path: root/fs/ocfs2/inode.c
2009-06-22ocfs2: Add lockdep annotationsJan Kara
Add lockdep support to OCFS2. The support also covers all of the cluster locks except for open locks, journal locks, and local quotafile locks. These are special because they are acquired for a node, not for a particular process and lockdep cannot deal with such type of locking. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-04-03ocfs2: fix rare stale inode errors when exporting via nfswengang wang
For nfs exporting, ocfs2_get_dentry() returns the dentry for fh. ocfs2_get_dentry() may read from disk when the inode is not in memory, without any cross cluster lock. this leads to the file system loading a stale inode. This patch fixes above problem. Solution is that in case of inode is not in memory, we get the cluster lock(PR) of alloc inode where the inode in question is allocated from (this causes node on which deletion is done sync the alloc inode) before reading out the inode itsself. then we check the bitmap in the group (the inode in question allcated from) to see if the bit is clear. if it's clear then it's stale. if the bit is set, we then check generation as the existing code does. We have to read out the inode in question from disk first to know its alloc slot and allot bit. And if its not stale we read it out using ocfs2_iget(). The second read should then be from cache. And also we have to add a per superblock nfs_sync_lock to cover the lock for alloc inode and that for inode in question. this is because ocfs2_get_dentry() and ocfs2_delete_inode() lock on them in reverse order. nfs_sync_lock is locked in EX mode in ocfs2_get_dentry() and in PR mode in ocfs2_delete_inode(). so that mutliple ocfs2_delete_inode() can run concurrently in normal case. [mfasheh@suse.com: build warning fixes and comment cleanups] Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-04-03ocfs2: Optimize inode allocation by remembering last groupTao Ma
In ocfs2, the inode block search looks for the "emptiest" inode group to allocate from. So if an inode alloc file has many equally (or almost equally) empty groups, new inodes will tend to get spread out amongst them, which in turn can put them all over the disk. This is undesirable because directory operations on conceptually "nearby" inodes force a large number of seeks. So we add ip_last_used_group in core directory inodes which records the last used allocation group. Another field named ip_last_used_slot is also added in case inode stealing happens. When claiming new inode, we passed in directory's inode so that the allocation can use this information. For more details, please see http://oss.oracle.com/osswiki/OCFS2/DesignDocs/InodeAllocationStrategy. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-04-03ocfs2: Increase max links countMark Fasheh
Since we've now got a directory format capable of handling a large number of entries, we can increase the maximum link count supported. This only gets increased if the directory indexing feature is turned on. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <joel.becker@oracle.com>
2009-04-03ocfs2: Add a name indexed b-tree to directory inodesMark Fasheh
This patch makes use of Ocfs2's flexible btree code to add an additional tree to directory inodes. The new tree stores an array of small, fixed-length records in each leaf block. Each record stores a hash value, and pointer to a block in the traditional (unindexed) directory tree where a dirent with the given name hash resides. Lookup exclusively uses this tree to find dirents, thus providing us with constant time name lookups. Some of the hashing code was copied from ext3. Unfortunately, it has lots of unfixed checkpatch errors. I left that as-is so that tracking changes would be easier. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <joel.becker@oracle.com>
2009-01-05ocfs2: Use metadata-specific ocfs2_journal_access_*() functions.Joel Becker
The per-metadata-type ocfs2_journal_access_*() functions hook up jbd2 commit triggers and allow us to compute metadata ecc right before the buffers are written out. This commit provides ecc for inodes, extent blocks, group descriptors, and quota blocks. It is not safe to use extened attributes and metaecc at the same time yet. The ocfs2_extent_tree and ocfs2_path abstractions in alloc.c both hide the type of block at their root. Before, it didn't matter, but now the root block must use the appropriate ocfs2_journal_access_*() function. To keep this abstract, the structures now have a pointer to the matching journal_access function and a wrapper call to call it. A few places use naked ocfs2_write_block() calls instead of adding the blocks to the journal. We make sure to calculate their checksum and ecc before the write. Since we pass around the journal_access functions. Let's typedef them in ocfs2.h. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: block read meta ecc.Joel Becker
Add block check calls to the read_block validate functions. This is the almost all of the read-side checking of metaecc. xattr buckets are not checked yet. Writes are also unchecked, and so a read-write mount will quickly fail. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add quota calls for allocation and freeing of inodes and spaceJan Kara
Add quota calls for allocation and freeing of inodes and space, also update estimates on number of needed credits for a transaction. Move out inode allocation from ocfs2_mknod_locked() because vfs_dq_init() must be called outside of a transaction. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Mark system files as not subject to quota accountingJan Kara
Mark system files as not subject to quota accounting. This prevents possible recursions into quota code and thus deadlocks. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Assign feature bits and system inodes to quota feature and quota filesJan Kara
2009-01-05ocfs2: Validate metadata only when it's read from disk.Joel Becker
Add an optional validation hook to ocfs2_read_blocks(). Now the validation function is only called when a block was actually read off of disk. It is not called when the buffer was in cache. We add a buffer state bit BH_NeedsValidate to flag these buffers. It must always be one higher than the last JBD2 buffer state bit. The dinode, dirblock, extent_block, and xattr_block validators are lifted to this scheme directly. The group_descriptor validator needs to be split into two pieces. The first part only needs the gd buffer and is passed to ocfs2_read_block(). The second part requires the dinode as well, and is called every time. It's only 3 compares, so it's tiny. This also allows us to clean up the non-fatal gd check used by resize.c. It now has no magic argument. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Wrap inode block reads in a dedicated function.Joel Becker
The ocfs2 code currently reads inodes off disk with a simple ocfs2_read_block() call. Each place that does this has a different set of sanity checks it performs. Some check only the signature. A couple validate the block number (the block read vs di->i_blkno). A couple others check for VALID_FL. Only one place validates i_fs_generation. A couple check nothing. Even when an error is found, they don't all do the same thing. We wrap inode reading into ocfs2_read_inode_block(). This will validate all the above fields, going readonly if they are invalid (they never should be). ocfs2_read_inode_block_full() is provided for the places that want to pass read_block flags. Every caller is passing a struct inode with a valid ip_blkno, so we don't need a separate blkno argument either. We will remove the validation checks from the rest of the code in a later commit, as they are no longer necessary. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-11-10ocfs2: Set journal descriptor to NULL after journal shutdownSunil Mushran
Patch sets journal descriptor to NULL after the journal is shutdown. This ensures that jbd2_journal_release_jbd_inode(), which removes the jbd2 inode from txn lists, can be called safely from ocfs2_clear_inode() even after the journal has been shutdown. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Make cached block reads the common case.Joel Becker
ocfs2_read_blocks() currently requires the CACHED flag for cached I/O. However, that's the common case. Let's flip it around and provide an IGNORE_CACHE flag for the special users. This has the added benefit of cleaning up the code some (ignore_cache takes on its special meaning earlier in the loop). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Move ocfs2_bread() into dir.cJoel Becker
dir.c is the only place using ocfs2_bread(), so let's make it static to that file. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Simplify ocfs2_read_block()Joel Becker
More than 30 callers of ocfs2_read_block() pass exactly OCFS2_BH_CACHED. Only six pass a different flag set. Rather than have every caller care, let's make ocfs2_read_block() take no flags and always do a cached read. The remaining six places can call ocfs2_read_blocks() directly. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Require an inode for ocfs2_read_block(s)().Joel Becker
Now that synchronous readers are using ocfs2_read_blocks_sync(), all callers of ocfs2_read_blocks() are passing an inode. Use it unconditionally. Since it's there, we don't need to pass the ocfs2_super either. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Separate out sync reads from ocfs2_read_blocks()Joel Becker
The ocfs2_read_blocks() function currently handles sync reads, cached, reads, and sometimes cached reads. We're going to add some functionality to it, so first we should simplify it. The uncached, synchronous reads are much easer to handle as a separate function, so we instroduce ocfs2_read_blocks_sync(). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Don't check for NULL before brelse()Mark Fasheh
This is pointless as brelse() already does the check. Signed-off-by: Mark Fasheh
2008-10-13ocfs2: Switch over to JBD2.Joel Becker
ocfs2 wants JBD2 for many reasons, not the least of which is that JBD is limiting our maximum filesystem size. It's a pretty trivial change. Most functions are just renamed. The only functional change is moving to Jan's inode-based ordered data mode. It's better, too. Because JBD2 reads and writes JBD journals, this is compatible with any existing filesystem. It can even interact with JBD-based ocfs2 as long as the journal is formated for JBD. We provide a compatibility option so that paranoid people can still use JBD for the time being. This will go away shortly. [ Moved call of ocfs2_begin_ordered_truncate() from ocfs2_delete_inode() to ocfs2_truncate_for_delete(). --Mark ] Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Add extended attribute supportTiger Yang
This patch implements storing extended attributes both in inode or a single external block. We only store EA's in-inode when blocksize > 512 or that inode block has free space for it. When an EA's value is larger than 80 bytes, we will store the value via b-tree outside inode or block. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: POSIX file locks supportMark Fasheh
This is actually pretty easy since fs/dlm already handles the bulk of the work. The Ocfs2 userspace cluster stack module already uses fs/dlm as the underlying lock manager, so I only had to add the right calls. Cluster-aware POSIX locks ("plocks") can be turned off by the same means at UNIX locks - mount with 'noflocks', or create a local-only Ocfs2 volume. Internally, the file system uses two sets of file_operations, depending on whether cluster aware plocks is required. This turns out to be easier than implementing local-only versions of ->lock. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-01-25ocfs2: convert byte order of constant instead of variableMarcin Slusarz
Convert byte order of constant instead of variable it will be done at compile time vs run time. Remove unused le32_and_cpu. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Silence false lockdep warningsJan Kara
Create separate lockdep lock classes for system file's i_mutexes. They are used to guard allocations and similar things and thus rank differently than i_mutex of a regular file or directory. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Rename ocfs2_meta_[un]lockMark Fasheh
Call this the "inode_lock" now, since it covers both data and meta data. This patch makes no functional changes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Remove data locksMark Fasheh
The meta lock now covers both meta data and data, so this just removes the now-redundant data lock. Combining locks saves us a round of lock mastery per inode and one less lock to ping between nodes during read/write. We don't lose much - since meta locks were always held before a data lock (and at the same level) ordered writeout mode (the default) ensured that flushing for the meta data lock also pushed out data anyways. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Remove mount/unmount votesMark Fasheh
The node maps that are set/unset by these votes are no longer relevant, thus we can remove the mount and umount votes. Since those are the last two remaining votes, we can also remove the entire vote infrastructure. The vote thread has been renamed to the downconvert thread, and the small amount of functionality related to managing it has been moved into fs/ocfs2/dlmglue.c. All references to votes have been removed or updated. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-11-27ocfs2: log valid inode # on bad inodeMark Fasheh
If the inode block isn't valid then we don't want to print the value from that, instead print the block number which was passed in (which should always be correct). Also, turn this into a debug print for now - folks who hit an actual problem always have other logs indicating what the source is. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-11-27[PATCH] fs/ocfs2: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-10-12ocfs2: Write support for inline dataMark Fasheh
This fixes up write, truncate, mmap, and RESVSP/UNRESVP to understand inline inode data. For the most part, the changes to the core write code can be relied on to do the heavy lifting. Any code calling ocfs2_write_begin (including shared writeable mmap) can count on it doing the right thing with respect to growing inline data to an extent tree. Size reducing truncates, including UNRESVP can simply zero that portion of the inode block being removed. Size increasing truncatesm, including RESVP have to be a little bit smarter and grow the inode to an extent tree if necessary. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Joel Becker <joel.becker@oracle.com>
2007-10-12ocfs2: Structure updates for inline dataMark Fasheh
Add the disk, network and memory structures needed to support data in inode. Struct ocfs2_inline_data is defined and embedded in ocfs2_dinode for storing inline data. A new inode field, i_dyn_features, is added to facilitate tracking of dynamic inode state. Since it will be used often, we want to mirror it on ocfs2_inode_info, and transfer it via the meta data lvb. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Joel Becker <joel.becker@oracle.com>
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2Mark Fasheh
None of these are actually harmful, but the noise makes looking for real problems difficult. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02[PATCH] Copy i_flags to ocfs2 inode flags on writeJan Kara
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ocfs2-specific ip_attr. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: Wrap access of directory allocations with ip_alloc_sem.Joel Becker
OCFS2_I(inode)->ip_alloc_sem is a read-write semaphore protecting local concurrent access of ocfs2 inodes. However, ocfs2 directories were not taking the semaphore while they accessed or modified the allocation tree. ocfs2_extend_dir() needs to take the semaphore in a write mode when it adds to the allocation. All other directory users get there via ocfs2_bread(), which takes the semaphore in read mode. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Cache extent recordsMark Fasheh
The extent map code was ripped out earlier because of an inability to deal with holes. This patch adds back a simpler caching scheme requiring far less code. Our old extent map caching was designed back when meta data block caching in Ocfs2 didn't work very well, resulting in many disk reads. These days our metadata caching is much better, resulting in no un-necessary disk reads. As a result, extent caching doesn't have to be as fancy, nor does it have to cache as many extents. Keeping the last 3 extents seen should be sufficient to give us a small performance boost on some streaming workloads. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Fix up i_blocks calculation to know about holesMark Fasheh
Older file systems which didn't support holes did a dumb calculation of i_blocks based on i_size. This is no longer accurate, so fix things up to take actual allocation into account. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Read from an unwritten extent returns zerosMark Fasheh
Return an optional extent flags field from our lookup functions and wire up callers to treat unwritten regions as holes for the purpose of returning zeros to the user. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: zero tail of sparse files on truncateMark Fasheh
Since we don't zero on extend anymore, truncate needs to be fixed up to zero the part of a file between i_size and and end of it's cluster. Otherwise a subsequent extend could expose bad data. This introduced a new helper, which can be used in ocfs2_write(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: teach extend/truncate about sparse filesMark Fasheh
For ocfs2_truncate_file(), we eliminate the "simple" truncate case which no longer exists since i_size is not tied to i_clusters. In ocfs2_extend_file(), we skip the allocation / page zeroing code for file systems which understand sparse files. The core truncate code is changed to do a bottom up tree traversal. This gets abstracted out into it's own function. To make things more readable, most of the special case handling for in-inode extents from ocfs2_do_truncate() is also removed. Though write support for sparse files comes in a later patch, we at least update ocfs2_prepare_inode_for_write() to skip allocation for sparse files. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: temporarily remove extent map cachingMark Fasheh
The code in extent_map.c is not prepared to deal with a subtree being rotated between lookups. This can happen when filling holes in sparse files. Instead of a lengthy patch to update the code (which would likely lose the benefit of caching subtree roots), we remove most of the algorithms and implement a simple path based lookup. A less ambitious extent caching scheme will be added in a later patch. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: small cleanup of ocfs2_request_delete()Mark Fasheh
There are two checks in there (one for inode newness, one for other mounted nodes) which are unnecessary, so remove them. The DLM will allow the trylock in either case without any messaging overhead. Removing these makes ocfs2_request_delete() a one liner function, so just move the trylock out one level into ocfs2_query_inode_wipe(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: remove unused codeTiger Yang
Remove node messaging code that becomes unused with the delete inode vote removal. [Removed even more cruft which I spotted during review --Mark] Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-04-26ocfs2: Remove delete inode voteTiger Yang
Ocfs2 currently does cluster-wide node messaging to check the open state of an inode during delete. This patch removes that mechanism in favor of an inode cluster lock which is taken at shared read when an inode is first read and dropped in clear_inode(). This allows a deleting node to test the liveness of an inode by attempting to take an exclusive lock. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-01-21ocfs2: cleanup ocfs2_iget() errorsMark Fasheh
Get rid of some error prints in the ocfs2_iget() path from ocfs2_get_dentry(). NFSD can easily cause us to read stale inodes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-07ocfs2: local mountsSunil Mushran
This allows users to format an ocfs2 file system with a special flag, OCFS2_FEATURE_INCOMPAT_LOCAL_MOUNT. When the file system sees this flag, it will not use any cluster services, nor will it require a cluster configuration, thus acting like a 'local' file system. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: core atime update functionsTiger Yang
This patch adds the core routines for updating atime in ocfs2. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: Remove struct ocfs2_journal_handle in favor of handle_tMark Fasheh
This is mostly a search and replace as ocfs2_journal_handle is now no more than a container for a handle_t pointer. ocfs2_commit_trans() becomes very straight forward, and we remove some out of date comments / code. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove handle argument to ocfs2_start_trans()Mark Fasheh
All callers either pass in NULL directly, or a local variable that is already set to NULL. The internals of ocfs2_start_trans() get a nice cleanup as a result. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: pass ocfs2_super * into ocfs2_commit_trans()Mark Fasheh
This sets us up to remove handle->journal. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
