path: root/fs/ocfs2/ioctl.c
2009-09-23Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (85 commits) ocfs2: Use buffer IO if we are appending a file. ocfs2: add spinlock protection when dealing with lockres->purge. dlmglue.c: add missed mlog lines ocfs2: __ocfs2_abort() should not enable panic for local mounts ocfs2: Add ioctl for reflink. ocfs2: Enable refcount tree support. ocfs2: Implement ocfs2_reflink. ocfs2: Add preserve to reflink. ocfs2: Create reflinked file in orphan dir. ocfs2: Use proper parameter for some inode operation. ocfs2: Make transaction extend more efficient. ocfs2: Don't merge in 1st refcount ops of reflink. ocfs2: Modify removing xattr process for refcount. ocfs2: Add reflink support for xattr. ocfs2: Create an xattr indexed block if needed. ocfs2: Call refcount tree remove process properly. ocfs2: Attach xattr clusters to refcount tree. ocfs2: Abstract ocfs2 xattr tree extend rec iteration process. ocfs2: Abstract the creation of xattr block. ocfs2: Remove inode from ocfs2_xattr_bucket_get_name_value. ...
2009-09-22ocfs2: Add ioctl for reflink.Tao Ma
The ioctl will take 3 parameters: old_path, new_path and preserve and call vfs_reflink. It is useful when we backport reflink features to old kernels. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13ocfs2: Don't check for NULL before brelse()Mark Fasheh
This is pointless as brelse() already does the check. Signed-off-by: Mark Fasheh
2008-04-19[PATCH] r/o bind mounts: elevate write count for ioctls()Dave Hansen
Some ioctl()s can cause writes to the filesystem. Take these, and make them use mnt_want/drop_write() instead. [AV: updated] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-18ocfs2: Convert ocfs2 over to unlocked_ioctlAndi Kleen
As far as I can see there is nothing in ocfs2_ioctl that requires the BKL, so use unlocked_ioctl Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Move o2hb functionality into the stack glue.Joel Becker
The last bit of classic stack used directly in ocfs2 code is o2hb. Specifically, the check for heartbeat during mount and the call to ocfs2_hb_ctl during unmount. We create an extra API, ocfs2_cluster_hangup(), to encapsulate the call to ocfs2_hb_ctl. Other stacks will just leave hangup() empty. The check for heartbeat is moved into ocfs2_cluster_connect(). It will be matched by a similar check for other stacks. With this change, only stackglue.c includes cluster/ headers. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-01-25ocfs2: Add missing permission checksMark Fasheh
Check that an online resize is being driven by a user with permission to change system resource limits. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25[PATCH 2/2] ocfs2: Implement group add for online resizeTao Ma
This patch adds the ability for a userspace program to request that a properly formatted cluster group be added to the main allocation bitmap for an Ocfs2 file system. The request is made via an ioctl, OCFS2_IOC_GROUP_ADD. On a high level, this is similar to ext3, but we use a different ioctl as the structure which has to be passed through is different. During an online resize, tunefs.ocfs2 will format any new cluster groups which must be added to complete the resize, and call OCFS2_IOC_GROUP_ADD on each one. Kernel verifies that the core cluster group information is valid and then does the work of linking it into the global allocation bitmap. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25[PATCH 1/2] ocfs2: Add group extend for online resizeTao Ma
This patch adds the ability for a userspace program to request an extend of last cluster group on an Ocfs2 file system. The request is made via ioctl, OCFS2_IOC_GROUP_EXTEND. This is derived from EXT3_IOC_GROUP_EXTEND, but is obviously Ocfs2 specific. tunefs.ocfs2 would call this for an online-resize operation if the last cluster group isn't full. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Rename ocfs2_meta_[un]lockMark Fasheh
Call this the "inode_lock" now, since it covers both data and meta data. This patch makes no functional changes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10ocfs2: Support xfs style space reservation ioctlsMark Fasheh
We re-use the RESVSP/UNRESVSP ioctls from xfs which allow the user to allocate and deallocate regions to a file without zeroing data or changing i_size. Though renamed, the structure passed in from user is identical to struct xfs_flock64. The three fields that are actually used right now are l_whence, l_start and l_len. This should get ocfs2 immediate compatibility with userspace software using the pre-existing xfs ioctls. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02[PATCH] Copy i_flags to ocfs2 inode flags on writeJan Kara
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ocfs2-specific ip_attr. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: Implement compat_ioctl()Mark Fasheh
We need this to support 32 bit system calls on 64 bit kernels. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: Remove struct ocfs2_journal_handle in favor of handle_tMark Fasheh
This is mostly a search and replace as ocfs2_journal_handle is now no more than a container for a handle_t pointer. ocfs2_commit_trans() becomes very straight forward, and we remove some out of date comments / code. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove handle argument to ocfs2_start_trans()Mark Fasheh
All callers either pass in NULL directly, or a local variable that is already set to NULL. The internals of ocfs2_start_trans() get a nice cleanup as a result. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: pass ocfs2_super * into ocfs2_commit_trans()Mark Fasheh
This sets us up to remove handle->journal. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove unused handle argument from ocfs2_meta_lock_full()Mark Fasheh
Now that this is unused and all callers pass NULL, we can safely remove it. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-20[PATCH] fs/ocfs2/ioctl.c should #include "ioctl.h"Adrian Bunk
Every file should #include the headers containing the prototypes for its global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-20ocfs2: add ext2 attributesHerbert Poetzl
Support immutable, and other attributes. Some renaming and other minor fixes done by myself. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
