SYSCALLx magic should take care of things, according to Linus...
new helper (wrapper around mnt_drop_write()) to be used in pair with
mnt_want_write_file().
In setlease, we use i_writecount to decide whether we can give out a
read lease.
In open, we break leases before incrementing i_writecount.
There is therefore a window between the break lease and the i_writecount
increment when setlease could add a new read lease.
This would leave us with a simultaneous write open and read lease, which
shouldn't happen.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
The kludge in question is undocumented and doesn't work for 32bit
binaries on amd64, sparc64 and s390. Passing (mode_t)-1 as
mode had (since 0.99.14v and contrary to behaviour of any
other Unix, prescriptions of POSIX, SuS and our own manpages)
was kinda-sorta no-op. Note that any software relying on
that (and looking for examples shows none) would be visibly
broken on sparc64, where practically all userland is built
32bit. No such complaints noticed...
Replace unclear (struct dentry *) to (struct file *) typecast with ERR_CAST() macro.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
dentry_open() requires callers to pass a valid vfsmount.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits)
AppArmor: kill unused macros in lsm.c
AppArmor: cleanup generated files correctly
KEYS: Add an iovec version of KEYCTL_INSTANTIATE
KEYS: Add a new keyctl op to reject a key with a specified error code
KEYS: Add a key type op to permit the key description to be vetted
KEYS: Add an RCU payload dereference macro
AppArmor: Cleanup make file to remove cruft and make it easier to read
SELinux: implement the new sb_remount LSM hook
LSM: Pass -o remount options to the LSM
SELinux: Compute SID for the newly created socket
SELinux: Socket retains creator role and MLS attribute
SELinux: Auto-generate security_is_socket_class
TOMOYO: Fix memory leak upon file open.
Revert "selinux: simplify ioctl checking"
selinux: drop unused packet flow permissions
selinux: Fix packet forwarding checks on postrouting
selinux: Fix wrong checks for selinux_policycap_netpeer
selinux: Fix check for xfrm selinux context algorithm
ima: remove unnecessary call to ima_must_measure
IMA: remove IMA imbalance checking
For readlinkat() we simply allow empty pathname; it will fail unless
we have dfd equal to O_PATH-opened symlink, so we are outside of
POSIX scope here. For fchownat() and fstatat() we allow AT_EMPTY_PATH;
let the caller explicitly ask for such behaviour.
New flag for open(2) - O_PATH. Semantics:
* pathname is resolved, but the file itself is _NOT_ opened
as far as filesystem is concerned.
* almost all operations on the resulting descriptors shall
fail with -EBADF. Exceptions are:
1) operations on descriptors themselves (i.e.
close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD),
fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD),
fcntl(fd, F_SETFD, ...))
2) fcntl(fd, F_GETFL), for a common non-destructive way to
check if descriptor is open
3) "dfd" arguments of ...at(2) syscalls, i.e. the starting
points of pathname resolution
* closing such descriptor does *NOT* affect dnotify or
posix locks.
* permissions are checked as usual along the way to file;
no permission checks are applied to the file itself. Of course,
giving such thing to syscall will result in permission checks (at
the moment it means checking that starting point of ....at() is
a directory and caller has exec permissions on it).
fget() and fget_light() return NULL on such descriptors; use of
fget_raw() and fget_raw_light() is needed to get them. That protects
existing code from dealing with those things.
There are two things still missing (they come in the next commits):
one is handling of symlinks (right now we refuse to open them that
way; see the next commit for semantics related to those) and another
is descriptor passing via SCM_RIGHTS datagrams.
new function: file_open_root(dentry, mnt, name, flags) opens the file
vfs_path_lookup would arrive to.
Note that name can be empty; in that case the usual requirement that
dentry should be a directory is lifted.
open-coded equivalents switched to it, may_open() got down exactly
one caller and became static.
take calculation of open_flags by open(2) arguments into new helper
in fs/open.c, move filp_open() over there, have it and do_sys_open()
use that helper, switch exec.c callers of do_filp_open() to explicit
(and constant) struct open_flags.
In the fallocate path the kernel doesn't check for the immutable/append
flag. It's possible to have a race condition in this scenario: an
application open a file in read/write and it does something, meanwhile
root set the immutable flag on the file, the application at that point
can call fallocate with success. In addition, we don't allow to do any
unreserve operation on an append only file but only the reserve one.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
In commit 31e6b01f4183 ("fs: rcu-walk for path lookup") we started doing
path lookup using RCU, which then falls back to a careful non-RCU lookup
in case of problems (LOOKUP_REVAL). So do_filp_open() has this "re-do
the lookup carefully" looping case.
However, that means that we must not release the open-intent file data
if we are going to loop around and use it once more!
Fix this by moving the release of the open-intent data to the function
that allocates it (do_filp_open() itself) rather than the helper
functions that can get called multiple times (finish_open() and
do_last()). This makes the logic for the lifetime of that field much
more obvious, and avoids the possible double free.
Reported-by: J. R. Okajima <hooanon05@yahoo.co.jp>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nick Piggin <npiggin@kernel.dk>
ima_counts_get() updated the readcount and invalidated the PCR,
as necessary. Only update the i_readcount in the VFS layer.
Move the PCR invalidation checks to ima_file_check(), where it
belongs.
Maintaining the i_readcount in the VFS layer, will allow other
subsystems to use i_readcount.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Acked-by: Eric Paris <eparis@redhat.com>
Currently all filesystems except XFS implement fallocate asynchronously,
while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC
I/O we really want our allocation on disk, especially for the !KEEP_SIZE
case where we actually grow the file with user-visible zeroes. On the
other hand always commiting the transaction is a bad idea for fast-path
uses of fallocate like for example in recent Samba versions. Given
that block allocation is a data plane operation anyway change it from
an inode operation to a file operation so that we have the file structure
available that lets us check for O_SYNC.
This also includes moving the code around for a few of the filesystems,
and remove the already unnedded S_ISDIR checks given that we only wire
up fallocate for regular files.
Hole punching has already been implemented by XFS and OCFS2, and has the
potential to be implemented on both BTRFS and EXT4 so we need a generic way to
get to this feature. The simplest way in my mind is to add FALLOC_FL_PUNCH_HOLE
to fallocate() since it already looks like the normal fallocate() operation.
I've tested this patch with XFS and BTRFS to make sure XFS did what it's
supposed to do and that BTRFS failed like it was supposed to. Thank you,
Signed-off-by: Josef Bacik <josef@redhat.com>
nameidata_to_filp() drops nd->path or transfers it to opened
file. In the former case it's a Bad Idea(tm) to do mnt_drop_write()
on nd->path.mnt, since we might race with umount and vfsmount in
question might be gone already.
Fix: don't drop it, then... IOW, have nameidata_to_filp() grab nd->path
in case it transfers it to file and do path_drop() in callers. After
they are through with accessing nd->path...
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
fs: cleanup files_lock locking
Lock tty_files with a new spinlock, tty_files_lock; provide helpers to
manipulate the per-sb files list; unexport the files_lock spinlock.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Acked-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Acked-by: John Kacur <jkacur@redhat.com>
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits)
fanotify: use both marks when possible
fsnotify: pass both the vfsmount mark and inode mark
fsnotify: walk the inode and vfsmount lists simultaneously
fsnotify: rework ignored mark flushing
fsnotify: remove global fsnotify groups lists
fsnotify: remove group->mask
fsnotify: remove the global masks
fsnotify: cleanup should_send_event
fanotify: use the mark in handler functions
audit: use the mark in handler functions
dnotify: use the mark in handler functions
inotify: use the mark in handler functions
fsnotify: send fsnotify_mark to groups in event handling functions
fsnotify: Exchange list heads instead of moving elements
fsnotify: srcu to protect read side of inode and vfsmount locks
fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called
fsnotify: use _rcu functions for mark list traversal
fsnotify: place marks on object in order of group memory address
vfs/fsnotify: fsnotify_close can delay the final work in fput
fsnotify: store struct file not struct path
Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
Currently MAY_ACCESS means that filesystems must check the permissions
right then and not rely on cached results or the results of future
operations on the object. This can be because of a call to sys_access() or
because of a call to chdir() which needs to check search without relying on
any future operations inside that dir. I plan to use MAY_ACCESS for other
purposes in the security system, so I split the MAY_ACCESS and the
MAY_CHDIR cases.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
When commit be6d3e56a6b9b3a4ee44a0685e39e595073c6f0d "introduce new LSM hooks
where vfsmount is available." was proposed, regarding security_path_truncate(),
only "struct file *" argument (which AppArmor wanted to use) was removed.
But length and time_attrs arguments are not used by TOMOYO nor AppArmor.
Thus, let's remove these arguments.
Acked-by: Nick Piggin <npiggin@suse.de>
fanotify, the upcoming notification system actually needs a struct path so it can
do opens in the context of listeners, and it needs a file so it can get f_flags
from the original process. Close was the only operation that already was passing
a struct file to the notification hook. This patch passes a file for access,
modify, and open as well as they are easily available to these hooks.
nothing uses inotify in the kernel, drop it!
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits)
quota: stop using QUOTA_OK / NO_QUOTA
dquot: cleanup dquot initialize routine
dquot: move dquot initialization responsibility into the filesystem
dquot: cleanup dquot drop routine
dquot: move dquot drop responsibility into the filesystem
dquot: cleanup dquot transfer routine
dquot: move dquot transfer responsibility into the filesystem
dquot: cleanup inode allocation / freeing routines
dquot: cleanup space allocation / freeing routines
ext3: add writepage sanity checks
ext3: Truncate allocated blocks if direct IO write fails to update i_size
quota: Properly invalidate caches even for filesystems with blocksize < pagesize
quota: generalize quota transfer interface
quota: sb_quota state flags cleanup
jbd: Delay discarding buffers in journal_unmap_buffer
ext3: quota_write cross block boundary behaviour
quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota
quota: split out compat_sys_quotactl support from quota.c
quota: split out netlink notification support from quota.c
quota: remove invalid optimization from quota_sync_all
Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
Currently various places in the VFS call vfs_dq_init directly. This means
we tie the quota code into the VFS. Get rid of that and make the
filesystem responsible for the initialization. For most metadata operations
this is a straight forward move into the methods, but for truncate and
open it's a bit more complicated.
For truncate we currently only call vfs_dq_init for the sys_truncate case
because open already takes care of it for ftruncate and open(O_TRUNC) - the
new code causes an additional vfs_dq_init for those which is harmless.
For open the initialization is moved from do_filp_open into the open method,
which means it happens slightly earlier now, and only for regular files.
The latter is fine because we don't need to initialize it for operations
on special files, and we already do it as part of the namespace operations
for directories.
Add a dquot_file_open helper that filesystems that support generic quotas
can use to fill in ->open.
... instead of mixing FMODE_ and O_
* pull ACC_MODE to fs.h; we have several copies all over the place
* nightmarish expression calculating f_mode by f_flags deserves a helper
too (OPEN_FMODE(flags))
Just set f_flags when shoving struct file into nameidata; don't
postpone that until __dentry_open(). do_filp_open() has correct
value; lookup_instantiate_filp() doesn't - we lose the difference
between O_RDWR and 3 by that point.
We still set .intent.open.flags, so no fs code needs to be changed.
* do ima_get_count() in __dentry_open()
* stop doing that in followups
* move ima_path_check() to right after nameidata_to_filp()
* don't bump counters on it
All users outside of fs/ of get_empty_filp() have been removed. This patch
moves the definition from the include/ directory to internal.h so no new
users crop up and removes the EXPORT_SYMBOL. I'd love to see open intents
stop using it too, but that's a problem for another day and a smarter
developer!
Acked-by: Miklos Szeredi <miklos@szeredi.hu>
We should call security_path_chmod()/security_path_chown() after mutex_lock()
in order to avoid races.
Acked-by: John Johansen <john.johansen@canonical.com>
This patch allows pathname based LSM modules to check chroot() operations.
This hook is used by TOMOYO.
This patch allows pathname based LSM modules to check chmod()/chown()
operations. Since notify_change() does not receive "struct vfsmount *",
we add security_path_chmod() and security_path_chown() to the caller of
notify_change().
These hooks are used by TOMOYO.
For this system call user space passes a signed long length parameter,
while the kernel side takes an unsigned long parameter and converts it
later to signed long again.
This has led to bugs in compat wrappers see e.g. dd90bbd5 "powerpc: Add
compat_sys_truncate". The s390 compat wrapper for this functions is
broken as well since it also performs zero extension instead of sign
extension for the length parameter.
In addition if hpa comes up with an automated way of generating
compat wrappers it would generate a wrong one here.
So change the length parameter from unsigned long to long.
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking
for credential management. The additional code keeps track of the number of
pointers from task_structs to any given cred struct, and checks to see that
this number never exceeds the usage count of the cred struct (which includes
all references, not just those from task_structs).
Furthermore, if SELinux is enabled, the code also checks that the security
pointer in the cred struct is never seen to be invalid.
This attempts to catch the bug whereby inode_has_perm() faults in an nfsd
kernel thread on seeing cred->security be a NULL pointer (it appears that the
credential struct has been previously released):
http://www.kerneloops.org/oops.php?number=252883
When suid is set and the non-owner user has write permission, any writing
into this file should be allowed and suid should be removed after that.
However, current kernel only allows writing without truncations, when we
do truncations on that file, we get EPERM. This is a bug.
Steps to reproduce this bug:
% ls -l rootdir/file1
-rwsrwsrwx 1 root root 3 Jun 25 15:42 rootdir/file1
% echo h > rootdir/file1
zsh: operation not permitted: rootdir/file1
% echo h >> rootdir/file1
-rwxrwxrwx 1 root root 5 Jun 25 16:34 rootdir/file1
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Eric Sandeen <esandeen@redhat.com>
Cc: Eugene Teo <eteo@redhat.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
ioctls
This patch adds ioctls to vfs for compatibility with legacy XFS
pre-allocation ioctls (XFS_IOC_*RESVP*). The implementation
effectively invokes sys_fallocate for the new ioctls.
Also handles the compat_ioctl case.
Note: These legacy ioctls are also implemented by OCFS2.
[AV: folded fixes from hch]
Signed-off-by: Ankit Jain <me@ankitjain.org>
This patch speeds up lmbench lat_mmap test by about another 2% after the
first patch.
Before:
avg = 462.286
std = 5.46106
After:
avg = 453.12
std = 9.58257
(50 runs of each, stddev gives a reasonable confidence)
It does this by introducing mnt_clone_write, which avoids some heavyweight
operations of mnt_want_write if called on a vfsmount which we know already
has a write count; and mnt_want_write_file, which can call mnt_clone_write
if the file is open for write.
After these two patches, mnt_want_write and mnt_drop_write go from 7% on
the profile down to 1.3% (including mnt_clone_write).
[AV: mnt_want_write_file() should take file alone and derive mnt from it;
not only all callers have that form, but that's the only mnt about which
we know that it's already held for write if file is opened for write]
Cc: Dave Hansen <haveblue@us.ibm.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
... and make path_lookup_open() static
Don't pull it in sched.h; very few files actually need it and those
can include directly. sched.h itself only needs forward declaration
of struct fs_struct;
Use lowercase names of quota functions instead of old uppercase ones.
CC: Alexander Viro <viro@zeniv.linux.org.uk>
