path: root/fs/reiserfs
2009-05-09Fix races around the access to ->s_optionsAl Viro
Put generic_show_options read access to s_options under rcu_read_lock, split save_mount_options() into "we are setting it the first time" (uses in foo_fill_super()) and "we are relacing and freeing the old one", synchronize_rcu() before kfree() in the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: remove privroot hiding in lookupJeff Mahoney
With Al Viro's patch to move privroot lookup to fs mount, there's no need to have special code to hide the privroot in reiserfs_lookup. I've also cleaned up the privroot hiding in reiserfs_readdir_dentry and removed the last user of reiserfs_xattrs(). Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: dont associate security.* with xattr filesJeff Mahoney
The security.* xattrs are ignored for xattr files, so don't create them. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: fixup xattr_root cachingJeff Mahoney
The xattr_root caching was broken from my previous patch set. It wouldn't cause corruption, but could cause decreased performance due to allocating a larger chunk of the journal (~ 27 blocks) than it would actually use. This patch loads the xattr root dentry at xattr initialization and creates it on-demand. Since we're using the cached dentry, there's no point in keeping lookup_or_create_dir around, so that's removed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Always lookup priv_root on reiserfs mount and keep itAl Viro
... even if it's a negative dentry. That way we can set ->d_op on root before anyone could race with us. Simplify d_compare(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: Expand i_mutex to enclose lookup_one_lenJeff Mahoney
2.6.30-rc3 introduced some sanity checks in the VFS code to avoid NFS bugs by ensuring that lookup_one_len is always called under i_mutex. This patch expands the i_mutex locking to enclose lookup_one_len. This was always required, but not not enforced in the reiserfs code since it does locking around the xattr interactions with the xattr_sem. This is obvious enough, and it survived an overnight 50 thread ACL test. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02fs/reiserfs: return f_fsid for statfs(2)Coly Li
Make reiserfs3 return f_fsid info for statfs(2). By Andreas' suggestion, this patch populates a persistent f_fsid between boots/mounts with help of on-disk uuid record. Randy Dunlap reported a compiling error from v2 patch like: fs/built-in.o: In function `reiserfs_statfs': super.c:(.text+0x7332b): undefined reference to `crc32_le' super.c:(.text+0x7333f): undefined reference to `crc32_le' Also he provided helpful solution to fix this error. The modification of v3 patch is based on Randy's suggestion, add 'select CRC32' in fs/reiserfs/Kconfig. Signed-off-by: Coly Li <coly.li@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-30Merge branch 'proc-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: Revert "proc: revert /proc/uptime to ->read_proc hook" proc 2/2: remove struct proc_dir_entry::owner proc 1/2: do PDE usecounting even for ->read_proc, ->write_proc proc: fix sparse warnings in pagemap_read() proc: move fs/proc/inode-alloc.txt comment into a source file
2009-03-30reiserfs: xattr_create is unused with xattrs disabledJeff Mahoney
This patch ifdefs xattr_create when xattrs aren't enabled. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-30Merge branch 'reiserfs-updates' from Jeff MahoneyLinus Torvalds
* reiserfs-updates: (35 commits) reiserfs: rename [cn]_* variables reiserfs: rename p_._ variables reiserfs: rename p_s_tb to tb reiserfs: rename p_s_inode to inode reiserfs: rename p_s_bh to bh reiserfs: rename p_s_sb to sb reiserfs: strip trailing whitespace reiserfs: cleanup path functions reiserfs: factor out buffer_info initialization reiserfs: add atomic addition of selinux attributes during inode creation reiserfs: use generic readdir for operations across all xattrs reiserfs: journaled xattrs reiserfs: use generic xattr handlers reiserfs: remove i_has_xattr_dir reiserfs: make per-inode xattr locking more fine grained reiserfs: eliminate per-super xattr lock reiserfs: simplify xattr internal file lookups/opens reiserfs: Clean up xattrs when REISERFS_FS_XATTR is unset reiserfs: remove IS_PRIVATE helpers reiserfs: remove link detection code ... Fixed up conflicts manually due to: - quota name cleanups vs variable naming changes: fs/reiserfs/inode.c fs/reiserfs/namei.c fs/reiserfs/stree.c fs/reiserfs/xattr.c - exported include header cleanups include/linux/reiserfs_fs.h
2009-03-30reiserfs: rename [cn]_* variablesJeff Mahoney
This patch renames n_, c_, etc variables to something more sane. This is the sixth in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_._ variablesJeff Mahoney
This patch is a simple s/p_._//g to the reiserfs code. This is the fifth in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_tb to tbJeff Mahoney
This patch is a simple s/p_s_tb/tb/g to the reiserfs code. This is the fourth in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_inode to inodeJeff Mahoney
This patch is a simple s/p_s_inode/inode/g to the reiserfs code. This is the third in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_bh to bhJeff Mahoney
This patch is a simple s/p_s_bh/bh/g to the reiserfs code. This is the second in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rename p_s_sb to sbJeff Mahoney
This patch is a simple s/p_s_sb/sb/g to the reiserfs code. This is the first in a series of patches to rip out some of the awful variable naming in reiserfs. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: strip trailing whitespaceJeff Mahoney
This patch strips trailing whitespace from the reiserfs code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: cleanup path functionsJeff Mahoney
This patch cleans up some redundancies in the reiserfs tree path code. decrement_bcount() is essentially the same function as brelse(), so we use that instead. decrement_counters_in_path() is exactly the same function as pathrelse(), so we kill that and use pathrelse() instead. There's also a bit of cleanup that makes the code a bit more readable. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: factor out buffer_info initializationJeff Mahoney
This is the first in a series of patches to make balance_leaf() not quite so insane. This patch factors out the open coded initializations of buffer_info structures and defines a few initializers for the 4 cases they're used. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: add atomic addition of selinux attributes during inode creationJeff Mahoney
Some time ago, some changes were made to make security inode attributes be atomically written during inode creation. ReiserFS fell behind in this area, but with the reworking of the xattr code, it's now fairly easy to add. The following patch adds the ability for security attributes to be added automatically during inode creation. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use generic readdir for operations across all xattrsJeff Mahoney
The current reiserfs xattr implementation open codes reiserfs_readdir and frees the path before calling the filldir function. Typically, the filldir function is something that modifies the file system, such as a chown or an inode deletion that also require reading of an inode associated with each direntry. Since the file system is modified, the path retained becomes invalid for the next run. In addition, it runs backwards in attempt to minimize activity. This is clearly suboptimal from a code cleanliness perspective as well as performance-wise. This patch implements a generic reiserfs_for_each_xattr that uses the generic readdir and a specific filldir routine that simply populates an array of dentries and then performs a specific operation on them. When all files have been operated on, it then calls the operation on the directory itself. The result is a noticable code reduction and better performance. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: journaled xattrsJeff Mahoney
Deadlocks are possible in the xattr code between the journal lock and the xattr sems. This patch implements journalling for xattr operations. The benefit is twofold: * It gets rid of the deadlock possibility by always ensuring that xattr write operations are initiated inside a transaction. * It corrects the problem where xattr backing files aren't considered any differently than normal files, despite the fact they are metadata. I discussed the added journal load with Chris Mason, and we decided that since xattrs (versus other journal activity) is fairly rare, the introduction of larger transactions to support journaled xattrs wouldn't be too big a deal. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use generic xattr handlersJeff Mahoney
Christoph Hellwig had asked me quite some time ago to port the reiserfs xattrs to the generic xattr interface. This patch replaces the reiserfs-specific xattr handling code with the generic struct xattr_handler. However, since reiserfs doesn't split the prefix and name when accessing xattrs, it can't leverage generic_{set,get,list,remove}xattr without needlessly reconstructing the name on the back end. Update 7/26/07: Added missing dput() to deletion path. Update 8/30/07: Added missing mark_inode_dirty when i_mode is used to represent an ACL and no previous ACL existed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove i_has_xattr_dirJeff Mahoney
With the changes to xattr root locking, the i_has_xattr_dir flag is no longer needed. This patch removes it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: make per-inode xattr locking more fine grainedJeff Mahoney
The per-inode locking can be made more fine-grained to surround just the interaction with the filesystem itself. This really only applies to protecting reads during a write, since concurrent writes are barred with inode->i_mutex at the vfs level. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: eliminate per-super xattr lockJeff Mahoney
With the switch to using inode->i_mutex locking during lookups/creation in the xattr root, the per-super xattr lock is no longer needed. This patch removes it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: simplify xattr internal file lookups/opensJeff Mahoney
The xattr file open/lookup code is needlessly complex. We can use vfs-level operations to perform the same work, and also simplify the locking constraints. The locking advantages will be exploited in future patches. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: Clean up xattrs when REISERFS_FS_XATTR is unsetJeff Mahoney
The current reiserfs xattr implementation will not clean up old xattr files if files are deleted when REISERFS_FS_XATTR is unset. This results in inaccessible lost files, wasting space. This patch compiles in basic xattr knowledge, such as how to delete them and change ownership for quota tracking. If the file system has never used xattrs, then the operation is quite fast: it returns immediately when it sees there is no .reiserfs_priv directory. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove IS_PRIVATE helpersJeff Mahoney
There are a number of helper functions for marking a reiserfs inode private that were leftover from reiserfs did its own thing wrt to private inodes. S_PRIVATE has been in the kernel for some time, so this patch removes the helpers and uses IS_PRIVATE instead. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove link detection codeJeff Mahoney
Early in the reiserfs xattr development, there was a plan to use hardlinks to save disk space for identical xattrs. That code never materialized and isn't going to, so this patch removes the detection code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: xattr reiserfs_get_page takes offset instead of indexJeff Mahoney
This patch changes reiserfs_get_page to take an offset rather than an index since no callers calculate the index differently. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: small variable cleanupJeff Mahoney
This patch removes the xinode and mapping variables from reiserfs_xattr_{get,set}. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use reiserfs_error()Jeff Mahoney
This patch makes many paths that are currently using warnings to handle the error. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: introduce reiserfs_error()Jeff Mahoney
Although reiserfs can currently handle severe errors such as journal failure, it cannot handle less severe errors like metadata i/o failure. The following patch adds a reiserfs_error() function akin to the one in ext3. Subsequent patches will use this new error handler to handle errors more gracefully in general. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rearrange journal abortJeff Mahoney
This patch kills off reiserfs_journal_abort as it is never called, and combines __reiserfs_journal_abort_{soft,hard} into one function called reiserfs_abort_journal, which performs the same work. It is silent as opposed to the old version, since the message was always issued after a regular 'abort' message. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_panicJeff Mahoney
ReiserFS panics can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: add locking around error bufferJeff Mahoney
The formatting of the error buffer is race prone. It uses static buffers for both formatting and output. While overwriting the error buffer can product garbled output, overwriting the format buffer with incompatible % directives can cause crashes. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: prepare_error_buf wrongly consumes va_argJeff Mahoney
vsprintf will consume varargs on its own. Skipping them manually results in garbage in the error buffer, or Oopses in the case of pointers. This patch removes the advancement and fixes a number of bugs where crashes were observed as side effects of a regular error report. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_warningJeff Mahoney
ReiserFS warnings can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: make some warnings informationalJeff Mahoney
In several places, reiserfs_warning is used when there is no warning, just a notice. This patch changes some of them to indicate that the message is merely informational. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use more consistent printk formattingJeff Mahoney
The output format between a warning/error/panic/info/etc changes with which one is used. The following patch makes the messages more internally consistent, but also more consistent with other Linux filesystems. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use buffer_info for leaf_paste_entriesJeff Mahoney
This patch makes leaf_paste_entries more consistent with respect to the other leaf operations. Using buffer_info instead of buffer_head directly allows us to get a superblock pointer for use in error handling. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: audit transaction ids to always be unsigned intsJeff Mahoney
This patch fixes up the reiserfs code such that transaction ids are always unsigned ints. In places they can currently be signed ints or unsigned longs. The former just causes an annoying clm-2200 warning and may join a transaction when it should wait. The latter is just for correctness since the disk format uses a 32-bit transaction id. There aren't any runtime problems that result from it not wrapping at the correct location since the value is truncated correctly even on big endian systems. The 0 value might make it to disk, but the mount-time checks will bump it to 10 itself. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: add support for mount count incrementingJeff Mahoney
The following patch adds the fields for tracking mount counts and last fsck timestamps to the superblock. It also increments the mount count on every read-write mount. Reiserfsprogs 3.6.21 added support for these fields. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits) fs: avoid I_NEW inodes Merge code for single and multiple-instance mounts Remove get_init_pts_sb() Move common mknod_ptmx() calls into caller Parse mount options just once and copy them to super block Unroll essentials of do_remount_sb() into devpts vfs: simple_set_mnt() should return void fs: move bdev code out of buffer.c constify dentry_operations: rest constify dentry_operations: configfs constify dentry_operations: sysfs constify dentry_operations: JFS constify dentry_operations: OCFS2 constify dentry_operations: GFS2 constify dentry_operations: FAT constify dentry_operations: FUSE constify dentry_operations: procfs constify dentry_operations: ecryptfs constify dentry_operations: CIFS constify dentry_operations: AFS ...
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-03-26reiserfs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: reiserfs-devel@vger.kernel.org
