path: root/fs/ocfs2/mmap.c
2010-05-21Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (47 commits) ocfs2: Silence a gcc warning. ocfs2: Don't retry xattr set in case value extension fails. ocfs2:dlm: avoid dlm->ast_lock lockres->spinlock dependency break ocfs2: Reset xattr value size after xa_cleanup_value_truncate(). fs/ocfs2/dlm: Use kstrdup fs/ocfs2/dlm: Drop memory allocation cast Ocfs2: Optimize punching-hole code. Ocfs2: Make ocfs2_find_cpos_for_left_leaf() public. Ocfs2: Fix hole punching to correctly do CoW during cluster zeroing. Ocfs2: Optimize ocfs2 truncate to use ocfs2_remove_btree_range() instead. ocfs2: Block signals for mkdir/link/symlink/O_CREAT. ocfs2: Wrap signal blocking in void functions. ocfs2/dlm: Increase o2dlm lockres hash size ocfs2: Make ocfs2_extend_trans() really extend. ocfs2/trivial: Code cleanup for allocation reservation. ocfs2: make ocfs2_adjust_resv_from_alloc simple. ocfs2: Make nointr a default mount option ocfs2/dlm: Make o2dlm domain join/leave messages KERN_NOTICE o2net: log socket state changes ocfs2: print node # when tcp fails ...
2010-05-10ocfs2: Wrap signal blocking in void functions.Joel Becker
ocfs2 sometimes needs to block signals around dlm operations, but it currently does it with sigprocmask(). Even worse, it's checking the error code of sigprocmask(). The in-kernel sigprocmask() can only error if you get the SIG_* argument wrong. We don't. Wrap the sigprocmask() calls with ocfs2_[un]block_signals(). These functions are void, but they will BUG() if somehow sigprocmask() returns an error. Signed-off-by: Joel Becker <joel.becker@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: page_mkwrite change prototype to match faultNick Piggin
Change the page_mkwrite prototype to take a struct vm_fault, and return VM_FAULT_xxx flags. There should be no functional change. This makes it possible to return much more detailed error information to the VM (and also can provide more information eg. virtual_address to the driver, which might be important in some special cases). This is required for a subsequent fix. And will also make it easier to merge page_mkwrite() with fault() in future. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Chris Mason <chris.mason@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Felix Blyakher <felixb@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-10ocfs2: return 0 in page_mkwrite to let VFS retry.Tao Ma
In ocfs2_page_mkwrite, we return -EINVAL when we found the page mapping isn't updated, and it will cause the user space program get SIGBUS and exit. The reason is that during race writeable mmap, we will do unmap_mapping_range in ocfs2_data_downconvert_worker. The good thing is that if we reuturn 0 in page_mkwrite, VFS will retry fault and then call page_mkwrite again, so it is safe to return 0 here. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-01-25ocfs2: Rename ocfs2_meta_[un]lockMark Fasheh
Call this the "inode_lock" now, since it covers both data and meta data. This patch makes no functional changes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Remove data locksMark Fasheh
The meta lock now covers both meta data and data, so this just removes the now-redundant data lock. Combining locks saves us a round of lock mastery per inode and one less lock to ping between nodes during read/write. We don't lose much - since meta locks were always held before a data lock (and at the same level) ordered writeout mode (the default) ensured that flushing for the meta data lock also pushed out data anyways. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-20fix some conversion overflowsNick Piggin
Fix page index to offset conversion overflows in buffer layer, ecryptfs, and ocfs2. It would be nice to convert the whole tree to page_offset, but for now just fix the bugs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #1Nick Piggin
Change ->fault prototype. We now return an int, which contains VM_FAULT_xxx code in the low byte, and FAULT_RET_xxx code in the next byte. FAULT_RET_ code tells the VM whether a page was found, whether it has been locked, and potentially other things. This is not quite the way he wanted it yet, but that's changed in the next patch (which requires changes to arch code). This means we no longer set VM_CAN_INVALIDATE in the vma in order to say that a page is locked which requires filemap_nopage to go away (because we can no longer remain backward compatible without that flag), but we were going to do that anyway. struct fault_data is renamed to struct vm_fault as Linus asked. address is now a void __user * that we should firmly encourage drivers not to use without really good reason. The page is now returned via a page pointer in the vm_fault struct. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: merge populate and nopage into fault (fixes nonlinear)Nick Piggin
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes the virtual address -> file offset differently from linear mappings. ->populate is a layering violation because the filesystem/pagecache code should need to know anything about the virtual memory mapping. The hitch here is that the ->nopage handler didn't pass down enough information (ie. pgoff). But it is more logical to pass pgoff rather than have the ->nopage function calculate it itself anyway (because that's a similar layering violation). Having the populate handler install the pte itself is likewise a nasty thing to be doing. This patch introduces a new fault handler that replaces ->nopage and ->populate and (later) ->nopfn. Most of the old mechanism is still in place so there is a lot of duplication and nice cleanups that can be removed if everyone switches over. The rationale for doing this in the first place is that nonlinear mappings are subject to the pagefault vs invalidate/truncate race too, and it seemed stupid to duplicate the synchronisation logic rather than just consolidate the two. After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in pagecache. Seems like a fringe functionality anyway. NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no users have hit mainline yet. [akpm@linux-foundation.org: cleanup] [randy.dunlap@oracle.com: doc. fixes for readahead] [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fix fault vs invalidate race for linear mappingsNick Piggin
Fix the race between invalidate_inode_pages and do_no_page. Andrea Arcangeli identified a subtle race between invalidation of pages from pagecache with userspace mappings, and do_no_page. The issue is that invalidation has to shoot down all mappings to the page, before it can be discarded from the pagecache. Between shooting down ptes to a particular page, and actually dropping the struct page from the pagecache, do_no_page from any process might fault on that page and establish a new mapping to the page just before it gets discarded from the pagecache. The most common case where such invalidation is used is in file truncation. This case was catered for by doing a sort of open-coded seqlock between the file's i_size, and its truncate_count. Truncation will decrease i_size, then increment truncate_count before unmapping userspace pages; do_no_page will read truncate_count, then find the page if it is within i_size, and then check truncate_count under the page table lock and back out and retry if it had subsequently been changed (ptl will serialise against unmapping, and ensure a potentially updated truncate_count is actually visible). Complexity and documentation issues aside, the locking protocol fails in the case where we would like to invalidate pagecache inside i_size. do_no_page can come in anytime and filemap_nopage is not aware of the invalidation in progress (as it is when it is outside i_size). The end result is that dangling (->mapping == NULL) pages that appear to be from a particular file may be mapped into userspace with nonsense data. Valid mappings to the same place will see a different page. Andrea implemented two working fixes, one using a real seqlock, another using a page->flags bit. He also proposed using the page lock in do_no_page, but that was initially considered too heavyweight. However, it is not a global or per-file lock, and the page cacheline is modified in do_no_page to increment _count and _mapcount anyway, so a further modification should not be a large performance hit. Scalability is not an issue. This patch implements this latter approach. ->nopage implementations return with the page locked if it is possible for their underlying file to be invalidated (in that case, they must set a special vm_flags bit to indicate so). do_no_page only unlocks the page after setting up the mapping completely. invalidation is excluded because it holds the page lock during invalidation of each page (and ensures that the page is not mapped while holding the lock). This also allows significant simplifications in do_no_page, because we have the page locked in the right place in the pagecache from the start. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10ocfs2: shared writeable mmapMark Fasheh
Implement cluster consistent shared writeable mappings using the ->page_mkwrite() callback. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Turn off shared writeable mmap for local files systems with holes.Mark Fasheh
This will be turned back on once we can do allocation in ->page_mkwrite(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-07ocfs2: local mountsSunil Mushran
This allows users to format an ocfs2 file system with a special flag, OCFS2_FEATURE_INCOMPAT_LOCAL_MOUNT. When the file system sees this flag, it will not use any cluster services, nor will it require a cluster configuration, thus acting like a 'local' file system. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: update file system paths to set atimeTiger Yang
Conditionally update atime in ocfs2_file_aio_read(), ocfs2_readdir() and ocfs2_mmap(). Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-29ocfs2: Compile-time disabling of ocfs2 debugging output.Joel Becker
Give gcc the chance to compile out the debug logging code in ocfs2. This saves some size at the expense of being able to debug the code. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
