path: root/fs/udf
2008-02-08udf: fix adding entry to a directoryJan Kara
When adding directory entry to a directory, we have to properly increase length of the last extent. Handle this similarly as extending regular files - make extents always have size multiple of block size (it will be truncated down to proper size in udf_clear_inode()). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: cleanup directory offset handlingJan Kara
Position in directory returned by readdir is offset of directory entry divided by four (don't ask me why). Make this conversion only when reading f_pos from userspace / writing it there and internally work in bytes. It makes things more easily readable and also fixes a bug (we forgot to divide length of the entry by 4 when advancing f_pos in udf_add_entry()). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: avoid unnecessary synchronous writesMike Galbraith
Fix udf_clear_inode() to request asynchronous writeout in icache reclaim path. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: fix signedness issueMarcin Slusarz
sparse generated: fs/udf/namei.c:896:15: originally declared here fs/udf/namei.c:1147:41: warning: incorrect type in argument 3 (different signedness) fs/udf/namei.c:1147:41: expected int *offset fs/udf/namei.c:1147:41: got unsigned int *<noident> fs/udf/namei.c:1152:78: warning: incorrect type in argument 3 (different signedness) fs/udf/namei.c:1152:78: expected int *offset fs/udf/namei.c:1152:78: got unsigned int *<noident> Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: fix 3 signedness & 1 unitialized variable warningsMarcin Slusarz
sparse generated: fs/udf/inode.c:324:41: warning: incorrect type in argument 4 (different signedness) fs/udf/inode.c:324:41: expected long *<noident> fs/udf/inode.c:324:41: got unsigned long *<noident> inode_getblk always set 4th argument to uint32_t value 3rd parameter of map_bh is sector_t (which is unsigned long or u64) so convert phys value to sector_t fs/udf/inode.c:1818:47: warning: incorrect type in argument 3 (different signedness) fs/udf/inode.c:1818:47: expected int *<noident> fs/udf/inode.c:1818:47: got unsigned int *<noident> fs/udf/inode.c:1826:46: warning: incorrect type in argument 3 (different signedness) fs/udf/inode.c:1826:46: expected int *<noident> fs/udf/inode.c:1826:46: got unsigned int *<noident> udf_get_filelongad and udf_get_shortad are called always for uint32_t values (struct extent_position->offset), so it's safe to convert offset parameter to uint32_t gcc warned: fs/udf/inode.c: In function 'udf_get_block': fs/udf/inode.c:299: warning: 'phys' may be used uninitialized in this function initialize it to 0 (if someday someone will break inode_getblk we will catch it immediately) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove wrong prototype of udf_readdirMarcin Slusarz
sparse generated: fs/udf/dir.c:78:5: warning: symbol 'udf_readdir' was not declared. Should it be static? there are 2 different prototypes of udf_readdir - remove them and move code around to make it still compile Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kill UDFFS_{DATE,VERSION}Adrian Bunk
Printing date and version of a driver makes sense if there's a maintainer who's maintaining and using these, but printing ancient version information only confuses users. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: improve readability of udf_load_partitionMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: cache struct udf_inode_infoMarcin Slusarz
cache UDF_I(struct inode *) return values when there are at least 2 uses in one function Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove UDF_I_* macros and open code themMarcin Slusarz
2008-02-08udf: convert byte order of constant instead of variableMarcin Slusarz
convert byte order of constant instead of variable, which can be done at compile time (vs run time) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: replace loops coded with goto to real loopsMarcin Slusarz
2008-02-08udf: create common function for changing free space counterMarcin Slusarz
2008-02-08udf: create common function for tag checksummingMarcin Slusarz
2008-02-08udf: fix coding styleMarcin Slusarz
fix coding style errors found by checkpatch: - assignments in if conditions - braces {} around single statement blocks - no spaces after commas - printks without KERN_* - lines longer than 80 characters - spaces between "type *" and variable name before: 192 errors, 561 warnings, 8987 lines checked after: 1 errors, 38 warnings, 9468 lines checked Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: fix sparse warnings (shadowing & mismatch between declaration and ↵Marcin Slusarz
definition) fix sparse warnings: fs/udf/super.c:1431:24: warning: symbol 'bh' shadows an earlier one fs/udf/super.c:1347:21: originally declared here fs/udf/super.c:472:6: warning: symbol 'udf_write_super' was not declared. Should it be static? Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: move calculating of nr_groups into helper functionMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: convert macros related to bitmaps to functionsMarcin Slusarz
convert UDF_SB_ALLOC_BITMAP macro to udf_sb_alloc_bitmap function convert UDF_SB_FREE_BITMAP macro to udf_sb_free_bitmap function Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: check if udf_load_logicalvol failedMarcin Slusarz
udf_load_logicalvol may fail eg in out of memory conditions - check it and propagate error further Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: convert UDF_SB_ALLOC_PARTMAPS macro to udf_sb_alloc_partition_maps functionMarcin Slusarz
- convert UDF_SB_ALLOC_PARTMAPS macro to udf_sb_alloc_partition_maps function - convert kmalloc + memset to kcalloc - check if kcalloc failed (partially) Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove some ugly macrosMarcin Slusarz
remove macros: - UDF_SB_PARTMAPS - UDF_SB_PARTTYPE - UDF_SB_PARTROOT - UDF_SB_PARTLEN - UDF_SB_PARTVSN - UDF_SB_PARTNUM - UDF_SB_TYPESPAR - UDF_SB_TYPEVIRT - UDF_SB_PARTFUNC - UDF_SB_PARTFLAGS - UDF_SB_VOLIDENT - UDF_SB_NUMPARTS - UDF_SB_PARTITION - UDF_SB_SESSION - UDF_SB_ANCHOR - UDF_SB_LASTBLOCK - UDF_SB_LVIDBH - UDF_SB_LVID - UDF_SB_UMASK - UDF_SB_GID - UDF_SB_UID - UDF_SB_RECORDTIME - UDF_SB_SERIALNUM - UDF_SB_UDFREV - UDF_SB_FLAGS - UDF_SB_VAT - UDF_UPDATE_UDFREV - UDF_SB_FREE and open code them convert UDF_SB_LVIDIU macro to udf_sb_lvidiu function rename some struct udf_sb_info fields: - s_volident to s_volume_ident - s_lastblock to s_last_block - s_lvidbh to s_lvid_bh - s_recordtime to s_record_time - s_serialnum to s_serial_number; - s_vat to s_vat_inode; Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: fix coding style of super.cMarcin Slusarz
fix coding style errors found by checkpatch: - assignments in if conditions - braces {} around single statement blocks - no spaces after commas - printks without KERN_* - lines longer than 80 characters before: total: 50 errors, 207 warnings, 1835 lines checked after: total: 0 errors, 164 warnings, 1872 lines checked all 164 warnings left are lines longer than 80 characters; this file has too much indentation with really long expressions to break all those lines now; will fix later Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/udf/balloc.c: mark a variable as uninitialized_var()WANG Cong
Kill a may-be-used-uninitialized warning. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17UDF: coding style fixupsCyrill Gorcunov
This patch does additional coding style fixup. Initially the code is being distorted by Lindent (in my patches sent not very long ago) and fixed in the followup patches but this stuff was accidently missed. New and old compiled files were compared with cmp to check for being identically. So the patch will not break the kernel. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16udf: convert to new aopsNick Piggin
Convert udf to new aops. Also seem to have fixed pagecache corruption in udf_adinicb_commit_write -- page was marked uptodate when it is not. Also, fixed the silly setup where prepare_write was doing a kmap to be used in commit_write: just do kmap_atomic in write_end. Use libfs helpers to make this easier. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31Fix possible NULL pointer dereference in udf_table_free_blocks()Jan Kara
Fix possible NULL pointer dereference when freeing blocks in case table of free space is used. Also fix handling of the case when we need to move extent from one block to another one to make space for indirect extent. BTW: Nobody seem to have ever used this code. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31UDF: handle wrong superblock betterJan Kara
If UDF superblock is incorrect, we can fail to find a table of free / allocated space and consequently Oops. Handle this situation more gracefully by ignoring the broken UDF partition. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31UDF: fix UID and GID mount option ignoranceCyrill Gorcunov
This patch fix weird behaviour of UDF mounting procedure. To get UID changed (for now) we have to type mount -t udf -o uid=some_user,uid=ignore /dev/device /mnt/moun_point and specifying two uid at once is strange a bit. So with the patch we are able to mount without additional 'uid=ignore' option. The same for GID option is done. This patch will not break current mount scheme (with two option). Btw this does fix (I hope) the following [BUG 6124] mount of UDF fs ignores UID and GID options http://bugzilla.kernel.org/show_bug.cgi?id=6124 Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael <auslands-kv@gmx.de> Cc: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17arch/i386/* fs/* ipc/*: mark variables with uninitialized_var()Jeff Garzik
Mark variables with uninitialized_var() if such a warning appears, and analysis proves that the var is initialized properly on all paths it is used. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16UDF: fix function name from udf_crc16 to udf_crcCyrill Gorcunov
We have to change udf_crc16() name to udf_crc() to be able to play with CRC test. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for inode dataCyrill Gorcunov
This patch adds checking for granted memory while filling up inode data to prevent possible NULL pointer usage. If there is not enough memory to fill inode data we just mark it as "bad". Also some whitespace cleanup. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16UDF: check for allocated memory for data of new inodesCyrill Gorcunov
Add checking for granted memory for inode data at the moment of its creation. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-16udf: fix possible leakage of blocksJan Kara
We have to take care that when we call udf_discard_prealloc() from udf_clear_inode() we have to write inode ourselves afterwards (otherwise, some changes might be lost leading to leakage of blocks, use of free blocks or improperly aligned extents). Also udf_discard_prealloc() does two different things - it removes preallocated blocks and truncates the last extent to exactly match i_size. We move the latter functionality to udf_truncate_tail_extent(), call udf_discard_prealloc() when last reference to a file is dropped and call udf_truncate_tail_extent() when inode is being removed from inode cache (udf_clear_inode() call). We cannot call udf_truncate_tail_extent() earlier as subsequent open+write would find the last block of the file mapped and happily write to the end of it, although the last extent says it's shorter. [akpm@linux-foundation.org: Make checkpatch.pl happier] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Eric Sandeen <sandeen@sandeen.net> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01parse errors in ifdefsYoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Jan Kara <jack@ucw.cz> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01Fix possible UDF data corruptionJan Kara
update_next_aext() could possibly rewrite values in elen and eloc, possibly leading to data corruption when rewriting a file. Use temporary variables instead. Also advance cur_epos as it can also point to an indirect extent pointer. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: possible null pointer dereference while load_partitionDmitriy Monakhov
sb_read may return NULL, let's explicitly check it. Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: support files larger than 1GJan Kara
Make UDF work correctly for files larger than 1GB. As no extent can be longer than (1<<30)-blocksize bytes, we have to create several extents if a big hole is being created. As a side-effect, we now don't discard preallocated blocks when creating a hole. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: add assertionsJan Kara
Add a few assertions into udf_discard_prealloc() to check that the file is sane (mostly helps debugging further patches ;). Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use get_bh()Jan Kara
Make UDF use get_bh() instead of directly accessing b_count and use brelse() instead of udf_release_data() which does just brelse()... Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08UDF: introduce struct extent_positionJan Kara
Introduce a structure extent_position to store a position of an extent and the corresponding buffer_head in one place. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: use sector_t and loff_t for file offsetsJan Kara
Use sector_t and loff_t for file offsets in UDF filesystem. Otherwise an overflow may occur for long files. Also make inode_bmap() return offset in the extent in number of blocks instead of number of bytes - for most callers this is more convenient. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08udf: decrement correct link count in udf_rmdirStephen Mollett
It appears that a minor thinko occurred in udf_rmdir and the (already-cleared) link count on the directory that is being removed was being decremented instead of the link count on its parent directory. This gives rise to lots of kernel messages similar to: UDF-fs warning (device loop1): udf_rmdir: empty directory has nlink != 2 (8) when removing directory trees. No other ill effects have been observed but I guess it could theoretically result in the link count overflowing on a very long-lived, much modified directory. Signed-off-by: Stephen Mollett <molletts@yahoo.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Jan Kara <jack@ucw.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
