir which usually uses file->f_pos directly as well Since the special characteristics of the BKL (unlocked on schedule) are not necessary in this case, the inode mutex can be used for locking as provided by generic_file_llseek(). This is only possible since all filesystems, except reiserfs, either use a directory as a flat file or with disk address offsets. Reiserfs on the other hand uses a 32bit hash off the filename as the offset so generic_file_llseek() can get used as well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) - blocksize). Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Anders Larsen <al@alarsen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24udf: Remove dead quota codeJan Kara
Quota on UDF is non-functional at least since 2.6.16 (I'm too lazy to do more archeology) because it does not provide .quota_write and .quota_read functions and thus quotaon(8) just returns EINVAL. Since nobody complained for all those years and quota support is not even in UDF standard just nuke it. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: rename default quotactl methods to dquot_Christoph Hellwig
Follow the dquot_* style used elsewhere in dquot.c. [Jan Kara: Fixed up missing conversion of ext2] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: explicitly set ->dq_op and ->s_qcopChristoph Hellwig
Only set the quota operation vectors if the filesystem actually supports quota instead of doing it for all filesystems in alloc_super(). [Jan Kara: Export dquot_operations and vfs_quotactl_ops] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move unmount handling into the filesystemChristoph Hellwig
Currently the VFS calls into the quotactl interface for unmounting filesystems. This means filesystems with their own quota handling can't easily distinguish between user-space originating quotaoff and an unount. Instead move the responsibily of the unmount handling into the filesystem to be consistent with all other dquot handling. Note that we do call dquot_disable a lot later now, e.g. after a sync_filesystem. But this is fine as the quota code does all its writes via blockdev's mapping and that is synced even later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
