commit f7cf4f5bfe073ad792ab49c04f247626b3e38db6 upstream.
Do not put bh when buffer_uptodate failed in ocfs2_write_block and
ocfs2_write_super_or_backup, because it will put bh in b_end_io.
Otherwise it will hit a warning "VFS: brelse: Trying to free free
buffer".
Signed-off-by: Alex Chen <alex.chen@huawei.com>
Reviewed-by: Joseph Qi <joseph.qi@huawei.com>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Acked-by: Joel Becker <jlbec@evilplan.org>
commit ded2cf71419b9353060e633b59e446c42a6a2a09 upstream.
There is a race window in dlm_do_recovery() between dlm_remaster_locks()
and dlm_reset_recovery() when the recovery master nearly finish the
recovery process for a dead node. After the master sends FINALIZE_RECO
message in dlm_remaster_locks(), another node may become the recovery
master for another dead node, and then send the BEGIN_RECO message to
all the nodes included the old master, in the handler of this message
dlm_begin_reco_handler() of old master, dlm->reco.dead_node and
dlm->reco.new_master will be set to the second dead node and the new
master, then in dlm_reset_recovery(), these two variables will be reset
to default value. This will cause new recovery master can not finish
the recovery process and hung, at last the whole cluster will hung for
recovery.
old recovery master: new recovery master:
become recovery master for
another dead node.
dlm_send_begin_reco_message()
if (dlm->reco.state & DLM_RECO_STATE_FINALIZE) {
return -EAGAIN;
dlm_set_reco_master(dlm, br->node_idx);
dlm_set_reco_dead_node(dlm, br->dead_node);
dlm_set_reco_dead_node(dlm, O2NM_INVALID_NODE_NUM);
dlm_set_reco_master(dlm, O2NM_INVALID_NODE_NUM);
will hang in dlm_remaster_locks() for
request dlm locks info
Before send FINALIZE_RECO message, recovery master should set
DLM_RECO_STATE_FINALIZE for itself and clear it after the recovery done,
this can break the race windows as the BEGIN_RECO messages will not be
handled before DLM_RECO_STATE_FINALIZE flag is cleared.
A similar race may happen between new recovery master and normal node
which is in dlm_finalize_reco_handler(), also fix it.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com>
commit 34aa8dac482f1358d59110d5e3a12f4351f6acaa upstream.
This issue was introduced by commit 800deef3f6f8 ("ocfs2: use
list_for_each_entry where benefical") in 2007 where it replaced
list_for_each with list_for_each_entry. The variable "lock" will point
to invalid data if "tmpq" list is empty and a panic will be triggered
due to this. Sunil advised reverting it back, but the old version was
also not right. At the end of the outer for loop, that
list_for_each_entry will also set "lock" to an invalid data, then in the
next loop, if the "tmpq" list is empty, "lock" will be an stale invalid
data and cause the panic. So reverting the list_for_each back and reset
"lock" to NULL to fix this issue.
Another concern is that this seemes can not happen because the "tmpq"
list should not be empty. Let me describe how.
old lock resource owner(node 1): migratation target(node 2):
image there's lockres with a EX lock from node 2 in
granted list, a NR lock from node x with convert_type
EX in converting list.
dlm_empty_lockres() {
dlm_pick_migration_target() {
pick node 2 as target as its lock is the first one
in granted list.
dlm_migrate_lockres() {
dlm_mark_lockres_migrating() {
res->state |= DLM_LOCK_RES_BLOCK_DIRTY;
wait_event(dlm->ast_wq, !dlm_lockres_is_dirty(dlm, res));
//after the above code, we can not dirty lockres any more,
// so dlm_thread shuffle list will not run
downconvert lock from EX to NR
upconvert lock from NR to EX
<<< migration may schedule out here, then
<<< node 2 send down convert request to convert type from EX to
<<< NR, then send up convert request to convert type from NR to
<<< EX, at this time, lockres granted list is empty, and two locks
<<< in the converting list, node x up convert lock followed by
<<< node 2 up convert lock.
// will set lockres RES_MIGRATING flag, the following
// lock/unlock can not run
dlm_lockres_release_ast(dlm, res);
dlm_send_one_lockres()
dlm_process_recovery_data()
for (i=0; i<mres->num_locks; i++)
if (ml->node == dlm->node_num)
for (j = DLM_GRANTED_LIST; j <= DLM_BLOCKED_LIST; j++) {
list_for_each_entry(lock, tmpq, list)
if (lock) break; <<< lock is invalid as grant list is empty.
if (lock->ml.node != ml->node)
BUG() >>> crash here
I see the above locks status from a vmcore of our internal bug.
Cc: Sunil Mushran <sunil.mushran@gmail.com>
commit 1b56e98990bcdbb20b9fab163654b9315bf158e8 upstream.
commit 15c34a760630ca2c803848fba90ca0646a9907dd upstream.
Global quota files are accessed from different nodes. Thus we cannot
cache offset of quota structure in the quota file after we drop our node
reference count to it because after that moment quota structure may be
freed and reallocated elsewhere by a different node resulting in
corruption of quota file.
Fix the problem by clearing dq_off when we are releasing dquot structure.
We also remove the DB_READ_B handling because it is useless -
DQ_ACTIVE_B is set iff DQ_READ_B is set.
Cc: Goldwyn Rodrigues <rgoldwyn@suse.de>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream.
Call fiemap ioctl(2) with given start offset as well as an desired mapping
range should show extents if possible. However, we somehow figure out the
end offset of mapping via 'mapping_end -= cpos' before iterating the
extent records which would cause problems if the given fiemap length is
too small to a cluster size, e.g,
Cluster size 4096:
debugfs.ocfs2 1.6.3
Block Size Bits: 12 Cluster Size Bits: 12
The extended fiemap test utility From David:
https://gist.github.com/anonymous/6172331
# dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000
# ./fiemap /ocfs2/test_file 4096 10
start: 4096, length: 10
File /ocfs2/test_file has 0 extents:
# Logical Physical Length Flags
^^^^^ <-- No extent is shown
In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the
loop of searching extent records was not executed at all.
This patch remove the in question 'mapping_end -= cpos', and loops
until the cpos is larger than the mapping_end as usual.
File /ocfs2/test_file has 1 extents:
0: 0000000000000000 0000000056a01000 0000000006a00000 0000
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reported-by: David Weber <wb@munzinger.de>
Tested-by: David Weber <wb@munzinger.de>
Cc: Mark Fashen <mfasheh@suse.de>
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream.
Inlined xattr shared free space of inode block with inlined data or data
extent record, so the size of the later two should be adjusted when
inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't
done well when reflink. For inode with inlined data, its max inlined
data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But
for inode with data extent record, its record count isn't adjusted. Fix
it, or data extent record and inlined xattr may overwrite each other,
then cause data corruption or xattr failure.
One panic caused by this bug in our test environment is the following:
kernel BUG at fs/ocfs2/xattr.c:1435!
invalid opcode: 0000 [#1] SMP
Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1
RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2]
RSP: e02b:ffff88007a587948 EFLAGS: 00010283
RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4
RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68
RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010
R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68
FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660
Process multi_reflink_t
Call Trace:
ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2]
ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2]
ocfs2_xa_set+0xcc/0x250 [ocfs2]
ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2]
__ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2]
ocfs2_xattr_set+0x6c6/0x890 [ocfs2]
ocfs2_xattr_user_set+0x46/0x50 [ocfs2]
generic_setxattr+0x70/0x90
__vfs_setxattr_noperm+0x80/0x1a0
vfs_setxattr+0xa9/0xb0
setxattr+0xc3/0x120
sys_fsetxattr+0xa8/0xd0
system_call_fastpath+0x16/0x1b
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
dlm_mig_lockres_handler() is missing a dlm_lockres_put() on an error path.
Signed-off-by: joyce <xuejiufei@huawei.com>
Reviewed-by: shencanquan <shencanquan@huawei.com>
While removing a non-empty directory, the kernel dumps a message:
(rmdir,21743,1):ocfs2_unlink:953 ERROR: status = -39
Suppress the error message from being printed in the dmesg so users
don't panic.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
If an error occurs, for example an EIO in __ocfs2_prepare_orphan_dir,
ocfs2_prep_new_orphaned_file will release the inode_ac, then when the
caller of ocfs2_prep_new_orphaned_file gets a 0 return, it will refer to
a NULL ocfs2_alloc_context struct in the following functions. A kernel
panic happens.
Signed-off-by: "Xiaowei.Hu" <xiaowei.hu@oracle.com>
Cc: Joe Jin <joe.jin@oracle.com>
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and
then we did a thorough search for all lock resources in
ocfs2_inode_info, including rw, inode and open lockres and found this
bug. My kernel version is 3.0.13, and it is also in the lastest version
3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should
goto out_unlock instead of out, because we need release buffer head, up
read alloc sem and unlock inode.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Cc: <stable@vger.kernel.org>
In ocfs2_file_aio_write(), it does ocfs2_rw_lock() first and then
ocfs2_inode_lock().
But if ocfs2_inode_lock() failed, it goes to out_sems without unlocking
rw lock. This will cause a bug in ocfs2_lock_res_free() when testing
res->l_ex_holders, which is increased in __ocfs2_cluster_lock() and
decreased in __ocfs2_cluster_unlock().
Cc: Li Zefan <lizefan@huawei.com>
Cc: "Duyongfeng (B)" <du.duyongfeng@huawei.com>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
This removes the retry-based AIO infrastructure now that nothing in tree
is using it.
We want to remove retry-based AIO because it is fundemantally unsafe.
It retries IO submission from a kernel thread that has only assumed the
mm of the submitting task. All other task_struct references in the IO
submission path will see the kernel thread, not the submitting task.
This design flaw means that nothing of any meaningful complexity can use
retry-based AIO.
This removes all the code and data associated with the retry machinery.
The most significant benefit of this is the removal of the locking
around the unused run list in the submission path.
Signed-off-by: Zach Brown <zab@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
kfree on a NULL pointer is a no-op. Remove the redundant null pointer
check.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Mark Fasheh <mfasheh@suse.de>
We can't dereference "bg" before it has been assigned. GCC should have
warned about this but "bg" was initialized to NULL. I've fixed that as
well.
Smatch complains that if we hit an error (for example if the file is
immutable) then "range" has uninitialized stack data and we copy it to
the user.
I've re-written the error handling to avoid this problem and make it a
little cleaner as well.
Fix to return a negative error code from the error handling case instead
of 0, as returned elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
There is no need to start the inode update transactions before/while
verifying the input flags. As a refinement, this patch delay the
transactions utill the pre-check up is ok.
now it can be done - put mutex into pipe_inode_info, use it instead
of ->i_mutex
Add missing MODULE_ALIAS_FS("ocfs2") how did I miss that?
Remove unnecessary MODULE_ALIAS_FS("devpts") devpts can not be modular.
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Convert to the much saner new idr interface.
ocfs2_block_group_alloc_discontig() disables chain relink by setting
ac->ac_allow_chain_relink = 0 because it grabs clusters from multiple
cluster groups.
It doesn't keep the credits for all chain relink,but
ocfs2_claim_suballoc_bits overrides this in this call trace:
ocfs2_block_group_claim_bits()->ocfs2_claim_clusters()->
__ocfs2_claim_clusters()->ocfs2_claim_suballoc_bits()
ocfs2_claim_suballoc_bits set ac->ac_allow_chain_relink = 1; then call
ocfs2_search_chain() one time and disable it again, and then we run out
of credits.
Fix is to allow relink by default and disable it in
ocfs2_block_group_alloc_discontig.
Without this patch, End-users will run into a crash due to run out of
credits, backtrace like this:
RIP: 0010:[<ffffffffa0808b14>] [<ffffffffa0808b14>]
jbd2_journal_dirty_metadata+0x164/0x170 [jbd2]
RSP: 0018:ffff8801b919b5b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff88022139ddc0 RCX: ffff880159f652d0
RDX: ffff880178aa3000 RSI: ffff880159f652d0 RDI: ffff880087f09bf8
RBP: ffff8801b919b5e8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000001e00 R11: 00000000000150b0 R12: ffff880159f652d0
R13: ffff8801a0cae908 R14: ffff880087f09bf8 R15: ffff88018d177800
FS: 00007fc9b0b6b6e0(0000) GS:ffff88022fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000040819c CR3: 0000000184017000 CR4: 00000000000006e0
Process dd (pid: 9945, threadinfo ffff8801b919a000, task ffff880149a264c0)
Call Trace:
ocfs2_journal_dirty+0x2f/0x70 [ocfs2]
ocfs2_relink_block_group+0x111/0x480 [ocfs2]
ocfs2_search_chain+0x455/0x9a0 [ocfs2]
Signed-off-by: Xiaowei.Hu <xiaowei.hu@oracle.com>
We need to re-initialize the security for a new reflinked inode with its
parent dirs if it isn't specified to be preserved for ocfs2_reflink().
However, the code logic is broken at ocfs2_init_security_and_acl()
although ocfs2_init_security_get() succeed. As a result,
ocfs2_acl_init() does not involked and therefore the default ACL of
parent dir was missing on the new inode.
Note this was introduced by 9d8f13ba3 ("security: new
security_inode_init_security API adds function callback")
To reproduce:
set default ACL for the parent dir(ocfs2 in this case):
$ setfacl -m default:user:jeff:rwx ../ocfs2/
$ getfacl ../ocfs2/
# file: ../ocfs2/
# owner: jeff
# group: jeff
user::rwx
group::r-x
other::r-x
default:user::rwx
default:group::r-x
default:mask::rwx
default:other::r-x
$ touch a
$ getfacl a
# file: a
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
Before patching, create reflink file b from a, the user
default ACL entry(user:jeff:rwx)was missing:
$ ./ocfs2_reflink a b
$ getfacl b
# file: b
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
In this case, the end user can also observed an error message at syslog:
(ocfs2_reflink,3229,2):ocfs2_init_security_and_acl:7193 ERROR: status = 0
After applying this patch, create reflink file c from a:
$ ./ocfs2_reflink a c
$ getfacl c
# file: c
# owner: jeff
# group: jeff
user::rw-
user:jeff:rwx #effective:rw-
group::r-x #effective:r--
mask::rw-
other::r--
Test program:
/* Usage: reflink <source> <dest> */
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <errno.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
static int
reflink_file(char const *src_name, char const *dst_name,
bool preserve_attrs)
int fd;
#ifndef REFLINK_ATTR_NONE
# define REFLINK_ATTR_NONE 0
#endif
#ifndef REFLINK_ATTR_PRESERVE
# define REFLINK_ATTR_PRESERVE 1
#endif
#ifndef OCFS2_IOC_REFLINK
struct reflink_arguments {
uint64_t old_path;
uint64_t new_path;
uint64_t preserve;
# define OCFS2_IOC_REFLINK _IOW ('o', 4, struct reflink_arguments)
#endif
struct reflink_arguments args = {
.old_path = (unsigned long) src_name,
.new_path = (unsigned long) dst_name,
.preserve = preserve_attrs ? REFLINK_ATTR_PRESERVE :
REFLINK_ATTR_NONE,
fd = open(src_name, O_RDONLY);
if (fd < 0) {
fprintf(stderr, "Failed to open %s: %s\n",
src_name, strerror(errno));
return -1;
if (ioctl(fd, OCFS2_IOC_REFLINK, &args) < 0) {
fprintf(stderr, "Failed to reflink %s to %s: %s\n",
src_name, dst_name, strerror(errno));
return -1;
int
main(int argc, char *argv[])
if (argc != 3) {
fprintf(stdout, "Usage: %s source dest\n", argv[0]);
return 1;
return reflink_file(argv[1], argv[2], 0);
Reviewed-by: Tao Ma <boyu.mt@taobao.com>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull ext2, ext3, udf updates from Jan Kara:
"Several UDF fixes, a support for UDF extent cache, and couple of ext2
and ext3 cleanups and minor fixes"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
Ext2: remove the static function release_blocks to optimize the kernel
Ext2: mark inode dirty after the function dquot_free_block_nodirty is called
Ext2: remove the overhead check about sb in the function ext2_new_blocks
udf: Remove unused s_extLength from udf_bitmap
udf: Make s_block_bitmap standard array
udf: Fix bitmap overflow on large filesystems with small block size
udf: add extent cache support in case of file reading
udf: Write LVID to disk after opening / closing
Ext3: return ENOMEM rather than EIO if sb_getblk fails
Ext2: return ENOMEM rather than EIO if sb_getblk fails
Ext3: use unlikely to improve the efficiency of the kernel
Ext2: use unlikely to improve the efficiency of the kernel
Ext3: add necessary check in case IO error happens
Ext2: free memory allocated and forget buffer head when io error happens
ext3: Fix memory leak when quota options are specified multiple times
ext3, ext4, ocfs2: remove unused macro NAMEI_RA_INDEX
My static checker complains that this is called with a spin_lock held
in dlm_master_requery_handler() from dlmrecovery.c. Probably the reason
we have not received any bug reports about this is that recovery is not
a common operation.
Signed-off-by: Joel Becker <jlbec@evilplan.org>
Running AIO is pinning inode in memory using file reference. Once AIO
is completed using aio_complete(), file reference is put and inode can
be freed from memory. So we have to be sure that calling aio_complete()
is the last thing we do with the inode.
Commit ea022dfb3c2a4680483b00eb2fecc9fc4f6091d1 was missing a var init.
Reported-and-Tested-by: Vincent Etienne <vetienne@aprogsys.com>
Signed-off-by: Sunil Mushran <sunil.mushran@gmail.com>
This patch is a follow up on below patch:
[PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type
commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Vivek Trivedi <t.vivek@samsung.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Sage Weil <sage@inktank.com>
very few users left...
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace and namespace infrastructure changes from Eric W Biederman:
"This set of changes starts with a few small enhnacements to the user
namespace. reboot support, allowing more arbitrary mappings, and
support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the
user namespace root.
I do my best to document that if you care about limiting your
unprivileged users that when you have the user namespace support
enabled you will need to enable memory control groups.
There is a minor bug fix to prevent overflowing the stack if someone
creates way too many user namespaces.
The bulk of the changes are a continuation of the kuid/kgid push down
work through the filesystems. These changes make using uids and gids
typesafe which ensures that these filesystems are safe to use when
multiple user namespaces are in use. The filesystems converted for
3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The
changes for these filesystems were a little more involved so I split
the changes into smaller hopefully obviously correct changes.
XFS is the only filesystem that remains. I was hoping I could get
that in this release so that user namespace support would be enabled
with an allyesconfig or an allmodconfig but it looks like the xfs
changes need another couple of days before it they are ready."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits)
cifs: Enable building with user namespaces enabled.
cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t
cifs: Convert struct cifs_sb_info to use kuids and kgids
cifs: Modify struct smb_vol to use kuids and kgids
cifs: Convert struct cifsFileInfo to use a kuid
cifs: Convert struct cifs_fattr to use kuid and kgids
cifs: Convert struct tcon_link to use a kuid.
cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t
cifs: Convert from a kuid before printing current_fsuid
cifs: Use kuids and kgids SID to uid/gid mapping
cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc
cifs: Use BUILD_BUG_ON to validate uids and gids are the same size
cifs: Override unmappable incoming uids and gids
nfsd: Enable building with user namespaces enabled.
nfsd: Properly compare and initialize kuids and kgids
nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids
nfsd: Modify nfsd4_cb_sec to use kuids and kgids
nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion
nfsd: Convert nfsxdr to use kuids and kgids
nfsd: Convert nfs3xdr to use kuids and kgids
Pull trivial tree from Jiri Kosina:
"Assorted tiny fixes queued in trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits)
DocBook: update EXPORT_SYMBOL entry to point at export.h
Documentation: update top level 00-INDEX file with new additions
ARM: at91/ide: remove unsused at91-ide Kconfig entry
percpu_counter.h: comment code for better readability
x86, efi: fix comment typo in head_32.S
IB: cxgb3: delay freeing mem untill entirely done with it
net: mvneta: remove unneeded version.h include
time: x86: report_lost_ticks doesn't exist any more
pcmcia: avoid static analysis complaint about use-after-free
fs/jfs: Fix typo in comment : 'how may' -> 'how many'
of: add missing documentation for of_platform_populate()
btrfs: remove unnecessary cur_trans set before goto loop in join_transaction
sound: soc: Fix typo in sound/codecs
treewide: Fix typo in various drivers
btrfs: fix comment typos
Update ibmvscsi module name in Kconfig.
powerpc: fix typo (utilties -> utilities)
of: fix spelling mistake in comment
h8300: Fix home page URL in h8300/README
xtensa: Fix home page URL in Kconfig
When stable pages are required, we have to wait if the page is just
going to disk and we want to modify it. Add proper callback to
ocfs2_grab_pages_for_write().
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
If lockres refresh failed, the super lock will never be released which
will cause some processes on other cluster nodes hung forever.
smatch analysis indicates a number of redundant NULL checks before
calling kfree(), eg:
fs/ocfs2/alloc.c:6138 ocfs2_begin_truncate_log_recovery() info:
redundant null check on *tl_copy calling kfree()
fs/ocfs2/alloc.c:6755 ocfs2_zero_range_for_truncate() info:
redundant null check on pages calling kfree()
etc....
[akpm@linux-foundation.org: revert dubious change in ocfs2_begin_truncate_log_recovery()]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Convert between uid and gids stored in the on the wire format of dlm
locks aka struct ocfs2_meta_lvb and kuids and kgids stored in
inode->i_uid and inode->i_gid.
Explicitly deal with the different kinds of acls because they need
different conversions.
drivers/devfreq/exynos4_bus.c
Sync with Linus' tree to be able to apply patches that are
against newer code (mvneta).
This macro, initially introduced by ext2 in v0.99.15, does not
have any users from the beginning. It has been removed in later
ext2 version but still remains in the code of ext3, ext4, ocfs2.
Remove this macro there.
Cc: Jan Kara <jack@suse.cz>
Cc: linux-ext4@vger.kernel.org
Cc: ocfs2-devel@oss.oracle.com
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
Correct spelling typo in printk within various drivers.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
