path: root/fs/reiserfs
2016-09-16reiserfs: Unlock superblock before calling reiserfs_quota_on_mount()Mike Galbraith
If we hold the superblock lock while calling reiserfs_quota_on_mount(), we can deadlock our own worker - mount blocks kworker/3:2, sleeps forever more. crash> ps|grep UN 715 2 3 ffff880220734d30 UN 0.0 0 0 [kworker/3:2] 9369 9341 2 ffff88021ffb7560 UN 1.3 493404 123184 Xorg 9665 9664 3 ffff880225b92ab0 UN 0.0 47368 812 udisks-daemon 10635 10403 3 ffff880222f22c70 UN 0.0 14904 936 mount crash> bt ffff880220734d30 PID: 715 TASK: ffff880220734d30 CPU: 3 COMMAND: "kworker/3:2" #0 [ffff8802244c3c20] schedule at ffffffff8144584b #1 [ffff8802244c3cc8] __rt_mutex_slowlock at ffffffff814472b3 #2 [ffff8802244c3d28] rt_mutex_slowlock at ffffffff814473f5 #3 [ffff8802244c3dc8] reiserfs_write_lock at ffffffffa05f28fd [reiserfs] #4 [ffff8802244c3de8] flush_async_commits at ffffffffa05ec91d [reiserfs] #5 [ffff8802244c3e08] process_one_work at ffffffff81073726 #6 [ffff8802244c3e68] worker_thread at ffffffff81073eba #7 [ffff8802244c3ec8] kthread at ffffffff810782e0 #8 [ffff8802244c3f48] kernel_thread_helper at ffffffff81450064 crash> rd ffff8802244c3cc8 10 ffff8802244c3cc8: ffffffff814472b3 ffff880222f23250 .rD.....P2.".... ffff8802244c3cd8: 0000000000000000 0000000000000286 ................ ffff8802244c3ce8: ffff8802244c3d30 ffff880220734d80 0=L$.....Ms .... ffff8802244c3cf8: ffff880222e8f628 0000000000000000 (.."............ ffff8802244c3d08: 0000000000000000 0000000000000002 ................ crash> struct rt_mutex ffff880222e8f628 struct rt_mutex { wait_lock = { raw_lock = { slock = 65537 } }, wait_list = { node_list = { next = 0xffff8802244c3d48, prev = 0xffff8802244c3d48 } }, owner = 0xffff880222f22c71, save_state = 0 } crash> bt 0xffff880222f22c70 PID: 10635 TASK: ffff880222f22c70 CPU: 3 COMMAND: "mount" #0 [ffff8802216a9868] schedule at ffffffff8144584b #1 [ffff8802216a9910] schedule_timeout at ffffffff81446865 #2 [ffff8802216a99a0] wait_for_common at ffffffff81445f74 #3 [ffff8802216a9a30] flush_work at ffffffff810712d3 #4 [ffff8802216a9ab0] schedule_on_each_cpu at ffffffff81074463 #5 [ffff8802216a9ae0] invalidate_bdev at ffffffff81178aba #6 [ffff8802216a9af0] vfs_load_quota_inode at ffffffff811a3632 #7 [ffff8802216a9b50] dquot_quota_on_mount at ffffffff811a375c #8 [ffff8802216a9b80] finish_unfinished at ffffffffa05dd8b0 [reiserfs] #9 [ffff8802216a9cc0] reiserfs_fill_super at ffffffffa05de825 [reiserfs] RIP: 00007f7b9303997a RSP: 00007ffff443c7a8 RFLAGS: 00010202 RAX: 00000000000000a5 RBX: ffffffff8144ef12 RCX: 00007f7b932e9ee0 RDX: 00007f7b93d9a400 RSI: 00007f7b93d9a3e0 RDI: 00007f7b93d9a3c0 RBP: 00007f7b93d9a2c0 R8: 00007f7b93d9a550 R9: 0000000000000001 R10: ffffffffc0ed040e R11: 0000000000000202 R12: 000000000000040e R13: 0000000000000000 R14: 00000000c0ed040e R15: 00007ffff443ca20 ORIG_RAX: 00000000000000a5 CS: 0033 SS: 002b Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mike Galbraith <mgalbraith@suse.de> Cc: <stable@vger.kernel.org> Signed-off-by: Jan Kara <jack@suse.cz>
2016-08-02reiserfs: fix "new_insert_key may be used uninitialized ..."Jeff Mahoney
new_insert_key only makes any sense when it's associated with a new_insert_ptr, which is initialized to NULL and changed to a buffer_head when we also initialize new_insert_key. We can key off of that to avoid the uninitialized warning. Link: http://lkml.kernel.org/r/5eca5ffb-2155-8df2-b4a2-f162f105efed@suse.com Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jan Kara <jack@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26Merge branch 'for-4.8/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "This branch also contains core changes. I've come to the conclusion that from 4.9 and forward, I'll be doing just a single branch. We often have dependencies between core and drivers, and it's hard to always split them up appropriately without pulling core into drivers when that happens. That said, this contains: - separate secure erase type for the core block layer, from Christoph. - set of discard fixes, from Christoph. - bio shrinking fixes from Christoph, as a followup up to the op/flags change in the core branch. - map and append request fixes from Christoph. - NVMeF (NVMe over Fabrics) code from Christoph. This is pretty exciting! - nvme-loop fixes from Arnd. - removal of ->driverfs_dev from Dan, after providing a device_add_disk() helper. - bcache fixes from Bhaktipriya and Yijing. - cdrom subchannel read fix from Vchannaiah. - set of lightnvm updates from Wenwei, Matias, Johannes, and Javier. - set of drbd updates and fixes from Fabian, Lars, and Philipp. - mg_disk error path fix from Bart. - user notification for failed device add for loop, from Minfei. - NVMe in general: + NVMe delay quirk from Guilherme. + SR-IOV support and command retry limits from Keith. + fix for memory-less NUMA node from Masayoshi. + use UINT_MAX for discard sectors, from Minfei. + cancel IO fixes from Ming. + don't allocate unused major, from Neil. + error code fixup from Dan. + use constants for PSDT/FUSE from James. + variable init fix from Jay. + fabrics fixes from Ming, Sagi, and Wei. + various fixes" * 'for-4.8/drivers' of git://git.kernel.dk/linux-block: (115 commits) nvme/pci: Provide SR-IOV support nvme: initialize variable before logical OR'ing it block: unexport various bio mapping helpers scsi/osd: open code blk_make_request target: stop using blk_make_request block: simplify and export blk_rq_append_bio block: ensure bios return from blk_get_request are properly initialized virtio_blk: use blk_rq_map_kern memstick: don't allow REQ_TYPE_BLOCK_PC requests block: shrink bio size again block: simplify and cleanup bvec pool handling block: get rid of bio_rw and READA block: don't ignore -EOPNOTSUPP blkdev_issue_write_same block: introduce BLKDEV_DISCARD_ZERO to fix zeroout NVMe: don't allocate unused nvme_major nvme: avoid crashes when node 0 is memoryless node. nvme: Limit command retries loop: Make user notify for adding loop device failed nvme-loop: fix nvme-loop Kconfig dependencies nvmet: fix return value check in nvmet_subsys_alloc() ...
2016-07-26Merge branch 'for-4.8/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block updates from Jens Axboe: - the big change is the cleanup from Mike Christie, cleaning up our uses of command types and modified flags. This is what will throw some merge conflicts - regression fix for the above for btrfs, from Vincent - following up to the above, better packing of struct request from Christoph - a 2038 fix for blktrace from Arnd - a few trivial/spelling fixes from Bart Van Assche - a front merge check fix from Damien, which could cause issues on SMR drives - Atari partition fix from Gabriel - convert cfq to highres timers, since jiffies isn't granular enough for some devices these days. From Jan and Jeff - CFQ priority boost fix idle classes, from me - cleanup series from Ming, improving our bio/bvec iteration - a direct issue fix for blk-mq from Omar - fix for plug merging not involving the IO scheduler, like we do for other types of merges. From Tahsin - expose DAX type internally and through sysfs. From Toshi and Yigal * 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits) block: Fix front merge check block: do not merge requests without consulting with io scheduler block: Fix spelling in a source code comment block: expose QUEUE_FLAG_DAX in sysfs block: add QUEUE_FLAG_DAX for devices to advertise their DAX support Btrfs: fix comparison in __btrfs_map_block() block: atari: Return early for unsupported sector size Doc: block: Fix a typo in queue-sysfs.txt cfq-iosched: Charge at least 1 jiffie instead of 1 ns cfq-iosched: Fix regression in bonnie++ rewrite performance cfq-iosched: Convert slice_resid from u64 to s64 block: Convert fifo_time from ulong to u64 blktrace: avoid using timespec block/blk-cgroup.c: Declare local symbols static block/bio-integrity.c: Add #include "blk.h" block/partition-generic.c: Remove a set-but-not-used variable block: bio: kill BIO_MAX_SIZE cfq-iosched: temporarily boost queue priority for idle classes block: drbd: avoid to use BIO_MAX_SIZE block: bio: remove BIO_MAX_SECTORS ...
2016-07-20block: get rid of bio_rw and READAChristoph Hellwig
These two are confusing leftover of the old world order, combining values of the REQ_OP_ and REQ_ namespaces. For callers that don't special case we mostly just replace bi_rw with bio_data_dir or op_is_write, except for the few cases where a switch over the REQ_OP_ values makes more sense. Any check for READA is replaced with an explicit check for REQ_RAHEAD. Also remove the READA alias for REQ_RAHEAD. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-19Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull UDF fixes and a reiserfs fix from Jan Kara: "A couple of udf fixes (most notably a bug in parsing UDF partitions which led to inability to mount recent Windows installation media) and a reiserfs fix for handling kstrdup failure" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: reiserfs: check kstrdup failure udf: Use correct partition reference number for metadata udf: Use IS_ERR when loading metadata mirror file entry udf: Don't BUG on missing metadata partition descriptor
2016-06-07fs: have ll_rw_block users pass in op and flags separatelyMike Christie
This has ll_rw_block users pass in the operation and flags separately, so ll_rw_block can setup the bio op and bi_rw flags on the bio that is submitted. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-07fs: have submit_bh users pass in op and flags separatelyMike Christie
This has submit_bh users pass in the operation and flags separately, so submit_bh_wbc can setup the bio op and bi_rw flags on the bio that is submitted. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-27switch xattr_handler->set() to passing dentry and inode separatelyAl Viro
preparation for similar switch in ->setxattr() (see the next commit for rationale). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-25reiserfs: check kstrdup failureMikulas Patocka
Check out-of-memory failure of the kstrdup option. Note that the argument "arg" may be NULL (in that case kstrup returns NULL), so out of memory condition happened if arg was non-NULL and kstrdup returned NULL. The patch also changes the call to replace_mount_options - if we didn't pass any filesystem-specific options, we don't call replace_mount_options (thus we don't erase existing reported options). Note that to properly report options after remount, the reiserfs filesystem should implement the show_options method. Without the show_options method, options changed with remount replace existing options. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-05-20lib/uuid.c: move generate_random_uuid() to uuid.cAndy Shevchenko
Let's gather the UUID related functions under one hood. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-17Merge branch 'work.preadv2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs cleanups from Al Viro: "More cleanups from Christoph" * 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: use RWF_SYNC fs: add RWF_DSYNC aand RWF_SYNC ceph: use generic_write_sync fs: simplify the generic_write_sync prototype fs: add IOCB_SYNC and IOCB_DSYNC direct-io: remove the offset argument to dio_complete direct-io: eliminate the offset argument to ->direct_IO xfs: eliminate the pos variable in xfs_file_dio_aio_write filemap: remove the pos argument to generic_file_direct_write filemap: remove pos variables in generic_file_read_iter
2016-05-09more trivial ->iterate_shared conversionsAl Viro
2016-05-02reiserfs: open-code reiserfs_mutex_lock_safe() in reiserfs_unpack()Al Viro
... and have it use inode_lock() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02Merge getxattr prototype change into work.lookupsAl Viro
The rest of work.xattr stuff isn't needed for this branch
2016-05-01direct-io: eliminate the offset argument to ->direct_IOChristoph Hellwig
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually work, so eliminate the superflous argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-10xattr_handler: pass dentry and inode as separate arguments of ->get()Al Viro
... and do not assume they are already attached to each other Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-10reiserfs: switch to generic_{get,set,remove}xattr()Al Viro
reiserfs_xattr_[sg]et() will fail with -EOPNOTSUPP for V1 inodes anyway, and all reiserfs instances of ->[sg]et() call it and so does ->set_acl(). Checks for name length in the instances had been bogus; they should've been "bugger off if it's _exactly_ the prefix" (as generic would do on its own) and not "bugger off if it's shorter than the prefix" - that can't happen. xattr_full_name() is needed to adjust for the fact that generic instances will skip the prefix in the name passed to ->[gs]et(); reiserfs homegrown analogues didn't. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: remove remaining PAGE_CACHE_* and page_cache_{get,release} usageKirill A. Shutemov
Mostly direct substitution with occasional adjustment or removing outdated comments. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-31posix_acl: Inode acl caching fixesAndreas Gruenbacher
When get_acl() is called for an inode whose ACL is not cached yet, the get_acl inode operation is called to fetch the ACL from the filesystem. The inode operation is responsible for updating the cached acl with set_cached_acl(). This is done without locking at the VFS level, so another task can call set_cached_acl() or forget_cached_acl() before the get_acl inode operation gets to calling set_cached_acl(), and then get_acl's call to set_cached_acl() results in caching an outdate ACL. Prevent this from happening by setting the cached ACL pointer to a task-specific sentinel value before calling the get_acl inode operation. Move the responsibility for updating the cached ACL from the get_acl inode operations to get_acl(). There, only set the cached ACL if the sentinel value hasn't changed. The sentinel values are chosen to have odd values. Likewise, the value of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have an even value (ACLs are aligned in memory). This allows to distinguish uncached ACLs values from ACL objects. In addition, switch from guarding inode->i_acl and inode->i_default_acl upates by the inode->i_lock spinlock to using xchg() and cmpxchg(). Filesystems that do not want ACLs returned from their get_acl inode operations to be cached must call forget_cached_acl() to prevent the VFS from doing so. (Patch written by Al Viro and Andreas Gruenbacher.) Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-03-28reiserfs_cache_default_acl(): use get_acl()Al Viro
2016-02-09quota: Add support for ->get_nextdqblk() for VFS quotaJan Kara
Add infrastructure for supporting get_nextdqblk() callback for VFS quotas. Translate the operation into a callback to appropriate filesystem and consequently to quota format callback. Signed-off-by: Jan Kara <jack@suse.cz>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-21reiserfs: fix dereference of ERR_PTRSudip Mukherjee
reiserfs_iget() returns either NULL or error code in ERR_PTR. And we were only checking for NULL, so in case of some other error we will try to dereference the ERR_PTR(-errno) thinking it to be a valid pointer. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-12Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "All kinds of stuff. That probably should've been 5 or 6 separate branches, but by the time I'd realized how large and mixed that bag had become it had been too close to -final to play with rebasing. Some fs/namei.c cleanups there, memdup_user_nul() introduction and switching open-coded instances, burying long-dead code, whack-a-mole of various kinds, several new helpers for ->llseek(), assorted cleanups and fixes from various people, etc. One piece probably deserves special mention - Neil's lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets called without ->i_mutex and tries to avoid ever taking it. That, of course, means that it's not useful for any directory modifications, but things like getting inode attributes in nfds readdirplus are fine with that. I really should've asked for moratorium on lookup-related changes this cycle, but since I hadn't done that early enough... I *am* asking for that for the coming cycle, though - I'm going to try and get conversion of i_mutex to rwsem with ->lookup() done under lock taken shared. There will be a patch closer to the end of the window, along the lines of the one Linus had posted last May - mechanical conversion of ->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/ inode_is_locked()/inode_lock_nested(). To quote Linus back then: ----- | This is an automated patch using | | sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/' | sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/' | sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/' | sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/' | sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/' | | with a very few manual fixups ----- I'm going to send that once the ->i_mutex-affecting stuff in -next gets mostly merged (or when Linus says he's about to stop taking merges)" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) nfsd: don't hold i_mutex over userspace upcalls fs:affs:Replace time_t with time64_t fs/9p: use fscache mutex rather than spinlock proc: add a reschedule point in proc_readfd_common() logfs: constify logfs_block_ops structures fcntl: allow to set O_DIRECT flag on pipe fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE fs: xattr: Use kvfree() [s390] page_to_phys() always returns a multiple of PAGE_SIZE nbd: use ->compat_ioctl() fs: use block_device name vsprintf helper lib/vsprintf: add %*pg format specifier fs: use gendisk->disk_name where possible poll: plug an unused argument to do_poll amdkfd: don't open-code memdup_user() cdrom: don't open-code memdup_user() rsxx: don't open-code memdup_user() mtip32xx: don't open-code memdup_user() [um] mconsole: don't open-code memdup_user_nul() [um] hostaudio: don't open-code memdup_user() ...
2016-01-11Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "Andreas' xattr cleanup series. It's a followup to his xattr work that went in last cycle; -0.5KLoC" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: xattr handlers: Simplify list operation ocfs2: Replace list xattr handler operations nfs: Move call to security_inode_listsecurity into nfs_listxattr xfs: Change how listxattr generates synthetic attributes tmpfs: listxattr should include POSIX ACL xattrs tmpfs: Use xattr handler infrastructure btrfs: Use xattr handler infrastructure vfs: Distinguish between full xattr names and proper prefixes posix acls: Remove duplicate xattr name definitions gfs2: Remove gfs2_xattr_acl_chmod vfs: Remove vfs_xattr_cmp
2016-01-06fs: use block_device name vsprintf helperDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-30switch ->get_link() to delayed_call, kill ->put_link()Al Viro
2015-12-13xattr handlers: Simplify list operationAndreas Gruenbacher
Change the list operation to only return whether or not an attribute should be listed. Copying the attribute names into the buffer is moved to the callers. Since the result only depends on the dentry and not on the attribute name, we do not pass the attribute name to list operations. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06vfs: Distinguish between full xattr names and proper prefixesAndreas Gruenbacher
Add an additional "name" field to struct xattr_handler. When the name is set, the handler matches attributes with exactly that name. When the prefix is set instead, the handler matches attributes with the given prefix and with a non-empty suffix. This patch should avoid bugs like the one fixed in commit c361016a in the future. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06posix acls: Remove duplicate xattr name definitionsAndreas Gruenbacher
Remove POSIX_ACL_XATTR_{ACCESS,DEFAULT} and GFS2_POSIX_ACL_{ACCESS,DEFAULT} and replace them with the definitions in <include/uapi/linux/xattr.h>. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-13Merge branch 'for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr cleanups from Al Viro. * 'for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: f2fs: xattr simplifications squashfs: xattr simplifications 9p: xattr simplifications xattr handlers: Pass handler to operations instead of flags jffs2: Add missing capability check for listing trusted xattrs hfsplus: Remove unused xattr handler list operations ubifs: Remove unused security xattr handler vfs: Fix the posix_acl_xattr_list return value vfs: Check attribute names in posix acl xattr handers
2015-11-13xattr handlers: Pass handler to operations instead of flagsAndreas Gruenbacher
The xattr_handler operations are currently all passed a file system specific flags value which the operations can use to disambiguate between different handlers; some file systems use that to distinguish the xattr namespace, for example. In some oprations, it would be useful to also have access to the handler prefix. To allow that, pass a pointer to the handler to operations instead of the flags value alone. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-09fs/reiserfs/namei.c: remove unnecessary new_valid_dev() checkYaowei Bai
new_valid_dev() always returns 1, so the !new_valid_dev() check is not needed. Remove it. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04fs: create and use seq_show_option for escapingKees Cook
Many file systems that implement the show_options hook fail to correctly escape their output which could lead to unescaped characters (e.g. new lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This could lead to confusion, spoofed entries (resulting in things like systemd issuing false d-bus "mount" notifications), and who knows what else. This looks like it would only be the root user stepping on themselves, but it's possible weird things could happen in containers or in other situations with delegated mount privileges. Here's an example using overlay with setuid fusermount trusting the contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use of "sudo" is something more sneaky: $ BASE="ovl" $ MNT="$BASE/mnt" $ LOW="$BASE/lower" $ UP="$BASE/upper" $ WORK="$BASE/work/ 0 0 none /proc fuse.pwn user_id=1000" $ mkdir -p "$LOW" "$UP" "$WORK" $ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt $ cat /proc/mounts none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0 none /proc fuse.pwn user_id=1000 0 0 $ fusermount -u /proc $ cat /proc/mounts cat: /proc/mounts: No such file or directory This fixes the problem by adding new seq_show_option and seq_show_option_n helpers, and updating the vulnerable show_option handlers to use them as needed. Some, like SELinux, need to be open coded due to unusual existing escape mechanisms. [akpm@linux-foundation.org: add lost chunk, per Kees] [keescook@chromium.org: seq_show_option should be using const parameters] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: J. R. Okajima <hooanon05g@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-23reiserfs: Handle error from dquot_initialize()Jan Kara
dquot_initialize() can now return error. Handle it where possible. Signed-off-by: Jan Kara <jack@suse.com>
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25fs/reiserfs: remove unneeded castFiro Yang
kmem_cache_alloc() returns void*. Signed-off-by: Firo Yang <firogm@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-02writeback: separate out include/linux/backing-dev-defs.hTejun Heo
With the planned cgroup writeback support, backing-dev related declarations will be more widely used across block and cgroup; unfortunately, including backing-dev.h from include/linux/blkdev.h makes cyclic include dependency quite likely. This patch separates out backing-dev-defs.h which only has the essential definitions and updates blkdev.h to include it. c files which need access to more backing-dev details now include backing-dev.h directly. This takes backing-dev.h off the common include dependency chain making it a lot easier to use it across block and cgroup. v2: fs/fat build failure fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third hunk of vfs changes from Al Viro: "This contains the ->direct_IO() changes from Omar + saner generic_write_checks() + dealing with fcntl()/{read,write}() races (mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of repeatedly looking at ->f_flags, which can be changed by fcntl(2), check ->ki_flags - which cannot) + infrastructure bits for dhowells' d_inode annotations + Christophs switch of /dev/loop to vfs_iter_write()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits) block: loop: switch to VFS ITER_BVEC configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode VFS: Make pathwalk use d_is_reg() rather than S_ISREG() VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR() VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk NFS: Don't use d_inode as a variable name VFS: Impose ordering on accesses of d_inode and d_flags VFS: Add owner-filesystem positive/negative dentry checks nfs: generic_write_checks() shouldn't be done on swapout... ocfs2: use __generic_file_write_iter() mirror O_APPEND and O_DIRECT into iocb->ki_flags switch generic_write_checks() to iocb and iter ocfs2: move generic_write_checks() before the alignment checks ocfs2_file_write_iter: stop messing with ppos udf_file_write_iter: reorder and simplify fuse: ->direct_IO() doesn't need generic_write_checks() ext4_file_write_iter: move generic_write_checks() up xfs_file_aio_write_checks: switch to iocb/iov_iter generic_write_checks(): drop isblk argument blkdev_write_iter: expand generic_file_checks() call in there ...
2015-04-16Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull quota and udf updates from Jan Kara: "The pull contains quota changes which complete unification of XFS and VFS quota interfaces (so tools can use either interface to manipulate any filesystem). There's also a patch to support project quotas in VFS quota subsystem from Li Xi. Finally there's a bunch of UDF fixes and cleanups and tiny cleanup in reiserfs & ext3" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: (21 commits) udf: Update ctime and mtime when directory is modified udf: return correct errno for udf_update_inode() ext3: Remove useless condition in if statement. vfs: Add general support to enforce project quota limits reiserfs: fix __RASSERT format string udf: use int for allocated blocks instead of sector_t udf: remove redundant buffer_head.h includes udf: remove else after return in __load_block_bitmap() udf: remove unused variable in udf_table_free_blocks() quota: Fix maximum quota limit settings quota: reorder flags in quota state quota: paranoia: check quota tree root quota: optimize i_dquot access quota: Hook up Q_XSETQLIM for id 0 to ->set_info xfs: Add support for Q_SETINFO quota: Make ->set_info use structure with neccesary info to VFS and XFS quota: Remove ->get_xstate and ->get_xstatev callbacks gfs2: Convert to using ->get_state callback xfs: Convert to using ->get_state callback quota: Wire up Q_GETXSTATE and Q_GETXSTATV calls to work with ->get_state ...
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Remove rw from {,__,do_}blockdev_direct_IO()Omar Sandoval
Most filesystems call through to these at some point, so we'll start here. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
