commit f2e95355891153f66d4156bf3a142c6489cd78c6 upstream.
udf_setsize() called truncate_setsize() with i_data_sem held. Thus
truncate_pagecache() called from truncate_setsize() could lock a page
under i_data_sem which can deadlock as page lock ranks below
i_data_sem - e. g. writeback can hold page lock and try to acquire
i_data_sem to map a block.
Fix the problem by moving truncate_setsize() calls from under
i_data_sem. It is safe for us to change i_size without holding
i_data_sem as all the places that depend on i_size being stable already
hold inode_lock.
Fixes: 7e49b6f2480cb9a9e7322a91592e56a5c85361f5
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
commit bb00c898ad1ce40c4bb422a8207ae562e9aea7ae upstream.
If a name contains at least some characters with Unicode values
exceeding single byte, the CS0 output should have 2 bytes per character.
And if other input characters have single byte Unicode values, then
the single input byte is converted to 2 output bytes, and the length
of output becomes larger than the length of input. And if the input
name is long enough, the output length may exceed the allocated buffer
length.
All this means that conversion from UTF8 or NLS to CS0 requires
checking of output length in order to stop when it exceeds the given
output buffer size.
[JK: Make code return -ENAMETOOLONG instead of silently truncating the
name]
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
commit ad402b265ecf6fa22d04043b41444cdfcdf4f52d upstream.
udf_CS0toUTF8 function stops the conversion when the output buffer
length reaches UDF_NAME_LEN-2, which is correct maximum name length,
but, when checking, it leaves the space for a single byte only,
while multi-bytes output characters can take more space, causing
buffer overflow.
Similar error exists in udf_CS0toNLS function, that restricts
the output length to UDF_NAME_LEN, while actual maximum allowed
length is UDF_NAME_LEN-2.
In these cases the output can override not only the current buffer
length field, causing corruption of the name buffer itself, but also
following allocation structures, causing kernel crash.
Adjust the output length checks in both functions to prevent buffer
overruns in case of multi-bytes UTF8 or NLS characters.
commit b0918d9f476a8434b055e362b83fa4fd1d462c3f upstream.
udf_next_aext() just follows extent pointers while extents are marked as
indirect. This can loop forever for corrupted filesystem. Limit number
the of indirect extents we are willing to follow in a row.
[JK: Updated changelog, limit, style]
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Jan Kara <jack@suse.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
When read-write mount of a filesystem is requested but we find out we
can mount the filesystem only in read-only mode, we still modify
LVID in udf_close_lvid(). That is both unnecessary and contrary to
expectation that when we fall back to read-only mount we don't modify
the filesystem.
Make sure we call udf_close_lvid() only if we called udf_open_lvid() so
that filesystem gets modified only if we verified we are allowed to
write to it.
Reported-by: Karel Zak <kzak@redhat.com>
Signed-off-by: Jan Kara <jack@suse.com>
For a UDF filesystem configured with an Unallocated Space Table,
a filesystem operation that triggers an update to the table results
in on-disk corruption that prevents remounting:
udf_read_tagged: tag version 0x0000 != 0x0002 || 0x0003, block 274
For example:
1. Create a filesystem
$ mkudffs --media-type=hd --blocksize=512 --lvid=BUGTEST \
--vid=BUGTEST --fsid=BUGTEST --space=unalloctable \
/dev/mmcblk0
2. Mount it
# mount /dev/mmcblk0 /mnt
3. Create a file
$ echo "No corruption, please" > /mnt/new.file
4. Umount
# umount /mnt
5. Attempt remount
This appears to be a longstanding bug caused by zero-initialization of
the Unallocated Space Entry block buffer and only partial repopulation
of required fields before writing to disk.
Commit 0adfb339fd64 ("udf: Fix unalloc space handling in udf_update_inode")
addressed one such field, but several others are required.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
list_entry is just a wrapper for container_of, but it is arguably
wrong (and slightly confusing) to use it when the pointed-to struct
member is not a struct list_head. Use container_of directly instead.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
There are some missing braces here which means this function never
succeeds.
Fixes: e9d4cf411f75 ('udf: improve error management in udf_CS0toUTF8()')
Use first err declaration for generic_write_sync() return value.
The "fh_len" passed to ->fh_to_* is not guaranteed to be that same as
that returned by encode_fh - it may be larger.
With NFSv2, the filehandle is fixed length, so it may appear longer
than expected and be zero-padded.
So we must test that fh_len is at least some value, not exactly equal
to it.
Signed-off-by: NeilBrown <neilb@suse.de>
Return appropriate error from udf_find_entry() instead of just NULL.
That way we can distinguish the fact that some error happened when
looking up filename (and return error to userspace) from the fact that
we just didn't find the filename. Also update callers of
udf_find_entry() accordingly.
[JK: Improved udf_find_entry() documentation]
Suggested-by: Jan Kara <jack@suse.cz>
Zero length file name isn't really valid. So check the length of the
final file name generated by udf_translate_to_linux() and return -EINVAL
instead of zero length file name. Update caller of udf_get_filename() to
not check for 0 return value.
UDF volume is only mounted with UDF_FLAG_UTF8
or UDF_FLAG_NLS_MAP (see fill udf_fill_super().
BUG() if we have something different in udf_get_filename()
Only callsite udf_get_filename() now returns error code as well.
udf_CS0toUTF8() now returns -EINVAL on error.
udf_load_pvoldesc() and udf_get_filename() do the same.
We can remove parameter checks:
udf_build_ustr_exact() is only called by udf_get_filename()
which now assures dest is not NULL
udf_find_entry() and udf_readdir() call udf_get_filename()
after checking sname
udf_symlink_filler() calls udf_pc_to_char() with sname=kmap(page).
udf_find_entry() and udf_readdir() call udf_get_filename with UDF_NAME_LEN
udf_pc_to_char() with PAGE_SIZE
Return -ENOMEM when allocation fails in udf_get_filename(). Update
udf_pc_to_char(), udf_readdir(), and udf_find_entry() to handle the
error appropriately. This allows us to pass appropriate error to
userspace instead of corrupting symlink contents by omitting some path
elements.
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull quota and udf updates from Jan Kara:
"The pull contains quota changes which complete unification of XFS and
VFS quota interfaces (so tools can use either interface to manipulate
any filesystem). There's also a patch to support project quotas in
VFS quota subsystem from Li Xi.
Finally there's a bunch of UDF fixes and cleanups and tiny cleanup in
reiserfs & ext3"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: (21 commits)
udf: Update ctime and mtime when directory is modified
udf: return correct errno for udf_update_inode()
ext3: Remove useless condition in if statement.
vfs: Add general support to enforce project quota limits
reiserfs: fix __RASSERT format string
udf: use int for allocated blocks instead of sector_t
udf: remove redundant buffer_head.h includes
udf: remove else after return in __load_block_bitmap()
udf: remove unused variable in udf_table_free_blocks()
quota: Fix maximum quota limit settings
quota: reorder flags in quota state
quota: paranoia: check quota tree root
quota: optimize i_dquot access
quota: Hook up Q_XSETQLIM for id 0 to ->set_info
xfs: Add support for Q_SETINFO
quota: Make ->set_info use structure with neccesary info to VFS and XFS
quota: Remove ->get_xstate and ->get_xstatev callbacks
gfs2: Convert to using ->get_state callback
xfs: Convert to using ->get_state callback
quota: Wire up Q_GETXSTATE and Q_GETXSTATV calls to work with ->get_state
that's the bulk of filesystem drivers dealing with inodes of their own
... returning -E... upon error and amount of data left in iter after
(possible) truncation upon success. Note, that normal case gives
a non-zero (positive) return value, so any tests for != 0 _must_ be
updated.
fs/ext4/file.c
it's easier to do generic_write_checks() first
all remaining callers are passing 0; some just obscure that fact.
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
The rw parameter to direct_IO is redundant with iov_iter->type, and
treated slightly differently just about everywhere it's used: some users
do rw & WRITE, and others do rw == WRITE where they should be doing a
bitwise check. Simplify this with the new iov_iter_rw() helper, which
always returns either READ or WRITE.
Most filesystems call through to these at some point, so we'll start
here.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
We failed to update ctime & mtime of a directory when new entry was
created in it during rename, link, create, etc. Fix that.
Reported-by: Taesoo Kim <tsgatesv@gmail.com>
Instead of -ENOMEM, properly return -EIO udf_update_inode()
error, similar/consistent to the rest of filesystems.
Signed-off-by: Changwoo Min <changwoo.m@gmail.com>
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
Fix the following warnings:
fs/udf/balloc.c:768:15: warning: conversion to 'sector_t' from 'int'
may change the sign of the result [-Wsign-conversion]
allocated = udf_bitmap_prealloc_blocks(sb,
fs/udf/balloc.c:773:15: warning: conversion to 'sector_t' from 'int'
allocated = udf_table_prealloc_blocks(sb,
fs/udf/balloc.c:778:15: warning: conversion to 'sector_t' from 'int'
fs/udf/balloc.c:783:15: warning: conversion to 'sector_t' from 'int'
fs/udf/balloc.c:791:26: warning: conversion to 'loff_t' from 'sector_t'
inode_add_bytes(inode, allocated << sb->s_blocksize_bits);
fs/udf/balloc.c:792:2: warning: conversion to 'int' from 'sector_t'
may alter its value [-Wconversion]
return allocated;
buffer_head.h was already included in udfdecl.h
else after return is not needed.
Fix set but not used warning.
There is no need to pass the total request length in the kiocb, as
we already get passed in through the iov_iter argument.
Fix the following coccinelle warnings:
fs/udf/inode.c:753:2-13: WARNING: Assignment of bool to 0/1
fs/udf/inode.c:795:2-13: WARNING: Assignment of bool to 0/1
variable 'done' is only used for true/false in loop.
Commit 6fb1ca92a640 "udf: Fix race between write(2) and close(2)"
changed the condition when preallocation is released. The idea was that
we don't want to release the preallocation for an inode on close when
there are other writeable file descriptors for the inode. However the
condition was written in the opposite way so we released preallocation
only if there were other writeable file descriptors. Fix the problem by
changing the condition properly.
CC: stable@vger.kernel.org
Fixes: 6fb1ca92a6409a9d5b0696447cd4997bc9aaf5a2
Reported-by: Fabian Frederick <fabf@skynet.be>
Call mutex_destroy() on superblock mutex in udf_put_super()
otherwise mutex debugging code isn't able to detect that
mutex is used after being freed.
(thanks to Jan Kara for complete definition).
Check length of extended attributes and allocation descriptors when
loading inodes from disk. Otherwise corrupted filesystems could confuse
the code and make the kernel oops.
Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no>
Store blocksize in a local variable in udf_fill_inode() since it is used
a lot of times.
Update description of UDF in Kconfig to mention that UDF is also
suitable for removable USB disks.
Replace repeated dereferences like dir->i_sb by storing superblock
pointer in a variable and using that.
Check that length specified in a component of a symlink fits in the
input buffer we are reading. Also properly ignore component length for
component types that do not use it. Otherwise we read memory after end
of buffer for corrupted udf image.
