path: root/fs/sysfs
2008-02-07sysfs: remove BUG_ON() from sysfs_remove_group()Greg Kroah-Hartman
It's possible that the caller of sysfs_remove_group messed up and passed in an attribute group that was not really registered to this kobject. But don't panic for such a foolish error, spit out a warning about what happened, and continue on our way safely. Cc: Roland Dreier <rdreier@cisco.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-24Driver Core: kill subsys_attribute and default sysfs opsKay Sievers
Remove the no longer needed subsys_attributes, they are all converted to the more sensical kobj_attributes. There is no longer a magic fallback in sysfs attribute operations, all kobjects which create simple attributes need explicitely a ktype assigned, which tells the core what was intended here. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24sysfs: remove SPIN_LOCK_UNLOCKEDJiri Slaby
SPIN_LOCK_UNLOCKED is deprecated, use DEFINE_SPINLOCK instead Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Tejun Heo <teheo@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24sysfs: create optimal relative symlink targetsKay Sievers
Instead of walking from the source down to the root of sysfs, and back to the target, we stop at the first directory the source and the target share. This link: /devices/pci0000:00/0000:00:1d.7/usb1/1-0:1.0/ep_81 pointed to: ../../../../../devices/pci0000:00/0000:00:1d.0/usb2/2-0:1.0/usb_endpoint/usbdev2.1_ep81 now it just points to: usb_endpoint/usbdev1.1_ep81 Thanks to Denis Cheng for bringing this up, and sending the initial patch. CC: Denis Cheng <crquan@gmail.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24sysfs: Fix a copy-n-paste typo in commentJean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-23[SCSI] sysfs: add filter function to groupsJames Bottomley
This patch allows the various users of attribute_groups to selectively allow the appearance of group attributes. The primary consumer of this will be the transport classes in which we currently have elaborate attribute selection algorithms to do this same thing. Acked-by: Greg KH <greg@kroah.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] sysfs: fix the sysfs_add_file_to_group interfacesJames Bottomley
I can't see a reason why these shouldn't work on every group. However, they only seem to work on named groups. This patch allows the group functions to work on anonymous groups (those with NULL names). Acked-by: Tejun Heo <htejun@gmail.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-16sysfs: fix bugs in sysfs_rename/move_dir()Tejun Heo
sysfs_rename/move_dir() have the following bugs. - On dentry lookup failure, kfree() is called on ERR_PTR() value. - sysfs_move_dir() has an extra dput() on success path. Fix them. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-16sysfs: make sysfs_lookup() return ERR_PTR(-ENOENT) on failed lookupTejun Heo
sysfs tries to keep dcache a strict subset of sysfs_dirent tree by shooting down dentries when a node is removed, that is, no negative dentry for sysfs. However, the lookup function returned NULL and thus created negative dentries when the target node didn't exist. Make sysfs_lookup() return ERR_PTR(-ENOENT) on lookup failure. This fixes the NULL dereference bug in sysfs_get_dentry() discovered by bluetooth rfcomm device moving around. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-28sysfs: fix off-by-one error in fill_read_buffer()Miao Xie
I found that there is a off-by-one problem in the following code. Version: 2.6.24-rc2 File: fs/sysfs/file.c:118-122 Function: fill_read_buffer -------------------------------------------------------------------- count = ops->show(kobj, attr_sd->s_attr.attr, buffer->page); sysfs_put_active_two(attr_sd); BUG_ON(count > (ssize_t)PAGE_SIZE); -------------------------------------------------------------------- Because according to the specification of the sysfs and the implement of the show methods, the show methods return the number of bytes which would be generated for the given input, excluding the trailing null.So if the return value of the show methods equals PAGE_SIZE - 1, the buffer is full in fact. And if the return value equals PAGE_SIZE, the resulting string was already truncated,or buffer overflow occurred. This patch fixes an off-by-one error in fill_read_buffer. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Tejun Heo <teheo@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-30sysfs: make sysfs_{get,put}_active() staticAdrian Bunk
sysfs_{get,put}_active() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-20sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistakeChris Malley
Spelling error in sysfs_create_file kerneldoc. Signed-off-by: Chris Malley <mail@chrismalley.co.uk> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17spin_lock_unlocked cleanupsRoel Kluin
Replace some SPIN_LOCK_UNLOCKED with DEFINE_SPINLOCK Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: bdi init hooksPeter Zijlstra
provide BDI constructor/destructor hooks [akpm@linux-foundation.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17partially fix up the lookup_one_noperm messChristoph Hellwig
Try to fix the mess created by sysfs braindamage. - refactor code internal to fs/namei.c a little to avoid too much duplication: o __lookup_hash_kern is renamed back to __lookup_hash o the old __lookup_hash goes away, permission checks moves to the two callers o useless inline qualifiers on above functions go away - lookup_one_len_kern loses it's last argument and is renamed to lookup_one_noperm to make it's useage a little more clear - added kerneldoc comments to describe lookup_one_len aswell as lookup_one_noperm and make it very clear that no one should use the latter ever. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16implement simple fs aopsNick Piggin
Implement new aops for some of the simpler filesystems. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12sysfs: add copyrightsTejun Heo
Sysfs has gone through considerable amount of reimplementation. Add copyrights. Any objections? :-) Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: move sysfs file poll implementation to sysfs_open_direntTejun Heo
Sysfs file poll implementation is scattered over sysfs and kobject. Event numbering is done in sysfs_dirent but wait itself is done on kobject. This not only unecessarily bloats both kobject and sysfs_dirent but is also buggy - if a sysfs_dirent is removed while there still are pollers, the associaton betwen the kobject and sysfs_dirent breaks and kobject may be freed with the pollers still sleeping on it. This patch moves whole poll implementation into sysfs_open_dirent. Each time a sysfs_open_dirent is created, event number restarts from 1 and pollers sleep on sysfs_open_dirent. As event sequence number is meaningless without any open file and pollers should have open file and thus sysfs_open_dirent, this ephemeral event counting works and is a saner implementation. This patch fixes the dnagling sleepers bug and reduces the sizes of kobject and sysfs_dirent by one pointer. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: implement sysfs_open_direntTejun Heo
Implement sysfs_open_dirent which represents an open file (attribute) sysfs_dirent. A file sysfs_dirent with one or more open files have one sysfs_dirent and all sysfs_buffers (one for each open instance) are linked to it. sysfs_open_dirent doesn't actually do anything yet but will be used to off-load things which are specific for open file sysfs_dirent from it. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: move sysfs_dirent->s_children into sysfs_dirent->s_dirTejun Heo
Children list head is only meaninful for directory nodes. Move it into s_dir. This doesn't save any space currently but it will with further changes. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: make sysfs_root a regular directory direntTejun Heo
sysfs_root is different from a regular directory dirent in that it's of type SYSFS_ROOT and doesn't have a name. These differences aren't used by anybody and only adds to complexity. Make sysfs_root a regular directory dirent. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: open code sysfs_attach_dentry()Tejun Heo
sysfs_attach_dentry() now has only one caller and isn't doing much other than obfuscating the code. Open code and kill it. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: make s_elem an anonymous unionTejun Heo
Make s_elem an anonymous union. Prefixing with s_elem makes things needlessly longer without any advantage. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: make bin attr open get active reference of parent tooTejun Heo
All bin attr operations require active references of itself and its parent. There's no reason to allow open when its parent has been deactivated and allowing it is inconsistent with regular sysfs file. Use sysfs_get_active_two() in bin attribute open function. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: kill unnecessary NULL pointer check in sysfs_release()Tejun Heo
In sysfs_release(), sysfs_buffer pointed to by filp->private_data is guaranteed to exist. Kill the unnecessary NULL check. This also makes the code more consistent with the counterpart in fs/sysfs/bin.c. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: kill unnecessary sysfs_get() in open pathsTejun Heo
There's no reason to get an extra reference to sysfs_dirent for an open file. Open file has a reference to the dentry which in turn has a reference to sysfs_dirent. This is fairly obvious as otherwise open itself won't be able to access the sysfs_dirent. Kill the extra sysfs_get() and matching sysfs_put(). Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: reposition sysfs_dirent->s_mode.Tejun Heo
Move s_mode downward such that it's side-by-side with s_iattr which is used for the same thing. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: kill sysfs_update_file()Tejun Heo
sysfs_update_file() depends on inode->i_mtime but sysfs iondes are now reclaimable making the reported modification time unreliable. There's only one user (pci hotplug) of this notification mechanism and it reportedly isn't utilized from userland. Kill sysfs_update_file(). Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: clean up header filesTejun Heo
sysfs is about to go through major overhaul making this a pretty good opportunity to clean up (out-of-tree changes and pending patches will need regeneration anyway). Clean up headers. * Kill space between * and symbolname. * Move SYSFS_* type constants and flags into fs/sysfs/sysfs.h. They're internal to sysfs. * Reformat function prototypes and add argument symbol names. * Make dummy function definition order match that of function prototypes. * Add some comments. * Reorganize fs/sysfs/sysfs.h according to which file the declared variable or feature lives in. This patch does not introduce any behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: fix sysfs_chmod_file() such that it updates sd->s_mode tooTejun Heo
sysfs_chmod_file() looked and updated only inode of the target file. Dentry and inode are reclaimable and the update mode data will go away when the inode is reclaimed. This patch makes sysfs_chmod_file() update sd->s_mode too such that the change is permanent. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: fix comments of sysfs_add/remove_one()Tejun Heo
sysfs_add/remove_one() now link and unlink the target dirent into and from the children list. Update comments accordingly. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: spit a warning to users when they try to create a duplicate sysfs fileGreg Kroah-Hartman
We want to let people know when we create a duplicate sysfs file, as they need to fix up their code. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Rewrite sysfs_move_dir in terms of sysfs direntsEric W. Biederman
This patch rewrites sysfs_move_dir to perform it's checks as much as possible on the underlying sysfs_dirents instead of the contents of the dcache, making sysfs_move_dir more like the rest of the sysfs directory modification code. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Rewrite rename in terms of sysfs direntsEric W. Biederman
This patch rewrites sysfs_rename_dir to perform it's checks as much as possible on the underlying sysfs_dirents instead of the contents of the dcache. It turns out that this version is a little simpler, and a little more like the rest of the sysfs directory modification code. tj: fixed double locking of sysfs_mutex Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Remove s_dentryEric W. Biederman
The only uses of s_dentry left are the code that maintains s_dentry and trivial users that don't actually need it. So this patch removes the s_dentry maintenance code and restructures the trivial uses to use something else. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: simply sysfs_get_dentryTejun Heo
Now that we know the sysfs tree structure cannot change under us and sysfs shadow support is dropped, sysfs_get_dentry() can be simplified greatly. It can just look up from the root and there's no need to retry on failure. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Introduce sysfs_rename_mutexEric W. Biederman
Looking carefully at the rename code we have a subtle dependency that the structure of sysfs not change while we are performing a rename. If the parent directory of the object we are renaming changes while the rename is being performed nasty things could happen when we go to release our locks. So introduce a sysfs_rename_mutex to prevent this highly unlikely theoretical issue. In addition hold sysfs_rename_mutex over all calls to sysfs_get_dentry. Allowing sysfs_get_dentry to be simplified in the future. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Rewrite sysfs_drop_dentry.Eric W. Biederman
Currently we find the dentry to drop by looking at sd->s_dentry. We can just as easily accomplish the same task by looking up the sysfs inode and finding all of the dentries from there, with the added bonus that we don't need to play with the sysfs_assoc_lock. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Simplify readdir.Eric W. Biederman
At some point someone wrote sysfs_readdir to insert a cursor into the list of sysfs_dirents to ensure that sysfs_readdir would restart properly. That works but it is complex code and tends to be expensive. The same effect can be achieved by keeping the sysfs_dirents in inode order and using the inode number as the f_pos. Then when we restart we just have to find the first dirent whose inode number is equal or greater then the last sysfs_dirent we attempted to return. Removing the sysfs directory cursor also allows the remove of all of the mysterious checks for sysfs_type(sd) != 0. Which were nonbovious checks to see if a cursor was in a directory list. tj: offset marker for EOF is changed from UINT_MAX to INT_MAX to avoid overflow in case offset is 32bit. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: In sysfs_lookup don't open code sysfs_find_direntEric W. Biederman
This is a small cleanup patch that makes the code just a little bit cleaner. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Make sysfs_mount staticEric W. Biederman
This patch modifies the users of sysfs_mount to use sysfs_root instead (which is what they are looking for). It then makes sysfs_mount static to keep people from using it by accident. The net result is slightly faster and cleaner code. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Use kill_anon_superEric W. Biederman
Since sysfs no longer stores fs directory information in the dcache on a permanent basis kill_litter_super it is inappropriate and actively wrong. It will decrement the count on all dentries left in the dcache before trying to free them. At the moment this is not biting us only because we never unmount sysfs. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Remove sysfs_instantiateEric W. Biederman
Now that sysfs_get_inode is dropping the inode lock we no longer have a need from sysfs_instantiate. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Move all of inode initialization into sysfs_init_inodeEric W. Biederman
Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: fix i_mutex locking in sysfs_get_dentry()Tejun Heo
lookup_one_len_kern() should be called with the parent's i_mutex locked. Fix it. Spotted by Eric W. Biederman. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: Fix typos in fs/sysfs/file.cRolf Eike Beer
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: make sysfs_addrm_finish() return voidTejun Heo
With the previous sysfs_add_one() update, there is only one user of the return value of sysfs_addrm_finish() and the user can switch to testing @sd easily. Make sysfs_addrm_finish() return void for cleaner semantics as suggested by Satyam Sharma. This patch doesn't introduce any noticeable behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Satyam Sharma <satyam.sharma@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysfs: make sysfs_add_one() automatically check for duplicate entryTejun Heo
Make sysfs_add_one() check for duplicate entry and return -EEXIST if such entry exists. This simplifies node addition code a bit. This patch doesn't introduce any noticeable behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
