path: root/fs/reiserfs
2014-04-07Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3 improvements, cleanups, reiserfs fix from Jan Kara: "various cleanups for ext2, ext3, udf, isofs, a documentation update for quota, and a fix of a race in reiserfs readdir implementation" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: reiserfs: fix race in readdir ext2: acl: remove unneeded include of linux/capability.h ext3: explicitly remove inode from orphan list after failed direct io fs/isofs/inode.c add __init to init_inodecache() ext3: Speedup WB_SYNC_ALL pass fs/quota/Kconfig: Update filesystems ext3: Update outdated comment before ext3_ordered_writepage() ext3: Update PF_MEMALLOC handling in ext3_write_inode() ext2/3: use prandom_u32() instead of get_random_bytes() ext3: remove an unneeded check in ext3_new_blocks() ext3: remove unneeded check in ext3_ordered_writepage() fs: Mark function as static in ext3/xattr_security.c fs: Mark function as static in ext3/dir.c fs: Mark function as static in ext2/xattr_security.c ext3: Add __init macro to init_inodecache ext2: Add __init macro to init_inodecache udf: Add __init macro to init_inodecache fs: udf: parse_options: blocksize check
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-04-03fs/reiserfs/super.c: add __init to init_inodecacheFabian Frederick
init_inodecache is only called by __init init_reiserfs_fs. Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03fs/reiserfs: move prototype declaration to header fileRashika Kheria
Move prototype declaration to header file reiserfs/reiserfs.h from reiserfs/super.c because they are used by more than one file. This eliminates the following warning in reiserfs/bitmap.c: fs/reiserfs/bitmap.c:647:6: warning: no previous prototype for `show_alloc_options' [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03reiserfs: fix race in readdirJeff Mahoney
jdm-20004 reiserfs_delete_xattrs: Couldn't delete all xattrs (-2) The -ENOENT is due to readdir calling dir_emit on the same entry twice. If the dir_emit callback sleeps and the tree is changed underneath us, we won't be able to trust deh_offset(deh) anymore. We need to save next_pos before we might sleep so we can find the next entry. CC: stable@vger.kernel.org Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2014-02-17reiserfs: fix utterly brain-damaged indentation.Dave Jones
This has been this way for years, and every time I stumble across it I lose my lunch. After coming across it for the nth time in the Coverity results, I had to overcome the bystander effect and do something about it. This ignores the 79 column limit in favor of making it look like C instead of gibberish. The correct thing to do here would be to lose some of the indentation by breaking this function up into several smaller ones. I might do that at some point if I have the stomach to look at this again. (Also some of those overlong ternary operations would likely be more readable as regular if's) Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "Assorted stuff; the biggest pile here is Christoph's ACL series. Plus assorted cleanups and fixes all over the place... There will be another pile later this week" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits) __dentry_path() fixes vfs: Remove second variable named error in __dentry_path vfs: Is mounted should be testing mnt_ns for NULL or error. Fix race when checking i_size on direct i/o read hfsplus: remove can_set_xattr nfsd: use get_acl and ->set_acl fs: remove generic_acl nfs: use generic posix ACL infrastructure for v3 Posix ACLs gfs2: use generic posix ACL infrastructure jfs: use generic posix ACL infrastructure xfs: use generic posix ACL infrastructure reiserfs: use generic posix ACL infrastructure ocfs2: use generic posix ACL infrastructure jffs2: use generic posix ACL infrastructure hfsplus: use generic posix ACL infrastructure f2fs: use generic posix ACL infrastructure ext2/3/4: use generic posix ACL infrastructure btrfs: use generic posix ACL infrastructure fs: make posix_acl_create more useful fs: make posix_acl_chmod more useful ...
2014-01-25reiserfs: use generic posix ACL infrastructureChristoph Hellwig
Also don't bother to set up a .get_acl method for symlinks as we do not support access control (ACLs or even mode bits) for symlinks in Linux. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_create more usefulChristoph Hellwig
Rename the current posix_acl_created to __posix_acl_create and add a fully featured helper to set up the ACLs on file creation that uses get_acl(). Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_chmod more usefulChristoph Hellwig
Rename the current posix_acl_chmod to __posix_acl_chmod and add a fully featured ACL chmod helper that uses the ->set_acl inode operation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25reiserfs: prefix ACL symbols with reiserfs_Christoph Hellwig
2014-01-25kill reiserfs_bdevname()Al Viro
it's never called with NULL argument... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-23remove extra definitions of U32_MAXAlex Elder
Now that the definition is centralized in <linux/kernel.h>, the definitions of U32_MAX (and related) elsewhere in the kernel can be removed. Signed-off-by: Alex Elder <elder@linaro.org> Acked-by: Sage Weil <sage@inktank.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23conditionally define U32_MAXAlex Elder
The symbol U32_MAX is defined in several spots. Change these definitions to be conditional. This is in preparation for the next patch, which centralizes the definition in <linux/kernel.h>. Signed-off-by: Alex Elder <elder@linaro.org> Cc: Sage Weil <sage@inktank.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-24reiserfs: fix race with flush_used_journal_lists and flush_journal_listJeff Mahoney
There are two locks involved in managing the journal lists. The general reiserfs_write_lock and the journal->j_flush_mutex. While flush_journal_list is sleeping to acquire the j_flush_mutex or to submit a block for write, it will drop the write lock. This allows another thread to acquire the write lock and ultimately call flush_used_journal_lists to traverse the list of journal lists and select one for flushing. It can select the journal_list that has just had flush_journal_list called on it in the original thread and call it again with the same journal_list. The second thread then drops the write lock to acquire j_flush_mutex and the first thread reacquires it and continues execution and eventually clears and frees the journal list before dropping j_flush_mutex and returning. The second thread acquires j_flush_mutex and ends up operating on a journal_list that has already been released. If the memory hasn't been reused, we'll soon after hit a BUG_ON because the transaction id has already been cleared. If it's been reused, we'll crash in other fun ways. Since flush_journal_list will synchronize on j_flush_mutex, we can fix the race by taking a proper reference in flush_used_journal_lists and checking to see if it's still valid after the mutex is taken. It's safe to iterate the list of journal lists and pick a list with just the write lock as long as a reference is taken on the journal list before we drop the lock. We already have code to handle whether a transaction has been flushed already so we can use that to handle the race and get rid of the trans_id BUG_ON. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-24reiserfs: remove useless flush_old_journal_listsJeff Mahoney
Commit a3172027 introduced test_transaction as a requirement for flushing old lists -- but it can never return 1 unless the transaction has already been flushed. As a result, we have a routine that iterates the j_realblocks list but doesn't actually do anything. Since it's been this way since 2006 and the latency numbers were what Chris expected, let's just rip it out. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, reiserfs, udf & isofs fixes from Jan Kara: "The contains a bunch of ext3 cleanups and minor improvements, major reiserfs locking changes which should hopefully fix deadlocks introduced by BKL removal, and udf/isofs changes to refuse mounting fs rw instead of mounting it ro automatically which makes eject button work as expected for all media (see the changelog for why userspace should be ok with this change)" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: jbd: use a single printk for jbd_debug() reiserfs: locking, release lock around quota operations reiserfs: locking, handle nested locks properly reiserfs: locking, push write lock out of xattr code jbd: relocate assert after state lock in journal_commit_transaction() udf: Refuse RW mount of the filesystem instead of making it RO udf: Standardize return values in mount sequence isofs: Refuse RW mount of the filesystem instead of making it RO ext3: allow specifying external journal by pathname mount option jbd: remove unneeded semicolon
2013-08-08reiserfs: locking, release lock around quota operationsJeff Mahoney
Previous commits released the write lock across quota operations but missed several places. In particular, the free operations can also call into the file system code and take the write lock, causing deadlocks. This patch introduces some more helpers and uses them for quota call sites. Without this patch applied, reiserfs + quotas runs into deadlocks under anything more than trivial load. Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2013-08-08reiserfs: locking, handle nested locks properlyJeff Mahoney
The reiserfs write lock replaced the BKL and uses similar semantics. Frederic's locking code makes a distinction between when the lock is nested and when it's being acquired/released, but I don't think that's the right distinction to make. The right distinction is between the lock being released at end-of-use and the lock being released for a schedule. The unlock should return the depth and the lock should restore it, rather than the other way around as it is now. This patch implements that and adds a number of places where the lock should be dropped. Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2013-08-08reiserfs: locking, push write lock out of xattr codeJeff Mahoney
The reiserfs xattr code doesn't need the write lock and sleeps all over the place. We can simplify the locking by releasing it and reacquiring after the xattr call. Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2013-08-05reiserfs: fix deadlock in umountAl Viro
Since remove_proc_entry() started to wait for IO in progress (i.e. since 2007 or so), the locking in fs/reiserfs/proc.c became wrong; if procfs read happens between the moment when umount() locks the victim superblock and removal of /proc/fs/reiserfs/<device>/*, we'll get a deadlock - read will wait for s_umount (in sget(), called by r_start()), while umount will wait in remove_proc_entry() for that read to finish, holding s_umount all along. Fortunately, the same change allows a much simpler race avoidance - all we need to do is remove the procfs entries in the very beginning of reiserfs ->kill_sb(); that'll guarantee that pointer to superblock will remain valid for the duration for procfs IO, so we don't need sget() to keep the sucker alive. As the matter of fact, we can get rid of the home-grown iterator completely, and use single_open() instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Lots of bug fixes, cleanups and optimizations. In the bug fixes category, of note is a fix for on-line resizing file systems where the block size is smaller than the page size (i.e., file systems 1k blocks on x86, or more interestingly file systems with 4k blocks on Power or ia64 systems.) In the cleanup category, the ext4's punch hole implementation was significantly improved by Lukas Czerner, and now supports bigalloc file systems. In addition, Jan Kara significantly cleaned up the write submission code path. We also improved error checking and added a few sanity checks. In the optimizations category, two major optimizations deserve mention. The first is that ext4_writepages() is now used for nodelalloc and ext3 compatibility mode. This allows writes to be submitted much more efficiently as a single bio request, instead of being sent as individual 4k writes into the block layer (which then relied on the elevator code to coalesce the requests in the block queue). Secondly, the extent cache shrink mechanism, which was introduce in 3.9, no longer has a scalability bottleneck caused by the i_es_lru spinlock. Other optimizations include some changes to reduce CPU usage and to avoid issuing empty commits unnecessarily." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits) ext4: optimize starting extent in ext4_ext_rm_leaf() jbd2: invalidate handle if jbd2_journal_restart() fails ext4: translate flag bits to strings in tracepoints ext4: fix up error handling for mpage_map_and_submit_extent() jbd2: fix theoretical race in jbd2__journal_restart ext4: only zero partial blocks in ext4_zero_partial_blocks() ext4: check error return from ext4_write_inline_data_end() ext4: delete unnecessary C statements ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree() jbd2: move superblock checksum calculation to jbd2_write_superblock() ext4: pass inode pointer instead of file pointer to punch hole ext4: improve free space calculation for inline_data ext4: reduce object size when !CONFIG_PRINTK ext4: improve extent cache shrink mechanism to avoid to burn CPU time ext4: implement error handling of ext4_mb_new_preallocation() ext4: fix corruption when online resizing a fs with 1K block size ext4: delete unused variables ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents jbd2: remove debug dependency on debug_fs and update Kconfig help text jbd2: use a single printk for jbd_debug() ...
2013-06-29reiserfs: switch reiserfs_readdir_dentry to inodeAl Viro
... and clean the callers up a bit Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29reiserfs: is_privroot_deh() needs only directory inode, actuallyAl Viro
... and that - only to get the superblock. Privroot is a directory and we don't allow hardlinks to those... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert reiserfsAl Viro
2013-05-31reiserfs: fix deadlock with nfs racing on create/lookupJeff Mahoney
Reiserfs is currently able to be deadlocked by having two NFS clients where one has removed and recreated a file and another is accessing the file with an open file handle. If one client deletes and recreates a file with timing such that the recreated file obtains the same [dirid, objectid] pair as the original file while another client accesses the file via file handle, the create and lookup can race and deadlock if the lookup manages to create the in-memory inode first. The create thread, in insert_inode_locked4, will hold the write lock while waiting on the other inode to be unlocked. The lookup thread, anywhere in the iget path, will release and reacquire the write lock while it schedules. If it needs to reacquire the lock while the create thread has it, it will never be able to make forward progress because it needs to reacquire the lock before ultimately unlocking the inode. This patch drops the write lock across the insert_inode_locked4 call so that the ordering of inode_wait -> write lock is retained. Since this would have been the case before the BKL push-down, this is safe. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-31reiserfs: fix problems with chowning setuid file w/ xattrsJeff Mahoney
reiserfs_chown_xattrs() takes the iattr struct passed into ->setattr and uses it to iterate over all the attrs associated with a file to change ownership of xattrs (and transfer quota associated with the xattr files). When the setuid bit is cleared during chown, ATTR_MODE and iattr->ia_mode are passed to all the xattrs as well. This means that the xattr directory will have S_IFREG added to its mode bits. This has been prevented in practice by a missing IS_PRIVATE check in reiserfs_acl_chmod, which caused a double-lock to occur while holding the write lock. Since the file system was completely locked up, the writeout of the corrupted mode never happened. This patch temporarily clears everything but ATTR_UID|ATTR_GID for the calls to reiserfs_setattr and adds the missing IS_PRIVATE check. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-31reiserfs: fix spurious multiple-fill in reiserfs_readdir_dentryJeff Mahoney
After sleeping for filldir(), we check to see if the file system has changed and research. The next_pos pointer is updated but its value isn't pushed into the key used for the search itself. As a result, the search returns the same item that the last cycle of the loop did and filldir() is called multiple times with the same data. The end result is that the buffer can contain the same name multiple times. This can be returned to userspace or used internally in the xattr code where it can manifest with the following warning: jdm-20004 reiserfs_delete_xattrs: Couldn't delete all xattrs (-2) reiserfs_for_each_xattr uses reiserfs_readdir_dentry to iterate over the xattr names and ends up trying to unlink the same name twice. The second attempt fails with -ENOENT and the error is returned. At some point I'll need to add support into reiserfsck to remove the orphaned directories left behind when this occurs. The fix is to push the value into the key before researching. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-21reiserfs: use ->invalidatepage() length argumentLukas Czerner
->invalidatepage() aop now accepts range to invalidate so we can make use of it in reiserfs_invalidatepage() Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: reiserfs-devel@vger.kernel.org
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-05-07Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge more incoming from Andrew Morton: - Various fixes which were stalled or which I picked up recently - A large rotorooting of the AIO code. Allegedly to improve performance but I don't really have good performance numbers (I might have lost the email) and I can't raise Kent today. I held this out of 3.9 and we could give it another cycle if it's all too late/scary. I ended up taking only the first two thirds of the AIO rotorooting. I left the percpu parts and the batch completion for later. - Linus * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (33 commits) aio: don't include aio.h in sched.h aio: kill ki_retry aio: kill ki_key aio: give shared kioctx fields their own cachelines aio: kill struct aio_ring_info aio: kill batch allocation aio: change reqs_active to include unreaped completions aio: use cancellation list lazily aio: use flush_dcache_page() aio: make aio_read_evt() more efficient, convert to hrtimers wait: add wait_event_hrtimeout() aio: refcounting cleanup aio: make aio_put_req() lockless aio: do fget() after aio_get_req() aio: dprintk() -> pr_debug() aio: move private stuff out of aio.h aio: add kiocb_cancel() aio: kill return value of aio_complete() char: add aio_{read,write} to /dev/{null,zero} aio: remove retry-based AIO ...
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07make blkdev_put() return voidAl Viro
same story as with the previous patches - note that return value of blkdev_close() is lost, since there's nowhere the caller (__fput()) could return it to. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()David Howells
Don't access the proc_dir_entry in ReiserFS's r_open(), r_start() r_show() procfs interface functions. ReiserFS stores the ->show() method pointer in PDE->data and the super_block pointer in PDE->parent->data. This isn't changing. Currently, ReiserFS passes the PDE pointer into seq_file::private from r_open() so that r_start() and r_show() can then access it. Instead, use seq_open_private() to allocate a two-pointer struct that's passed through seq_file::private and put the ->show() method and the sb pointers in there. Signed-off-by: David Howells <dhowells@redhat.com> cc: reiserfs-devel@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Add proc_mkdir_data()David Howells
Add proc_mkdir_data() to allow procfs directories to be created that are annotated at the time of creation with private data rather than doing this post-creation. This means no access is then required to the proc_dir_entry struct to set this. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Neela Syam Kolli <megaraidlinux@lsi.com> cc: Jerry Chuang <jerry-chuang@realtek.com> cc: linux-scsi@vger.kernel.org cc: devel@driverdev.osuosl.org cc: linux-wireless@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09reiserfs: use proc_remove_subtree()Al Viro
2013-04-09reiserfs: don't wank with EFBIG before calling do_sync_write()Al Viro
look for file_capable() in there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-29reiserfs: Fix warning and inode leak when deleting inode with xattrsJan Kara
After commit 21d8a15a (lookup_one_len: don't accept . and ..) reiserfs started failing to delete xattrs from inode. This was due to a buggy test for '.' and '..' in fill_with_dentries() which resulted in passing '.' and '..' entries to lookup_one_len() in some cases. That returned error and so we failed to iterate over all xattrs of and inode. Fix the test in fill_with_dentries() along the lines of the one in lookup_one_len(). Reported-by: Pawel Zawora <pzawora@gmail.com> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2013-03-11reiserfs: Use kstrdup instead of kmalloc/strcpyIonut-Gabriel Radu
Signed-off-by: Ionut-Gabriel Radu <ihonius@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26fs: encode_fh: return FILEID_INVALID if invalid fid_typeNamjae Jeon
This patch is a follow up on below patch: [PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63 Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Vivek Trivedi <t.vivek@samsung.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Sage Weil <sage@inktank.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-20reiserfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-19reiserfs: Move quota calls out of write lockJan Kara
Calls into highlevel quota code cannot happen under the write lock. These calls take dqio_mutex which ranks above write lock. So drop write lock before calling back into quota code. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19reiserfs: Protect reiserfs_quota_write() with write lockJan Kara
Calls into reiserfs journalling code and reiserfs_get_block() need to be protected with write lock. We remove write lock around calls to high level quota code in the next patch so these paths would suddently become unprotected. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19reiserfs: Protect reiserfs_quota_on() with write lockJan Kara
In reiserfs_quota_on() we do quite some work - for example unpacking tail of a quota file. Thus we have to hold write lock until a moment we call back into the quota code. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19reiserfs: Fix lock ordering during remountJan Kara
When remounting reiserfs dquot_suspend() or dquot_resume() can be called. These functions take dqonoff_mutex which ranks above write lock so we have to drop it before calling into quota code. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
