This patch is an attempt to remove the Bkl based locking scheme from
reiserfs and is intended.
It is a bit inspired from an old attempt by Peter Zijlstra:
http://lkml.indiana.edu/hypermail/linux/kernel/0704.2/2174.html
The bkl is heavily used in this filesystem to prevent from
concurrent write accesses on the filesystem.
Reiserfs makes a deep use of the specific properties of the Bkl:
- It can be acqquired recursively by a same task
- It is released on the schedule() calls and reacquired when schedule() returns
The two properties above are a roadmap for the reiserfs write locking so it's
very hard to simply replace it with a common mutex.
- We need a recursive-able locking unless we want to restructure several blocks
of the code.
- We need to identify the sites where the bkl was implictly relaxed
(schedule, wait, sync, etc...) so that we can in turn release and
reacquire our new lock explicitly.
Such implicit releases of the lock are often required to let other
resources producer/consumer do their job or we can suffer unexpected
starvations or deadlocks.
So the new lock that replaces the bkl here is a per superblock mutex with a
specific property: it can be acquired recursively by a same task, like the
bkl.
For such purpose, we integrate a lock owner and a lock depth field on the
superblock information structure.
The first axis on this patch is to turn reiserfs_write_(un)lock() function
into a wrapper to manage this mutex. Also some explicit calls to
lock_kernel() have been converted to reiserfs_write_lock() helpers.
The second axis is to find the important blocking sites (schedule...(),
wait_on_buffer(), sync_dirty_buffer(), etc...) and then apply an explicit
release of the write lock on these locations before blocking. Then we can
safely wait for those who can give us resources or those who need some.
Typically this is a fight between the current writer, the reiserfs workqueue
(aka the async commiter) and the pdflush threads.
The third axis is a consequence of the second. The write lock is usually
on top of a lock dependency chain which can include the journal lock, the
flush lock or the commit lock. So it's dangerous to release and trying to
reacquire the write lock while we still hold other locks.
This is fine with the bkl:
T1 T2
lock_kernel()
mutex_lock(A)
unlock_kernel()
// do something
lock_kernel()
mutex_lock(A) -> already locked by T1
schedule() (and then unlock_kernel())
lock_kernel()
mutex_unlock(A)
This is not fine with a mutex:
T1 T2
mutex_lock(write)
mutex_lock(A)
mutex_unlock(write)
// do something
mutex_lock(write)
schedule()
mutex_lock(write) -> already locked by T2
deadlock
The solution in this patch is to provide a helper which releases the write
lock and sleep a bit if we can't lock a mutex that depend on it. It's another
simulation of the bkl behaviour.
The last axis is to locate the fs callbacks that are called with the bkl held,
according to Documentation/filesystem/Locking.
Those are:
- reiserfs_remount
- reiserfs_fill_super
- reiserfs_put_super
Reiserfs didn't need to explicitly lock because of the context of these callbacks.
But now we must take care of that with the new locking.
After this patch, reiserfs suffers from a slight performance regression (for now).
On UP, a high volume write with dd reports an average of 27 MB/s instead
of 30 MB/s without the patch applied.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Bron Gondwana <brong@fastmail.fm>
LKML-Reference: <1239070789-13354-1-git-send-email-fweisbec@gmail.com>
This patch strips trailing whitespace from the reiserfs code.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Quota files cannot have tails because quota_write and quota_read functions do
not support them. So far when quota files did have tail, we just refused to
turn quotas on it. Sadly this check has been wrong and so there are now
plenty installations where quota files don't have NOTAIL flag set and so now
after fixing the check, they suddently fail to turn quotas on. Since it's
easy to unpack the tail from kernel, do this from reiserfs_quota_on() which
solves the problem and is generally nicer to users anyway.
Reported-by: <urhausen@urifabi.net>
Cc: Chris Mason <chris.mason@oracle.com>
Some ioctl()s can cause writes to the filesystem. Take these, and make them
use mnt_want/drop_write() instead.
[AV: updated]
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Forbid user from changing file flags on quota files. User has no bussiness
in playing with these flags when quota is on. Furthermore there is a
remote possibility of deadlock due to a lock inversion between quota file's
i_mutex and transaction's start (i_mutex for quota file is locked only when
trasaction is started in quota operations) in ext3 and ext4.
Cc: LIOU Payphone <lioupayphone@gmail.com>
Cc: <linux-ext4@vger.kernel.org>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: <reiserfs-dev@namesys.com>
Convert reiserfs to new aops
Signed-off-by: Vladimir Saveliev <vs@namesys.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant
users to it. This is done because we want to avoid bugs in the future
where we check for only effective fsuid of the current task against a
file's owning uid, without simultaneously checking for CAP_FOWNER as
well, thus violating its semantics.
[ XFS uses special macros and structures, and in general looked ...
untouchable, so we leave it alone -- but it has been looked over. ]
The (current->fsuid != inode->i_uid) check in generic_permission() and
exec_permission_lite() is left alone, because those operations are
covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations
falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone.
Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
Cc: Al Viro <viro@ftp.linux.org.uk>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
driver [try #6]
Move the ReiserFS device ioctl compat stuff from fs/compat_ioctl.c to the
ReiserFS driver so that the ReiserFS header file doesn't need to be included.
Signed-Off-By: David Howells <dhowells@redhat.com>
The correct lock ordering is inode lock -> BKL
Signed-off-by: Chris Mason <mason@suse.com>
fs: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
This was a pure indentation change, using:
scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h
to make reiserfs match the regular Linux indentation style. As Jeff
Mahoney <jeffm@suse.com> writes:
The ReiserFS code is a mix of a number of different coding styles, sometimes
different even from line-to-line. Since the code has been relatively stable
for quite some time and there are few outstanding patches to be applied, it
is time to reformat the code to conform to the Linux style standard outlined
in Documentation/CodingStyle.
This patch contains the result of running scripts/Lindent against
fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the
code can be made to look better, but I'd rather keep those patches separate
so that there isn't a subtle by-hand hand accident in the middle of a huge
patch. To be clear: This patch is reformatting *only*.
A number of patches may follow that continue to make the code more consistent
with the Linux coding style.
Hans wasn't particularly enthusiastic about these patches, but said he
wouldn't really oppose them either.
ReiserFS currently will allow the user to set/get attrs for files
regardless if they are enabled. The patch checks to see if they are
enabled, and returns -NOTTY if they are not.
ext[23] doesn't need this check because attrs are always enabled.
infrastructure for it.
Let it rip!
