path: root/fs/quota
2013-09-10fs: convert fs shrinkers to new scan/count APIDave Chinner
Convert the filesystem shrinkers to use the new API, and standardise some of the behaviours of the shrinkers at the same time. For example, nr_to_scan means the number of objects to scan, not the number of objects to free. I refactored the CIFS idmap shrinker a little - it really needs to be broken up into a shrinker per tree and keep an item count with the tree root so that we don't need to walk the tree every time the shrinker needs to count the number of objects in the tree (i.e. all the time under memory pressure). [glommer@openvz.org: fixes for ext4, ubifs, nfs, cifs and glock. Fixes are needed mainly due to new code merged in the tree] [assorted fixes folded in] Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Glauber Costa <glommer@openvz.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Arve Hjønnevåg <arve@android.com> Cc: Carlos Maiolino <cmaiolino@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Rientjes <rientjes@google.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: J. Bruce Fields <bfields@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Jerome Glisse <jglisse@redhat.com> Cc: John Stultz <john.stultz@linaro.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Kent Overstreet <koverstreet@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-10super: fix calculation of shrinkable objects for small numbersGlauber Costa
The sysctl knob sysctl_vfs_cache_pressure is used to determine which percentage of the shrinkable objects in our cache we should actively try to shrink. It works great in situations in which we have many objects (at least more than 100), because the aproximation errors will be negligible. But if this is not the case, specially when total_objects < 100, we may end up concluding that we have no objects at all (total / 100 = 0, if total < 100). This is certainly not the biggest killer in the world, but may matter in very low kernel memory situations. Signed-off-by: Glauber Costa <glommer@openvz.org> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Arve Hjønnevåg <arve@android.com> Cc: Carlos Maiolino <cmaiolino@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: David Rientjes <rientjes@google.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Greg Thelen <gthelen@google.com> Cc: J. Bruce Fields <bfields@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Jerome Glisse <jglisse@redhat.com> Cc: John Stultz <john.stultz@linaro.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Kent Overstreet <koverstreet@google.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-09Merge tag 'xfs-for-linus-v3.12-rc1' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs updates from Ben Myers: "For 3.12-rc1 there are a number of bugfixes in addition to work to ease usage of shared code between libxfs and the kernel, the rest of the work to enable project and group quotas to be used simultaneously, performance optimisations in the log and the CIL, directory entry file type support, fixes for log space reservations, some spelling/grammar cleanups, and the addition of user namespace support. - introduce readahead to log recovery - add directory entry file type support - fix a number of spelling errors in comments - introduce new Q_XGETQSTATV quotactl for project quotas - add USER_NS support - log space reservation rework - CIL optimisations - kernel/userspace libxfs rework" * tag 'xfs-for-linus-v3.12-rc1' of git://oss.sgi.com/xfs/xfs: (112 commits) xfs: XFS_MOUNT_QUOTA_ALL needed by userspace xfs: dtype changed xfs_dir2_sfe_put_ino to xfs_dir3_sfe_put_ino Fix wrong flag ASSERT in xfs_attr_shortform_getvalue xfs: finish removing IOP_* macros. xfs: inode log reservations are too small xfs: check correct status variable for xfs_inobt_get_rec() call xfs: inode buffers may not be valid during recovery readahead xfs: check LSN ordering for v5 superblocks during recovery xfs: btree block LSN escaping to disk uninitialised XFS: Assertion failed: first <= last && last < BBTOB(bp->b_length), file: fs/xfs/xfs_trans_buf.c, line: 568 xfs: fix bad dquot buffer size in log recovery readahead xfs: don't account buffer cancellation during log recovery readahead xfs: check for underflow in xfs_iformat_fork() xfs: xfs_dir3_sfe_put_ino can be static xfs: introduce object readahead to log recovery xfs: Simplify xfs_ail_min() with list_first_entry_or_null() xfs: Register hotcpu notifier after initialization xfs: add xfs sb v4 support for dirent filetype field xfs: Add write support for dirent filetype field xfs: Add read-only support for dirent filetype field ...
2013-08-20quota: Add a new quotactl command Q_XGETQSTATVChandra Seetharaman
XFS now supports three types of quotas (user, group and project). Current version of Q_XGETSTAT has support for only two types of quotas. In order to support three types of quotas, the interface, specifically struct fs_quota_stat, need to be expanded. Current version of fs_quota_stat does not allow expansion without breaking backward compatibility. So, a quotactl command and new fs_quota_stat structure need to be added. This patch adds a new command Q_XGETQSTATV to quotactl() which takes a new data structure fs_quota_statv. This new data structure provides support for future expansion and backward compatibility. Callers of the new quotactl command have to set the version of the data structure being passed, and kernel will fill as much data as requested. If the kernel does not support the user-space provided version, EINVAL will be returned. User-space can reduce the version number and call the same quotactl again. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Rich Johnston <rjohnston@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> [v2: Applied rjohnston's suggestions as per Chandra's request. -bpm]
2013-08-17quota: provide interface for readding allocated space into reserved spaceJan Kara
ext4 needs to convert allocated (metadata) blocks back into blocks reserved for delayed allocation. Add functions into quota code for supporting such operation. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-07-04quota: Convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-03-11quota: add missing use of dq_data_lock in __dquot_initializeJeff Mahoney
The bulk of __dquot_initialize runs under the dqptr_sem which protects the inode->i_dquot pointers. It doesn't protect the dereferenced contents, though. Those are protected by the dq_data_lock, which is missing around the dquot_resv_space call. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-12-13quota: Use the pre-processor to compile out quotactl_cmd_write when ↵Lee Jones
!CONFIG_BLOCK quotactl_cmd_write() is only ever invoked when BLOCK is configured. When !CONFIG_BLOCK, the build warning below is displayed. Let's fix that. fs/quota/quota.c:311:12: warning: ‘quotactl_cmd_write’ defined but not used [-Wunused-function] Cc: Jan Kara <jack@suse.cz> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Jan Kara <jack@suse.cz>
2012-10-16Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext2, ext3, quota fixes from Jan Kara: "Fix three regressions caused by user namespace conversions (ext2, ext3, quota) and minor ext3 fix and cleanup." * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: quota: Silence warning about PRJQUOTA not being handled in need_print_warning() ext3: fix return values on parse_options() failure ext2: fix return values on parse_options() failure ext3: ext3_bread usage audit ext3: fix possible non-initialized variable on htree_dirblock_to_tree()
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-09quota: Silence warning about PRJQUOTA not being handled in need_print_warning()Jan Kara
PRJQUOTA value of quota type should never reach need_print_warning() since XFS (which is the only fs which uses that type) doesn't use generic functions calling this function. Anyway, add PRJQUOTA case to the switch to make gcc happy. Signed-off-by: Jan Kara <jack@suse.cz>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-18userns: Convert quotaEric W. Biederman
Now that the type changes are done, here is the final set of changes to make the quota code work when user namespaces are enabled. Small cleanups and fixes to make the code build when user namespaces are enabled. Cc: Jan Kara <jack@suse.cz> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Convert struct dquot_warnEric W. Biederman
Convert w_dq_id to be a struct kquid and remove the now unncessary w_dq_type. This is a simple conversion and enough other places have already been converted that this actually reduces the code complexity by a little bit, when removing now unnecessary type conversions. Cc: Jan Kara <jack@suse.cz> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Convert struct dquot dq_id to be a struct kqidEric W. Biederman
Change struct dquot dq_id to a struct kqid and remove the now unecessary dq_type. Make minimal changes to dquot, quota_tree, quota_v1, quota_v2, ext3, ext4, and ocfs2 to deal with the change in quota structures and signatures. The ocfs2 changes are larger than most because of the extensive tracing throughout the ocfs2 quota code that prints out dq_id. quota_tree.c:get_index is modified to take a struct kqid instead of a qid_t because all of it's callers pass in dquot->dq_id and it allows me to introduce only a single conversion. The rest of the changes are either just replacing dq_type with dq_id.type, adding conversions to deal with the change in type and occassionally adding qid_eq to allow quota id comparisons in a user namespace safe way. Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Jan Kara <jack@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Theodore Tso <tytso@mit.edu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Modify dqget to take struct kqidEric W. Biederman
Modify dqget to take struct kqid instead of a type and an identifier pair. Modify the callers of dqget in ocfs2 and dquot to take generate a struct kqid so they can continue to call dqget. The conversion to create struct kqid should all be the final conversions that are needed in those code paths. Cc: Jan Kara <jack@suse.cz> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Convert quota netlink aka quota_send_warningEric W. Biederman
Modify quota_send_warning to take struct kqid instead a type and identifier pair. When sending netlink broadcasts always convert uids and quota identifiers into the intial user namespace. There is as yet no way to send a netlink broadcast message with different contents to receivers in different namespaces, so for the time being just map all of the identifiers into the initial user namespace which preserves the current behavior. Change the callers of quota_send_warning in gfs2, xfs and dquot to generate a struct kqid to pass to quota send warning. When all of the user namespaces convesions are complete a struct kqid values will be availbe without need for conversion, but a conversion is needed now to avoid needing to convert everything at once. Cc: Ben Myers <bpm@sgi.com> Cc: Alex Elder <elder@kernel.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Convert qutoactlEric W. Biederman
Update the quotactl user space interface to successfull compile with user namespaces support enabled and to hand off quota identifiers to lower layers of the kernel in struct kqid instead of type and qid pairs. The quota on function is not converted because while it takes a quota type and an id. The id is the on disk quota format to use, which is something completely different. The signature of two struct quotactl_ops methods were changed to take struct kqid argumetns get_dqblk and set_dqblk. The dquot, xfs, and ocfs2 implementations of get_dqblk and set_dqblk are minimally changed so that the code continues to work with the change in parameter type. This is the first in a series of changes to always store quota identifiers in the kernel in struct kqid and only use raw type and qid values when interacting with on disk structures or userspace. Always using struct kqid internally makes it hard to miss places that need conversion to or from the kernel internal values. Cc: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: Alex Elder <elder@kernel.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-18userns: Implement struct kqidEric W. Biederman
Add the data type struct kqid which holds the kernel internal form of the owning identifier of a quota. struct kqid is a replacement for the implicit union of uid, gid and project id stored in an unsigned int and the quota type field that is was used in the quota data structures. Making the data type explicit allows the kuid_t and kgid_t type safety to propogate more thoroughly through the code, revealing more places where uid/gid conversions need be made. Along with the data type struct kqid comes the helper functions qid_eq, qid_lt, from_kqid, from_kqid_munged, qid_valid, make_kqid, make_kqid_invalid, make_kqid_uid, make_kqid_gid. Cc: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-08-15quota: Move down dqptr_sem read after initializing default warn[] type at ↵Jeff Liu
__dquot_alloc_space(). sb->s_dqopt->dqptr_sem is used to serialize ops using pointers from inode to dquots. But for __dquot_alloc_space(), it could be safely moved down after the default warn[] array got initialized. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-07-24Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull misc udf, ext2, ext3, and isofs fixes from Jan Kara: "Assorted, mostly trivial, fixes for udf, ext2, ext3, and isofs. I'm on vacation and scarcely checking email since we are expecting baby any day now but these fixes should be safe to go in and I don't want to delay them unnecessarily." * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: avoid info leak on export isofs: avoid info leak on export udf: Improve table length check to avoid possible overflow ext3: Check return value of blkdev_issue_flush() jbd: Check return value of blkdev_issue_flush() udf: Do not decrement i_blocks when freeing indirect extent block udf: Fix memory leak when mounting ext2: cleanup the confused goto label UDF: Remove unnecessary variable "offset" from udf_fill_inode udf: stop using s_dirt ext3: force ro mount if ext3_setup_super() fails quota: fix checkpatch.pl warning by replacing <asm/uaccess.h> with <linux/uaccess.h>
2012-07-22quota: Split dquot_quota_sync() to writeback and cache flushing partJan Kara
Split off part of dquot_quota_sync() which writes dquots into a quota file to a separate function. In the next patch we will use the function from filesystems and we do not want to abuse ->quota_sync quotactl callback more than necessary. Acked-by: Steven Whitehouse <swhiteho@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-09quota: fix checkpatch.pl warning by replacing <asm/uaccess.h> with ↵Jeff Liu
<linux/uaccess.h> checkpatch.pl warns: "WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>" Below patch fixes it. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15quota: Get rid of nested I_MUTEX_QUOTA locking subclassJan Kara
So far i_mutex was ranking above dqonoff_mutex and i_mutex on quota files was special and ranking below dqonoff_mutex (and several other locks). However there's no real need for i_mutex on quota files to be special. IO on quota files is serialized by dqio_mutex anyway so we don't need to take i_mutex when writing to quota files. Other places where we take i_mutex on quota file can accomodate standard i_mutex lock ranking, we only need to change the lock ranking to be dqonoff_mutex > i_mutex which is a matter of changing documentation because there's no place which would enforce ordering in the other direction. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15quota: Use precomputed value of sb_dqopt in dquot_quota_syncJan Kara
2012-05-15quota: Fix double lock in add_dquot_ref() with CONFIG_QUOTA_DEBUGJan Kara
When CONFIG_QUOTA_DEBUG is enabled we call inode_get_rsv_space() from add_dquot_ref() while holding i_lock. But inode_get_rsv_space() is trying to get i_lock as well resulting in double lock. Fix the problem by moving inode_get_rsv_space() call out of i_lock. Reported-and-analyzed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-03-28Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, UDF, and quota fixes from Jan Kara: "A couple of ext3 & UDF fixes and also one improvement in quota locking." * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext3: fix start and len arguments handling in ext3_trim_fs() udf: Fix deadlock in udf_release_file() udf: Fix file entry logicalBlocksRecorded udf: Fix handling of i_blocks quota: Make quota code not call tty layer with dqptr_sem held udf: Init/maintain file entry checkpoint field ext3: Update ctime in ext3_splice_branch() only when needed ext3: Don't call dquot_free_block() if we don't update anything udf: Remove unnecessary OOM messages
2012-03-23Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull XFS updates from Ben Myers: "Scalability improvements for dquots, log grant code cleanups, plus bugfixes and cleanups large and small" Fix up various trivial conflicts that were due to some of the earlier patches already having been integrated into v3.3 as bugfixes, and then there were development patches on top of those. Easily merged by just taking the newer version from the pulled branch. * 'for-linus' of git://oss.sgi.com/xfs/xfs: (45 commits) xfs: fallback to vmalloc for large buffers in xfs_getbmap xfs: fallback to vmalloc for large buffers in xfs_attrmulti_attr_get xfs: remove remaining scraps of struct xfs_iomap xfs: fix inode lookup race xfs: clean up minor sparse warnings xfs: remove the global xfs_Gqm structure xfs: remove the per-filesystem list of dquots xfs: use per-filesystem radix trees for dquot lookup xfs: per-filesystem dquot LRU lists xfs: use common code for quota statistics xfs: reimplement fdatasync support xfs: split in-core and on-disk inode log item fields xfs: make xfs_inode_item_size idempotent xfs: log timestamp updates xfs: log file size updates at I/O completion time xfs: log file size updates as part of unwritten extent conversion xfs: do not require an ioend for new EOF calculation xfs: use per-filesystem I/O completion workqueues quota: make Q_XQUOTASYNC a noop xfs: include reservations in quota reporting ...
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates for 3.4 from James Morris: "The main addition here is the new Yama security module from Kees Cook, which was discussed at the Linux Security Summit last year. Its purpose is to collect miscellaneous DAC security enhancements in one place. This also marks a departure in policy for LSM modules, which were previously limited to being standalone access control systems. Chromium OS is using Yama, and I believe there are plans for Ubuntu, at least. This patchset also includes maintenance updates for AppArmor, TOMOYO and others." Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key rename. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) AppArmor: Fix location of const qualifier on generated string tables TOMOYO: Return error if fails to delete a domain AppArmor: add const qualifiers to string arrays AppArmor: Add ability to load extended policy TOMOYO: Return appropriate value to poll(). AppArmor: Move path failure information into aa_get_name and rename AppArmor: Update dfa matching routines. AppArmor: Minor cleanup of d_namespace_path to consolidate error handling AppArmor: Retrieve the dentry_path for error reporting when path lookup fails AppArmor: Add const qualifiers to generated string tables AppArmor: Fix oops in policy unpack auditing AppArmor: Fix error returned when a path lookup is disconnected KEYS: testing wrong bit for KEY_FLAG_REVOKED TOMOYO: Fix mount flags checking order. security: fix ima kconfig warning AppArmor: Fix the error case for chroot relative path name lookup AppArmor: fix mapping of META_READ to audit and quiet flags AppArmor: Fix underflow in xindex calculation AppArmor: Fix dropping of allowed operations that are force audited AppArmor: Add mising end of structure test to caps unpacking ...
2012-02-29quota: Make quota code not call tty layer with dqptr_sem heldJan Kara
dqptr_sem can be called from slab reclaim. tty layer uses GFP_KERNEL mask for allocation so it can end up calling slab reclaim. Given quota code can call into tty layer to print warning this creates possibility for lock inversion between tty->atomic_write_lock and dqptr_sem. Using direct printing of warnings from quota layer is obsolete but since it's easy enough to change quota code to not hold any locks when printing warnings, let's just do it. It seems like a good thing to do even when we use netlink layer to transmit warnings to userspace. Reported-by: Markus <M4rkusXXL@web.de> Signed-off-by: Jan Kara <jack@suse.cz>
2012-02-29quota: make Q_XQUOTASYNC a noopChristoph Hellwig
Now that XFS takes quota reservations into account there is no need to flush anything before reporting quotas - in addition to beeing fully transactional all quota information is also 100% coherent with the rest of the filesystem now. Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com>
2012-02-13quota: Fix deadlock with suspend and quotasJan Kara
This script causes a kernel deadlock: set -e DEVICE=/dev/vg1/linear lvchange -ay $DEVICE mkfs.ext3 $DEVICE mount -t ext3 -o usrquota,grpquota $DEVICE /mnt/test quotacheck -gu /mnt/test umount /mnt/test mount -t ext3 -o usrquota,grpquota $DEVICE /mnt/test quotaon /mnt/test dmsetup suspend $DEVICE setquota -u root 1 2 3 4 /mnt/test & sleep 1 dmsetup resume $DEVICE setquota acquired semaphore s_umount for read and then tried to perform a transaction (and waits because the device is suspended). dmsetup resume tries to acquire s_umount for write before resuming the device (and waits for setquota). Fix the deadlock by grabbing a thawed superblock for quota commands which need it. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-02-14security: trim security.hAl Viro
Trim security.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-12quota: Pass information that quota is stored in system file to userspaceJan Kara
Quota tools need to know whether quota is stored in a system file or in classical aquota.{user|group} files. So pass this information as a flag in GETINFO quotactl. Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-06vfs: prefer ->dentry->d_sb to ->mnt->mnt_sbAl Viro
2012-01-03fs: move code out of buffer.cAl Viro
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export kill_bdev as well, so brd doesn't have to open code it. Reduce buffer_head.h requirement accordingly. Removed a rather large comment from invalidate_bdev, as it looked a bit obsolete to bother moving. The small comment replacing it says enough. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-06Merge branch 'writeback-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux * 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Add a 'reason' to wb_writeback_work writeback: send work item to queue_io, move_expired_inodes writeback: trace event balance_dirty_pages writeback: trace event bdi_dirty_ratelimit writeback: fix ppc compile warnings on do_div(long long, unsigned long) writeback: per-bdi background threshold writeback: dirty position control - bdi reserve area writeback: control dirty pause time writeback: limit max dirty pause time writeback: IO-less balance_dirty_pages() writeback: per task dirty rate limit writeback: stabilize bdi->dirty_ratelimit writeback: dirty rate control writeback: add bg_threshold parameter to __bdi_update_bandwidth() writeback: dirty position control writeback: account per-bdi accumulated dirtied pages
2011-11-02Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Cleanup metadata flags handling udf: Skip mirror metadata FE loading when metadata FE is ok ext3: Allow quota file use root reservation udf: Remove web reference from UDF MAINTAINERS entry quota: Drop path reference on error exit from quotactl udf: Neaten udf_debug uses udf: Neaten logging output, use vsprintf extension %pV udf: Convert printks to pr_<level> udf: Rename udf_warning to udf_warn udf: Rename udf_error to udf_err udf: Promote some debugging messages to udf_error ext3: Remove the obsolete broken EXT3_IOC32_WAIT_FOR_READONLY. udf: Add readpages support for udf. ext3/balloc.c: local functions should be static ext2: fix the outdated comment in ext2_nfs_get_inode() ext3: remove deprecated oldalloc fs/ext3/balloc.c: delete useless initialization fs/ext2/balloc.c: delete useless initialization ext3: fix message in ext3_remount for rw-remount case ext3: Remove i_mutex from ext3_sync_file() Fix up trivial (printf format cleanup) conflicts in fs/udf/udfdecl.h
2011-10-31quota: Drop path reference on error exit from quotactlJan Kara
One error exit from quotactl forgot to do path_put(). Fix that. Reported-by: Valerie Aurora <val@vaaconsulting.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-10-31writeback: Add a 'reason' to wb_writeback_workCurt Wohlgemuth
This creates a new 'reason' field in a wb_writeback_work structure, which unambiguously identifies who initiates writeback activity. A 'wb_reason' enumeration has been added to writeback.h, to enumerate the possible reasons. The 'writeback_work_class' and tracepoint event class and 'writeback_queue_io' tracepoints are updated to include the symbolic 'reason' in all trace events. And the 'writeback_inodes_sbXXX' family of routines has had a wb_stats parameter added to them, so callers can specify why writeback is being started. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-09-26VFS: Fix the remaining automounter semantics regressionsTrond Myklebust
The concensus seems to be that system calls such as stat() etc should not trigger an automount. Neither should the l* versions. This patch therefore adds a LOOKUP_AUTOMOUNT flag to tag those lookups that _should_ trigger an automount on the last path element. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> [ Edited to leave out the cases that are already covered by LOOKUP_OPEN, LOOKUP_DIRECTORY and LOOKUP_CREATE - all of which also fundamentally force automounting for their own reasons - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Don't write quota info in dquot_commit() ext3: Fix writepage credits computation for ordered mode
2011-04-01quota: Don't write quota info in dquot_commit()Jan Kara
There's no reason to write quota info in dquot_commit(). The writing is a relict from the old days when we didn't have dquot_acquire() and dquot_release() and thus dquot_commit() could have created / removed quota structures from the file. These days dquot_commit() only updates usage counters / limits in quota structure and thus there's no need to write quota info. This also fixes an issue with journaling filesystem which didn't reserve enough space in the transaction for write of quota info (it could have been dirty at the time of dquot_commit() because of a race with other operation changing it). CC: stable@kernel.org Reported-and-tested-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-24fs: move i_sb_list out from under inode_lockDave Chinner
Protect the per-sb inode list with a new global lock inode_sb_list_lock and use it to protect the list manipulations and traversals. This lock replaces the inode_lock as the inodes on the list can be validity checked while holding the inode->i_lock and hence the inode_lock is no longer needed to protect the list. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: protect inode->i_state with inode->i_lockDave Chinner
Protect inode state transitions and validity checks with the inode->i_lock. This enables us to make inode state transitions independently of the inode_lock and is the first step to peeling away the inode_lock from the code. This requires that __iget() is done atomically with i_state checks during list traversals so that we don't race with another thread marking the inode I_FREEING between the state check and grabbing the reference. Also remove the unlock_new_inode() memory barrier optimisation required to avoid taking the inode_lock when clearing I_NEW. Simplify the code by simply taking the inode->i_lock around the state change and wakeup. Because the wakeup is no longer tricky, remove the wake_up_inode() function and open code the wakeup where necessary. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-24quota: return -ENOMEM when memory allocation failsDavidlohr Bueso
Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-12quota: Fix deadlock during path resolutionJan Kara
As Al Viro pointed out path resolution during Q_QUOTAON calls to quotactl is prone to deadlocks. We hold s_umount semaphore for reading during the path resolution and resolution itself may need to acquire the semaphore for writing when e. g. autofs mountpoint is passed. Solve the problem by performing the resolution before we get hold of the superblock (and thus s_umount semaphore). The whole thing is complicated by the fact that some filesystems (OCFS2) ignore the path argument. So to distinguish between filesystem which want the path and which do not we introduce new .quota_on_meta callback which does not get the path. OCFS2 then uses this callback instead of old .quota_on. CC: Al Viro <viro@ZenIV.linux.org.uk> CC: Christoph Hellwig <hch@lst.de> CC: Ted Ts'o <tytso@mit.edu> CC: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-10quota: Use %pV and __attribute__((format (printf in __quota_error and fix ↵Joe Perches
fallout Use %pV in __quota_error so a single printk can not be interleaved with other logging messages. Add __attribute__((format (printf, 3, 4))) so format and arguments can be verified by compiler. Make sure printk formats and arguments match. Block # needed a pointer dereference. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
