smbfs has been scheduled for removal in 2.6.27, so
maybe we can now move it to drivers/staging on the
way out.
smbfs still uses the big kernel lock and nobody
is going to fix that, so we should be getting
rid of it soon.
This removes the 32 bit compat mount and ioctl
handling code, which is implemented in common fs
code, and moves all smbfs related files into
drivers/staging/smbfs.
Acked-by: Jeff Layton <jlayton@redhat.com>
Remove duplicated #include('s) in fs/smbfs/symlink.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Data allocated with "__getname()" should always be free'd with "__putname()"
because of the AUDITSYSCALL code.
Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com>
Cc: Urban Widmark <urban@teststation.com>
This fixes up the symlink functions for the calling convention change:
* afs, autofs4, befs, devfs, freevxfs, jffs2, jfs, ncpfs, procfs,
smbfs, sysvfs, ufs, xfs - prototype change for ->follow_link()
* befs, smbfs, xfs - same for ->put_link()
infrastructure for it.
Let it rip!
