path: root/fs/sysfs
2012-01-24sysfs: Complain bitterly about attempts to remove files from nonexistent ↵Eric W. Biederman
directories. Recently an OOPS was observed from the usb serial io_ti driver when it tried to remove sysfs directories. Upon investigation it turns out this driver was always buggy and that a recent sysfs change had stopped guarding itself against removing attributes from sysfs directories that had already been removed. :( Historically we have been silent about attempting to files from nonexistent sysfs directories and have politely returned error codes. That has resulted in people writing broken code that ignores the error codes. Issue a kernel WARNING and a stack backtrace to make it clear in no uncertain terms that abusing sysfs is not ok, and the callers need to fix their code. This change transforms the io_ti OOPS into a more comprehensible error message and stack backtrace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Wolfgang Frisch <wfpub@roembden.net> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-03sysfs: propagate umode_tAl Viro
2012-01-03switch sysfs_chmod_file() to umode_tAl Viro
2012-01-03switch ->is_visible() to returning umode_tAl Viro
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-01sysfs: Make sysfs_rename safe with sysfs_dirents in rbtrees.Eric W. Biederman
In sysfs_rename we need to remove the optimization of not calling sysfs_unlink_sibling and sysfs_link_sibling if the renamed parent directory is not changing. This optimization is no longer valid now that sysfs dirents are stored in an rbtree sorted by name. Move the assignment of s_ns before the call of sysfs_link_sibling. With no sysfs_dirent fields changing after the call of sysfs_link_sibling this allows sysfs_link_sibling to take any of the directory entries into account when it builds the rbtrees, and s_ns looks like a prime canidate to be used in the rbtree in the future. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Greg KH <gregkh@suse.de> Cc: David Miller <davem@davemloft.net> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-25sysfs: Remove support for tagged directories with untagged members (again)Eric W. Biederman
In commit 8a9ea3237e7e ("Merge git://.../davem/net-next") where my sysfs changes from the net tree merged with the sysfs rbtree changes from Mickulas Patocka the conflict resolution failed to preserve the simplified property that was the point of my changes. That is sysfs_find_dirent can now say something is a match if and only s_name and s_ns match what we are looking for, and sysfs_readdir can simply return all of the directory entries where s_ns matches the directory that we should be returning. Now that we are back to exact matches we can tweak sysfs_find_dirent and the name rb_tree to order sysfs_dirents by s_ns s_name and remove the second loop in sysfs_find_dirent. However that change seems a bit much for a conflict resolution so it can come later. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-19sysfs: Reject with a warning invalid uses of tagged directories.Eric W. Biederman
sysfs is a core piece of ifrastructure that many people use and few people have all of the rules in their head on how to use it correctly. Add warnings for people using tagged directories improperly to that any misuses can be caught and diagnosed quickly. A single inexpensive test in sysfs_find_dirent is almost sufficient to catch all possible misuses. An additional warning is needed in sysfs_add_dirent so that we actually fail when attempting to add an untagged dirent in a tagged directory. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19sysfs: Remove support for tagged directories with untagged members.Eric W. Biederman
Now that /sys/class/net/bonding_masters is implemented as a tagged sysfs file we can remove support for untagged files in tagged directories. This change removes any ambiguity of what a NULL namespace value means. A NULL namespace parameter after this patch means that we are talking about an untagged sysfs dirent. This makes the sysfs code much less prone to mistakes when during maintenance. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19sysfs: Implement support for tagged files in sysfs.Eric W. Biederman
Looking up files in sysfs is hard to understand and analyize because we currently allow placing untagged files in tagged directories. In the implementation of that we have two subtly different meanings of NULL. NULL meaning there is no tag on a directory entry and NULL meaning we don't care which namespace the lookup is performed for. This multiple uses of NULL have resulted in subtle bugs (since fixed) in the code. Currently it is only the bonding driver that needs to have an untagged file in a tagged directory. To untagle this mess I am adding support for tagged files to sysfs. Modifying the bonding driver to implement bonding_masters as a tagged file. Registering bonding_masters once for each network namespace. Then I am removing support for untagged entries in tagged sysfs directories. Resulting in code that is much easier to reason about. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-26sysfs: add unsigned long cast to prevent compile warningHeiko Carstens
"sysfs: use rb-tree for inode number lookup" added a new printk which causes a new compile warning on s390 (and few other architectures): fs/sysfs/dir.c: In function 'sysfs_link_sibling': fs/sysfs/dir.c:63:4: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type 'ino_t' [-Wform Add an explicit unsigned long cast since ino_t is an unsigned long on most architectures. Cc: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22sysfs: use rb-tree for inode number lookupMikulas Patocka
sysfs: use rb-tree for inode number lookup This patch makes sysfs use red-black tree for inode number lookup. Together with a previous patch to use red-black tree for name lookup, this patch makes all sysfs lookups to have O(log n) complexity. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22sysfs: remove s_sibling hacksMikulas Patocka
sysfs: remove s_sibling hacks s_sibling was used for three different purposes: 1) as a linked list of entries in the directory 2) as a linked list of entries to be deleted 3) as a pointer to "struct completion" This patch removes the hack and introduces new union u which holds pointers for cases 2) and 3). This change is needed for the following patch that removes s_sibling at all and replaces it with a rb tree. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22sysfs: use rb-tree for name lookupsMikulas Patocka
sysfs: use rb-tree for name lookups Use red-black tree for name lookups. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22sysfs: count subdirectoriesMikulas Patocka
sysfs: count subdirectories This patch introduces a subdirectory counter for each sysfs directory. Without the patch, sysfs_refresh_inode would walk all entries of the directory to calculate the number of subdirectories. This patch improves time of "ls -la /sys/block" when there are 10000 block devices from 9 seconds to 0.19 seconds. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-12Delay struct net freeing while there's a sysfs instance refering to itAl Viro
* new refcount in struct net, controlling actual freeing of the memory * new method in kobj_ns_type_operations (->drop_ns()) * ->current_ns() semantics change - it's supposed to be followed by corresponding ->drop_ns(). For struct net in case of CONFIG_NET_NS it bumps the new refcount; net_drop_ns() decrements it and calls net_free() if the last reference has been dropped. Method renamed to ->grab_current_ns(). * old net_free() callers call net_drop_ns() instead. * sysfs_exit_ns() is gone, along with a large part of callchain leading to it; now that the references stored in ->ns[...] stay valid we do not need to hunt them down and replace them with NULL. That fixes problems in sysfs_lookup() and sysfs_readdir(), along with getting rid of sb->s_instances abuse. Note that struct net *shutdown* logics has not changed - net_cleanup() is called exactly when it used to be called. The only thing postponed by having a sysfs instance refering to that struct net is actual freeing of memory occupied by struct net. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-13sysfs: remove "last sysfs file:" line from the oops messagesGreg Kroah-Hartman
On some arches (x86, sh, arm, unicore, powerpc) the oops message would print out the last sysfs file accessed. This was very useful in finding a number of sysfs and driver core bugs in the 2.5 and early 2.6 development days, but it has been a number of years since this file has actually helped in debugging anything that couldn't also be trivially determined from the stack traceback. So it's time to delete the line. This is good as we need all the space we can get for oops messages at times on consoles. Acked-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-10SYSFS: Fix erroneous comments for sysfs_update_group().Robert P. J. Day
Fix what is clearly a simple copy-and-paste error in commenting the sysfs_update_group() routine. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-10Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: driver core: Document that device_rename() is only for networking sysfs: remove useless test from sysfs_merge_group driver-core: merge private parts of class and bus driver core: fix whitespace in class_attr_string
2011-01-10headers: kobject.h reduxAlexey Dobriyan
Remove kobject.h from files which don't need it, notably, sched.h and fs.h. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-11-29sysfs: remove useless test from sysfs_merge_groupAlan Stern
Dan Carpenter pointed out that the new sysfs_merge_group() and sysfs_unmerge_group() routines requires their grp argument to be non-NULL, because they dereference grp to obtain the list of attributes. Hence it's pointless for the routines to include a test and special-case handling for when grp is NULL. This patch (as1433) removes the unneeded tests. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-29convert sysfsAl Viro
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22sysfs: only access bin file vm_ops with the active lockEric W. Biederman
bb->vm_ops is a cached copy of the vm_ops of the underlying sysfs bin file, which means that after sysfs_bin_remove_file completes it is only longer valid to deference bb->vm_ops. So move all of the tests of bb->vm_ops inside of where we hold the sysfs active lock. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22sysfs: Fail bin file mmap if vma close is implemented.Eric W. Biederman
It is not reasonably possible to wrap vma->close(). To correctly wrap close would imply calling close on any vmas that remain when sysfs_remove_bin_file is called. Finding the proper lists walking them getting the locking right etc, requires deep knowledge of the mm subsystem and as such would require assistence from the mm subsystem to implement. That assistence does not currently exist. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-17sysfs: Add sysfs_merge_group() and sysfs_unmerge_group()Alan Stern
This patch (as1420) adds sysfs_merge_group() and sysfs_unmerge_group() functions, allowing drivers easily to add and remove sets of attributes to a pre-existing attribute group directory. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-09-03sysfs: checking for NULL instead of ERR_PTRDan Carpenter
d_path() returns an ERR_PTR and it doesn't return NULL. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: stable <stable@kernel.org> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09switch sysfs to ->evict_inode()Al Viro
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-05sysfs: sysfs_chmod_file's attr can be constJean Delvare
sysfs_chmod_file doesn't change the attribute it operates on, so this attribute can be marked const. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26sysfs: allow creating symlinks from untagged to tagged directoriesEric W. Biederman
Supporting symlinks from untagged to tagged directories is reasonable, and needed to support CONFIG_SYSFS_DEPRECATED. So don't fail a prior allowing that case to work. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26sysfs: sysfs_delete_link handle symlinks from untagged to tagged directories.Eric W. Biederman
This happens for network devices when SYSFS_DEPRECATED is enabled. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26sysfs: Don't allow the creation of symlinks we can't removeEric W. Biederman
Recently my tagged sysfs support revealed a flaw in the device core that a few rare drivers are running into such that we don't always put network devices in a class subdirectory named net/. Since we are not creating the class directory the network devices wind up in a non-tagged directory, but the symlinks to the network devices from /sys/class/net are in a tagged directory. All of which works until we go to remove or rename the symlink. When we remove or rename a symlink we look in the namespace of the target of the symlink. Since the target of the symlink is in a non-tagged sysfs directory we don't have a namespace to look in, and we fail to remove the symlink. Detect this problem up front and simply don't create symlinks we won't be able to remove later. This prevents symlink leakage and fails in a much clearer and more understandable way. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-04fix setattr error handling in sysfs, configfsNick Piggin
sysfs and configfs setattr functions have error cases after the generic inode's attributes have been changed. Fix consistency by changing the generic inode attributes only when it is guaranteed to succeed. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-27fs: convert simple fs to new truncateNick Piggin
Convert simple filesystems: ramfs, configfs, sysfs, block_dev to new truncate sequence. Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21sysfs: Remove usage of S_BIAS to avoid merge conflict with the vfs treeEric W. Biederman
In Al's latest vfs tree the code is reworked and S_BIAS has been removed. It turns out that checking to see if a super block is in the middle of an unmount in sysfs_exit_ns is unnecessary because we remove the super_block from the s_supers/s_instances list before struct sysfs_super_info pointed to by sb->s_fs_info is freed. For now just delete the unnecessary check to see if a superblock is in the middle of an unmount, it isn't necessary with or without Al's changes and it just causes a needless conflict. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21sysfs: Comment sysfs directory tagging logicSerge E. Hallyn
Add some in-line comments to explain the new infrastructure, which was introduced to support sysfs directory tagging with namespaces. I think an overall description someplace might be good too, but it didn't really seem to fit into Documentation/filesystems/sysfs.txt, which appears more geared toward users, rather than maintainers, of sysfs. (Tejun, please let me know if I can make anything clearer or failed altogether to comment something that should be commented.) Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21sysfs: Implement sysfs_delete_linkEric W. Biederman
When removing a symlink sysfs_remove_link does not provide enough information to figure out which tagged directory the symlink falls in. So I need sysfs_delete_link which is passed the target of the symlink to delete. sysfs_rename_link is updated to call sysfs_delete_link instead of sysfs_remove_link as we have all of the information necessary and the callers are interesting. Both of these functions now have enough information to find a symlink in a tagged directory. The only restriction is that they must be called before the target kobject is renamed or deleted. If they are called later I loose track of which tag the target kobject was marked with and can no longer find the old symlink to remove it. This patch was split from an earlier patch. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-21sysfs: Add support for tagged directories with untagged members.Eric W. Biederman
I had hopped to avoid this but the bonding driver adds a file to /sys/class/net/ and the easiest way to handle that file is to make it untagged and to register it only once. So relax the rules on tagged directories, and make bonding work. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
