path: root/fs/ubifs/recovery.c
2015-11-06UBIFS: Delete unnecessary checks before the function call "iput"Markus Elfring
The iput() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-10-03UBIFS: print verbose message when rescanning a corrupted nodeshengyong
This is a trivial fix of showing verbose message when leb-recovery detects a corrupted node, which is not the last one in the LEB. Rescan expects to show more detail of the corrupted node. Reviewed-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Signed-off-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-03-25UBIFS: extend debug/message capabilitiesSheng Yong
In the case where we have more than one volumes on different UBI devices, it may be not that easy to tell which volume prints the messages. Add ubi number and volume id in ubifs_msg/warn/error to help debug. These two values are passed by struct ubifs_info. For those where ubifs_info is not initialized yet, ubifs_* is replaced by pr_*. For those where ubifs_info is not avaliable, ubifs_info is passed to the calling function as a const parameter. The output looks like, [ 95.444879] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 696 [ 95.484688] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "test1" [ 95.484694] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 95.484699] UBIFS (ubi0:1): FS size: 30220288 bytes (28 MiB, 238 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs) [ 95.484703] UBIFS (ubi0:1): reserved for root: 1427378 bytes (1393 KiB) [ 95.484709] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 40DFFC0E-70BE-4193-8905-F7D6DFE60B17, small LPT model [ 95.489875] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 699 [ 95.529713] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "test2" [ 95.529718] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 95.529724] UBIFS (ubi1:0): FS size: 19808256 bytes (18 MiB, 156 LEBs), journal size 1015809 bytes (0 MiB, 8 LEBs) [ 95.529727] UBIFS (ubi1:0): reserved for root: 935592 bytes (913 KiB) [ 95.529733] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EEB7779D-F419-4CA9-811B-831CAC7233D4, small LPT model [ 954.264767] UBIFS error (ubi1:0 pid 756): ubifs_read_node: bad node type (255 but expected 6) [ 954.367030] UBIFS error (ubi1:0 pid 756): ubifs_read_node: bad node at LEB 0:0, LEB mapping status 1 Signed-off-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2015-03-25UBIFS: simplify returnsFabian Frederick
Directly return recover_head() and ubifs_leb_unmap() instead of storing value in err and testing it. Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-19UBIFS: kernel-doc warning fixFabian Frederick
No grouped argument in drop_last_node. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-19UBIFS: fix spelling of "scanned"Artem Bityutskiy
Randy Dunlap pointed that we should use "scanned" instead of "scaned". This patch makes the correction. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-19UBIFS: fix some commentsSeunghun Lee
This patch fixes some comments about return type. Signed-off-by: Seunghun Lee <waydi1@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-01-23fs/ubifs: use rbtree postorder iteration helper instead of opencodingCody P Schafer
Use rbtree_postorder_for_each_entry_safe() to destroy the rbtree instead of opencoding an alternate postorder iteration that modifies the tree Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Michel Lespinasse <walken@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-31UBIFS: comply with coding styleArtem Bityutskiy
Join all the split printk lines in order to stop checkpatch complaining. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-22UBIFS: fix error messages spellingArtem Bityutskiy
Corruptio -> corruption. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: Kill data type hintRichard Weinberger
We do not need this feature and to our shame it even was not working and there was a bug found very recently. -- Artem Bityutskiy Without the data type hint UBI2 (fastmap) will be easier to implement. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: get rid of dbg_errArtem Bityutskiy
This patch removes the 'dbg_err()' macro and we now use 'ubifs_err()' instead. The idea of 'dbg_err()' was to compile out some error message to make the binary a bit smaller - but I think it was a bad idea. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: rename dumping functionsArtem Bityutskiy
This commit re-names all functions which dump something from "dbg_dump_*()" to "ubifs_dump_*()". This is done for consistency with UBI and because this way it will be more logical once we remove the debugging sompilation option. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-02-29UBIFS: amend recovery debugging messageArtem Bityutskiy
Print LEB and offset as well. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2011-08-26UBIFS: fix the dark space calculationsrimugunthan dhandapani
The dark space calculation should be 64 bit type-casted, when assigning to tmp64 (similar to how total_free is calculated). Overflow will occur for very large flashes. Signed-off-by: srimugunthan <srimugunthan.dhandapani@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-07-08UBIFS: fix master node recoveryAnatolij Gustschin
When the 1st LEB was unmapped and written but 2nd LEB not, the master node recovery doesn't succeed after power cut. We see following error when mounting UBIFS partition on NOR flash: UBIFS error (pid 1137): ubifs_recover_master_node: failed to recover master node Correct 2nd master node offset check is needed to fix the problem. If the 2nd master node is at the end in the 2nd LEB, first master node is used for recovery. When checking for this condition we should check whether the master node is exactly at the end of the LEB (without remaining empty space) or whether it is followed by an empty space less than the master node size. Artem: when the error happened, offs2 = 261120, sz = 512, c->leb_size = 262016. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
2011-07-04UBIFS: switch to I/O helpersArtem Bityutskiy
Switch the rest of direct UBI calls to UBIFS helper functions. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: switch to ubifs_leb_readArtem Bityutskiy
Instead of using 'ubi_read()' function directly, used the 'ubifs_leb_read()' helper function instead. This allows to get rid of several redundant error messages and make sure that we always have a stack dump on read errors. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: introduce more I/O helpersArtem Bityutskiy
Introduce the following I/O helper functions: 'ubifs_leb_read()', 'ubifs_leb_write()', 'ubifs_leb_change()', 'ubifs_leb_unmap()', 'ubifs_leb_map()', 'ubifs_is_mapped(). The idea is to wrap all UBI I/O functions in order to encapsulate various assertions and error path handling (error message, stack dump, switching to R/O mode). And there are some other benefits of this which will be used in the following patches. This patch does not switch whole UBIFS to use these functions yet. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-01UBIFS: fix recovery broken by the previous recovery fixArtem Bityutskiy
Unfortunately, the recovery fix d1606a59b6be4ea392eabd40d1250aa1eeb19efb (UBIFS: fix extremely rare mount failure) broke recovery. This commit make UBIFS drop the last min. I/O unit in all journal heads, but this is needed only for the GC head. And this does not work for non-GC heads. For example, if suppose we have min. I/O units A and B, and A contains a valid node X, which was fsynced, and then a group of nodes Y which spans the rest of A and B. In this case we'll drop not only Y, but also X, which is obviously incorrect. This patch fixes the issue and additionally makes recovery to drop last min. I/O unit only for the GC head, and leave things as they have been for ages for the other heads - this is safer. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-01UBIFS: amend ubifs_recover_leb interfaceArtem Bityutskiy
Instead of passing "grouped" parameter to 'ubifs_recover_leb()' which tells whether the nodes are grouped in the LEB to recover, pass the journal head number and let 'ubifs_recover_leb()' look at the journal head's 'grouped' flag. This patch is a preparation to a further fix where we'll need to know the journal head number for other purposes. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-01UBIFS: supress false error messagesArtem Bityutskiy
Commit ab51afe05273741f72383529ef488aa1ea598ec6 was a good clean-up, but it introduced a regression - now UBIFS prints scary error messages during recovery on all corrupted nodes, even though the corruptions are expected (due to a power cut). This patch fixes the issue. Additionally fix a typo in a commentary introduced by the same commit. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-16UBIFS: fix extremely rare mount failureArtem Bityutskiy
This patch fixes an extremely rare mount failure after a power cut, when mount fails with ENOSPC error because UBIFS could not find the GC LEB. In short, the reason for this failure is that after recovery the GC head LEB contains less free space than it had contained just before the power cut happened. As a result, if the FS is full, 'ubifs_rcvry_gc_commit()' is unable to find a dirty LEB to GC and a free LEB, so mount fails. This patch contains a huge comment with more detailed explanation, please refer that comment. Since this is really really rare and unlikely situation, I do not send this patch to the stable tree, also because it requires a lot of preparation patches which I did before. So sending this to -stable would be too risky. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-16UBIFS: simplify LEB recovery function furtherArtem Bityutskiy
Further simplify 'ubifs_recover_leb()' by noticing that we have to call 'clean_buf()' in any case, and it is fine to call it if the offset is aligned to 'c->min_io_size'. Thus, we do not have to call it separately from every "if" - just call it once at the end. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-16UBIFS: always cleanup the recovered LEBArtem Bityutskiy
Now when we call 'ubifs_recover_leb()' only for LEBs which are potentially corrupted (i.e., only for last buds, not for all of them), we can cleanup every LEB, not only those where we find corruption. The reason - unstable bits. Even though the LEB may look good now, it might contain unstable bits which may hit us a bit later. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-16UBIFS: clean up LEB recovery functionArtem Bityutskiy
This patch cleans up 'ubifs_recover_leb()' function and makes it more readable. Move things which are done only once out of the loop and kill unneeded 'switch' statement. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-16UBIFS: improve debugging messagesArtem Bityutskiy
Print a bit more information is some recovery and replay paths. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: fix inode size debugging check failureArtem Bityutskiy
This patch fixes a problem with the following symptoms: UBIFS: deferred recovery completed UBIFS error (pid 15676): dbg_check_synced_i_size: ui_size is 11481088, synced_i_size is 11459081, but inode is clean UBIFS error (pid 15676): dbg_check_synced_i_size: i_ino 128, i_mode 0x81a4, i_size 11481088 It happens when additional debugging checks are enabled and we are recovering from a power cut. When we fixup corrupted inode size during recovery, we change them in-place and we change ui_size as well, but not synced_i_size, which causes this failure. This patch makes sure we change both fields and fixes the issue. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: remove an unneeded checkArtem Bityutskiy
In 'ubifs_recover_size()' we have an "if (!e->inode && c->ro_mount)" statement. But if 'c->ro_mount' is true, then '!e->inode' must always be true as well. So we can remove the unnecessary '!e->inode' test and put an 'ubifs_assert(!e->inode)' instead. This patch also removes an extra trailing white-space in a debugging print, as well as adds few empty lines to 'ubifs_recover_size()' to make it a bit more readable. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: fix debugging messageArtem Bityutskiy
When recovering the inode size, one of the debugging messages was printed incorrecly, this patches fixes it. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: refactor ubifs_rcvry_gc_commitArtem Bityutskiy
This commits refactors and cleans up 'ubifs_rcvry_gc_commit()' which was quite untidy, also removes the commentary which was not 100% correct. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: split ubifs_rcvry_gc_commitArtem Bityutskiy
Split the 'ubifs_rcvry_gc_commit()' function and introduce a 'grab_empty_leb()' heler. This cleans 'ubifs_rcvry_gc_commit()' a little and makes it a bit less of spagetti. Also, add a commentary which explains why it is crucial to first search for an empty LEB and then run commit. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: print useful debugging messages when cannot recover gc_lnumArtem Bityutskiy
If we fail to recover the gc_lnum we just return an error and it then it is difficult to figure out why this happened. This patch adds useful debugging information which should make it easier to debug the failure. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: remove dead GC LEB recovery piece of codeArtem Bityutskiy
This patch removes a piece of code in 'ubifs_rcvry_gc_commit()' which is never executed. We call 'ubifs_find_dirty_leb()' function with min_space = wbuf->offs, so if it returns us an LEB, it is guaranteed to have at lease 'wbuf->offs' bytes of free+dirty space. So we can remove the subsequent code which deals with "returned LEB has less than 'wbuf->offs' bytes of free+dirty space". This simplifies 'ubifs_rcvry_gc_commit()' a little. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: remove duplicated codeArtem Bityutskiy
We have duplicated code in 'ubifs_garbage_collect()' and 'ubifs_rcvry_gc_commit()', which is about handling the special case of free LEB. In both cases we just want to garbage-collect the LEB using 'ubifs_garbage_collect_leb()'. This patch teaches 'ubifs_garbage_collect_leb()' to handle free LEB's so that the caller does not have to do this and the duplicated code is removed. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-21UBIFS: fix master node recoveryArtem Bityutskiy
This patch fixes the following symptoms: 1. Unmount UBIFS cleanly. 2. Start mounting UBIFS R/W and have a power cut immediately 3. Start mounting UBIFS R/O, this succeeds 4. Try to re-mount UBIFS R/W - this fails immediately or later on, because UBIFS will write the master node to the flash area which has been written before. The analysis of the problem: 1. UBIFS is unmounted cleanly, both copies of the master node are clean. 2. UBIFS is being mounter R/W, starts changing master node copy 1, and a power cut happens. The copy N1 becomes corrupted. 3. UBIFS is being mounted R/O. It notices the copy N1 is corrupted and reads copy N2. Copy N2 is clean. 4. Because of R/O mode, UBIFS cannot recover copy 1. 5. The mount code (ubifs_mount()) sees that the master node is clean, so it decides that no recovery is needed. 6. We are re-mounting R/W. UBIFS believes no recovery is needed and starts updating the master node, but copy N1 is still corrupted and was not recovered! Fix this problem by marking the master node as dirty every time we recover it and we are in R/O mode. This forces further recovery and the UBIFS cleans-up the corruptions and recovers the copy N1 when re-mounting R/W later. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: stable@kernel.org
2011-03-08UBIFS: use max_write_size during recoveryArtem Bityutskiy
When recovering from unclean reboots UBIFS scans the journal and checks nodes. If a corrupted node is found, UBIFS tries to check if this is the last node in the LEB or not. This is is done by checking if there only 0xFF bytes starting from the next min. I/O unit. However, since now we write in c->max_write_size, we should actually check for 0xFFs starting from the next max. write unit. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-02-08UBIFS: fix LEB number in printkArtem Bityutskiy
This is a minor patch which fixes the LEB number we print when corrupted empty space is found. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-02-06UBIFS: describe UBIFS recovery logic some moreArtem Bityutskiy
This patch adds more commentaries about UBIFS recovery logic which should explain the famous UBIFS "corrupt empty space" errors. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-10-17UBIFS: add a commentary about log recoveryArtem Bityutskiy
Add a commentary which elaborates that 'ubifs_recover_log_leb()' recovers only the last log LEB, not any. Also remove some unneeded newlines. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-09-19UBIFS: introduce new flags for RO mountsArtem Bityutskiy
Commit 2fde99cb55fb9d9b88180512a5e8a5d939d27fec "UBIFS: mark VFS SB RO too" introduced regression. This commit made UBIFS set the 'MS_RDONLY' flag in the VFS superblock when it switches to R/O mode due to an error. This was done to make VFS show the R/O UBIFS flag in /proc/mounts. However, several places in UBIFS relied on the 'MS_RDONLY' flag and assume this flag can only change when we re-mount. For example, 'ubifs_put_super()'. This patch introduces new UBIFS flag - 'c->ro_mount' which changes only when we re-mount, and preserves the way UBIFS was originally mounted (R/W or R/O). This allows us to de-initialize UBIFS cleanly in 'ubifs_put_super()'. This patch also changes all 'ubifs_assert(!c->ro_media)' assertions to 'ubifs_assert(!c->ro_media && !c->ro_mount)', because we never should write anything if the FS was mounter R/O. All the places where we test for 'MS_RDONLY' flag in the VFS SB were changed and now we test the 'c->ro_mount' flag instead, because it preserves the original UBIFS mount type, unlike the 'MS_RDONLY' flag. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-07-13UBIFS: fix GC LEB recoveryArtem Bityutskiy
UBIFS tries to alway have an LEB reserved for GC, and stores it in c->gc_lnum. Besides, there is GC head which points to the current GC head LEB. In case of an unclean power cut, what may happen is that the GC head was switched to the reserved GC LEB (c->gc_lnum), but a new reserved GC LEB was not created yet. So, after an unclean reboot we may have no reserved GC LEB, and we need to find a new LEB for this. To do this, we find a dirty LEB which can fit the current GC head, move the data, unmap this dirty LEB, and it becomes our reserved GC LEB. However, if we cannot find a dirty enough LEB, we return failure, which is wrong, because we still can have free LEBs to use for the reserved GC LEB. This patch fixes the issue. This patch also fixes few typos in comments, which were spotted by aspell. Note, this patch fixes a real issue [ 14.328117] UBIFS: recovery needed [ 53.941378] UBIFS error (pid 462): ubifs_rcvry_gc_commit: could not find a dirty LEB [ 89.606399] UBIFS: recovery completed [ 89.609329] UBIFS assert failed in mount_ubifs at 1358 (pid 462) [ 89.616165] [<c0026144>] (unwind_backtrace+0x0/0xe4) from [<c0125ce4>] (ubifs_fill_super+0x11d0/0x1c4c) [ 89.625930] [<c0125ce4>] (ubifs_fill_super+0x11d0/0x1c4c) from [<c0126910>] (ubifs_get_sb+0x1b0/0x354) [ 89.635696] [<c0126910>] (ubifs_get_sb+0x1b0/0x354) from [<c008a50c>] (vfs_kern_mount+0x50/0xe0) [ 89.644485] [<c008a50c>] (vfs_kern_mount+0x50/0xe0) from [<c008a5e0>] (do_kern_mount+0x34/0xdc) [ 89.653274] [<c008a5e0>] (do_kern_mount+0x34/0xdc) from [<c00a29d8>] (do_mount+0x148/0x7cc) [ 89.662063] [<c00a29d8>] (do_mount+0x148/0x7cc) from [<c00a30f4>] (sys_mount+0x98/0xc8) [ 89.670852] [<c00a30f4>] (sys_mount+0x98/0xc8) from [<c0021f40>] (ret_fast_syscall+0x0/0x28) which was reported here: http://article.gmane.org/gmane.linux.drivers.mtd/29923 by Alexander Pazdnikov <pazdnikov@list.ru> Reported-by: Alexander Pazdnikov <pazdnikov@list.ru> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Adrian Hunter <adrian.hunter@nokia.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-10UBIFS: do not print scary error messages needlesslyArtem Bityutskiy
At the moment UBIFS print large and scary error messages and flash dumps in case of nearly any corruption, even if it is a recoverable corruption. For example, if the master node is corrupted, ubifs_scan() prints error dumps, then UBIFS recovers just fine and goes on. This patch makes UBIFS print scary error messages only in real cases, which are not recoverable. It adds 'quiet' argument to the 'ubifs_scan()' function, so the caller may ask 'ubi_scan()' not to print error messages if the caller is able to do recovery. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Adrian Hunter <Adrian.Hunter@nokia.com>
2009-07-09UBIFS: fix corruption dumpArtem Bityutskiy
In the 'ubifs_recover_leb()' function, when we find corrupted empty space, we dump 8K starting from the offset where the last node ends. This is OK if the corrupted empty space is somewhere near that offset. But if the corruption is far at the end of the LEB, we will dump all 0xFF bytes and complitely ignore the interesting data. This is observed on a PPC ("kilauea") with NOR flash. This patch changes the behavior and teaches UBIFS to print only interesting data. I.e., now we find where corruption starts and start dumping from that offset. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Adrian Hunter <Adrian.Hunter@nokia.com>
2009-07-09UBIFS: clean up free space checkingArtem Bityutskiy
recovery.c has 'is_empty()' helper and it is better to use this helper instead of re-implementing it in several places. This patch does this and removes some amount of unneeded code. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Adrian Hunter <Adrian.Hunter@nokia.com>
2009-07-09UBIFS: small amendments in the LEB scanning codeArtem Bityutskiy
This patch fixes few minor things I've spotted while going through code: 1. Better document return codes 2. If 'ubifs_scan_a_node()' returns some thing we do not expect, treat this as an error. 3. Try to do recovery only when 'ubifs_scan()' returns %-EUCLEAN, not on any error. 4. If empty space starts at a non-aligned address, print a message. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Adrian Hunter <Adrian.Hunter@nokia.com>
2009-05-29UBIFS: remove dead codeArtem Bityutskiy
UBIFS assumes that @c->min_io_size is 8 in case of NOR flash. This is because UBIFS alignes all nodes to 8-byte boundary, and maintaining @c->min_io_size introduced unnecessary complications. This patch removes senseless constructs like: if (c->min_io_size == 1) NOR-specific code Also, few commentaries amendments. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-03-31UBIFS: fix recovery bugAdrian Hunter
UBIFS did not recovery in a situation in which it could have. The relevant function assumed there could not be more nodes in an eraseblock after a corrupted node, but in fact the last (NAND) page written might contain anything. The correct approach is to check for empty space (0xFF bytes) from then on. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com>
