path: root/fs/partitions
2008-07-25fs/partitions/efi: convert to pr_debugThomas Gleixner
convert the local Dprintk() compile time debug printk wrappers to the generic pr_debug() wrapper. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25block/ioctl.c and fs/partition/check.c: check value returned by add_partition()Abdel Benamrouche
Now that add_partition() has been aught to propagate errors, let's check them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Abdel Benamrouche <draconux@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fs/partition/check.c: fix return value warningAbdel Benamrouche
fs/partitions/check.c:381: warning: ignoring return value of ___device_add___, declared with attribute warn_unused_result [akpm@linux-foundation.org: multiple-return-statements-per-function are evil] Signed-off-by: Abdel Benamrouche <draconux@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fs: ldm.[ch] use get_unaligned_* helpersHarvey Harrison
Replace the private BE16/BE32/BE64 macros with direct calls to get_unaligned_be16/32/64. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21driver core: remove KOBJ_NAME_LEN defineKay Sievers
Kobjects do not have a limit in name size since a while, so stop pretending that they do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-28fat: detect media without partition table correctlyFrank Seidel
I received a complaint that some FAT formated medias (e.g. sd memory cards) trigger a "unknown partition table" message even though there is no partition table and they work correctly, while in general (when e.g. formated with mkdosfs or even Windows Vista) this message is not shown. Currently this seems only to happen when the medias get formatted with Windows XP (and possibly Win 2000). Then the boot indicator byte contains garbage (part of text message) and so do the other parts checked by msdos_paritition which then later triggers this message. References: novell bug #364365 Most fat formatted media without partition table contains zeros in the boot indication and the other tested bytes and so falls through the checks in msdos_partition, leading it to return with 1 (all is fine). But some (e.g. WinXP formatted) fat fomated medias don't use boot_ind and so the check fails and causes a "unkown partition table" warning eventhough there is none and everything would be fine. This additional check directly verifies if there is a fat formatted medium without a partition table. Signed-off-by: Frank Seidel <fseidel@suse.de> Cc: Andreas Dilger <adilger@sun.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19block: send disk "change" event for rescan_partitions()Kay Sievers
Userspace likes to get notified that the disk may have changed, when rescan_partitions() is called after partitioning or media change. It will make it possible to update the state of the disk with the "change" event, before the following partition "add" events are handled. Cc: David Zeuthen <david@fubar.dk> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-08Enhanced partition statistics: remove old partition statisticsJerome Marchand
Removes the now unused old partition statistic code. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-08Enhanced partition statistics: sysfsJerome Marchand
Reports enhanced partition statistics in sysfs. Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
2008-02-08Enhanced partition statistics: update partition statiticsJerome Marchand
Updates the enhanced partition statistics in generic block layer besides the disk statistics. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-07Block: Fix whole_disk attribute bugGreg Kroah-Hartman
The "whole_disk" attribute was not properly converted in the block device conversion earlier, and if the file is read, bad things can happen. This patch fixes this, making the attribute an empty one, preserving the original functionality. Many thanks to David Miller for finding this, and pointing me in the proper place within the block code to look. Acked-by: David S. Miller <davem@davemloft.net> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-06partition: use DEFAULT_SGI_PARTITION for SGI_PARTION defaultThomas Bogendoerfer
Use DEFAULT_SGI_PARTITION for SGI_PARTION default Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24Kobject: convert fs/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: convert block from raw kobjects to core devicesKay Sievers
This moves the block devices to /sys/class/block. It will create a flat list of all block devices, with the disks and partitions in one directory. For compatibility /sys/block is created and contains symlinks to the disks. /sys/class/block |-- sda -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda |-- sda1 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda1 |-- sda10 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda10 |-- sda5 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda5 |-- sda6 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda6 |-- sda7 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda7 |-- sda8 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda8 |-- sda9 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda9 `-- sr0 -> ../../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 /sys/block/ |-- sda -> ../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda `-- sr0 -> ../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert block_subsys to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename block_subsys to block_kset to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: get rid of kobject_add_dirGreg Kroah-Hartman
kobject_create_and_add is the same as kobject_add_dir, so drop kobject_add_dir. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-14fs/partitions/sun.c endianness annotationsAl Viro
2007-10-12kobjects: fix up improper use of the kobject name fieldGreg Kroah-Hartman
A number of different drivers incorrect access the kobject name field directly. This is not correct as the name might not be in the array. Use the proper accessor function instead.
2007-07-30[PARTITION]: Sun/Solaris VTOC table correctionsMark Fortescue
Start doing VTOC validation before using its contents. The validation is adjusted so as not to break existing setups that do not set the VTOC version, sanity and partition count entries. VTOC tables with more than 8 partitions will NOT be used. Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30[PARTITION] MSDOS: Fix Sun num_partitions handling.Mark Fortescue
Correct the Solaris x86 number of partitions (slices) is a way that is backward compatible with the earlier size. This works without a new VTOC structure definition as the timestamp and v_asciilabel fields in the VTOC are not used by the kernel yet. Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Fix LDM for new field in the VOL5 VBLK.Anton Altaparmakov
Teach LDM about a new field encountered with Windows Vista. This fixes LDM for people using Vista who have disabled drive letter assignment from one or more volumes. Doing this introduces a so far unknown field in the LDM database in the VOL5 VBLK structure which causes the LDM driver to fail to parse the VBLK structure and hence LDM fails to parse the disk altogether. This patch teaches the driver about this field. Thanks got to Ashton Mills <amills@iinet.com.au> for reporting the problem and working with me on getting it fixed. It is now working for him. Signed-off-by: Anton Altaparmakov <aia21@cantab.net> CC: Richard Russon <ldm@flatcap.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix compiler warnings in acorn.cDenver Gingerich
warning: 'adfs_partition' defined but not used warning: 'riscix_partition' defined but not used warning: 'linux_partition' defined but not used Signed-off-by: Denver Gingerich <denver@ossguy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10[S390] fixed cdl-format detection.Stefan Haberland
CDL formated DASDs are now detected correctly even if no VOL1 label is on the disk. This prevents possible loss of data. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-21partitions/LDM: build fixJeff Garzik
This from a "tested" patch... Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21LDM: Fix for Windows Vista dynamic disksAnton Altaparmakov
This fixes the LDM driver so that it works with Windows Vista dynamic disks which are subtly different to Windows 2000/XP ones. The patch was needed to get a Vista formatted dynamic disk to be recognized and parsed successfully. Thanks go to Chris Teachworth for the report and testing. Cc: Richard Russon <ldm@flatcap.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11small cleanup in gpt partition handlingOlaf Hering
Remove unused argument in is_pmbr_valid() Remove unneeded initialization of local variable legacy_mbr Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Let SYSV68_PARTITION default to yes on VME onlyGeert Uytterhoeven
Don't enable SYSV68 partition table support on all m68k boxes by default, only on Motorola VME boards. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08partition: add support for sysv68 partitionsPhilippe De Muyter
Add support for the Motorola sysv68 disk partition (slices in motorola doc). Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: optimize acorn partition truncatePeter Zijlstra
invalidate_bdev() is superfluous when truncate_inode_pages() is also called. do call invalidate_bh_lrus() though, to avoid stale pointers. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-16[PATCH] change misleading EFI partition support descriptionJohannes Berg
Remove the misleading "Presently only useful on the IA-64 platform" text from the EFI partition Kconfig. EFI partitions are also used by Apple on their Intel-based machines and thus you need EFI partition support if you (for example) want to attach such a machine in target disk mode. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] fix rescan_partitions to return errors properlysuzuki
The only error code which comes from the partition checkers is -1, when they finds an EIO. As per the discussion, ENOMEM values were ignored, as they might scare the users. So, with the current code, we end up returning -1 and not EIO for the ioctl() calls. Which doesn't give any clue to the user of what went wrong. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] check_partition(): fix error checksuzuki
Fix inverted check introduced in 57881dd9df40b76dc7fc6a0d13fd75f337accb32 "Fix check_partition routines". Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16Driver: remove redundant kobject_unregister checksMariusz Kozlowski
Here is a patch that removes all redundant kobject_unregister argument checks. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-11Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Update defconfig. [SPARC64]: Add PCI MSI support on Niagara. [SPARC64] IRQ: Use irq_desc->chip_data instead of irq_desc->handler_data [SPARC64]: Add obppath sysfs attribute for SBUS and PCI devices. [PARTITION]: Add whole_disk attribute.
2007-02-11[PATCH] msdos partitions: fix logic error in AIX detectionOlaf Hering
Correct the AIX magic check to let 'echo > /dev/sdb' actually work. Signed-off-by: Olaf Hering <olh@suse.de> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] relax check for AIX in msdos partition tableOlaf Hering
The patch to identify AIX disks and ignore them has caused at least one machine to fail to find the root partition on 2.6.19. The patch is: http://lkml.org/lkml/2006/7/31/117 The problem is some disk formatters do not blow away the first 4 bytes of the disk. If the disk we are installing to used to have AIX on it, then the first 4 bytes will still have IBMA in EBCDIC. The install in question was debian etch. Im not sure what the best fix is, perhaps the AIX detection code could check more than the first 4 bytes. The whole partition info for primary partitions is in this block: dd if=/dev/sdb count=$(( 4 * 16 )) bs=1 skip=$(( 0x1be )) All other data do not matter, beside the 0x55aa marker at the end of the first block. Signed-off-by: Olaf Hering <olh@suse.de> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[PARTITION]: Add whole_disk attribute.Fabio Massimo Di Nitto
Some partitioning systems create special partitions that span the entire disk. One example are Sun partitions, and this whole-disk partition exists to tell the firmware the extent of the entire device so it can load the boot block and do other things. Such partitions should not be treated as normal partitions, because all the other partitions overlap this whole-disk one. So we'd see multiple instances of the same UUID etc. which we do not want. udev and friends can thus search for this 'whole_disk' attribute and use it to decide to ignore the partition. Signed-off-by: Fabio Massimo Di Nitto <fabbione@ubuntu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-09[MIPS] Rename SNI_RM200_PCI to just SNI_RM preparing for more RM machinesThomas Bogendoerfer
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-08[PATCH] fault-injection capability for disk IOAkinobu Mita
This patch provides fault-injection capability for disk IO. Boot option: fail_make_request=<probability>,<interval>,<space>,<times> <interval> -- specifies the interval of failures. <probability> -- specifies how often it should fail in percent. <space> -- specifies the size of free space where disk IO can be issued safely in bytes. <times> -- specifies how many times failures may happen at most. Debugfs: /debug/fail_make_request/interval /debug/fail_make_request/probability /debug/fail_make_request/specifies /debug/fail_make_request/times Example: fail_make_request=10,100,0,-1 echo 1 > /sys/blocks/hda/hda1/make-it-fail generic_make_request() on /dev/hda1 fails once per 10 times. Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Fix check_partition routinesSuzuki K P
check_partition() stops its probe once it hits an I/O error from the partition checkers. This would prevent the actual partition checker getting a chance to verify the partition. So this patch lets check_partition() continue probing untill it hits a success while recording the I/O error which might have been reported by the checking routines. Also, it does some cleanup of the partition methods for ibm, atari and amiga to return -1 upon hitting an I/O error. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fix rescan_partitions to return errors properlySuzuki Kp
The current rescan_partition implementation ignores the errors that comes from the lower layer. It reports success for unknown partitions as well as I/O error cases while reading the partition information. The unknown partition is not (and will not be) considered as an error in the kernel, since there are legal users of it (e.g, members of a RAID5 MD Device or a new disk which is not partitioned at all ). Changing this behaviour would scare the user about a serious problem with their disk and is not recommended. Thus for both "unknown partitions" to the Linux (eg., DEC VMS,Novell Netware) and the legal users of NULL partition, would still be reported as "SUCCESS". The patch attached here, scares the user about something which he does need to worry about. i.e, returning -EIO on disk I/O errors while reading the partition information. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Cc: Erik Mouw <erik@harddisk-recovery.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] Enable RAID autorun on Mac partition tables.David Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] fs/partitions/check: add sysfs error handlingJeff Garzik
Handle errors thrown in disk_sysfs_symlinks(), and propagate back to caller. The callers and associated functions don't do a real good job of handling kobject errors anyway (add_partition, register_disk, rescan_partitions), so this should do until something better comes along. Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] fs/partitions endianness annotationsAl Viro
