path: root/fs/ocfs2/suballoc.c
2007-09-20ocfs2: Allow smaller allocations during large writesMark Fasheh
The ocfs2 write code loops through a page much like the block code, except that ocfs2 allocation units can be any size, including larger than page size. Typically it's equal to or larger than page size - most kernels run 4k pages, the minimum ocfs2 allocation (cluster) size. Some changes introduced during 2.6.23 changed the way writes to pages are handled, and inadvertantly broke support for > 4k page size. Instead of just writing one cluster at a time, we now handle the whole page in one pass. This means that multiple (small) seperate allocations might happen in the same pass. The allocation code howver typically optimizes by getting the maximum which was reserved. This triggered a BUG_ON in the extend code where it'd ask for a single bit (for one part of a > 4k page) and get back more than it asked for. Fix this by providing a variant of the high level allocation function which allows the caller to specify a maximum. The traditional function remains and just calls the new one with a maximum determined from the initial reservation. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: use all extent block suballocatorsMark Fasheh
Now that we have a method to deallocate blocks from them, each node should allocate extent blocks from their local suballocator file. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: plug truncate into cached dealloc routinesMark Fasheh
2007-07-10ocfs2: simplify deallocation lockingMark Fasheh
Deallocation of suballocator blocks, most notably extent blocks, might involve multiple suballocator inodes. The locking for this can get extremely complicated, especially when the suballocator inodes to delete from aren't known until deep within an unrelated codepath. Implement a simple scheme for recording the blocks to be unlinked so that the actual deallocation can be done in a context which won't deadlock. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2Mark Fasheh
None of these are actually harmful, but the noise makes looking for real problems difficult. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Fix up i_blocks calculation to know about holesMark Fasheh
Older file systems which didn't support holes did a dumb calculation of i_blocks based on i_size. This is no longer accurate, so fix things up to take actual allocation into account. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01ocfs2: Remove struct ocfs2_journal_handle in favor of handle_tMark Fasheh
This is mostly a search and replace as ocfs2_journal_handle is now no more than a container for a handle_t pointer. ocfs2_commit_trans() becomes very straight forward, and we remove some out of date comments / code. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove handle argument to ocfs2_start_trans()Mark Fasheh
All callers either pass in NULL directly, or a local variable that is already set to NULL. The internals of ocfs2_start_trans() get a nice cleanup as a result. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: pass ocfs2_super * into ocfs2_commit_trans()Mark Fasheh
This sets us up to remove handle->journal. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove unused handle argument from ocfs2_meta_lock_full()Mark Fasheh
Now that this is unused and all callers pass NULL, we can safely remove it. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: don't use handle for locking in allocation functionsMark Fasheh
Instead we record our state on the allocation context structure which all callers already know about and lifetime correctly. This means the reservation functions don't need a handle passed in any more, and we can also take it off the alloc context. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove ocfs2_journal_handle flags fieldMark Fasheh
Callers can set h_sync directly on the handle_t, whether a transaction has been started or not can be determined via the existence of the handle_t on the struct ocfs2_journal_handle. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-08-07ocfs2: allocation hintsMark Fasheh
Record the most recently used allocation group on the allocation context, so that subsequent allocations can attempt to optimize for contiguousness. Local alloc especially should benefit from this as the current chain search tends to let it spew across the disk. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-08-07ocfs2: better group descriptor consistency checksMark Fasheh
Try to catch corrupted group descriptors with some stronger checks placed in a couple of strategic locations. Detect a failed resizefs and refuse to allocate past what bitmap i_clusters allows. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-24ocfs2: don't use MLF* in the file systemMark Fasheh
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
